Home » Modeling » UML2 Tools » Error in Drawing Position
Error in Drawing Position [message #472250] |
Fri, 11 January 2008 07:21  |
Hello friends...
I downloaded the last UML2Tools version (0.8.0M4) and its dependencies.
After compile any project, when I try to draw any kind of object in the
screen, the object goes to the left/top of the screen. It never goes in
the position where I try to draw it. =(
Has anybody got this error too?!?
Raphael
Re: Error in Drawing Position [message #472254 is a reply to message #472251] |
Fri, 11 January 2008 12:12   |
Hello Michael!!!
Well, when I try to run an example, it works fine, since I donŽt move any
object from its original position. If I change any object from his
original position, I got the same error.
I uploaded a print screen with the error at:
http://www.dc.ufscar.br/~raphael_oliveira/bug.JPG
I didnŽt get any error message when this error happens. The object just go
to the left/top of the window.
Thanks for your attencion,
Raphael
Michael Golubev wrote:
> Hello Raphael,
> Odd, I can not observe this in my development environment :).
> Could you please try to open one of the sample diagrams (from
[oeu2d.examples.class
> plugin]) and check that the contents is somehow layouted.
> It would allow to find whether it is the problem related to element creation
> or to more general issue.
> Also I would appreciate to see the error log on creating an wrong positioned
> element.
> Regards,
> Michael
>> Hello friends...
>> dependencies.
>> the screen, the object goes to the left/top of the screen. It never
>> goes in the position where I try to draw it. =(
>> Thanks,
>> Raphael
Re: Error in Drawing Position [message #472255 is a reply to message #472254] |
Fri, 11 January 2008 13:42   |
Hello Raphael,
There are some strange things on your screenshot.
Say, the class name is truncated to "..." -- the issue covered by bugzilla
209648 that was fixed in M3 build.
Is it true that you have tried to regenerate the diagrams from gmf artifacts,
not just using the sources from repository?
Also please make sure that you are using M4 jars for depending projects,
in particular GMF runtimes and GEF.
Michael
> Hello Michael!!!
> any object from its original position. If I change any object from his
> just go to the left/top of the window.
> Raphael
>> Hello Raphael,
>> plugin]) and check that the contents is somehow layouted. It would
>> positioned element.
>> Regards, Michael
>>> Hello friends...
>>> dependencies.
>>> Thanks,
>>> Raphael
Re: Error in Drawing Position [message #472258 is a reply to message #472255] |
Mon, 14 January 2008 06:50   |
Hello Michael...
IŽm just using the sources from CVS, and still not working.
I tested another thing. If I select the class object and click just once
to draw it, it will be drawed where I clicked. But, if I try to move this
object, it always goes to the screen lef/top.
Another test that done: when I select the class object and try to draw it
holding on the mouse button (to create a custom size), the object goes
always to the screen lef/top.
Also, IŽm using all M4 jars and its dependencies, and the error still
happening.
Raphael
> Hello Raphael,
artifacts,
> Regards,
> Michael
>> Hello Michael!!!
>> Well, when I try to run an example, it works fine, since I donÅœt move
>> I didnÅœt get any error message when this error happens. The object
>> Raphael
>>> Hello Raphael,
>>> positioned element.
>>> Regards, Michael
>>>> Hello friends...
>>>> dependencies.
>>>> Thanks,
>>>> Raphael
Re: Error in Drawing Position [message #472261 is a reply to message #472258] |
Mon, 14 January 2008 09:12   |
Hello Raphael,
I installed Eclipse and UML2Tools dependencies of M4 version. Everything
works properly.
Situation you described looks strange. Is there anything in your error log?
If so, could you, please, send us its content?
Best wishes,
Tatiana.
> Hello Michael...
> once to draw it, it will be drawed where I clicked. But, if I try to
> move this object, it always goes to the screen lef/top.
> it holding on the mouse button (to create a custom size), the object
> goes always to the screen lef/top.
> happening.
> Regards,
> Raphael
>> Hello Raphael,
>> bugzilla
> artifacts,
>> not just using the sources from repository? Also please make sure
>> that you are using M4 jars for depending projects, in particular GMF
>> runtimes and GEF.
>> Regards, Michael
>>> Hello Michael!!!
>>> move any object from its original position. If I change any object
>>> from his original position, I got the same error.
>>> Raphael
>>>> Hello Raphael,
>>>> positioned element.
>>>> Regards, Michael
>>>>> Hello friends...
>>>>> dependencies.
>>>>> in the screen, the object goes to the left/top of the screen. It
>>>>> never goes in the position where I try to draw it. =(
>>>>> Thanks,
>>>>> Raphael
Re: Error in Drawing Position [message #472267 is a reply to message #472261] |
Tue, 15 January 2008 08:28   |
Hello Tatiana!
Unfortunately, in my error log there is nothing =(
Well, letŽs just check. IŽm using the following resources:
Eclipse S-3.4M4-200712131700 (Windows XP)
EMF 2.4.0M4 S200712160044
Query 1.2.0M4 S200712171224
Transaction 1.2.0M4 S200712171243
Validation 1.2.0M4 S200712171225
OCL 1.2.0M4 S200712171124
UML2 2.2.0M4 S200712170918
GEF S-3.4M4-200712181544
GMF S-2.1M4-200801071111
UML2TOOLS 0.8.0M4
Is that all right?!
Thanks for your attention!
Raphael
Tatiana Fesenko wrote:
> Hello Raphael,
> works properly.
> Best wishes,
> Tatiana.
>> Hello Michael...
>> IÅœm just using the sources from CVS, and still not working.
>> Also, IÅœm using all M4 jars and its dependencies, and the error still
>> happening.
>> Regards,
>> Raphael
>>> Hello Raphael,
>>> bugzilla
>> artifacts,
>>> runtimes and GEF.
>>> Regards, Michael
>>>> Hello Michael!!!
>>>> Well, when I try to run an example, it works fine, since I donÃ
Åt
>>>> I didnÃ
Åt get any error message when this error happens. The object
>>>> Raphael
>>>>> Hello Raphael,
>>>>> positioned element.
>>>>> Regards, Michael
>>>>>> Hello friends...
>>>>>> dependencies.
>>>>>> Thanks,
>>>>>> Raphael
Hello Tatiana
Re: Error in Drawing Position [message #472369 is a reply to message #472267] |
Wed, 16 January 2008 15:53  |
Hi Raphael,
I puzzle over your problem... No ideas =(
You know both Michael and I checked it, but we have everything working correctly.
The only advice I can give is cruel - re-install everything(eclipse, uml2tools
and its dependencies) from zips clean.
Good luck,
Tatiana.
> Hello Tatiana!
> Unfortunately, in my error log there is nothing =( Well, letŽs just
> UML2TOOLS 0.8.0M4
> Is that all right?!
> Raphael
>> Hello Raphael,
>> Everything works properly.
>> error log? If so, could you, please, send us its content?
>> Best wishes,
>> Tatiana.
>>> Hello Michael...
>>> draw it holding on the mouse button (to create a custom size), the
>>> object goes always to the screen lef/top.
>>> still happening.
>>> Regards,
>>> Raphael
>>>> Hello Raphael,
>>>> bugzilla
>>> artifacts,
>>>> Regards, Michael
>>>>> Hello Michael!!!
>>>>> Åt move any object from its original position. If I change any
>>>>> object from his original position, I got the same error.
>>>>> I didnÃ
>>>>> object
>>>>> Raphael
>>>>>> Hello Raphael,
>>>>>> creation or to more general issue.
>>>>>> positioned element.
>>>>>> Regards, Michael
>>>>>>> Hello friends...
>>>>>>> dependencies.
>>>>>>> Thanks,
>>>>>>> Raphael
> Hello Tatiana
Re: Error in Drawing Position [message #615749 is a reply to message #472250] |
Fri, 11 January 2008 07:52  |
Hello Raphael,
Could you please try to open one of the sample diagrams (from [oeu2d.examples.class
element.
Michael
> Hello friends...
> dependencies.
> Raphael
Re: Error in Drawing Position [message #615753 is a reply to message #472251] |
Hello Michael!!!
Raphael
> Hello Raphael,
> element.
> Regards,
> Michael
>> Hello friends...
>> dependencies.
>> Thanks,
>> Raphael
Re: Error in Drawing Position [message #615756 is a reply to message #472254] |
Hello Raphael,
Michael
> Hello Michael!!!
> Raphael
>> Hello Raphael,
>> positioned element.
>> Regards, Michael
>>> Hello friends...
>>> dependencies.
>>> Thanks,
>>> Raphael
Re: Error in Drawing Position [message #615758 is a reply to message #472255] |
Hello Michael...
happening.
Raphael
> Hello Raphael,
artifacts,
> Regards,
> Michael
>> Hello Michael!!!
>> Raphael
>>> Hello Raphael,
>>> positioned element.
>>> Regards, Michael
>>>> Hello friends...
>>>> dependencies.
>>>> Thanks,
>>>> Raphael
Re: Error in Drawing Position [message #615760 is a reply to message #472258] |
Hello Raphael,
works properly.
Best wishes,
Tatiana.
> Hello Michael...
> happening.
> Regards,
> Raphael
>> Hello Raphael,
>> bugzilla
> artifacts,
>> runtimes and GEF.
>> Regards, Michael
>>> Hello Michael!!!
>>> Raphael
>>>> Hello Raphael,
>>>> positioned element.
>>>> Regards, Michael
>>>>> Hello friends...
>>>>> dependencies.
>>>>> Thanks,
>>>>> Raphael
Re: Error in Drawing Position [message #615767 is a reply to message #472261] |
Hello Tatiana!
UML2TOOLS 0.8.0M4
Is that all right?!
Raphael
> Hello Raphael,
> works properly.
> Best wishes,
> Tatiana.
>> Hello Michael...
>> happening.
>> Regards,
>> Raphael
>>> Hello Raphael,
>>> bugzilla
>> artifacts,
>>> runtimes and GEF.
>>> Regards, Michael
>>>> Hello Michael!!!
Åt
>>>> I didnÃ
>>>> Raphael
>>>>> Hello Raphael,
>>>>> positioned element.
>>>>> Regards, Michael
>>>>>> Hello friends...
>>>>>> dependencies.
>>>>>> Thanks,
>>>>>> Raphael
Hello Tatiana
Re: Error in Drawing Position [message #616734 is a reply to message #472267] |
Hi Raphael,
Good luck,
Tatiana.
> Hello Tatiana!
> UML2TOOLS 0.8.0M4
> Is that all right?!
> Raphael
>> Hello Raphael,
>> Best wishes,
>> Tatiana.
>>> Hello Michael...
>>> still happening.
>>> Regards,
>>> Raphael
>>>> Hello Raphael,
>>>> bugzilla
>>> artifacts,
>>>> Regards, Michael
>>>>> Hello Michael!!!
>>>>> I didnÃ
>>>>> object
>>>>> Raphael
>>>>>> Hello Raphael,
>>>>>> positioned element.
>>>>>> Regards, Michael
>>>>>>> Hello friends...
>>>>>>> dependencies.
>>>>>>> Thanks,
>>>>>>> Raphael
> Hello Tatiana
Current Time: Fri Jul 25 21:38:02 EDT 2025
Powered by FUDForum. Page generated in 0.05343 seconds
