Home » Modeling » Modeling (top-level project) » I don't find the solution
I don't find the solution [message #384285] Tue, 14 April 2009 10:07 Go to next message
In the method actionPerformed of a button ,how can I invoke my plugin (4
files jar) which is a graphical editor developped with GMF ?
Re: I don't find the solution [message #384286 is a reply to message #384285] Tue, 14 April 2009 10:18 Go to previous messageGo to next message
--------------080406060502040708050201
Please use the GMF newsgroup for questions about GMF. I've added it to
the "to" list of the reply, so no need to repost. Here's how EMF's
generated wizard opens the editor upon completion.
public boolean performFinish() {
try {
// Remember the file.
final IFile modelFile = getModelFile();
// Do the work within an operation.
WorkspaceModifyOperation operation =
new WorkspaceModifyOperation() {
protected void execute(IProgressMonitor
progressMonitor) {
try {
// Create a resource set
ResourceSet resourceSet = new
ResourceSetImpl();
// Get the URI of the model file.
URI fileURI =
URI.createPlatformResourceURI(modelFile.getFullPath().toStri ng(), true);
// Create a resource for this file.
Resource resource =
resourceSet.createResource(fileURI);
// Add the initial model object to the
contents.
EObject rootObject = createInitialModel();
if (rootObject != null) {
resource.getContents().add(rootObject);
// Save the contents of the resource to
the file system.
Map<Object, Object> options = new
HashMap<Object, Object>();
options.put(XMLResource.OPTION_ENCODING,
initialObjectCreationPage.getEncoding());
resource.save(options);
catch (Exception exception) {
CustOrderEditorPlugin.INSTANCE.log(exception);
finally {
progressMonitor.done();
getContainer().run(false, false, operation);
// Select the new file resource in the current view.
IWorkbenchWindow workbenchWindow =
workbench.getActiveWorkbenchWindow();
IWorkbenchPage page = workbenchWindow.getActivePage();
final IWorkbenchPart activePart = page.getActivePart();
if (activePart instanceof ISetSelectionTarget) {
final ISelection targetSelection = new
StructuredSelection(modelFile);
getShell().getDisplay().asyncExec
(new Runnable() {
public void run() {
((ISetSelectionTarget)activePart).selectReveal(targetSelecti on);
// Open an editor on the new file.
try {
page.openEditor
(new FileEditorInput(modelFile),
workbench.getEditorRegistry().getDefaultEditor(modelFile.get FullPath().toString()).getId());
catch (PartInitException exception) {
MessageDialog.openError(workbenchWindow.getShell(),
CustOrderEditorPlugin.INSTANCE.getString("_UI_OpenEditorError_label "),
exception.getMessage());
return false;
return true;
return false;
> plugin (4 files jar) which is a graphical editor developped with GMF ?
> Thanks
<html>
<head>
http-equiv="Content-Type">
</head>
Re: I don't find the solution [message #384287 is a reply to message #384286] Tue, 14 April 2009 10:32 Go to previous messageGo to next message
thanks
Can I applicate this code in a one external java file in another IDE like
JCreator ?
Re: I don't find the solution [message #384397 is a reply to message #384287] Tue, 14 April 2009 10:50 Go to previous message
I don't think so. I'm not sure how to make an Eclipse do something from
another process. That's not even a GMF question...
basem-ca wrote:
> thanks
> like JCreator ?
Re: I don't find the solution [message #615329 is a reply to message #384285] Tue, 14 April 2009 10:18 Go to previous message
try {
progressMonitor) {
try {
ResourceSetImpl();
URI fileURI =
Resource resource =
contents.
the file system.
finally {
(new Runnable() {
public void run() {
try {
page.openEditor
return false;
return true;
return false;
> Thanks
<html>
<head>
</head>
Re: I don't find the solution [message #615331 is a reply to message #384286] Tue, 14 April 2009 10:32 Go to previous message
thanks
JCreator ?
Re: I don't find the solution [message #615704 is a reply to message #384287] Tue, 14 April 2009 10:50 Go to previous message
basem-ca wrote:
> thanks
> like JCreator ?
Previous Topic:I don't find the solution
Next Topic:[PMF] Business modeling
Current Time: Sat Nov 01 05:28:38 EDT 2025
Powered by FUDForum. Page generated in 0.29329 seconds
