Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » CDO-Hibernate-Teneo
CDO-Hibernate-Teneo [message #111737] Mon, 04 February 2008 05:13 Go to next message
Hi Eike,
I have started to integration with the teneo mapping generator. For this I have created an interface
HibernateMappingGenerator and an implementation (TeneoHibernateMappingProvider) in a separate plugin.
I have changed the structure of the hibernate store, mainly that the handling of cdopackages is done
using a separate sessionfactory.
The initialzation is now a two-step procedure: 1) initialize the package sessionfactory/store, 2)
read the cdopackages from the database and generate the mapping.
I moved the code for handling (reading/writing) cdopackages to a separate class. This made the
hibernatestore code and initialization a bit cleaner.
I started to work on the unsupportedexceptions. My first one is related to the method:
HibernateStoreWriter.primeNewObject. This method gets a class and returns a new cdoid object. Is
this method for new objects which need to be persisted?
I also noticed that the first object which is persisted is a resource object. You mentioned before
that resources are persisted. What is the (database) model for a resource? In your opinion, should
this be added to a static cdo hibernate mapping (meta.hbm.xml)?
Hibernate works best if each type (eclass) also has a version feature for handling optimistic
locking. It also uses the version property to detect if an object is new or not. In your testmodel
there is no version feature and not all types have a feature which can be used for the id. Do you
agree that I create a separate testmodel which contains this info together with some teneo
annotations? It can be a copy of model1.
Btw, I think you detect that an object is new by looking at the cdoid, correct? Maybe we can use
that in hibernate to detect 'new-ness' instead of the version feature.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: CDO-Hibernate-Teneo [message #111748 is a reply to message #111737] Mon, 04 February 2008 12:42 Go to previous messageGo to next message
Hi Martin,
As I mentioned I£m a bit limited here with my customer, including the
swiss keyboard ;-)
I just read your comments and would like to warn you: I£ve got a lot of
API changes in my local workspace which I can£t commit before they£re
tested. I can send you a patch so that you can preview. It all depends a
bit on how easy I£ll get net-access in the hotel later on...
Cheers
/Eike
Re: CDO-Hibernate-Teneo [message #111753 is a reply to message #111748] Mon, 04 February 2008 15:07 Go to previous messageGo to next message
Originally posted by: stepper.sympedia.de
Hi Martin,
I've attached a patch to bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=217117
Please cc yourself then we can use it to discuss.
Cheers
/Eike
Eike Stepper schrieb:
> Hi Martin,
> swiss keyboard ;-)
> Cheers
> /Eike
Re: CDO-Hibernate-Teneo [message #111758 is a reply to message #111737] Mon, 04 February 2008 15:18 Go to previous messageGo to next message
Martin Taal schrieb:
> Hi Eike,
> I have created an interface HibernateMappingGenerator and an
> handling of cdopackages is done using a separate sessionfactory.
> sessionfactory/store, 2) read the cdopackages from the database and
> separate class. This made the hibernatestore code and initialization a
> bit cleaner.
This seems to be more like a static refactoring without influence on the functionality, right?
> to the method:
> returns a new cdoid object. Is this method for new objects which need to
> be persisted?
This method doesn't exist anymore with the Patch v1.
> object. You mentioned before that resources are persisted. What is the
> (database) model for a resource? In your opinion, should this be added
With CDO a Resource is really an ordinary persistent object much like any other EObject. I think there's no need to add it to the static meta model mapping. At least there was no need for the DBStore. I recall that the CDOResource class has only 2 non-transient features: path and contents. These should be mapped as normal for EObjects.
> for handling optimistic locking. It also uses the version property to
> detect if an object is new or not. In your testmodel there is no version
> Do you agree that I create a separate testmodel which contains this info
> together with some teneo annotations? It can be a copy of model1.
The version is, much like the CDOID, an internal "feature" of each CDOObject:
public interface CDOObject extends EObject
public CDOClass cdoClass();
public CDOID cdoID();
public CDOState cdoState();
public CDOView cdoView();
public CDOResource cdoResource();
public CDORevision cdoRevision();
Of course you can create a separate test model if you think this is necessary ;-)
> correct? Maybe we can use that in hibernate to detect 'new-ness' instead
Hmm, I think you're right. Currently I use something like revision.getID().isTemporary() which indicates if the object has a temporary id because it was newly created in a client side transaction. revision.getVersion() == 1 would have the same effect.
Cheers
/EIke
Re: CDO-Hibernate-Teneo [message #111780 is a reply to message #111758] Mon, 04 February 2008 17:03 Go to previous messageGo to next message
Hi Eike,
See below.
gr. Martin
>> Hi Eike,
>> this I have created an interface HibernateMappingGenerator and an
>> package sessionfactory/store, 2) read the cdopackages from the
>> bit cleaner.
MT>> I did not change the current functionality but added re-initialization of the store when the
epackages change.
>> to be persisted?
MT>> that's easy :-)
MT>> contents can contain any type of eobject from the model, right? If the resource is also
persisted then I can add it to the generated mapping. I need to think about how to map the contents
feature (assuming that any type of eobject can be in the root of the resource).
>> the id. Do you agree that I create a separate testmodel which contains
>> this info together with some teneo annotations? It can be a copy of
>> model1.
> CDOObject:
> necessary ;-)
MT>> It is better if we can use the current native version support of cdo. Below I see you can do
cdoRevision.getVersion() to get the version number.
MT>> Okay
> Cheers
> /EIke
The Netherlands
Re: CDO-Hibernate-Teneo [message #111786 is a reply to message #111753] Mon, 04 February 2008 17:05 Go to previous messageGo to next message
Hi Eike,
The attachment in the bugzilla was only 69 bytes it seemed. Is there another file I should download?
I have added myself as cc.
Okay, I will take care of the hbm for the cdopackage. Did you check in your last version?
Btw, I did the part which reads the ecore str. from the cdopackage and translates it into an ecore
model.
gr. Martin
Eike Stepper wrote:
> Hi Martin,
> Cheers
> /Eike
>> Hi Martin,
>> swiss keyboard ;-)
>> of API changes in my local workspace which I can£t commit before
>> they£re tested. I can send you a patch so that you can preview. It all
>> depends a bit on how easy I£ll get net-access in the hotel later on...
>> Cheers
>> /Eike
The Netherlands
Re: CDO-Hibernate-Teneo [message #111792 is a reply to message #111786] Tue, 05 February 2008 01:42 Go to previous messageGo to next message
> Hi Eike,
Grr. somehow the create patch (Mylyn ChangeSet) didn't work ;-(
I'll try it again...
> your last version?
No, my DBStore is currently broken due to the changes. Hopefully I can fix, test and commit that this evening. This is why I tried to post a patch which you can use to get my latest local state.
> translates it into an ecore model.
Ah, great ;-)
I'm thinking about creating a sibling folder to org.eclipse.emf.cdo/plugins/ in CVS, so that I can nominate you as a committer for that folder. Then you'd be able to add new plugins as well.
Cheers
/Eike
> gr. Martin
> Eike Stepper wrote:
>> Hi Martin,
>> Cheers
>> /Eike
>>> Hi Martin,
>>> swiss keyboard ;-)
>>> all depends a bit on how easy I£ll get net-access in the hotel later
>>> on...
>>> Cheers
>>> /Eike
Re: CDO-Hibernate-Teneo [message #111795 is a reply to message #111780] Tue, 05 February 2008 01:54 Go to previous messageGo to next message
> Hi Eike,
> See below.
> gr. Martin
>>> Hi Eike,
>>> a bit cleaner.
> re-initialization of the store when the epackages change.
Ok, that seems fine. Can you add a patch to https://bugs.eclipse.org/bugs/show_bug.cgi?id=217117 for your changes after you merged in my Patch v2?
>>> the (database) model for a resource? In your opinion, should this be
> the resource is also persisted then I can add it to the generated
> mapping. I need to think about how to map the contents feature (assuming
Do you mean "add it to the manually created mapping"?
I think either approach is ok. I leave it up to you.
The problem with EObject as target type for references could potentially occur at other model places as well, right? An internal flat technical key is practical for these cases ;-)
>>> for the id. Do you agree that I create a separate testmodel which
>>> contains this info together with some teneo annotations? It can be a
>>> copy of model1.
>> CDOObject:
>> necessary ;-)
> cdo. Below I see you can do cdoRevision.getVersion() to get the version
> number.
Right ;-)
Cheers
/Eike
>>> cdoid, correct? Maybe we can use that in hibernate to detect
> MT>> Okay
>> Cheers
>> /EIke
Re: CDO-Hibernate-Teneo [message #111801 is a reply to message #111795] Tue, 05 February 2008 07:32 Go to previous message
Hi Eike,
Yes I will add a patch, this will probably be tomorrow as it really needs to do something (persist
objects) before I want to send something.
With internal flat key, you mean something like a generic reference which can be stored in a string
field. The reference is then for example classname followed by id or something. At least that is
what I was thinking of.
gr. Martin
>> Hi Eike,
>> See below.
>> gr. Martin
>>>> Hi Eike,
>>>> a bit cleaner.
>>>> resource object. You mentioned before that resources are persisted.
>> If the resource is also persisted then I can add it to the generated
>>>> feature for handling optimistic locking. It also uses the version
>>>> can be used for the id. Do you agree that I create a separate
>>> CDOObject:
>>> necessary ;-)
>> version number.
> Right ;-)
> Cheers
> /Eike
>> MT>> Okay
>>> Cheers
>>> /EIke
The Netherlands
Re: CDO-Hibernate-Teneo [message #615390 is a reply to message #111737] Mon, 04 February 2008 12:42 Go to previous message
Hi Martin,
swiss keyboard ;-)
Cheers
/Eike
Re: CDO-Hibernate-Teneo [message #615391 is a reply to message #111748] Mon, 04 February 2008 15:07 Go to previous message
Hi Martin,
Cheers
/Eike
> Hi Martin,
> swiss keyboard ;-)
> Cheers
> /Eike
Re: CDO-Hibernate-Teneo [message #615392 is a reply to message #111737] Mon, 04 February 2008 15:18 Go to previous message
> Hi Eike,
> bit cleaner.
> to the method:
> be persisted?
Cheers
/EIke
Re: CDO-Hibernate-Teneo [message #615396 is a reply to message #111758] Mon, 04 February 2008 17:03 Go to previous message
Hi Eike,
See below.
gr. Martin
>> Hi Eike,
>> bit cleaner.
epackages change.
>> to be persisted?
>> model1.
> CDOObject:
> necessary ;-)
MT>> Okay
> Cheers
> /EIke
The Netherlands
Re: CDO-Hibernate-Teneo [message #615397 is a reply to message #111753] Mon, 04 February 2008 17:05 Go to previous message
Hi Eike,
model.
gr. Martin
Eike Stepper wrote:
> Hi Martin,
> Cheers
> /Eike
>> Hi Martin,
>> swiss keyboard ;-)
>> Cheers
>> /Eike
The Netherlands
Re: CDO-Hibernate-Teneo [message #615398 is a reply to message #111786] Tue, 05 February 2008 01:42 Go to previous message
> Hi Eike,
> your last version?
Ah, great ;-)
Cheers
/Eike
> gr. Martin
> Eike Stepper wrote:
>> Hi Martin,
>> Cheers
>> /Eike
>>> Hi Martin,
>>> swiss keyboard ;-)
>>> on...
>>> Cheers
>>> /Eike
Re: CDO-Hibernate-Teneo [message #615399 is a reply to message #111780] Tue, 05 February 2008 01:54 Go to previous message
> Hi Eike,
> See below.
> gr. Martin
>>> Hi Eike,
>>> a bit cleaner.
>>> copy of model1.
>> CDOObject:
>> necessary ;-)
> number.
Right ;-)
Cheers
/Eike
> MT>> Okay
>> Cheers
>> /EIke
Re: CDO-Hibernate-Teneo [message #615400 is a reply to message #111795] Tue, 05 February 2008 07:32 Go to previous message
Hi Eike,
gr. Martin
>> Hi Eike,
>> See below.
>> gr. Martin
>>>> Hi Eike,
>>>> a bit cleaner.
>>> CDOObject:
>>> necessary ;-)
>> version number.
> Right ;-)
> Cheers
> /Eike
>> MT>> Okay
>>> Cheers
>>> /EIke
The Netherlands
Previous Topic:CDO-Hibernate-Teneo
Next Topic:SQL handling in CDO
Current Time: Fri Jul 18 16:58:53 EDT 2025
Powered by FUDForum. Page generated in 0.20963 seconds
