Home » Archived » Visual Editor (VE) » JScroolPane in a JTextArea
JScroolPane in a JTextArea [message #137059] Sat, 31 March 2007 10:17 Go to next message
Anyone knows how to put a scrool pane in a textarea using the VE?? and how
do i set for it rool automatic when the text get at the end of the
textarea??
thank!
Re: JScroolPane in a JTextArea [message #137304 is a reply to message #137059] Wed, 18 April 2007 10:22 Go to previous messageGo to next message
> the end of the
> textarea??
> thank!
I believe that you would have to put the TextArea into the ScrollPane to make that work.
Brian
Re: JScroolPane in a JTextArea [message #137397 is a reply to message #137304] Tue, 24 April 2007 09:11 Go to previous messageGo to next message
Originally posted by: javaloco.argentina.com
Did you try with Jigloo?
is more easier
Re: JScroolPane in a JTextArea [message #137449 is a reply to message #137059] Sat, 28 April 2007 13:55 Go to previous message
Originally posted by: marcelabx.gmail.com
You have to write the code
Example:
JTextArea txarea= new JTextArea();
JScrollPane pScroll = new JScrollPane(txarea, JScrollPane.VERTICAL_SCROLLBAR_ALWAYS, JScrollPane.HORIZONTAL_SCROLLBAR_ALWAYS);
then you add the jscrollpane at the panel
p1 = new JPanel(new BorderLayout());
p1.add(pScroll, BorderLayout.CENTER);
Re: JScroolPane in a JTextArea [message #615196 is a reply to message #137059] Wed, 18 April 2007 10:22 Go to previous message
> the end of the
> textarea??
> thank!
Brian
Re: JScroolPane in a JTextArea [message #615204 is a reply to message #137304] Tue, 24 April 2007 09:11 Go to previous message
is more easier
Re: JScroolPane in a JTextArea [message #615209 is a reply to message #137059] Sat, 28 April 2007 13:55 Go to previous message
Example:
Previous Topic:problem with building VE from head
Next Topic:VE freezes when running from laptop battery
Current Time: Sat Jul 19 00:14:26 EDT 2025
Powered by FUDForum. Page generated in 0.30154 seconds
