Home » Archived » Visual Editor (VE) » Eclipse 3.2.1 and VE on Ubuntu Edgy
Eclipse 3.2.1 and VE on Ubuntu Edgy [message #136750] Wed, 21 March 2007 23:55 Go to next message
Originally posted by: mcasagra.tampabay.rr.com
How do I install VE in Ubuntu Eclipse 3.2.1 ?
I have downloaded the following pkgs in Synaptic Manager:
eclipse (version 3.2.1-0ubuntu1) will be installed
eclipse-jdt (version 3.2.1-0ubuntu1) will be installed
eclipse-jdt-gcj (version 3.2.1-0ubuntu1) will be installed
eclipse-pde (version 3.2.1-0ubuntu1) will be installed
eclipse-platform (version 3.2.1-0ubuntu1) will be installed
eclipse-rcp (version 3.2.1-0ubuntu1) will be installed
eclipse-rcp-gcj (version 3.2.1-0ubuntu1) will be installed
eclipse-source (version 3.2.1-0ubuntu1) will be installed
libswt3.2-gtk-gcj (version 3.2.1-0ubuntu1) will be installed
libswt3.2-gtk-java (version 3.2.1-0ubuntu1) will be installed
I then selected the Callisto package (complete)feature updates in the
Eclipse Software Update Manager.
I always end up with an error during the load when it wants to install
a 3.2.2 version of the org.eclipse.platform.3.2.2.r322_v2007019-RQghnd
and a few more chars for good luck!!!
Can you even load the Callisto updates on Ubuntu Eclipse 3.2.1-0ubuntu1?
Has anyone done so successfully?
Mark
Re: Eclipse 3.2.1 and VE on Ubuntu Edgy [message #136764 is a reply to message #136750] Thu, 22 March 2007 09:28 Go to previous messageGo to next message
You didn't even get to the VE part of the download. It got stuck in the
base part, so a better place to ask this question would be on the
eclipse.platform newsgroup.
> Regards,
> Mark
Rich Kulp
Re: Eclipse 3.2.1 and VE on Ubuntu Edgy [message #136799 is a reply to message #136750] Sat, 24 March 2007 15:53 Go to previous message
Mark,
The VE does not work properly with GCJ. Please install Sun's Java, then
install Eclipse using the packages from eclipse.org rather than those
available from Synaptic. Once that is installed, use the Update Manager
to install VE and the prereq versions of EMF and GEF. The VE will run
correctly on Ubuntu with that configuration.
Hope this helps,
- Jeff
> Regards,
> Mark
Re: Eclipse 3.2.1 and VE on Ubuntu Edgy [message #615151 is a reply to message #136750] Thu, 22 March 2007 09:28 Go to previous message
> Regards,
> Mark
Rich Kulp
Re: Eclipse 3.2.1 and VE on Ubuntu Edgy [message #615154 is a reply to message #136750] Sat, 24 March 2007 15:53 Go to previous message
Mark,
Hope this helps,
- Jeff
> Regards,
> Mark
Previous Topic:ClassNotFoundException at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoad
Next Topic:jToolBar
Current Time: Fri Jul 18 20:09:08 EDT 2025
Powered by FUDForum. Page generated in 0.04987 seconds
