Home » Eclipse Projects » GEF » draw2d & property sheet
draw2d & property sheet [message #61186] Sun, 02 February 2003 14:07 Go to next message
Hi!
I want to use the property sheet view to let the user customize the colour
of a clicked figure.
When i use a treeview i only need to implement the Ipropertysource
interface, but how to do that with a canvas?
Stefan
Re: draw2d & property sheet [message #61260 is a reply to message #61186] Mon, 03 February 2003 00:35 Go to previous messageGo to next message
Are you using just Draw2d of GEF?
A GEF EditPartViewer is an ISelectionPRovider, and can be hooked into the
workbench's selection service, which feeds the PropertySheet. The unit of
selection is an EditPart, so either the EditPart is the IPropertySource, or
it is IAdaptable and returns an instance of an IPRopertySource.
"stefan" <sg@media-style.com> wrote in message
news:b1joba$klr$1@rogue.oti.com...
> Hi!
> Thanks
> Stefan
Re: draw2d & property sheet [message #61481 is a reply to message #61260] Mon, 03 February 2003 12:25 Go to previous messageGo to next message
Just Draw2d to paint some valuegraphs. Should i use the hole GEF?
Re: draw2d & property sheet [message #61504 is a reply to message #61481] Mon, 03 February 2003 13:10 Go to previous messageGo to next message
Draw2d has no built-in support for selection or accessibility. It's your
choice.
news:b1m6mg$4ee$1@rogue.oti.com...
Re: draw2d & property sheet [message #61644 is a reply to message #61504] Mon, 03 February 2003 13:28 Go to previous messageGo to next message
> choice.
If it is possible i would stay only by draw2d. But i dont know how to
implement the stuff manually.
Can you give me only some keywords.
If you must give me more then 10 keyword i will switch to gef. ;:-)
Thanks!
Stefan
Re: draw2d & property sheet [message #61667 is a reply to message #61644] Mon, 03 February 2003 16:31 Go to previous message
The problem is that nothing in draw2d maintians a set of selected items.
Nothing implements ISelectionProvider. You would be implementing the
equivalent of Swing's JList or some other widget like that.
news:b1mgp7$c08$1@rogue.oti.com...
your
> > choice.
> Thanks!
> Stefan
Previous Topic:Putting the logic Editor in a View
Next Topic:where are the figures?
Current Time: Tue Nov 04 15:54:31 EST 2025
Powered by FUDForum. Page generated in 0.04763 seconds
