Home » Modeling » UML2 Tools » Generate models from existing source
Generate models from existing source [message #472158] Fri, 21 December 2007 07:28 Go to next message
Hi.
I've been trying out uml2 tools for a couple of hours now trying to find a
way to generate class diagrams from my existing source (a java project). I
cant find a way to do it yet.
Anyone using uml2 tools for this purpose and can point me in the right
direction to accomplish this or does the tool not support this?
/Andreas
Re: Generate models from existing source [message #472164 is a reply to message #472158] Fri, 21 December 2007 08:05 Go to previous message
--------------030505020403080409000507
Andreas,
I don't think the tools support this. I don't recall if the GMT project
has any reverse engineering tools like what you want. EMF does
something similar but that requires you annotate the source code (with
@model annotations in the Javadoc) to indicate which things are part of
the model and how methods in the Java code correspond to operations
verses features in the model:
< http://help.eclipse.org/help33/topic/org.eclipse.emf.doc/tut orials/clibmod/clibmod.html#step1b>
From an Ecore model, it's possible to export it to a UML model; it's
also possible, with the Ecore tools component of EMFT, to create a
UML-style class diagram directly for the Ecore model.
Andreas wrote:
> Hi. I've been trying out uml2 tools for a couple of hours now trying
> to find a way to generate class diagrams from my existing source (a
> java project). I cant find a way to do it yet.
> Thanks
> /Andreas
<html>
<head>
http-equiv="Content-Type">
</head>
Andreas,<br>
<br>
Re: Generate models from existing source [message #614529 is a reply to message #472158] Fri, 21 December 2007 08:05 Go to previous message
Andreas,
> Thanks
> /Andreas
<html>
<head>
</head>
Andreas,<br>
<br>
Previous Topic:Re: How to use partition in uml2tool activity diagram
Next Topic:How can I associate a inputPIN with a AcceptEventAction
Current Time: Sat Jul 26 22:22:43 EDT 2025
Powered by FUDForum. Page generated in 0.07134 seconds
