Home » Archived » Service Oriented Architecture Tools Platform (STP) » Re: Subversion Build of STP
Re: Subversion Build of STP [message #374663] Tue, 08 April 2008 04:56 Go to next message
Antoine Toulme wrote:
> I don't know much, Oisin and Adrian Skehill working on this particular
> part of the project, but I am pretty sure that we are using Buckminster.
> I think you should look for messages from Adrian on the buckminster
> newsroup, he looked for help there at some point.
> Antoine
> Tas Frangoullides wrote:
>> Hi STP team,
>> I notcied that you use a subversion repository for STP and was hoping
>> you might be able to help. I'm trying to setup an automated PDE Build
>> using Subversion and having trouble finding information about how to
>> get this working. I know how to do this with CVS and Releng tools but
>> don't know what support there is for subversion. If you have any quick
>> pointers I would really appreciate the help. In the meantime I will
>> try to decipher what's in your repository.
>> Thanks,
>> Tas
Yup, we're using Buckminster to do the build. If you take a look at the
build.xml in the build folder you'll see how it kicks off things. We use
Buckminster to bootstrap things, meaning it goes and checks out the code from
svn, ensures all dependencies are present and then delegates to the PDE build
to build plugins, create the update site etc.
If you need some help on any aspects of this, feel free to drop me a line.
A.
Re: Subversion Build of STP [message #374668 is a reply to message #374663] Tue, 08 April 2008 10:03 Go to previous messageGo to next message
Originally posted by: tas.frangoullides.barclaysglobal.com
Hi Adrian,
Thanks for offering to help, I will probably be in touch soon.
Before I do that let me investigate buckminster and get myself familar.
Thanks again,
Tas
from
build
> A.
Re: Subversion Build of STP [message #374706 is a reply to message #374668] Thu, 01 May 2008 09:26 Go to previous messageGo to next message
Originally posted by: ohurley.iona.com
Hi Tas,
> I've had a chance to play with buckminster and kind I'm started to get a
> feel for it. One of the things I noticed about STP is that you have used
> map files and svn-pde build, which I am familiar with. Are these still
> used by your build or are they historical artifacts no longer required by
> the buckminster build?
Those map and svn-pde build files are old and I really should get rid of
them. There are some lightweight build instructions at [0] to build the
whole project, but as I mentioned to Koen in a separate thread, I'm
tinkering to get ready for M7 builds. Currently I am having a lot of
'fun' resolving multiple versions of javax.wsdl :)
Try them out - best place to ask questions on the gory details is the
stp-dev mailing list.
best regards
Oisin
[0] http://wiki.eclipse.org/STP/Build/Build_101
Oisin Hurley at IONA
http://blogs.iona.com/ohurley/
Re: Subversion Build of STP [message #374716 is a reply to message #374706] Fri, 02 May 2008 04:40 Go to previous message
Thanks Oisin.
Re: Subversion Build of STP [message #614260 is a reply to message #374663] Tue, 08 April 2008 10:03 Go to previous message
Hi Adrian,
Thanks again,
Tas
from
build
> A.
Re: Subversion Build of STP [message #614471 is a reply to message #374668] Thu, 01 May 2008 06:36 Go to previous message
Hi Adrian,
Thanks for your help,
Tas
Re: Subversion Build of STP [message #614477 is a reply to message #614471] Thu, 01 May 2008 09:26 Go to previous message
Hi Tas,
best regards
Oisin
Re: Subversion Build of STP [message #615826 is a reply to message #374706] Fri, 02 May 2008 04:40 Go to previous message
Thanks Oisin.
Previous Topic:Multiple inputs from the client while the process is running
Next Topic:Updating the Web Service Definition
Current Time: Sat Jul 26 23:25:58 EDT 2025
Powered by FUDForum. Page generated in 0.15306 seconds
