Home » Eclipse Projects » JavaServer Faces » 2.0.1RC1 JSF semantics validator performance
2.0.1RC1 JSF semantics validator performance [message #475076] |
Tue, 11 September 2007 05:11  |
Hi!
Just installed WTP 2.0.1RC1 and noticed, that JSF Semantics validator
performance degraded about 15-20 times. Is such a performance drop to be
expected in FR of 2.0.1?
Searched bugzilla and haven't found any fixed/opened bugs related to jsf
validator mechanism. Sorry, if I panic too early, but I consider RC's as
bug fixing stage when no new features are added. And since jsf validator
was rather fast in previous 2.0.1 builds, I think it is something
intentionally changed :)
I used eclipse 3.3.1 (last stable M for Win32), sun's jdk 1.5.0_12.
Re: 2.0.1RC1 JSF semantics validator performance [message #475078 is a reply to message #475076] |
Tue, 11 September 2007 09:48   |
On 9/11/2007 5:11 AM, Vadim Dmitriev wrote:
> Hi!
I don't if there were any changes recently, but was it ever fast, really?
Maybe you were testing with different JSPs? The more complex the JSP,
the slower it gets, especially when there are many EL expressions.
This bug has been open for a while now, and just deferred to 3.0:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=163890
Re: 2.0.1RC1 JSF semantics validator performance [message #475080 is a reply to message #475078] |
Tue, 11 September 2007 12:42   |
Thanks for reply, Yury.
I was testing on project, that is almost complete and now it is in
testing stage so JSPs are mainly stay unchanged for a long time. It
consist of relatively 250 JSPs and with even 3 weeks-old WTP2.0.1 build
validated in 4 minutes topmost (the same for 2.0 release). With 2.0.1RC1
estimated completion time is about 40 or so minutes. It looks like
validation algorithm changed and i don't have nor time neither i have
will to check validation sources myself to see whether it is true :)
Well, maybe it worth to wait for RC2.
Best regards.
Re: 2.0.1RC1 JSF semantics validator performance [message #475081 is a reply to message #475080] |
Tue, 11 September 2007 13:54   |
I am seeing significant degradation on the variable resolver stress test:
Report for performance test: Stress Variable Resolver
Number of iterations: 100000
Max: 2,469,061,850, Max Index: 0
Min: 2,793,092, Min Index: 71,326
Avg: 3,793,538, StdDev: 8,415,462.297, StdDev Ignore Max/Min: 3,169,308.624
Compared with:
Max: 2,812,605,233, Max Index: 0
Min: 156,444, Min Index: 77,049
Avg: 257,688, StdDev: 8,915,112.194, StdDev Ignore Max/Min: 621,480.648
In the 2.0 pre-release baseline using Matthias' type info caching
mechanism. The property resolver may have degraded slightly too, but it
looks like by only about 10% which could be within the natural variance of
the test.
If this is a serious issue for you in 2.0 please escalate the bug:
by ramping the severity. Also, if you could run the StressTest test case
(use -Xmx256M -XX:PermSize=256M) in org.eclipse.jst.jsf.validation.el and
paste your console output to the bug, that would help too.
--Cam
Re: 2.0.1RC1 JSF semantics validator performance [message #475085 is a reply to message #475083] |
Sun, 16 September 2007 12:40  |
Cameron Bateman wrote:
> I think I have found the source of degradation in performance for
> variables. The JSPModelProcessor that discovers and caches variables
> declared by tags in a page is being disposed too early which causes page
> re-parses for each variable lookup. See updates to
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=163890 for more details.
> --Cam
Thanks for your effort, Cameron.
It's a relief to know that jsf validator performance is still
work-in-progress. I'll post my subjective opinion about acceptable
validation speed limits in related bugzilla entry.
P.S. I looked into running stress test you mentioned, but haven't found
one with provided name. Plus, I don't have enough experience with JUnit
(and running JUnits for eclipse plugins). Sorry.
Re: 2.0.1RC1 JSF semantics validator performance [message #614417 is a reply to message #475076] |
> Hi!
Re: 2.0.1RC1 JSF semantics validator performance [message #614418 is a reply to message #475078] |
Best regards.
Re: 2.0.1RC1 JSF semantics validator performance [message #614421 is a reply to message #475080] |
Compared with:
the test.
--Cam
Re: 2.0.1RC1 JSF semantics validator performance [message #614426 is a reply to message #475083] |
> --Cam
Current Time: Wed Jul 23 05:35:07 EDT 2025
Powered by FUDForum. Page generated in 0.05486 seconds
