Home » Eclipse Projects » JavaServer Faces » resource-bundle defined in faces-config.xml not used by validator and intellisen
resource-bundle defined in faces-config.xml not used by validator and intellisen [message #475016] Fri, 10 August 2007 12:58 Go to next message
in faces-config.xml i have following piece of configuration
<application>
<resource-bundle>
<base-name>bundles.messages</base-name>
<var>bundle</var>
</resource-bundle>
</application>
Bundle messages.properties is available in package "bundles". Everything
works when project is compiled and deployed. Only problem i have is
validation and intellisense. E.g. i have following tag in my jsp:
<h:outputText value="#{bundle.caption_preview}"></h:outputText>
Intellisense after "button." shows following items: class, keys, locale.
It should show keys from resource bundle.
Validation and intellisense works if <f:loadBundle is used.
Note: intellisense for backing-beans works well.
any idea how to solve the problem? Does someone else has the problem or is
it a bug or a feature?
thanks
best regards
jano
Re: resource-bundle defined in faces-config.xml not used by validator and intellisen [message #475018 is a reply to message #475016] Mon, 13 August 2007 13:50 Go to previous messageGo to next message
The most likely causes are:
1) There is no messages.properties under a bundles package in any
classpath container (by default the project creates the "src" dir). Note
that we currently don't support localized property files with this
feature, so you need a messages.properties file in addition to whatever
localized files you may have (i.e. messages_DE.properties).
2) Your project doesn't have a Faces 1.2 facet. The resource-bundle
feature in faces-config is for JSF 1.2 and above only.
--Cam
jmi wrote:
> Hello,
> <application>
> <resource-bundle>
> <var>bundle</var>
> </resource-bundle>
> </application>
> thanks
> best regards
> jano
Re: resource-bundle defined in faces-config.xml not used by validator and intellisen [message #475021 is a reply to message #475018] Tue, 14 August 2007 12:48 Go to previous messageGo to next message
atm I don't have localized properties file, only one with
messages.properties name in bundles package in one of multiple source
folders. There is faces JSF 1.2 in project. Moreover everything works if
jsp uses tag
<f:loadBundle var="bundle" basename="bundles.messages" />
but if only faces-config.xml contains
<application>
<resource-bundle>
<var>bundle</var>
</resource-bundle>
</application>
intelisense and validation doesn't work. In runtime there is no
difference, and everything works.
according to your post it looks like that it works for you. Maybe i should
try with simplier project setup.
regards
jano
Re: resource-bundle defined in faces-config.xml not used by validator and intellisen [message #475022 is a reply to message #475021] Tue, 14 August 2007 18:48 Go to previous messageGo to next message
Two other things:
1) Go to the Project Properties menu and go to Project Facets. Ensure
that the version of the JSF facet 1.2.
2) Ensure you are using WTP 2.0. The resource bundle variable contributor
was not in WTP 1.5.x. The loadBundle contributor was.
--Cam
Re: resource-bundle defined in faces-config.xml not used by validator and intellisen [message #475023 is a reply to message #475022] Wed, 15 August 2007 03:24 Go to previous messageGo to next message
1) i have it there.
2) i'm using it. Downloaded few days ago.
does this feature work for you?
regards
jmi
Re: resource-bundle defined in faces-config.xml not used by validator and intellisen [message #475026 is a reply to message #475023] Wed, 15 August 2007 15:37 Go to previous messageGo to next message
Yes. Could you produce an example project (or your actual project if it
something you can make publicly available) where the features don't work
you and attach it to a bug? This way I can try the actual code that you
are using and try to debug the problem.
--Cam
Re: resource-bundle defined in faces-config.xml not used by validator and intellisen [message #475030 is a reply to message #475026] Thu, 16 August 2007 10:45 Go to previous message
when making minimalistic example, i found that it works now. Maybe opening
of all dialogs when checking the settings and closing them with OK instead
of cancel did something what helped. Don't know.
Project itself was created by maven, not by eclipse, and WTP2.0 stuff was
added manually. Maybe there was something wrong and corrected after
opening WTP dialogs.
many thanks.
best regards
jmi
Re: resource-bundle defined in faces-config.xml not used by validator and intellisen [message #613876 is a reply to message #475016] Mon, 13 August 2007 13:50 Go to previous message
--Cam
jmi wrote:
> Hello,
> <application>
> <resource-bundle>
> <var>bundle</var>
> </resource-bundle>
> </application>
> thanks
> best regards
> jano
Re: resource-bundle defined in faces-config.xml not used by validator and intellisen [message #613879 is a reply to message #475018] Tue, 14 August 2007 12:48 Go to previous message
jsp uses tag
<application>
<resource-bundle>
<var>bundle</var>
</resource-bundle>
</application>
regards
jano
Re: resource-bundle defined in faces-config.xml not used by validator and intellisen [message #613880 is a reply to message #475021] Tue, 14 August 2007 18:48 Go to previous message
Two other things:
--Cam
Re: resource-bundle defined in faces-config.xml not used by validator and intellisen [message #614171 is a reply to message #475022] Wed, 15 August 2007 03:24 Go to previous message
1) i have it there.
regards
jmi
Re: resource-bundle defined in faces-config.xml not used by validator and intellisen [message #614177 is a reply to message #475023] Wed, 15 August 2007 15:37 Go to previous message
--Cam
Re: resource-bundle defined in faces-config.xml not used by validator and intellisen [message #614189 is a reply to message #475026] Thu, 16 August 2007 10:45 Go to previous message
many thanks.
best regards
jmi
Previous Topic:Where can I change the HostElement attribute value?
Next Topic:AbstractTagConverter#doConvertRefresh
Current Time: Sat Jul 26 20:32:53 EDT 2025
Powered by FUDForum. Page generated in 0.04892 seconds
