Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] Class loader issues within a plugin
[Teneo] Class loader issues within a plugin [message #108589] Mon, 28 January 2008 06:07 Go to next message
Hi!
I'm trying to use Teneo within an Eclipse plugin project. Unfortunately I'm
running into issues concerning the interdependencies of the JPOX, Teneo and
JDO plugins. My plugin configuration is:
Plugin name depends on jar file included
javax.jdo - jdo2-api-2.0.jar
org.jpox javax.jdo (reexport) jpox-1.1.9.jar
org.postgresql
masterDataEditor org.jpox
org.eclipse.emf.teneo.jpox
org.eclipse.emf.teneo.eclipse
This gives me the following exception upon executing the code further down:
java.lang.ClassNotFoundException: org.jpox.PersistenceManagerFactoryImpl
at java.lang.ClassLoader.findClass(ClassLoader.java:358)
at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
at
org.eclipse.core.runtime.internal.adaptor.ContextFinder.load Class(ContextFinder.java:124)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
at javax.jdo.JDOHelper.getPersistenceManagerFactory(JDOHelper.j ava:530)
at javax.jdo.JDOHelper.getPersistenceManagerFactory(JDOHelper.j ava:478)
at
org.eclipse.emf.teneo.jpox.JpoxDataStore.createSchema(JpoxDa taStore.java:526)
at
org.eclipse.emf.teneo.jpox.JpoxDataStore.initialize(JpoxData Store.java:217)
at
org.acoveo.callcenter.masterdataeditor.NavigationView.create SampleData(NavigationView.java:195)
at
org.acoveo.callcenter.masterdataeditor.NavigationView.create PartControl(NavigationView.java:170)
at
org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java:370)
at org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:227)
at
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:592)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:29 9)
at org.eclipse.ui.internal.ViewPane.setVisible(ViewPane.java:53 1)
<snipped/>
Teneo is at version 0.8.0.v200712280940 installed from the EMFT update site.
The problem seems to be that the class loader of the javax.jdo plugin cannot
find the jpox classes (which doesn't come as a surprise). However, I can't
solve the problem by letting javax.jdo depend on org.jpox, because that
would result in a cyclic dependency graph (and org.jpox required javax.jdo
as well). Before using Teneo, I simply passed my plugin's
(masterDataEditor) classloader to the JDOHelper class:
PersistenceManagerFactory factory =
JDOHelper.getPersistenceManagerFactory("jpox_postgre.properties ",
Activator.class.getClassLoader());
persistenceManager = factory.getPersistenceManager();
That solved the dependency problems, because both the javax.jdo as well as
the org.jpox plugins are visible to the class loader of my plugin. Could
someone please tell me how to proceed with Teneo in order to achieve the
same effect?
Florian
Here is the code I'm trying to run:
Properties properties = new Properties();
properties.setProperty(PMFConfiguration.JDO_DATASTORE_DRIVER NAME_PROPERTY, "com.postgresql.Driver");
properties.setProperty(PMFConfiguration.JDO_DATASTORE_URL_PR OPERTY, "jdbc:postgresql://localhost/asterisk");
properties.setProperty(PMFConfiguration.JDO_DATASTORE_USERNA ME_PROPERTY, "asterisk");
properties.setProperty(PMFConfiguration.JDO_DATASTORE_PASSWO RD_PROPERTY, "aiLiegh0");
String pmfName = "MyPMF"; // the name of the JpoxDataStore
JpoxDataStore jpoxDataStore =
JpoxHelper.INSTANCE.createRegisterDataStore(pmfName);
jpoxDataStore.setProperties(properties);
jpoxDataStore.setEPackages(new EPackage[]{MasterdataPackage.eINSTANCE});
jpoxDataStore.initialize();
// TODO Auto-generated method stub
PersistenceManagerFactory pmf = jpoxDataStore.getPMF();
PersistenceManager pm = pmf.getPersistenceManager();
Transaction tx=pm.currentTransaction();
try
tx.begin();
AgentGroup agentGroup = MasterdataFactory.eINSTANCE.createAgentGroup();
agentGroup.setName("myAgentGroup");
agentGroup.setMusicClass("mymusicclass");
pm.makePersistent(agentGroup);
Agent agent = MasterdataFactory.eINSTANCE.createAgent();
agent.setAgentId("6000");
agent.setName("Florian Hackenberger");
agent.setPassword("6000");
pm.makePersistent(agent);
tx.commit();
finally
if (tx.isActive())
tx.rollback();
pm.close();
Re: [Teneo] Class loader issues within a plugin [message #108606 is a reply to message #108589] Mon, 28 January 2008 06:54 Go to previous messageGo to next message
Hi Florian,
I think it is related to the Eclipse-BuddyPolicy setting.
Does the javax.jdo have this line in its manifest.mf:
Eclipse-BuddyPolicy: dependent
or do you use another setting?
The same buddypolicy should be set in the org.jpox plugin.
gr. Martin
DI Florian Hackenberger wrote:
> Hi!
> org.postgresql
> at
> at
> at
> at
> at
> at
> at
> <snipped/>
> same effect?
> Cheers,
> Florian
> try
> tx.begin();
> tx.commit();
> finally
> if (tx.isActive())
> tx.rollback();
> pm.close();
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Class loader issues within a plugin [message #108645 is a reply to message #108606] Mon, 28 January 2008 09:24 Go to previous messageGo to next message
Martin Taal wrote:
> Hi Florian,
That solved it, thanks a lot!
Could someone with write access to the Teneo documentation on elver.org
please add this hint somewhere? Or have I just overlooked it (google
doesn't say so)?
Florian
Re: [Teneo] Class loader issues within a plugin [message #108659 is a reply to message #108645] Mon, 28 January 2008 09:45 Go to previous messageGo to next message
It is there:
http://www.elver.org/jpox/installation.html#JPOX+Libraries
But maybe it is not clear/notable enough (although it's in bold ;-).
Let me know if you have a better location/better hint for this. I am always willing to improve this.
gr. Martin
> Martin Taal wrote:
>> Hi Florian,
> doesn't say so)?
> Cheers,
> Florian
The Netherlands
Re: [Teneo] Class loader issues within a plugin [message #108673 is a reply to message #108606] Mon, 28 January 2008 09:56 Go to previous messageGo to next message
Martin Taal wrote:
> Hi Florian,
My previous reply was a bit too enthusiastic. While your hint solved the
jpox <-> jdo cyclic dependency, the jpox plugin now fails to load the
org.postgresql classes. I read the articles [1] and [2] and I have tried to
specify BP 'dependent' for both the jpox and jdo plugins, added the postgre
plugin as a dependecy for both jdo and jpox, as well as my plugin project
and tried to use BP registered instead of dependent for both jpox and jdo
and registered my plugin masterDataEditor to both of them. Neither solution
worked. BTW. the postgre dependency is always marked as 'reexport'. The
stacktrace is:
org.jpox.exceptions.ClassNotResolvedException: Class com.postgresql.Driver
was not found in the CLASSPATH. Please check your specification and your
CLASSPATH.
at
org.jpox.JDOClassLoaderResolver.classForName(JDOClassLoaderR esolver.java:214)
at
org.jpox.JDOClassLoaderResolver.classForName(JDOClassLoaderR esolver.java:373)
at
org.jpox.datasource.DriverManagerDataSource.<init>(DriverManagerDataSource.java:73)
at
org.jpox.AbstractPersistenceManagerFactory.freezeConfigurati on(AbstractPersistenceManagerFactory.java:257)
at
org.jpox.PersistenceManagerFactoryImpl.getPersistenceManager Factory(PersistenceManagerFactoryImpl.java:99)
at
at
at javax.jdo.JDOHelper.getPersistenceManagerFactory(JDOHelper.j ava:534)
at
at
at
at
<snipped/>
I'm a bit lost. Help is greatly appreciated :-)
[1]http://www.eclipsezone.com/articles/eclipse-vms/
[2] http://wiki.eclipse.org/index.php/Context_Class_Loader_Enhan cements#Buddy_Policy
Florian
Re: [Teneo] Class loader issues within a plugin [message #108687 is a reply to message #108673] Mon, 28 January 2008 10:07 Go to previous messageGo to next message
I just put all the jars in one plugin is this also a structure you can use? It would probably be
easier. And if this works then you can try to move the jars to their individual plugins.
gr. Martin
> Martin Taal wrote:
>> Hi Florian,
> stacktrace is:
> CLASSPATH.
> at
> at
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> at
> at
> at
> <snipped/>
> Cheers,
> Florian
The Netherlands
Re: [Teneo] Class loader issues within a plugin [message #108701 is a reply to message #108659] Mon, 28 January 2008 12:15 Go to previous messageGo to next message
Martin Taal wrote:
> It is there:
Ok thanks, I should see my oculist :-). I probably even read this, but at
that point in time, I had no idea what it was supposed to mean (buddy
policy) and obviously did not bother googling it either (very lazy indeed).
Maybe another sentence explaining the reason for placing all jars in one
plugin and why the Buddy policy is required if they are placed in separate
plugins. Thanks for your help!
Florian
Re: [Teneo] Class loader issues within a plugin [message #109293 is a reply to message #108687] Tue, 29 January 2008 13:51 Go to previous message
Originally posted by: tom.eiswind.de
It should be a matter of buddy-policies. i had lots of pain with spring
and hibernate on that, but finally with the right buddy policies
everything is fine. look at policy: registered and Register-Buddy.
> use? It would probably be easier. And if this works then you can try to
> gr. Martin
>> Martin Taal wrote:
>>> Hi Florian,
>> tried to
>> postgre
>> solution
>> stacktrace is:
>> CLASSPATH.
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> <snipped/>
>> Cheers,
>> Florian
Re: [Teneo] Class loader issues within a plugin [message #614111 is a reply to message #108589] Mon, 28 January 2008 06:54 Go to previous message
Hi Florian,
gr. Martin
> Hi!
> org.postgresql
> at
> at
> at
> at
> at
> at
> at
> <snipped/>
> same effect?
> Cheers,
> Florian
> try
> tx.begin();
> tx.commit();
> finally
> if (tx.isActive())
> tx.rollback();
> pm.close();
The Netherlands
Re: [Teneo] Class loader issues within a plugin [message #614114 is a reply to message #108606] Mon, 28 January 2008 09:24 Go to previous message
Martin Taal wrote:
> Hi Florian,
doesn't say so)?
Florian
Re: [Teneo] Class loader issues within a plugin [message #614115 is a reply to message #108645] Mon, 28 January 2008 09:45 Go to previous message
It is there:
gr. Martin
> Martin Taal wrote:
>> Hi Florian,
> doesn't say so)?
> Cheers,
> Florian
The Netherlands
Re: [Teneo] Class loader issues within a plugin [message #614116 is a reply to message #108606] Mon, 28 January 2008 09:56 Go to previous message
Martin Taal wrote:
> Hi Florian,
stacktrace is:
CLASSPATH.
at
at
at
at
at
at
at
at
at
at
at
<snipped/>
Florian
Re: [Teneo] Class loader issues within a plugin [message #614117 is a reply to message #108673] Mon, 28 January 2008 10:07 Go to previous message
gr. Martin
> Martin Taal wrote:
>> Hi Florian,
> stacktrace is:
> CLASSPATH.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> <snipped/>
> Cheers,
> Florian
The Netherlands
Re: [Teneo] Class loader issues within a plugin [message #614118 is a reply to message #108659] Mon, 28 January 2008 12:15 Go to previous message
Martin Taal wrote:
> It is there:
Florian
Re: [Teneo] Class loader issues within a plugin [message #614164 is a reply to message #108687] Tue, 29 January 2008 13:51 Go to previous message
> gr. Martin
>> Martin Taal wrote:
>>> Hi Florian,
>> tried to
>> postgre
>> solution
>> stacktrace is:
>> CLASSPATH.
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> <snipped/>
>> Cheers,
>> Florian
Previous Topic:[Compare] How to compare ecore models, content types
Next Topic:Re: Modeling tools
Current Time: Sun Jul 27 09:21:52 EDT 2025
Powered by FUDForum. Page generated in 0.06318 seconds
