[Teneo] Multi-column join? [message #106805] |
Mon, 14 January 2008 18:47  |
I haven't updated my version of Teneo in a while. My client has decided
that they really need to support of horribly written old tables and now
they're coming up to a multi-column join problem.
We looked into the code, it looks like the multiple column join is
specifically not supported. Do you know if it would be very hard to add
support for it? Any suggestions about what would need to be done to
support it. (I.E. is it something I could do myself relatively quickly?)
Thanks for any advice,
Jason
public class ManyToOneMapper
extends AbstractAssociationMapper
implements ExtensionPoint {
public void process(PAnnotatedEReference paReference) {
log.debug("Process many-to-one " + paReference);
final List<JoinColumn> jcs = getJoinColumns(paReference);
if (jcs.size() > 1) { // TODO support multiple join columns
log.error("Unsupported multiple join columns in " + paReference);
throw new MappingException("Unsupported multiple join columns",
paReference);
Re: [Teneo] Multi-column join? [message #106835 is a reply to message #106805] |
Tue, 15 January 2008 01:08   |
--------------090904020207090004090706
Hi Jason,
I have a testcase which shows support for composite ids and multiple join columns (see the attached
ecore and then the children collection in parent).
Or do you mean something else?
gr. Martin
> Jason
> paReference);
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Content-Type: text/xml;
name="compositeid.ecore"
Content-Disposition: inline;
filename="compositeid.ecore"
<ecore:EPackage xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="compositeid"
nsURI="http:///org/elver/samples/emf/annotations/compositeid.ecore" nsPrefix="org.eclipse.emf.teneo.samples.emf.annotations.compositeid ">
<eClassifiers xsi:type="ecore:EClass" name="Parent" eSuperTypes="#//Person">
<eStructuralFeatures xsi:type="ecore:EReference" name="children" upperBound="-1"
eType="#//Child">
<eAnnotations source="teneo.jpa">
<details key="appinfo" value=" @JoinColumns({
	@JoinColumn(name="m yParentFirstName", referencedColumnName="firstName"),
 ;	@JoinColumn(name="myParentLastName&qu ot;, referencedColumnName="lastName"),
</eAnnotations>
</eStructuralFeatures>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Child" eSuperTypes="#//Person"/>
<eClassifiers xsi:type="ecore:EClass" name="Person">
<details key="appinfo" value=" @IdClass(org.eclipse.emf.teneo.samples.emf.annotations.compo siteid.PersonID) "/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="firstName" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString">
<details key="appinfo" value="@Id"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="lastName" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString">
</eAnnotations>
</eClassifiers>
</ecore:EPackage>
--------------090904020207090004090706--
Re: [Teneo] Multi-column join? [message #107621 is a reply to message #107608] |
Fri, 18 January 2008 01:30  |
Hi Jason,
Check in has been done. You should do a cvs update for most projects as I also cleaned up an
internal api which resulted in a number of smaller changes in various locations.
I have added a description of the solution in the bugzilla:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=215635
This description will be added to the docs also.
gr. Martin
Martin Taal wrote:
> Okay thanks, I will check in the solution early tomorrow morning
> (netherlands timezone).
> gr. Martin
>> Just heads up that I added those XSDs to the bug,
>> Jason
The Netherlands
Re: [Teneo] Multi-column join? [message #613986 is a reply to message #106805] |
Hi Jason,
gr. Martin
> Jason
> paReference);
The Netherlands
eType="#//Child">
</eAnnotations>
</eClassifiers>
</eAnnotations>
</eAnnotations>
</eAnnotations>
</eClassifiers>
</ecore:EPackage>
Re: [Teneo] Multi-column join? [message #614042 is a reply to message #107581] |
Thu, 17 January 2008 18:28  |
Okay thanks, I will check in the solution early tomorrow morning (netherlands timezone).
gr. Martin
> Jason
The Netherlands
Re: [Teneo] Multi-column join? [message #614043 is a reply to message #107608] |
Hi Jason,
gr. Martin
> gr. Martin
>> Jason
The Netherlands
FUDForum. Page generated in 0.05181 seconds
