Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] Multi-column join?
[Teneo] Multi-column join? [message #106805] Mon, 14 January 2008 18:47 Go to next message
I haven't updated my version of Teneo in a while. My client has decided
that they really need to support of horribly written old tables and now
they're coming up to a multi-column join problem.
We looked into the code, it looks like the multiple column join is
specifically not supported. Do you know if it would be very hard to add
support for it? Any suggestions about what would need to be done to
support it. (I.E. is it something I could do myself relatively quickly?)
Thanks for any advice,
Jason
public class ManyToOneMapper
extends AbstractAssociationMapper
implements ExtensionPoint {
public void process(PAnnotatedEReference paReference) {
log.debug("Process many-to-one " + paReference);
final List<JoinColumn> jcs = getJoinColumns(paReference);
if (jcs.size() > 1) { // TODO support multiple join columns
log.error("Unsupported multiple join columns in " + paReference);
throw new MappingException("Unsupported multiple join columns",
paReference);
Re: [Teneo] Multi-column join? [message #106835 is a reply to message #106805] Tue, 15 January 2008 01:08 Go to previous messageGo to next message
--------------090904020207090004090706
Hi Jason,
I have a testcase which shows support for composite ids and multiple join columns (see the attached
ecore and then the children collection in parent).
Or do you mean something else?
gr. Martin
> Jason
> paReference);
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Content-Type: text/xml;
name="compositeid.ecore"
Content-Disposition: inline;
filename="compositeid.ecore"
<ecore:EPackage xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="compositeid"
nsURI="http:///org/elver/samples/emf/annotations/compositeid.ecore" nsPrefix="org.eclipse.emf.teneo.samples.emf.annotations.compositeid ">
<eClassifiers xsi:type="ecore:EClass" name="Parent" eSuperTypes="#//Person">
<eStructuralFeatures xsi:type="ecore:EReference" name="children" upperBound="-1"
eType="#//Child">
<eAnnotations source="teneo.jpa">
<details key="appinfo" value=" @JoinColumns({&#xA;&#x9;@JoinColumn(name=&quot;m yParentFirstName&quot;, referencedColumnName=&quot;firstName&quot;),&#xA ;&#x9;@JoinColumn(name=&quot;myParentLastName&qu ot;, referencedColumnName=&quot;lastName&quot;),&#xA; }) "/>
</eAnnotations>
</eStructuralFeatures>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Child" eSuperTypes="#//Person"/>
<eClassifiers xsi:type="ecore:EClass" name="Person">
<details key="appinfo" value=" @IdClass(org.eclipse.emf.teneo.samples.emf.annotations.compo siteid.PersonID) "/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="firstName" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString">
<details key="appinfo" value="@Id"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="lastName" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString">
</eAnnotations>
</eClassifiers>
</ecore:EPackage>
--------------090904020207090004090706--
Re: [Teneo] Multi-column join? [message #107581 is a reply to message #106835] Thu, 17 January 2008 14:34 Go to previous messageGo to next message
Just heads up that I added those XSDs to the bug,
Jason
Re: [Teneo] Multi-column join? [message #107608 is a reply to message #107581] Thu, 17 January 2008 18:28 Go to previous messageGo to next message
Okay thanks, I will check in the solution early tomorrow morning (netherlands timezone).
gr. Martin
> Jason
The Netherlands
Re: [Teneo] Multi-column join? [message #107621 is a reply to message #107608] Fri, 18 January 2008 01:30 Go to previous message
Hi Jason,
Check in has been done. You should do a cvs update for most projects as I also cleaned up an
internal api which resulted in a number of smaller changes in various locations.
I have added a description of the solution in the bugzilla:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=215635
This description will be added to the docs also.
gr. Martin
> gr. Martin
>> Jason
The Netherlands
Re: [Teneo] Multi-column join? [message #613986 is a reply to message #106805] Tue, 15 January 2008 01:08 Go to previous message
Hi Jason,
gr. Martin
> Jason
> paReference);
The Netherlands
eType="#//Child">
</eAnnotations>
</eClassifiers>
</eAnnotations>
</eAnnotations>
</eAnnotations>
</eClassifiers>
</ecore:EPackage>
Re: [Teneo] Multi-column join? [message #614040 is a reply to message #106835] Thu, 17 January 2008 14:34 Go to previous message
Jason
Re: [Teneo] Multi-column join? [message #614042 is a reply to message #107581] Thu, 17 January 2008 18:28 Go to previous message
gr. Martin
> Jason
The Netherlands
Re: [Teneo] Multi-column join? [message #614043 is a reply to message #107608] Fri, 18 January 2008 01:30 Go to previous message
Hi Jason,
gr. Martin
> gr. Martin
>> Jason
The Netherlands
Previous Topic:[CDO][0.8.0] CDORevision List - should have a better implementation for UNINITIALIZED data.
Next Topic:Bug in TENEO 0.8.0.v2007.12.28.0940
Current Time: Fri Jul 25 22:23:49 EDT 2025
Powered by FUDForum. Page generated in 0.06740 seconds
