Home » Eclipse Projects » GEF » Pop up menu with IFigure
Pop up menu with IFigure [message #60931] Fri, 31 January 2003 10:27 Go to next message
Originally posted by: OscarMartin.es.ibm.com
Hello
I need to create a popup menu for a Figure object inside an IEditorPart.
In the createPartControl of the editor
I am following the example about pop-up menusin the documentation but it
does not seem to work.
Re: Pop up menu with IFigure [message #60955 is a reply to message #60931] Fri, 31 January 2003 10:30 Go to previous messageGo to next message
Sorry for the previous mesage. This is the right one :)
Hello
I need help associating a pop-up menu with a IFigure object.
I have been following the example in the documentation about how to create a
pop-up menu. The problem is that I know how to register the menu with a
composite, using the "setMenu" method of Control, but I don
Re: Pop up menu with IFigure [message #60978 is a reply to message #60955] Fri, 31 January 2003 10:35 Go to previous messageGo to next message
Figures are not designed to host popup menus.
In GEF, Figures are not meant to be the "interesting" objects. EditParts
are.
The recommended way to do this is to have a single popup menu for the
Viewers. The popup is built based on the currently selected EditParts. If
you right-click on a Figure, the EditPart will get selected first, followed
by the Menu's being shown. See ContextMenuProvider.
"Oscar Martin" <OscarMartin@es.ibm.com> wrote in message
news:b1e3kg$noh$1@rogue.oti.com...
> Hello
a
Re: Pop up menu with IFigure [message #61284 is a reply to message #60978] Mon, 03 February 2003 04:09 Go to previous messageGo to next message
Thank you for your help
My problem is more complex: the figure i want the context menu to be for is
inside another figure :
I have a "main" Figure which represents a flow chart. Every state in that
flow chart is another Figure and I want to use popup menu with those
states...
Cheers
"Randy Hudson" <none@us.ibm.com> wrote in message
news:b1e423$o39$1@rogue.oti.com...
> are.
If
followed
> > Hello
create
> a
Re: Pop up menu with IFigure [message #61386 is a reply to message #61284] Mon, 03 February 2003 08:31 Go to previous messageGo to next message
There is one popup menu for the EditPartViewer, and when it is shown, you
build its entries based on the selection. The Logic example shows slightly
different popup menu based on what is selected.
news:b1laa8$c1i$1@rogue.oti.com...
> Hi
is
> states...
> Cheers
EditParts
> > are.
> If
> followed
> > > Hello
> create
> > a
a
Re: Pop up menu with IFigure [message #61714 is a reply to message #61284] Tue, 04 February 2003 02:35 Go to previous message
Hi Oscar,
I had a similar problem, I solved it in that way that the subfigures are no
more subfigures in gef but are in the same gef hierachie like the parent,
than you can select the subfigure the same way like the parent. I also had
problems with the clipping of the parent which was also solved by this
aproach. the only thing is when moving the parent you have to move the
childs manually, in the other case it's done together with the parent.
Dieter
"Oscar Martin" <OscarMartin@es.ibm.com> schrieb im Newsbeitrag
> Hi
is
> states...
> Cheers
EditParts
> > are.
> If
> followed
> > > Hello
> create
> > a
a
Previous Topic:where are the figures?
Next Topic:Connections and their parent
Current Time: Sun Oct 19 09:34:53 EDT 2025
Powered by FUDForum. Page generated in 0.26513 seconds
