Home » Eclipse Projects » Dali » NPE when generating entities from Oracle 11g DB
NPE when generating entities from Oracle 11g DB [message #435243] Mon, 19 January 2009 18:12 Go to next message
I've been seeing the following exception thrown when generating entities
from an Oracle 11g DB. This is using Dali 2.0.
Any hints of what might be causing this? I assume it has something to do
with the relationships in the DB. I was trying to debug this a bit myself,
but so far no luck. I'm wondering if something is going wrong because it
seems to be "configuring" a manyToMany relationship, when there isn't one
in the DB.
!MESSAGE An internal error occurred during: "Generating Entities".
!STACK 0
at
org.eclipse.jpt.db.internal.DTPForeignKeyWrapper.getReferenc edTable(Unknown
Source)
at
Source)
at org.eclipse.jpt.gen.internal.GenTable.addReferencedTablesTo( Unknown
Source)
at org.eclipse.jpt.gen.internal.GenScope.buildReferencedTables( Unknown
Source)
at
org.eclipse.jpt.gen.internal.GenScope.configureManyToManyRel ations(Unknown
Source)
at org.eclipse.jpt.gen.internal.GenScope.initialize(Unknown Source)
at org.eclipse.jpt.gen.internal.GenScope.<init>(Unknown Source)
at org.eclipse.jpt.gen.internal.PackageGenerator.<init>(Unknown Source)
at org.eclipse.jpt.gen.internal.PackageGenerator.generateEntiti es(Unknown
Source)
at
org.eclipse.jpt.ui.internal.platform.base.EntitiesGenerator$ GenerateEntitiesRunnable.runInWorkspace(Unknown
Source)
at org.eclipse.core.internal.resources.InternalWorkspaceJob.run (Unknown
Source)
at org.eclipse.core.internal.jobs.Worker.run(Unknown Source)
The DDL used to generate the tables looked something like this...
CREATE TABLE NOTES
(NOTE_ID NUMBER(15,0) NOT NULL
,ORG_ID NUMBER(15) NOT NULL
,CREATE_DT DATE
,CREATED_BY VARCHAR2(30)
,NOTE VARCHAR2(4000) NOT NULL
CREATE TABLE ORGANIZATIONS
(ORG_ID NUMBER(15) NOT NULL
,NAME VARCHAR2(70) NOT NULL
,STREET VARCHAR2(100)
,CITY VARCHAR2(20)
,PHONE_WK VARCHAR2(10)
,PHONE_WK_EXT VARCHAR2(10)
,EMAIL VARCHAR2(35)
,CREATE_DT DATE
,COMMENTS VARCHAR2(70)
,PRIVATE_YN VARCHAR2(1) DEFAULT 'N' NOT NULL
,MEMBER_OF_ORG_ID NUMBER(15)
CREATE INDEX NOTES_ORG_FK_I ON NOTES
(ORG_ID)
-- TABLESPACE I_IX
CREATE INDEX ORG_ORG_FK_I ON ORGANIZATIONS
(MEMBER_OF_ORG_ID)
-- TABLESPACE I_IX
ALTER TABLE NOTES
ADD (CONSTRAINT NOTE_PK PRIMARY KEY
(NOTE_ID)
USING INDEX)
-- TABLESPACE I_IX)
ALTER TABLE ORGANIZATIONS
ADD (CONSTRAINT ORG_PK PRIMARY KEY
(ORG_ID)
USING INDEX)
-- TABLESPACE I_IX)
ALTER TABLE NOTES ADD (CONSTRAINT
NOTES_ORG_FK FOREIGN KEY
(ORG_ID) REFERENCES ORGANIZATIONS
(ORG_ID) ON DELETE CASCADE)
ALTER TABLE ORGANIZATIONS ADD (CONSTRAINT
ORG_ORG_FK FOREIGN KEY
(MEMBER_OF_ORG_ID) REFERENCES ORGANIZATIONS
(ORG_ID))
-- (ORG_ID) ON DELETE RESTRICT)
CREATE SEQUENCE ORG_SEQ
NOMAXVALUE
NOMINVALUE
NOCYCLE
CREATE SEQUENCE NOTES_SEQ
NOMAXVALUE
NOMINVALUE
NOCYCLE
CREATE PUBLIC SYNONYM NOTES FOR NOTES
CREATE PUBLIC SYNONYM ORGANIZATIONS FOR ORGANIZATIONS
CREATE PUBLIC SYNONYM NOTES_SEQ FOR NOTES_SEQ
CREATE PUBLIC SYNONYM ORG_SEQ FOR ORG_SEQ
Re: NPE when generating entities from Oracle 11g DB [message #435245 is a reply to message #435243] Tue, 20 January 2009 09:20 Go to previous messageGo to next message
This looks a lot like http://bugs.eclipse.org/231286 which was determined
to be a driver issue in MaxDB, unfortunately it looks like you are now
seeing this on oracle. Does this help you figure out the problem, if not,
could you open a bug?
Karen
Re: NPE when generating entities from Oracle 11g DB [message #435250 is a reply to message #435245] Wed, 21 January 2009 07:40 Go to previous message
I ended up opening https://bugs.eclipse.org/bugs/show_bug.cgi?id=261807
after not being able to determine if this was a driver issue or not.
Chris
Re: NPE when generating entities from Oracle 11g DB [message #613786 is a reply to message #435243] Tue, 20 January 2009 09:20 Go to previous message
Karen
Re: NPE when generating entities from Oracle 11g DB [message #613789 is a reply to message #435245] Wed, 21 January 2009 07:40 Go to previous message
Chris
Previous Topic:Dali reports that some fields cannot be resolved
Next Topic:Dali 2.2 and JPA 2.0 tolerance
Current Time: Fri Jul 25 22:18:52 EDT 2025
Powered by FUDForum. Page generated in 0.07088 seconds
