Home » Archived » GMT (Generative Modeling Technologies) » Re: [ATL][AM3] editing Models
Re: [ATL][AM3] editing Models [message #381237] Wed, 05 March 2008 07:28 Go to next message
Hi Adil,
You may take a look to the following FAQ entry:
http://wiki.eclipse.org/ATL_FAQ#How_to_create_a_terminal_mod el.3F
HTH.
Freddy.
Quentin Glineur a écrit :
> Hi Adil,
> This problem is not related to ATL but to KM3, that's why I have added
> it to the GMT newsgroup.
> Regards
> adil a écrit :
>> Hello,
>> I�m new in using ATL language. I want to use this language in order to
>> defining transformation rules targeting a web service platform. To
>> this end I created an input metamodel and I Defined some
>> transformation rules in order to generate A WSDL file. I Created
>> the Metamodels using KM3, but the problem is how to edit the models
>> that conform to the input metamodel . In some papers, they use
>> Poseidon for editing the models and they generates A XMI files. But
>> this approach ( according to some friends) introduces a compatibility
>> problem. in others work they use Ecore to edit models.
>> what is the best way to creat the input models that conform to the
>> input metamodels.
>> Best regards.
>> Adil
Re: [ATL][AM3] editing Models [message #381240 is a reply to message #381237] Tue, 11 March 2008 16:14 Go to previous messageGo to next message
I tested the creation of models according to their metamodels using the
EMF Generated Editor. To this end, I used the Families.ecore metamodel (
the example Provided With ATL_UML2_Bundle_2.0.0RC2_Windows ) and I want
Create a model that conforms to "Families.ecore". So, With a right click
on the Families.ecore metamodel, I Point (New > Other... Eclipse Modeling
Framework> but I can't generate the genmodel file. In the Step "Ecore
Import", When I click the load button, I have the message " problems were
detected while validating and converting the ecore models".
how I can resolve this problem?
best regards,
Adil.
Re: [ATL][AM3] editing Models [message #381241 is a reply to message #381240] Wed, 12 March 2008 05:40 Go to previous messageGo to next message
--------------030309060608040703010303
Hi Adil,
"Families" metamodel misses some required fields (if you click on
"Details" button, you will see the list of problems).
"Ns Prefix" and "Ns URI" properties of root packages (Families &
PrimitiveTypes) should be answered.
"Instance Type Name" property (and maybe Instance Class Name) of String
DataType should also be answered.
Freddy.
adil a
Re: [ATL][AM3] editing Models [message #381242 is a reply to message #381241] Wed, 12 March 2008 08:21 Go to previous messageGo to next message
I just wanted to precise that the Families metamodel lacks some fields
required for code generation, but does not lack any field for usage as a
metamodel.
Frédéric Jouault
Freddy Allilaire a écrit :
> Hi Adil,
> Regards,
> Freddy.
> adil a écrit :
>> Hello,
>> the EMF Generated Editor. To this end, I used the Families.ecore
>> metamodel ( the example Provided With ATL_UML2_Bundle_2.0.0RC2_Windows
>> ) and I want Create a model that conforms to "Families.ecore". So,
>> With a right click on the Families.ecore metamodel, I Point (New >
>> Other... Eclipse Modeling Framework> but I can't generate the genmodel
>> file. In the Step "Ecore Import", When I click the load button, I have
>> the message " problems were detected while validating and converting
>> the ecore models". how I can resolve this problem? best regards,
>> Adil.
Re: [ATL][AM3] editing Models [message #381243 is a reply to message #381242] Wed, 12 March 2008 08:44 Go to previous messageGo to next message
Frédéric,
It seems like generally an awfully good idea to have Ecore instances
that are well formed with respect to the constraints defined for Ecore.
Computing default values for properties that must be set would seem to
be a good approach. I.e., set the nsPrefix to be the same as the name
of the package and set instanceClassName to be java.lang.Object for data
types. The nsURI seems like a pretty important thing even from just a
metamodel point of view as a way to uniquely identify the model. But
then again, I don't really know the context of this very well, so maybe
what I'm saying isn't all that sensible; maybe it is best that folks
need to go in an manually add such information to ensure it's sensible...
Frédéric Jouault wrote:
> Hello,
> a metamodel.
> Regards,
> Frédéric Jouault
>> Hi Adil,
>> String DataType should also be answered.
>> Regards,
>> Freddy.
>> adil a écrit :
>>> Hello,
>>> ATL_UML2_Bundle_2.0.0RC2_Windows ) and I want Create a model that
>>> conforms to "Families.ecore". So, With a right click on the
>>> "Ecore Import", When I click the load button, I have the message "
>>> problems were detected while validating and converting the ecore
>>> Adil.
Re: [ATL][AM3] editing Models [message #381244 is a reply to message #381243] Wed, 12 March 2008 15:19 Go to previous messageGo to next message
Ed,
> types.
I agree that we should always provide .ecore files with nsURI and
nsPrefix set.
However, I cannot agree that an nsURI (i.e., an *XML* namespace URI) is
generally an important part of a metamodel (i.e., an *MDE* entity). On
the contrary, I do believe that a metamodel should not refer to any
specific technology/platform.
The same remark holds for the usage of Java classes/objects in a metamodel.
This is why we have historically only been setting default values for
nsURI, nsPrefix, and instanceClassName at .ecore file load time. At this
point, we have already committed to Java and XMI. Therefore, I consider
it normal to "bind" the metamodel to the actual platform.
The problem with this approach is that the binding does not persist. My
preference definitely goes to a separate specification of the binding
(i.e., in another file, not in the metamodel), which allows different
bindings on different platforms or for different usages. However, this
is not how EMF currently works. This is why I agree that we should
persist the platform binding in the .ecore files.
Frédéric Jouault
Re: [ATL][AM3] editing Models [message #381746 is a reply to message #381244] Wed, 12 March 2008 16:03 Go to previous message
Frédéric,
Comments below.
> Ed,
> data
> > types.
> nsPrefix set.
> is generally an important part of a metamodel (i.e., an *MDE* entity).
> On the contrary, I do believe that a metamodel should not refer to any
I'm not sure why you consider it technology or platform specific. It's
certainly a MOF concept and there it's platform neutral. And in a sense
even Java package names are namespaces in this same way. In all cases,
the idea is to provide something to ensure that entity can be uniquely
identified by something human readable and something other than its
physical location.
> metamodel.
That's certainly true if the model is meant to be used for more than Java.
> this point, we have already committed to Java and XMI. Therefore, I
> consider it normal to "bind" the metamodel to the actual platform.
UML generally supports things like stereo types so you can augment the
model with things that aren't intrinsic to the model. It is after all
important that a type representing int verses one that representing
String be bound correctly.
Indeed.
> My preference definitely goes to a separate specification of the
> binding (i.e., in another file, not in the metamodel), which allows
> different bindings on different platforms or for different usages
Yes, it's often a question of whether annotations are stored on the
object or stored separate and associated with an object. In a certain
sense, those two are equivalent.
> . However, this is not how EMF currently works. This is why I agree
> that we should persist the platform binding in the .ecore files.
Indeed, Ecore is very much focused on working primarily with Java. And
we've taken pragmatic liberties and in a pure sense might not sit so
well. Most folks are pragmatists rather than purists though... In any
case, EMF as a whole could be used for anything... It will be
interesting to see how the C# work unfolds.
> Best regards,
> Frédéric Jouault
Re: [ATL][AM3] editing Models [message #613606 is a reply to message #381237] Tue, 11 March 2008 16:14 Go to previous message
best regards,
Adil.
Re: [ATL][AM3] editing Models [message #613609 is a reply to message #381240] Wed, 12 March 2008 05:40 Go to previous message
Hi Adil,
Freddy.
adil a
Re: [ATL][AM3] editing Models [message #613611 is a reply to message #381241] Wed, 12 March 2008 08:21 Go to previous message
metamodel.
Frédéric Jouault
> Hi Adil,
> Regards,
> Freddy.
> adil a écrit :
>> Hello,
>> Adil.
Re: [ATL][AM3] editing Models [message #613617 is a reply to message #381242] Wed, 12 March 2008 08:44 Go to previous message
Frédéric,
> Hello,
> a metamodel.
> Regards,
> Frédéric Jouault
>> Hi Adil,
>> Regards,
>> Freddy.
>> adil a écrit :
>>> Hello,
>>> Adil.
Re: [ATL][AM3] editing Models [message #613618 is a reply to message #381243] Wed, 12 March 2008 15:19 Go to previous message
Ed,
> types.
nsPrefix set.
Frédéric Jouault
Re: [ATL][AM3] editing Models [message #613622 is a reply to message #381244] Wed, 12 March 2008 16:03 Go to previous message
Frédéric,
Comments below.
> Ed,
> data
> > types.
> nsPrefix set.
physical location.
> metamodel.
Indeed.
> Best regards,
> Frédéric Jouault
Previous Topic:Scalability of eCore / oAW
Next Topic:[TCS] Is "autoCreate=ifmissing" usable?
Current Time: Sat Jul 26 12:46:26 EDT 2025
Powered by FUDForum. Page generated in 0.10431 seconds
