Home » Archived » Eclipse Communications Framework (ECF) » ECF generic server down for while
ECF generic server down for while [message #609293] Tue, 28 November 2006 12:12 Go to next message
Hi Folks,
The ECF generic server available at ecftcp://ecf.eclipse.org:3282/server
is going to be down for a while (today, Tues Nov 28 and perhaps tomorrow
Wed 29), for upgrade to version 0.9.3. Once this upgrade is complete it
will be necessary for people to use 0.9.3 or better to use this server.
Please let me (slewis@composent.com) know if this creates a problem for
anyone.
Scott
How to set up an ECF generic server [message #612057 is a reply to message #609293] Thu, 01 February 2007 14:50 Go to previous messageGo to next message
All the documentation I have found so far on running your own ECF server
refers to a startup shell script that is no longer in the build.
ecf.eclipse.org seems to be hosted as a tomcat servlet (is this
correct). Are there any quickstart guides on how to set this up?
Jonathon
Scott Lewis wrote:
> Hi Folks,
> anyone.
> Scott
Re: How to set up an ECF generic server [message #612058 is a reply to message #612057] Thu, 01 February 2007 11:53 Go to previous messageGo to next message
Hi Jonathon,
The server "feature" has the shell scripts.
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.ecf/fea tures/org.eclipse.ecf.server-feature/?root=Technology_Projec t
You can also start it within Eclipse yourself if you have the code checked
out.
http://wiki.eclipse.org/index.php/ECF_Servers#Starting_up_th e_ECF_Server_from_within_Eclipse
If you take the second route, you can copy the command line argument
that's used by checking the process's properties in the "Debug" view and
then just paste it in the command line and start it that way.
I believe that's how it is but I'm not sure if we have any documentation
for that, someone else might know though.
Good luck.
Rem
Re: How to set up an ECF generic server [message #613277 is a reply to message #612057] Fri, 02 February 2007 17:31 Go to previous message
Hi Jonathan,
I've added a wiki page section for this here:
http://wiki.eclipse.org/index.php/ECF_Servers#Setting_up_an_ ECF_Server_with_the_Equinox_Servlet_Incubator
Hope this helps. We'll be adding to the server stuff for 0.9.7 so the
configuration of the ECF server is easier.
Scott
> Jonathon
> Scott Lewis wrote:
>> Hi Folks,
>> anyone.
>> Thanks,
>> Scott
Previous Topic:supported protocols
Next Topic:EclipseCon 2007
Current Time: Thu Jul 24 22:27:18 EDT 2025
Powered by FUDForum. Page generated in 0.04194 seconds
