Re: extension point org.eclipse.jst.pagedesigner.tagCreationFactories doesn't work [message #475020 is a reply to message #475019] |
Mon, 13 August 2007 15:41  |
Originally posted by: liming.wu.icesoft.com
Cameron Bateman wrote:
> Are you aiming to change the way the <link> tag works or write a custom
> tag converter for your own component?
Yes, you are right.
> How would loading the file
> relative to a plugin map to runtime behaviour? What if you copied the
> file from the plugin into the web content folder and then point to it?
> --Cam
Good question. Actually in runtime, default CSS and other resources are
embedded in a jar file. There is no problem in runtime. But in
designtime, WTP doesn't scan for such resources embedded in jar file. So
that the best way for us is to have those resources in plugin map and
customize loading process. We are trying to avoid making duplication of
those resources in web root folder.
Thank you.
Re: extension point org.eclipse.jst.pagedesigner.tagCreationFactories doesn't work [message #613099 is a reply to message #474860] |
Thu, 19 July 2007 11:54  |
Thanks Cameron.
What I want to do is to customize the behavior of trait
"requires-html-form" so that instead of h:form but my custom form
component gets inserted. Is there an alternative way to do that?
>> I have tried to use extension point
>> org.eclipse.jst.pagedesigner.tagCreationFactories but defined custom
>> TagCreator via org.eclipse.jst.pagedesigner.tagCreationFactories is
>> not respected.
> Can you describe what you are trying to do? Perhaps we can direct you
> to an alternative solution.
> --Cam
Re: extension point org.eclipse.jst.pagedesigner.tagCreationFactories doesn't work [message #613244 is a reply to message #474861] |
Mon, 23 July 2007 19:37  |
Hi Liming,
There is no easy way to do this at present. I can you provide you with a
workaround that should work if you are willing to learn about how GEF edit
policies work.
If a more generalized framework approach is important to you, please log a
bug describing the scenario(s) you need supported.
--Cam
Liming wrote:
> Thanks Cameron.
> Thanks
Re: extension point org.eclipse.jst.pagedesigner.tagCreationFactories doesn't work [message #613258 is a reply to message #474945] |
Tue, 31 July 2007 17:06  |
Thank you very much.
Could you please provide me with the workaround through editPolicy?
Very appreciated.
Liming
> Hi Liming,
> a workaround that should work if you are willing to learn about how GEF
> edit policies work.
> a bug describing the scenario(s) you need supported.
> --Cam
> Liming wrote:
>> Thanks Cameron.
>> Thanks
Re: extension point org.eclipse.jst.pagedesigner.tagCreationFactories doesn't work [message #613863 is a reply to message #474953] |
Mon, 06 August 2007 14:40  |
You will need to use the ElementEdit extension point to override the
default edit policy on the ElementEditPart. To do this you can use the
org.eclipse.jst.pagedesigner.pageDesignerExtension extension point with
"elementEditFactory" sequence to define a factory for creating
ElementEdit's associated with the tag lib URI you are interested in.
There are examples of this in the org.eclipse.jst.pagedesigner.jsf.ui
plugin. Once you have an ElementEdit factory you create new ElementEdit
objects for the tag you are interested in. See JSFHTMLElementEditFactory
for an example of how this is done.
In the ElementEdit object for the tag(s) you are interested in, you will
need to implement the createEditPolicies method and install your own
ItemCreationRequest.REQ_ITEM_CREATION edit policy. To look at the default
one, start at NodeEditPart.createEditPolicies(). Within your own edit
policy for element creation (you can probably sub-class the existing one
called ItemCreationEditPolicy or the common DropEditPolicy) you need to
tailor the creation command returned by the getCommand method.
This is fairly involved I know, but as I said it is a workaround. Let me
know if you have any further questions.
--Cam
Re: extension point org.eclipse.jst.pagedesigner.tagCreationFactories doesn't work [message #613871 is a reply to message #475005] |
Thu, 09 August 2007 17:54  |
Cameron,
Thank you very much. Unfortunately I still have problem with
getCommand(request).
I have install EditorPolicy ItemCreationRequest.REQ_ITEM_CREATION with
my ItemCreationEditPolicy object. But the request objects passed in with
getCommand (request) are instances of GroupRequest not
ItemCreationRequest which we expect because the getCommand call with
ItemCreationRequest has been issued before createEditPolicy. Without
ItemCreationRequest and IDomPosition, I couldn't find the way to insert
parent components. Are there other way around?
Thanks again!
Liming
> ElementEdit objects for the tag you are interested in. See
> JSFHTMLElementEditFactory for an example of how this is done.
> default one, start at NodeEditPart.createEditPolicies(). Within your own
> edit policy for element creation (you can probably sub-class the
> existing one called ItemCreationEditPolicy or the common DropEditPolicy)
> you need to tailor the creation command returned by the getCommand method.
> me know if you have any further questions.
> --Cam
Re: extension point org.eclipse.jst.pagedesigner.tagCreationFactories doesn't work [message #613872 is a reply to message #475013] |
Thu, 09 August 2007 18:41  |
You're right! Sorry about that, I forgot that the ITEM_CREATION policy is
created against the target edit part not the one being created. You
*could* use this strategy if you are able to install your edit policy on
all edit parts where the element you are creating may be dropped. Try
dragging something from the palette into the element you have set the edit
policy for and you should the correct request.
I'm afraid I can't think of anything else right now, but will continue to
try to find a workaround.
--Cam
Re: extension point org.eclipse.jst.pagedesigner.tagCreationFactories doesn't work [message #613875 is a reply to message #475015] |
Fri, 10 August 2007 12:56  |
Thank you much for your help!
I have 2 questions regarding stylesheet to bother you.
1. I have a link stylesheet component and it needs to be dropped into
<head> section but it looks like the section is not droppable. Am I
right? Is there a way around?
2. For <link> tag, the value of href attribute (actually relative path
to a css file) is resolved against webroot which is observed via view
source in preview mode event though in source text it is still a
relative path. What I want is to resolve the relative path based on
plugin's path. Is it possible?
Thank you very much
Liming
> I'm going to try and escalate a work around for this issue. I don't
> know if we'll be able to get it in for 2.0.1 and it won't be a full
> solution, but I'm hoping to get something that lets you workaround this
> issue more satisfactorily.
> If you want to track the issue, you can CC yourself on:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=199295
> Regards,
> Cameron
Re: extension point org.eclipse.jst.pagedesigner.tagCreationFactories doesn't work [message #613877 is a reply to message #475017] |
Mon, 13 August 2007 14:40  |
This is a bug. I have opened an issue.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=199788
tag converter for your own component? How would loading the file relative
to a plugin map to runtime behaviour? What if you copied the file from
--Cam
Re: extension point org.eclipse.jst.pagedesigner.tagCreationFactories doesn't work [message #613878 is a reply to message #475019] |
Yes, you are right.
> --Cam
Thank you.
FUDForum. Page generated in 0.51511 seconds
