Home » Archived » GMT (Generative Modeling Technologies) » [TCS] Last version of TCS injector from CVS
[TCS] Last version of TCS injector from CVS [message #381226] |
Wed, 13 February 2008 10:02  |
I am trying to reinstall ATL, TCS, etc from the available CVS sources.
I am experiencing some problems when trying to rebuild a (previously
working) TCS language project using AMMACore and AMMAScripts.
The build process fails when injecting the generated megamodel file (.mgm)
Here is the error message :
java.lang.NoSuchMethodError:
org.eclipse.gmt.tcs.injector.TCSInjector.createEnumLiteral(L java/lang/String;)Ljava/lang/Object;
at
org.eclipse.gmt.tcs.injector.AM3_ANTLR3Parser.locationType(A M3_ANTLR3Parser.java:635)
etc.
After exploring the differences between my previous setup and the new
plugin sources from the CVS repository, I have seen that changes have
occurred in TCSInjector.java : method createEnumLiteral() now returns an
Object instead of an ASMEnumLiteral.
I guess that my problem comes from the fact that the plugin
org.eclipse.m2m.atl.engine provides the previous version of class
TCSInjector (in lib/org.eclipse.gmt.tcs.injector_1.0.0.jar) while the AM3
parser uses the new version.
So, if my guess is correct, this message is a reminder that new JAR files
should be commited in org.eclipse.m2m.atl.engine/lib.
Thanks, and best regards,
Guillaume
Re: [TCS] Last version of TCS injector from CVS [message #381227 is a reply to message #381226] |
Thu, 14 February 2008 02:24   |
Here are the reasons for the problem you encountered:
We are currently improving TCS. For instance, we are progressively
removing the dependencies from TCSInjector to the older VM (e.g.,
ASMEnumLiteral). When this is done, you will still be able to use TCS
with both VMs, but you should not require the older one if you only want
to use the new one.
These changes require a rebuild of all parsers, as you noticed.
However, we are also preparing ATL to be released with Ganymede (i.e.,
Eclipse 3.4M5) for next week. For this reason, we decided to not
introduce potential errors in ATL at the current time. The changes were
committed in a new plugin, and in a separate branch for impacted
existing plugins.
Here are possible solutions to the problem:
- Wait until we commit the changes to HEAD on ATL, and use an older
version of TCS in the mean time.
- Use the new version by checking out the following elements:
- get new plugin org.eclipse.m2m.atl.dsls from HEAD
- get plugin org.eclipse.m2m.atl.engine from branch
DSL_binaries_separation (I would recommend deleting the project then
checking out the new branch, because we encountered problems with
"switch to branch").
Here are some additional remarks:
There is also an additional plugin in TCS that you should check out in
order to have all dependencies of the TCS plugins: org.eclipse.gmt.tcs.dsls.
These two new plugins (org.eclipse.{m2m.atl,gmt.tcs}.dsls) contain the
compiled version of required DSLs:
- ATL, and ACG for org.eclipse.m2m.atl.dsls
- TCS, KM3, and others for org.eclipse.gmt.tcs.dsls
This is also part of the improvements we are working on. When this
separation of DSL binaries is done, each element should appear only
once. This will make updates simpler.
Frédéric Jouault
Guillaume Savaton wrote:
> at
> etc.
> AM3 parser uses the new version.
> files should be commited in org.eclipse.m2m.atl.engine/lib.
> Guillaume
Re: [TCS] Last version of TCS injector from CVS [message #381228 is a reply to message #381227] |
Thu, 14 February 2008 08:22  |
This solution fixed my problem :
> - get plugin org.eclipse.m2m.atl.engine from branch DSL_binaries_separation
But I understand that this is just a temporary solution.
I will try the next official stable release as soon as it is available,
instead of relying on CVS builds.
Thanks for your help,
Guillaume
Re: [TCS] Last version of TCS injector from CVS [message #613163 is a reply to message #381226] |
to use the new one.
existing plugins.
Frédéric Jouault
> at
> etc.
> Guillaume
Re: [TCS] Last version of TCS injector from CVS [message #613165 is a reply to message #381227] |
Guillaume
Current Time: Sun Jul 27 09:05:54 EDT 2025
Powered by FUDForum. Page generated in 0.04058 seconds
