Home » Archived » Visual Editor (VE) » What are the Events fired when a component is resized in VE?
What are the Events fired when a component is resized in VE? [message #121485] Thu, 06 April 2006 01:28 Go to next message
Originally posted by: shobanaramaswamy.yahoo.co.in
Hi All,
Can anyone please explain me, what are all the events fired when a
component is resized in the Visual Editor?
Thanks in advance.
Shobana
Re: What are the Events fired when a component is resized in VE? [message #122046 is a reply to message #121485] Mon, 10 April 2006 15:38 Go to previous messageGo to next message
Hi Shobana,
Do you mean the events at runtime when the java.awt.Component is resized or
are you building some kind of VE extension plugin ? For the former it is
the compoentResized method on the java.awt.ComponentListener. You can add a
listener to a GUI component in the VE by using the Events>Add Event.. menu
option and selecting "component" in the list and then "componentResized".
This will generate code like:
jButton.addComponentListener(new java.awt.event.ComponentAdapter() {
public void componentResized(java.awt.event.ComponentEvent e) {
// Put your code here
If you're writing a plugin then can you give more background as to the
scenario you're trying to tackle ?
Joe Winchester
Re: What are the Events fired when a component is resized in VE? [message #122096 is a reply to message #122046] Tue, 11 April 2006 07:12 Go to previous message
Hi Joe,
Yes, I asked about the events fired at runtime, when the
java.awt.Component is resized. THANK YOU VERY MUCH. It worked.
Shobana.R
Re: What are the Events fired when a component is resized in VE? [message #612586 is a reply to message #121485] Mon, 10 April 2006 15:38 Go to previous message
Hi Shobana,
Joe Winchester
Re: What are the Events fired when a component is resized in VE? [message #612594 is a reply to message #122046] Tue, 11 April 2006 07:12 Go to previous message
Hi Joe,
Shobana.R
Previous Topic:Problem creating visual class
Next Topic:Loading Java class in the Plugin environment
Current Time: Mon Sep 08 14:35:30 EDT 2025
Powered by FUDForum. Page generated in 0.03293 seconds
