Home » Archived » Visual Editor (VE) » novice
novice [message #121232] Fri, 31 March 2006 12:53 Go to next message
Originally posted by: adoneNOSPAMborione.cantv.net
Hi all
I would like to ask if there is some tutorial on VE for me to start do
some coding.
I tried to open the examples "SimpleTextEditor" (file->new->example) but
the example only shows a skeleton class with almost no code.
A comment says "An example which shows off a functional simple text
editor. Includes a variety of events." but I can't see anything useful
So, how do I learn more?
Are there online courses?
Adone
Re: novice [message #121249 is a reply to message #121232] Fri, 31 March 2006 13:21 Go to previous messageGo to next message
Hmmm, there may be something wrong with your installation if you're not
getting the contents of the Examples. Check the error log by going to
Window->Show View->Other->PDE Runtime->Error log
Below is the code I get when I try the SimpleTextEditor example:
import javax.swing.JFrame;
import java.io.*;
import javax.swing.JFileChooser;
import javax.swing.JOptionPane;
* An example which shows off a functional simple text editor.
public class SimpleTextEditor extends JFrame {
private javax.swing.JPanel jContentPane = null;
private javax.swing.JPanel jPanel = null;
private javax.swing.JButton jButton = null;
private javax.swing.JButton jButton1 = null;
private javax.swing.JButton jButton2 = null;
private javax.swing.JScrollPane jScrollPane = null;
private javax.swing.JTextArea jTextArea = null;
private javax.swing.JFileChooser jFileChooser = null; //
@jve:visual-info decl-index=0 visual-constraint="582,36"
private boolean hasChanged = false;
private static final String title = "Simple Text Editor";
* This method initializes
public SimpleTextEditor() {
super();
initialize();
SimpleTextEditor ste = new SimpleTextEditor();
ste.show();
* This method initializes jContentPane
* @return javax.swing.JPanel
private javax.swing.JPanel getJContentPane() {
if (jContentPane == null) {
jContentPane = new javax.swing.JPanel();
jContentPane.setLayout(new java.awt.BorderLayout());
jContentPane.add(getJPanel(), java.awt.BorderLayout.SOUTH);
jContentPane.add(getJScrollPane(), java.awt.BorderLayout.CENTER);
jContentPane.setBorder(javax.swing.BorderFactory.createEmpty Border(
5, 5, 5, 5));
return jContentPane;
* This method initializes this
* @return void
private void initialize() {
this.setContentPane(getJContentPane());
this.setSize(480, 284);
this.setTitle(title);
this
..setDefaultCloseOperation(javax.swing.WindowConstants.DO_NO THING_ON_CLOSE);
this.addWindowListener(new java.awt.event.WindowAdapter() {
public void windowClosing(java.awt.event.WindowEvent e) {
doExit();
* This method initializes jPanel
private javax.swing.JPanel getJPanel() {
if (jPanel == null) {
jPanel = new javax.swing.JPanel();
jPanel.add(getJButton(), null);
jPanel.add(getJButton1(), null);
jPanel.add(getJButton2(), null);
return jPanel;
* This method initializes jButton
* @return javax.swing.JButton
private javax.swing.JButton getJButton() {
if (jButton == null) {
jButton = new javax.swing.JButton();
jButton.setText("Load File");
jButton.addActionListener(new java.awt.event.ActionListener() {
public void actionPerformed(java.awt.event.ActionEvent e) {
loadFile();
return jButton;
* This method initializes jButton1
private javax.swing.JButton getJButton1() {
if (jButton1 == null) {
jButton1 = new javax.swing.JButton();
jButton1.setText("Save File");
jButton1.addActionListener(new java.awt.event.ActionListener() {
saveFile();
return jButton1;
* This method initializes jButton2
private javax.swing.JButton getJButton2() {
if (jButton2 == null) {
jButton2 = new javax.swing.JButton();
jButton2.setText("Exit");
jButton2.addActionListener(new java.awt.event.ActionListener() {
doExit();
return jButton2;
* This method initializes jScrollPane
* @return javax.swing.JScrollPane
private javax.swing.JScrollPane getJScrollPane() {
if (jScrollPane == null) {
jScrollPane = new javax.swing.JScrollPane();
jScrollPane.setViewportView(getJTextArea());
return jScrollPane;
* This method initializes jTextArea
* @return javax.swing.JTextArea
private javax.swing.JTextArea getJTextArea() {
if (jTextArea == null) {
jTextArea = new javax.swing.JTextArea();
jTextArea.addKeyListener(new java.awt.event.KeyAdapter() {
public void keyTyped(java.awt.event.KeyEvent e) {
if (!hasChanged) {
setTitle(title + " *");
hasChanged = true;
return jTextArea;
* This method initializes jFileChooser
* @return javax.swing.JFileChooser
private javax.swing.JFileChooser getJFileChooser() {
if (jFileChooser == null) {
jFileChooser = new javax.swing.JFileChooser();
jFileChooser.setMultiSelectionEnabled(false);
return jFileChooser;
private void loadFile() {
int state = getJFileChooser().showOpenDialog(this);
if (state == JFileChooser.APPROVE_OPTION) {
File f = getJFileChooser().getSelectedFile();
try {
BufferedReader br = new BufferedReader(new FileReader(f));
getJTextArea().read(br, null);
br.close();
setTitle(title);
hasChanged = false;
} catch (FileNotFoundException e1) {
e1.printStackTrace();
} catch (IOException e1) {
private void saveFile() {
int state = getJFileChooser().showSaveDialog(this);
try {
BufferedWriter bw = new BufferedWriter(new FileWriter(f));
getJTextArea().write(bw);
bw.close();
setTitle(title);
hasChanged = false;
private void doExit() {
if (hasChanged) {
int state = JOptionPane.showConfirmDialog(this,
"File has been changed. Save before exit?");
if (state == JOptionPane.YES_OPTION) {
saveFile();
} else if (state == JOptionPane.CANCEL_OPTION) {
return;
System.exit(0);
} // @jve:visual-info decl-index=0 visual-constraint="20,27"
Re: novice [message #121256 is a reply to message #121249] Fri, 31 March 2006 13:31 Go to previous messageGo to next message
There is the following messages but I do not think are related to the
examples
eclipse.buildId=I20060223-1656
java.version=1.5.0_06
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=es_VE
Command-line arguments: -os win32 -ws win32 -arch x86
Error
2006-03-29 13:08:52.593
Unable to access site:
"http://http://update.eclipse.org/tools/ve/updates/1.0/" [http]
java.net.UnknownHostException: http
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknow n Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Un known
Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection$6.run(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getChainedExcept ion(Unknown
Source)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(U nknown
Source)
at
org.eclipse.update.internal.core.connection.ConnectionThread Manager$StreamRunnable.run(ConnectionThreadManager.java:97)
Caused by: java.net.UnknownHostException: http
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at sun.net.NetworkClient.doConnect(Unknown Source)
at sun.net.www.http.HttpClient.openServer(Unknown Source)
at sun.net.www.http.HttpClient.<init>(Unknown Source)
at sun.net.www.http.HttpClient.New(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient (Unknown
Source)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect(Unk nown Source)
at sun.net.www.protocol.http.HttpURLConnection.connect(Unknown Source)
Source)
at java.net.HttpURLConnection.getResponseCode(Unknown Source)
at
org.eclipse.update.internal.core.connection.HttpResponse.get StatusCode(HttpResponse.java:183)
at
org.eclipse.update.internal.core.UpdateManagerUtils.checkCon nectionResult(UpdateManagerUtils.java:553)
at
org.eclipse.update.internal.core.SiteURLFactory.createSite(S iteURLFactory.java:74)
at
org.eclipse.update.internal.core.InternalSiteManager.createS ite(InternalSiteManager.java:332)
at
org.eclipse.update.internal.core.InternalSiteManager.createS ite(InternalSiteManager.java:324)
at
org.eclipse.update.internal.core.InternalSiteManager.createS ite(InternalSiteManager.java:296)
at
org.eclipse.update.internal.core.InternalSiteManager.attempt CreateSite(InternalSiteManager.java:220)
at
org.eclipse.update.internal.core.InternalSiteManager.getSite (InternalSiteManager.java:161)
at org.eclipse.update.core.SiteManager.getSite(SiteManager.java :78)
at
org.eclipse.update.search.UpdateSearchRequest.searchOneSite( UpdateSearchRequest.java:345)
at
org.eclipse.update.search.UpdateSearchRequest.performSearch( UpdateSearchRequest.java:273)
at org.eclipse.update.ui.UpdateJob.runSearchForNew(UpdateJob.ja va:180)
at org.eclipse.update.ui.UpdateJob.run(UpdateJob.java:168)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
> import java.io.*;
> super();
> initialize();
> public static void main(String[] args) {
> ste.show();
> 5, 5, 5, 5));
> * @return void
> this
> doExit();
> return jPanel;
> loadFile();
> return jButton;
> saveFile();
> return jButton1;
> doExit();
> return jButton2;
> return jScrollPane;
> if (!hasChanged) {
> hasChanged = true;
> return jTextArea;
> try {
> br.close();
> setTitle(title);
> hasChanged = false;
> try {
> bw.close();
> setTitle(title);
> hasChanged = false;
> if (hasChanged) {
> saveFile();
> return;
> System.exit(0);
Re: novice [message #121281 is a reply to message #121256] Sat, 01 April 2006 11:25 Go to previous messageGo to next message
You need to take out that extra http:// in the update site url of the VE project//
Re: novice [message #121289 is a reply to message #121281] Sat, 01 April 2006 12:44 Go to previous messageGo to next message
Thanks Fred but I have done it and the update manager does not report any
update available.
How do I reinstall the examples?
project//
Re: novice [message #121337 is a reply to message #121289] Sat, 01 April 2006 20:33 Go to previous message
I got it!
At last I understood the philosophy of eclipse and its plugins!
I was able to create different installs of different versions. I
understood also what release and stream mean.
I understood that I cannot use update manager unless I am using a release
version.
EUREKA!!
I MADE IT!!!
Re: novice [message #612412 is a reply to message #121232] Fri, 31 March 2006 13:21 Go to previous message
import java.io.*;
super();
initialize();
ste.show();
5, 5, 5, 5));
* @return void
this
doExit();
return jPanel;
loadFile();
return jButton;
saveFile();
return jButton1;
doExit();
return jButton2;
return jScrollPane;
if (!hasChanged) {
hasChanged = true;
return jTextArea;
try {
br.close();
setTitle(title);
hasChanged = false;
try {
bw.close();
setTitle(title);
hasChanged = false;
if (hasChanged) {
saveFile();
return;
System.exit(0);
Re: novice [message #612415 is a reply to message #121249] Fri, 31 March 2006 13:31 Go to previous message
examples
Error
Source)
Source)
Source)
at
Source)
Source)
at
at
at
at
at
at
at
at
at
at
> import java.io.*;
> super();
> initialize();
> ste.show();
> 5, 5, 5, 5));
> * @return void
> this
> doExit();
> return jPanel;
> loadFile();
> return jButton;
> saveFile();
> return jButton1;
> doExit();
> return jButton2;
> return jScrollPane;
> if (!hasChanged) {
> hasChanged = true;
> return jTextArea;
> try {
> br.close();
> setTitle(title);
> hasChanged = false;
> try {
> bw.close();
> setTitle(title);
> hasChanged = false;
> if (hasChanged) {
> saveFile();
> return;
> System.exit(0);
Re: novice [message #612427 is a reply to message #121256] Sat, 01 April 2006 11:25 Go to previous message
Re: novice [message #612431 is a reply to message #121281] Sat, 01 April 2006 12:44 Go to previous message
update available.
project//
Re: novice [message #612448 is a reply to message #121289] Sat, 01 April 2006 20:33 Go to previous message
I got it!
version.
EUREKA!!
I MADE IT!!!
Previous Topic:Problems with VE Examples
Next Topic:EUREKA!!!!
Current Time: Fri Sep 19 00:44:18 EDT 2025
Powered by FUDForum. Page generated in 0.05644 seconds
