Home » Archived » Visual Editor (VE) » The VE do not open
The VE do not open [message #115897] Wed, 25 January 2006 23:07 Go to next message
Originally posted by: vinicius.negrisoli.gmail.com
I hava installed the VE but I am not getting use it. To use the eclipse
and VE I have unzipped the follow archieve:
eclipse-SDK-3.1.1-win32
emf-sdo-runtime-2.0.1
GEF-runtime-3.0.1
VE-runtime-1.2M1
After it I had started the eclipse with the flag -clean. The problem is
that when I try to open some Visual class with the VE it not works. A new
window of VE is openned but bottons of VE stay inactive and no error
messages are shown. I hava sawn on Manage Configuration and all,
including the VE, are enabled. Can someone help me ? Thank you!
Re: The VE do not open [message #115911 is a reply to message #115897] Thu, 26 January 2006 00:03 Go to previous messageGo to next message
Originally posted by: pangzi.sjtu.gmail.com
Vinicius wrote:
> GEF-runtime-3.0.1
> VE-runtime-1.2M1
> new window of VE is openned but bottons of VE stay inactive and no error
The same problem happens to me.
Re: The VE do not open [message #115923 is a reply to message #115911] Thu, 26 January 2006 07:12 Go to previous message
VE 1.2 M1 will only run on Eclipse 3.2 M4. See the requirements section
on the 1.2 M1 download page. You can use VE 1.1.0.1 on Eclipse 3.1.1.
Hope this helps,
- Jeff
Re: The VE do not open [message #611847 is a reply to message #115897] Thu, 26 January 2006 00:03 Go to previous message
Vinicius wrote:
> GEF-runtime-3.0.1
> VE-runtime-1.2M1
Re: The VE do not open [message #611850 is a reply to message #115911] Thu, 26 January 2006 07:12 Go to previous message
Hope this helps,
- Jeff
Previous Topic:The VE do not open
Next Topic:widget properties problem
Current Time: Thu Nov 06 17:56:15 EST 2025
Powered by FUDForum. Page generated in 0.04616 seconds
