Home » Archived » Visual Editor (VE) » How to insert a menu by VE
How to insert a menu by VE [message #115772] Tue, 24 January 2006 14:27 Go to next message
Originally posted by: alexandre.gzsistemas.com.br
Hi all,
I'm trying to insert a menu into a Shell but I can't find how to do it.
I've searched on newsgroups, helps, but I didn't find a solution.
Can anyone help me ?
Re: How to insert a menu by VE [message #115784 is a reply to message #115772] Tue, 24 January 2006 14:53 Go to previous messageGo to next message
Drop a menubar on the shell. Then you can drop menus on the menubar in
the JavaBeans viewer.
Alexandre Boaventura wrote:
> Hi all,
Rich Kulp
Re: How to insert a menu by VE [message #115835 is a reply to message #115772] Tue, 24 January 2006 17:04 Go to previous messageGo to next message
Originally posted by: nospamplease_enrictordera.vodafone.es
"Alexandre Boaventura" <alexandre@gzsistemas.com.br> escribi
Re: How to insert a menu by VE [message #115847 is a reply to message #115784] Wed, 25 January 2006 07:02 Go to previous messageGo to next message
Rich Kulp escreveu:
>> Hi all,
>> it. I've searched on newsgroups, helps, but I didn't find a solution.
Well, a menubar component is not available at swt pallete. What could be
wrong ?
Re: How to insert a menu by VE [message #115859 is a reply to message #115835] Wed, 25 January 2006 07:03 Go to previous messageGo to next message
Enric Tordera escreveu:
> "Alexandre Boaventura" <alexandre@gzsistemas.com.br> escribió en el mensaje
> news:dr5v38$3s7$1@utils.eclipse.org...
>> Hi all,
> Make sure you are using the last version of Visual Editor. If not sure try
> updating from the Help menu.
> Enric
I suppose I'm using the latest version because I downloaded and
installed from Update Manager yesterday !
Re: How to insert a menu by VE [message #115871 is a reply to message #115859] Wed, 25 January 2006 10:20 Go to previous messageGo to next message
Just check and make sure that you have VE 1.1.0.1 installed if you are
working on Eclipse 3.1.x. If you just did an install for the first time
of VE from the update manager it will pick up VE 1.1.0. You will need to
run update again to get it up to 1.1.0.1.
VE 1.1.0.1 has a palette category labeled SWT Menus.
Rich Kulp
Re: How to insert a menu by VE [message #115884 is a reply to message #115871] Wed, 25 January 2006 13:44 Go to previous message
Rich Kulp escreveu:
Thank you Rich.
Now it works !
Re: How to insert a menu by VE [message #611821 is a reply to message #115772] Tue, 24 January 2006 14:53 Go to previous message
> Hi all,
Rich Kulp
Re: How to insert a menu by VE [message #611827 is a reply to message #115772] Tue, 24 January 2006 17:04 Go to previous message
Re: How to insert a menu by VE [message #611830 is a reply to message #115784] Wed, 25 January 2006 07:02 Go to previous message
Rich Kulp escreveu:
>> Hi all,
wrong ?
Re: How to insert a menu by VE [message #611833 is a reply to message #115835] Wed, 25 January 2006 07:03 Go to previous message
>> Hi all,
> Enric
Re: How to insert a menu by VE [message #611837 is a reply to message #115859] Wed, 25 January 2006 10:20 Go to previous message
Rich Kulp
Re: How to insert a menu by VE [message #611839 is a reply to message #115871] Wed, 25 January 2006 13:44 Go to previous message
Rich Kulp escreveu:
Thank you Rich.
Now it works !
Previous Topic:Open with Visual Editor fails
Next Topic:The VE do not open
Current Time: Mon Nov 10 16:47:27 EST 2025
Powered by FUDForum. Page generated in 0.04859 seconds
