Home » Language IDEs » PHP Development Tools (PDT) » which jre?
which jre? [message #61151] Sun, 18 November 2007 16:02 Go to next message
Originally posted by: nonvalid.nonvalid.nonvalid
Hello togehther,
which version auf the JRE should I use for my eclipse + webtools + pdt to run properly?
1.5 oder 1.6?
thanks,
c ya
Re: which jre? [message #61176 is a reply to message #61151] Sun, 18 November 2007 17:47 Go to previous messageGo to next message
Originally posted by: dcarver.starstandard.org
Karsten Jung wrote:
> Hello togehther,
> to run properly?
> 1.5 oder 1.6?
1.5 or later.
Re: which jre? [message #61199 is a reply to message #61176] Sun, 18 November 2007 17:54 Go to previous messageGo to next message
David Carver schrieb:
> Karsten Jung wrote:
>> Hello togehther,
>> to run properly?
>> 1.5 oder 1.6?
> 1.5 or later.
Hmm, I though using 1.6 makes my pdt unstable...
Re: which jre? [message #61226 is a reply to message #61151] Mon, 19 November 2007 11:30 Go to previous message
Originally posted by: tatsudoshi.criion.net
Eclipse PDT team recommends JRE 1.5 (not 'or later') as I remember the text.
On http://download.eclipse.org/tools/pdt/downloads/?release=R20 070917
you find this note:
"Note that in addition you will need a Java runtime environment 5 (JRE
5) to use All-in-One package"
Also if you check the eclipse platform system requirements there is a
note explicitly stating JRE 1.5, which is the same as JRE 5
Hope this helps
/tatsudoshi
Previous Topic:SESSION vars do not work for zend debugger?
Next Topic:Error in PHP ui/Xdebug
Current Time: Thu Oct 09 02:36:28 EDT 2025
Powered by FUDForum. Page generated in 0.09656 seconds
