Home » Archived » B3 » missing requirement while aggregation the polarion update site whith b3 aggregator
missing requirement while aggregation the polarion update site whith b3 aggregator [message #611609] Wed, 04 August 2010 12:51 Go to next message
Hello everybody,
im trying to aggregate the subversion connectors from the http://community.polarion.com/projects/subversive/donwload/e clipse/2.0/update-site for a local update site and I'm getting this error:
Cannot complete the install because one or more required items could not be found.
Software being installed: all.contributed.content.feature.group 1.0.0
Missing requirement: JavaHL 1.6.6 Win32 Binaries (Optional) 2.2.2.I20100512-1900 (org.polarion.eclipse.team.svn.connector.javahl16.win32.feat ure.group 2.2.2.I20100512-1900) requires 'org.polarion.eclipse.team.svn.connector.javahl16.win32 [2.2.2.I20100512-1900]' but it could not be found
Cannot satisfy dependency:
To: org.polarion.eclipse.team.svn.connector.javahl16.win32.featu re.group 0.0.0
I added the update sitehttp://community.polarion.com/projects/subversive/donwlo ad/eclipse/2.0/update-siteas a "Mapped Repository" with no further configuration like "Bundles", "Features", Exclusion Rules" ...
Can anybody confirm this issue or doing I something wrong?
best regards & many thanks in advance
Re: missing requirement while aggregation the polarion update site whith b3 aggregator [message #611611 is a reply to message #611609] Wed, 04 August 2010 17:40 Go to previous message
--------------010000090902090606020205
Hi Simon,
the problem is in the original repository definition. It contains features that require bundles that are filtered for win32 platform only. As soon as you verify your repository for a configuration different from win32, the verification fails.
You can modify your aggregation file to avoid this problem though. Add a Valid Configuration Rule to your mapped repository for each of the win32 specific features and assign the only valid configuration (win32/win32) to them. Then you should get no errors and it should be possible to mirror the repository. Adding a validation rule means that verification of matching feature will be skipped for all configurations other than those mentioned in the rule.
You will find an example of the aggregation definition with successful verification in the attached file.
Filip
Simon Linden wrote:
> Hello everybody,
> From: all.contributed.content.feature.group 1.0.0
Content-Type: text/xml;
name="polarion.b3aggr"
filename="polarion.b3aggr"
<aggregator:Aggregator xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:aggregator="http://www.eclipse.org/b3/2010/aggregator/1.0.0" label="Polarion">
<configurations/>
<configurations operatingSystem="linux" windowSystem="gtk"/>
<contributions label="Polarion">
<repositories location=" http://community.polarion.com/projects/subversive/donwload/e clipse/2.0/update-site">
<mapRules xsi:type="aggregator:ValidConfigurationsRule" name=" org.polarion.eclipse.team.svn.connector.javahl.win32.feature .group " validConfigurations="//@configurations.0"/>
<mapRules xsi:type="aggregator:ValidConfigurationsRule" name=" org.polarion.eclipse.team.svn.connector.javahl15.win32.featu re.group " validConfigurations="//@configurations.0"/>
<mapRules xsi:type="aggregator:ValidConfigurationsRule" name=" org.polarion.eclipse.team.svn.connector.javahl16.win32.featu re.group " validConfigurations="//@configurations.0"/>
</repositories>
</contributions>
<validationRepositories location="http://download.eclipse.org/releases/helios"/>
</aggregator:Aggregator>
--------------010000090902090606020205--
Previous Topic:Unable to build Helios release with b3
Next Topic:Trouble installing b3 headless (3.6) under Windows
Current Time: Fri Jul 25 16:50:06 EDT 2025
Powered by FUDForum. Page generated in 0.03935 seconds
