Home » Archived » GMT (Generative Modeling Technologies) » [TCS] Which one should I choose, TCS or Jet?
[TCS] Which one should I choose, TCS or Jet? [message #380583] |
Wed, 19 December 2007 11:47  |
I'd like to develop a code generator for a language, say Java. I know
TCS can generate code based on syntactic description attached to the
metamodel, and I also know that Jet can produce source code of generator
too. I am confused which one I should adopt to build my generator.
Please give me some idea. If you recommend one,either TCS or Jet, it
will be great if you can tell me the reason.
Thanks.
Merry Christmas
Michael.
Re: [TCS] Which one should I choose, TCS or Jet? [message #380587 is a reply to message #380584] |
Thu, 20 December 2007 04:43   |
Originally posted by: mikael.barbero.gmail.com
Andy,
TCS is also able to pretty print the model of a program without changes
of the .tcs file. Naturally, the printed program is something being able
to be parsed by TCS :) Code generation with Jet & Co. would only be
needed if you only want to generate code and not parse it again afterward.
Then, I would say that TCS do T2M and M2T.
My $0.02
Regards.
Mikael
Andy Carpenter wrote:
> Michael,
> You will probably need both TCS and JET. I guess that
> for your requirements you will need to use TCS to produce
> a model from a 'program' written in your language (think of
> a model as an internal data structure representation of your
> program); this is a text-to-model transformation.
> The code generation would then use this model (internal
> data structure). If the code generation results in code that
> is similar in structure to your input language then what you
> will be performing is a model-to-text transformation for
> which JET is one possible implementation technology.
> If your language does not have a simple relationship to
> the code that you need to generate then the first step will
> be a model-to-model transformation. This transforms the
> original model representation of your program into a form
> closer to the code that you need to generate. Model-to-model
> transformation implementation possibilities include ATL.
> Once you have a model that is sufficiently close to the code
> that you need to generate, you can perform a model-to-text
> transformation; as described above.
> hope this helps
> Andy.
> "Michael" <my25@macs.hw.ac.uk> wrote in message
> news:fkbhv0$6eo$1@build.eclipse.org...
>> Hi,
>> Thanks.
>> Merry Christmas
>> Michael.
Mikaël Barbero - PhD Candidate
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssinière
44322 Nantes Cedex 3 - France
tel. +33 2 51 12 58 08 /\ cell.+33 6 07 63 19 00
email: Mikael.Barbero@{gmail.com, univ-nantes.fr}
http://www.sciences.univ-nantes.fr/lina/atl/
Re: [TCS] Which one should I choose, TCS or Jet? [message #380591 is a reply to message #380589] |
Thu, 20 December 2007 11:54  |
TCS has not been released yet.
Information on how to get it from CVS is available on this wiki page:
http://wiki.eclipse.org/TCS/Language_Project
Samples are available here: http://wiki.eclipse.org/TCS/Zoo
Mikael
Michael wrote:
> Thanks for the help from both of you.
> However, the problem is that the download of TCS is not available on the
> eclipse website. Do you have any idea of that?
> Michael.
> "Mikaël Barbero" <mikael.barbero@gmail.com> wrote in message
> news:fkddfj$nnb$1@build.eclipse.org...
>> Andy,
>> TCS is also able to pretty print the model of a program without changes of
>> the .tcs file. Naturally, the printed program is something being able to
>> be parsed by TCS :) Code generation with Jet & Co. would only be needed if
>> My $0.02
>> Regards.
>> Mikael
>>> Michael,
>>> hope this helps
>>> Andy.
>>>> Hi,
>>>> Thanks.
>>>> Merry Christmas
>>>> Michael.
Re: [TCS] Which one should I choose, TCS or Jet? [message #611027 is a reply to message #380583] |
Wed, 19 December 2007 17:40  |
Michael,
hope this helps
Andy.
> Thanks.
> Merry Christmas
> Michael.
Re: [TCS] Which one should I choose, TCS or Jet? [message #611080 is a reply to message #380584] |
Andy,
My $0.02
Regards.
Mikael
> Michael,
> hope this helps
> Andy.
>> Hi,
>> Thanks.
>> Merry Christmas
>> Michael.
Re: [TCS] Which one should I choose, TCS or Jet? [message #611083 is a reply to message #380589] |
Mikael
> Michael.
>> Andy,
>> My $0.02
>> Regards.
>> Mikael
>>> Michael,
>>> hope this helps
>>> Andy.
>>>> Hi,
>>>> Thanks.
>>>> Merry Christmas
>>>> Michael.
Current Time: Tue Jul 22 20:39:26 EDT 2025
Powered by FUDForum. Page generated in 0.52213 seconds
