Home » Eclipse Projects » JavaServer Faces » SEVERE: Allocate exception for servlet Faces Servlet java.lang.NullPointerException
SEVERE: Allocate exception for servlet Faces Servlet java.lang.NullPointerException [message #474156] Mon, 30 April 2007 05:06 Go to next message
Originally posted by: dnatochy.gmail.com
Hello there,
Pardon my ignorance, I am new to Eclipse and JSF.
I followed the steps from this webinar
https://admin.adobe.acrobat.com/_a300965365/p87371911/ to create a demo app.
However when I click on a jsp file and select Run As -> Run on Server, I am
getting a nasty error from Tomcat:
Apr 30, 2007 1:58:57 AM org.apache.catalina.core.ApplicationContext log
SEVERE: StandardWrapper.Throwable
at javax.faces.webapp.FacesServlet.init(FacesServlet.java:144)
at
org.apache.catalina.core.StandardWrapper.loadServlet(Standar dWrapper.java:1139)
at org.apache.catalina.core.StandardWrapper.load(StandardWrappe r.java:966)
at
org.apache.catalina.core.StandardContext.loadOnStartup(Stand ardContext.java:3956)
at org.apache.catalina.core.StandardContext.start(StandardConte xt.java:4230)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.j ava:1014)
at org.apache.catalina.core.StandardHost.start(StandardHost.jav a:736)
at org.apache.catalina.core.StandardEngine.start(StandardEngine .java:443)
at org.apache.catalina.core.StandardService.start(StandardServi ce.java:448)
at org.apache.catalina.core.StandardServer.start(StandardServer .java:700)
at org.apache.catalina.startup.Catalina.start(Catalina.java:552 )
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:2 95)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:43 3)
Apr 30, 2007 1:58:57 AM org.apache.catalina.core.StandardContext
loadOnStartup
SEVERE: Servlet /jsfwebinar threw load() exception
at
at
Apr 30, 2007 1:58:57 AM org.apache.coyote.http11.Http11BaseProtocol start
INFO: Starting Coyote HTTP/1.1 on http-8080
Apr 30, 2007 1:58:57 AM org.apache.jk.common.ChannelSocket init
INFO: JK: ajp13 listening on /0.0.0.0:8009
Apr 30, 2007 1:58:57 AM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/15 config=null
Apr 30, 2007 1:58:57 AM org.apache.catalina.storeconfig.StoreLoader load
INFO: Find registry server-registry.xml at classpath resource
Apr 30, 2007 1:58:57 AM org.apache.catalina.startup.Catalina start
INFO: Server startup in 719 ms
Apr 30, 2007 1:58:58 AM org.apache.catalina.core.ApplicationContext log
at
at
org.apache.catalina.core.StandardWrapper.allocate(StandardWr apper.java:791)
at
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:127)
at
org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:174)
at
org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:127)
at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:117)
at
org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:108)
at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:151)
at
org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:870)
at
org.apache.coyote.http11.Http11BaseProtocol$Http11Connection Handler.processConnection(Http11BaseProtocol.java:665)
at
org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(Poo lTcpEndpoint.java:528)
at
org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt( LeaderFollowerWorkerThread.java:81)
at
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru n(ThreadPool.java:685)
Apr 30, 2007 1:58:58 AM org.apache.catalina.core.StandardWrapperValve invoke
at
at
at
at
at
at
at
at
at
at
at
at
at
My guess is that JSF jars are not included in the deployed app. If so, how I
do tell Eclipse to do that?
I am running Eclipse 3.3 with Tomcat 5.5 (java jre1.5.0_10).
Dennis
Re: SEVERE: Allocate exception for servlet Faces Servlet java.lang.NullPointerException [message #474157 is a reply to message #474156] Mon, 30 April 2007 15:26 Go to previous messageGo to next message
Did you install the JSF facet when you created the dynamic web project?
That should cause the addition of the JSF libraries.
Can you show me your web.xml and faces-config.xml files? Also, which JSF
implementation are you using (i.e. where did you download it from).
--Cam
Re: SEVERE: Allocate exception for servlet Faces Servlet java.lang.NullPointerEx [message #474178 is a reply to message #474156] Mon, 30 April 2007 19:04 Go to previous messageGo to next message
Please check if you have any of the JSF libraries in a folder with spaces
in its name. I recollect getting similar errors with Tomcat 6.0.
-Raghu
Re: SEVERE: Allocate exception for servlet Faces Servlet java.lang.NullPointerException [message #474179 is a reply to message #474157] Wed, 02 May 2007 01:05 Go to previous messageGo to next message
Cameron/Raghu,
I am using :
Sun Reference implementation (RI) for JSR 127 (jsf1.1):
http://javashoplm.sun.com/ECom/docs/Welcome.jsp?StoreId=22&a mp;PartDetailId=jsf-1.1-ri-oth-JPR&SiteId=JSC&Transa ctionId=noreg
JSF facet is installed in Eclipse.
web.xml:
<?xml version="1.0" encoding="UTF-8"?><!DOCTYPE web-app PUBLIC "-//Sun
Microsystems, Inc.//DTD Web Application 2.3//EN"
"http://java.sun.com/dtd/web-app_2_3.dtd">
<web-app id="WebApp_ID">
<display-name>JSFWebinarDemo2</display-name>
<servlet>
<servlet-name>Faces Servlet</servlet-name>
<servlet-class>
javax.faces.webapp.FacesServlet</servlet-class>
<load-on-startup>1</load-on-startup>
</servlet>
<servlet-mapping>
<url-pattern>*.faces</url-pattern>
</servlet-mapping>
<welcome-file-list>
<welcome-file>index.html</welcome-file>
<welcome-file>index.htm</welcome-file>
<welcome-file>index.jsp</welcome-file>
<welcome-file>default.html</welcome-file>
<welcome-file>default.htm</welcome-file>
<welcome-file>default.jsp</welcome-file>
</welcome-file-list>
</web-app>
faces-config.xml:
<!DOCTYPE faces-config PUBLIC
"-//Sun Microsystems, Inc.//DTD JavaServer Faces Config 1.1//EN"
"http://java.sun.com/dtd/web-facesconfig_1_1.dtd">
<faces-config>
</faces-config>
JSF libraries do not have spaces in their names.
One strange thing: I've been testing on Tomcat 5.5. Then I installed 6.0 -
same issue. Tried 5.0 - works! Unfortunately I would like to use java 1.5,
which is not supported by tomcat 5.0 as far as I understand. :(
"Cameron Bateman" <cameron.bateman@oracle.com> wrote in message
news:5042aabec15132cd1df464eb5a8d0c9f$1@www.eclipse.org...
> --Cam
Re: SEVERE: Allocate exception for servlet Faces Servlet java.lang.NullPointerException [message #474182 is a reply to message #474179] Thu, 03 May 2007 14:34 Go to previous message
I am able to get a basic page working with your web.xml and
faces-config.xml, so it must be a configuration problem. Classpath (JSF
library) is a good candidate. What version of WTP/JSF tools are you
using? What jars are in your implementation JSF library?
--Cam
Re: SEVERE: Allocate exception for servlet Faces Servlet java.lang.NullPointerException [message #609345 is a reply to message #474156] Mon, 30 April 2007 15:26 Go to previous message
--Cam
Re: SEVERE: Allocate exception for servlet Faces Servlet java.lang.NullPointerEx [message #610953 is a reply to message #474156] Mon, 30 April 2007 19:04 Go to previous message
-Raghu
Re: SEVERE: Allocate exception for servlet Faces Servlet java.lang.NullPointerException [message #610954 is a reply to message #474157] Wed, 02 May 2007 01:05 Go to previous message
Cameron/Raghu,
I am using :
web.xml:
<servlet>
<servlet-class>
</servlet>
<servlet-mapping>
</servlet-mapping>
<welcome-file-list>
</web-app>
faces-config.xml:
<faces-config>
</faces-config>
> --Cam
Re: SEVERE: Allocate exception for servlet Faces Servlet java.lang.NullPointerException [message #610957 is a reply to message #474179] Thu, 03 May 2007 14:34 Go to previous message
--Cam
Previous Topic:WYSIWYG HTML editor
Next Topic:WTP 1.5.4 released
Current Time: Sat Jul 26 18:49:51 EDT 2025
Powered by FUDForum. Page generated in 0.08249 seconds
