Home » Archived » Visual Editor (VE) » VE installation problem (newbie)
VE installation problem (newbie) [message #108163] Mon, 26 September 2005 16:33 Go to next message
Originally posted by: dark_night00.gmx.net
Hello!
I've been trying to install VE lately, but didn't succeed.
I upacked the downloaded archives (emf-sdo-runtime-2.1.0.zip,
GEF-runtime-3.1.zip, VE-runtime-1.1.0.1.zip) into the correct plugin
directory of my Eclipse 3.1 installation. Afterwards I ran eclipse with
the -clean command. But the VE components still aren't there.
Did I forget anything? Any help is welcome. Thanks in advance.
Anton Meinert.
Re: VE installation problem (newbie) [message #108177 is a reply to message #108163] Mon, 26 September 2005 16:39 Go to previous messageGo to next message
Originally posted by: myersj.gmail.com
Unzip the zips you mentioned into the folder above your eclipse folder.
The zips contain the path eclipse/plugins/foo.plugin, so unziping
directly into the plugin folder does not work.
- Jeff
Anton Meinert wrote:
> Hello!
> Best regards,
> Anton Meinert.
Re: VE installation problem (newbie) [message #108190 is a reply to message #108177] Mon, 26 September 2005 17:14 Go to previous messageGo to next message
I also recommend using the update manager instead of zips. That will
make sure there aren't conflicts and that pre-reqs are there and it will
install correctly for you.
Note: The update manager will first install VE 1.1.0, then you can scan
for updates and get VE 1.1.0.1.
> - Jeff
>> Hello!
>> with the -clean command. But the VE components still aren't there.
>> Best regards,
>> Anton Meinert.
Rich Kulp
Re: VE installation problem (newbie) [message #108203 is a reply to message #108177] Mon, 26 September 2005 18:10 Go to previous messageGo to next message
Hello Jeff,
I'm pretty sure, I unzipped into the correct folder above the eclipse
folder. It did't work though.
I also tried the update manager, but I wouldn't help :-(
"Jeff Myers" <myersj@gmail.com> schrieb im Newsbeitrag
news:dh9m9u$2on$1@news.eclipse.org...
> The zips contain the path eclipse/plugins/foo.plugin, so unziping directly
> - Jeff
>> Hello!
>> Best regards,
>> Anton Meinert.
Re: VE installation problem (newbie) [message #108265 is a reply to message #108203] Tue, 27 September 2005 21:43 Go to previous messageGo to next message
Originally posted by: max.idatso.com
i have the same problem. i installed VE but it is not appearing anywhere
inside eclipse. i use eclipse 3.1, sun-jdk-1.5-05 both x86_64-linux. i
installed all packages via the update manager. also updated to ve 1.1.0.1.
are there any incompatibilities with eclipse running on 64-bit? i didn't
find any information on this topic.
thx
max
Re: VE installation problem (newbie) UPDATE [message #108291 is a reply to message #108265] Tue, 27 September 2005 22:09 Go to previous messageGo to next message
i found out that i can open an existing file with VE but am not able to
create new VE files.
seems to work... [message #108306 is a reply to message #108291] Wed, 28 September 2005 02:44 Go to previous messageGo to next message
everything seems fine. still i am interested in 64-bit information
regarding VE. where can i find such information? just want to know what is
working/not working.
thx anyway
max
Re: seems to work... [message #108327 is a reply to message #108306] Wed, 28 September 2005 08:53 Go to previous messageGo to next message
VE is currently supported on Linux/GTK x86_64, but hasn't been
extensively tested. If you run into any problems with that
configuration, please report them in VE's bugzilla. Other than that
there is no 64-bit specific information to be had.
Hope this helps,
- Jeff
> is working/not working.
> thx anyway
> max
Re: VE installation problem (newbie) UPDATE [message #108340 is a reply to message #108291] Wed, 28 September 2005 10:03 Go to previous message
Does not able to create mean the New Visual Class wizard fails? Or does
it mean you can't find the New Visual Class Wizard?
If it fails, please let us know how it fails.
If it is not found, we've seen cases where when you have an existing
customized perspective and then add the VE, that the Toolbar is not
updated with the new visual class wizard. However it should be under,
New->Other->Java
Rich Kulp
Re: VE installation problem (newbie) [message #610872 is a reply to message #108163] Mon, 26 September 2005 16:39 Go to previous message
- Jeff
> Hello!
> Best regards,
> Anton Meinert.
Re: VE installation problem (newbie) [message #610873 is a reply to message #108177] Mon, 26 September 2005 17:14 Go to previous message
> - Jeff
>> Hello!
>> Best regards,
>> Anton Meinert.
Rich Kulp
Re: VE installation problem (newbie) [message #610874 is a reply to message #108177] Mon, 26 September 2005 18:10 Go to previous message
Hello Jeff,
> - Jeff
>> Hello!
>> Best regards,
>> Anton Meinert.
Re: VE installation problem (newbie) [message #610879 is a reply to message #108203] Tue, 27 September 2005 21:43 Go to previous message
thx
max
Re: VE installation problem (newbie) UPDATE [message #610881 is a reply to message #108265] Tue, 27 September 2005 22:09 Go to previous message
seems to work... [message #610882 is a reply to message #108291] Wed, 28 September 2005 02:44 Go to previous message
thx anyway
max
Re: seems to work... [message #610883 is a reply to message #108306] Wed, 28 September 2005 08:53 Go to previous message
Hope this helps,
- Jeff
> thx anyway
> max
Re: VE installation problem (newbie) UPDATE [message #610884 is a reply to message #108291] Wed, 28 September 2005 10:03 Go to previous message
New->Other->Java
Rich Kulp
Previous Topic:VE installation failed
Next Topic:A Problem with a visual class that extends other visual class
Current Time: Sat Jul 19 08:23:49 EDT 2025
Powered by FUDForum. Page generated in 0.05747 seconds
