Home » Archived » Visual Editor (VE) » Error Message whenever i close Visual Editor
Error Message whenever i close Visual Editor [message #105574] Wed, 07 September 2005 15:28 Go to next message
I keep getting the following error whenever i close the visual editor.
!ENTRY org.eclipse.ui.workbench 4 2 2005-09-07 14:21:22.00
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.ui.workbench".
!STACK 0
at
org.eclipse.ve.internal.cde.core.EditDomain.setPaletteViewer (EditDomain.java:79)
at
org.eclipse.gef.ui.views.palette.PaletteViewerPage.dispose(P aletteViewerPage.java:73)
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$CustomPalettePage.dispose(JavaVisualEditorPart.java :2531)
at
org.eclipse.gef.ui.views.palette.PaletteView.doDestroyPage(P aletteView.java:74)
at org.eclipse.ui.part.PageBookView.removePage(PageBookView.jav a:718)
at org.eclipse.ui.part.PageBookView.partClosed(PageBookView.jav a:644)
at
org.eclipse.ui.internal.PartListenerList$3.run(PartListenerL ist.java:102)
at
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1044)
at org.eclipse.core.runtime.Platform.run(Platform.java:783)
at
org.eclipse.ui.internal.PartListenerList.fireEvent(PartListe nerList.java:58)
at
org.eclipse.ui.internal.PartListenerList.firePartClosed(Part ListenerList.java:100)
at
org.eclipse.ui.internal.PartService.firePartClosed(PartServi ce.java:100)
at
org.eclipse.ui.internal.WorkbenchPagePartList.firePartClosed (WorkbenchPagePartList.java:38)
at org.eclipse.ui.internal.PartList.partClosed(PartList.java:21 2)
at org.eclipse.ui.internal.PartList.removePart(PartList.java:14 7)
at
org.eclipse.ui.internal.WorkbenchPage.disposePart(WorkbenchP age.java:1431)
at
org.eclipse.ui.internal.WorkbenchPage.handleDeferredEvents(W orkbenchPage.java:1259)
at
org.eclipse.ui.internal.WorkbenchPage.deferUpdates(Workbench Page.java:1243)
at
org.eclipse.ui.internal.WorkbenchPage.closeEditors(Workbench Page.java:1217)
at
org.eclipse.ui.internal.WorkbenchPage.closeAllEditors(Workbe nchPage.java:1028)
at org.eclipse.ui.internal.WorkbenchPage.dispose(WorkbenchPage. java:1479)
at
org.eclipse.ui.internal.WorkbenchWindow.closeAllPages(Workbe nchWindow.java:763)
at
org.eclipse.ui.internal.WorkbenchWindow.hardClose(WorkbenchW indow.java:1392)
at
org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchW indow.java:646)
at
org.eclipse.ui.internal.WorkbenchWindow.access$0(WorkbenchWi ndow.java:627)
at org.eclipse.ui.internal.WorkbenchWindow$2.run(WorkbenchWindo w.java:728)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindo w.java:726)
at org.eclipse.jface.window.WindowManager.close(WindowManager.j ava:108)
at org.eclipse.ui.internal.Workbench$11.run(Workbench.java:588)
at
at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:5 85)
at org.eclipse.ui.internal.Workbench.access$8(Workbench.java:52 2)
at org.eclipse.ui.internal.Workbench$13.run(Workbench.java:713)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:711)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:686)
at
org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchW indow.java:643)
at
at org.eclipse.jface.window.Window.handleShellCloseEvent(Window .java:727)
at org.eclipse.jface.window.Window$3.shellClosed(Window.java:67 4)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:159)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:867)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:852)
at org.eclipse.swt.widgets.Decorations.closeWidget(Decorations. java:257)
at org.eclipse.swt.widgets.Decorations.WM_CLOSE(Decorations.jav a:1649)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3040 )
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.j ava:1582)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3706 )
at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:1651 )
at org.eclipse.swt.widgets.Shell.callWindowProc(Shell.java:410)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3123 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:16 56)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2711)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Re: Error Message whenever i close Visual Editor [message #105602 is a reply to message #105574] Wed, 07 September 2005 15:51 Go to previous messageGo to next message
What version of VE do you have installed?
Rich Kulp
Re: Error Message whenever i close Visual Editor [message #105629 is a reply to message #105574] Wed, 07 September 2005 16:05 Go to previous messageGo to next message
This is a bug. Please open a defect so when can fix it.
The problem is because you have a Palette View opened. If you used the
palette within the VE instead then it would work.
Rich Kulp
Re: Error Message whenever i close Visual Editor [message #105638 is a reply to message #105629] Wed, 07 September 2005 18:32 Go to previous messageGo to next message
Yeah that fixed the problem. Thanks a lot. It was VE 1.1.0
Re: Error Message whenever i close Visual Editor [message #105652 is a reply to message #105629] Wed, 07 September 2005 18:35 Go to previous messageGo to next message
What do you mean by "open a defect so we can fix it"?
Re: Error Message whenever i close Visual Editor [message #105675 is a reply to message #105652] Wed, 07 September 2005 23:46 Go to previous message
It would be most helpful for tracking problems in VE once a defect is
opened. You could open a defect on Eclipse bugzilla for the VE project
at https://bugs.eclipse.org/bugs/enter_bug.cgi?product=VE .
Sri.
Re: Error Message whenever i close Visual Editor [message #610692 is a reply to message #105574] Wed, 07 September 2005 15:51 Go to previous message
Rich Kulp
Re: Error Message whenever i close Visual Editor [message #610694 is a reply to message #105574] Wed, 07 September 2005 16:05 Go to previous message
Rich Kulp
Re: Error Message whenever i close Visual Editor [message #610695 is a reply to message #105629] Wed, 07 September 2005 18:32 Go to previous message
Re: Error Message whenever i close Visual Editor [message #610696 is a reply to message #105629] Wed, 07 September 2005 18:35 Go to previous message
Re: Error Message whenever i close Visual Editor [message #610698 is a reply to message #105652] Wed, 07 September 2005 23:46 Go to previous message
Sri.
Previous Topic:parsing factory call
Next Topic:stop parsing a method
Current Time: Mon Jul 28 03:34:45 EDT 2025
Powered by FUDForum. Page generated in 0.05123 seconds
