Extending The Visual Editor:= BUG in text proerty [message #101740] |
Wed, 10 August 2005 04:12  |
Hi, there is a bug in tutorial
"Extending The Visual Editor: Enabling support for a custom widget"
when I want to create editing behaviour of the text property there is
NullPointerException somewhere in EMF, because it doesn't find
somewhat(DELEGATE) of EMF EReference of the text property. Because of that
it will not show properties view.
HERE IS STACKTRACE OF EXCEPTION:
Thread [main] (Suspended (exception NullPointerException))
EReferenceImpl(EStructuralFeatureImpl).getSettingDelegate() line: 790
JavaObjectInstance(BasicEObjectImpl).eSettingDelegate(EStruc turalFeature)
line: 822
JavaObjectInstance(BasicEObjectImpl).eDynamicIsSet(EStructur alFeature)
line: 609
JavaObjectInstance(BasicEObjectImpl).eIsSet(EStructuralFeatu re) line: 600
CompositePropertySourceAdapter(BeanPropertySourceAdapter).ge tPropertyValue(Object)
line: 89
CompositePropertySourceAdapter(WidgetPropertySourceAdapter). getPropertyValue(Object)
line: 365
JavaCommandStackPropertySheetEntry(CommandStackPropertySheet Entry).primGetValues()
line: 173
JavaCommandStackPropertySheetEntry(AbstractPropertySheetEntr y).refreshValues()
line: 892
JavaCommandStackPropertySheetEntry(AbstractPropertySheetEntr y).refreshChildEntries()
line: 823
JavaCommandStackPropertySheetEntry(AbstractPropertySheetEntr y).setValues(Object[])
line: 1028
PropertySheetViewer.setInput(Object) line: 875
JavaVisualEditorPropertySheetPage(PropertySheetPage).selecti onChanged(IWorkbenchPart,
ISelection) line: 392
JavaVisualEditorPropertySheetPage(EToolsPropertySheetPage).s uperSelectionChanged(IWorkbenchPart,
ISelection) line: 250
EToolsPropertySheetPage.access$2(EToolsPropertySheetPage, IWorkbenchPart,
ISelection) line: 243
EToolsPropertySheetPage$1.run() line: 236
RunnableLock.run() line: 35
UISynchronizer(Synchronizer).runAsyncMessages(boolean) line: 123
Display.runAsyncMessages(boolean) line: 3057
Display.readAndDispatch() line: 2716
Workbench.runEventLoop(Window$IExceptionHandler, Display) line: 1699
Workbench.runUI() line: 1663
Workbench.createAndRunWorkbench(Display, WorkbenchAdvisor) line: 367
PlatformUI.createAndRunWorkbench(Display, WorkbenchAdvisor) line: 143
IDEApplication.run(Object) line: 103
PlatformActivator$1.run(Object) line: 226
EclipseStarter.run(Object) line: 376
EclipseStarter.run(String[], Runnable) line: 163
NativeMethodAccessorImpl.invoke0(Method, Object, Object[]) line: not
available [native method]
NativeMethodAccessorImpl.invoke(Object, Object[]) line: 39
DelegatingMethodAccessorImpl.invoke(Object, Object[]) line: 25
Method.invoke(Object, Object...) line: 585
Main.invokeFramework(String[], URL[]) line: 334
Main.basicRun(String[]) line: 278
Main.run(String[]) line: 973
Main.main(String[]) line: 948
Re: Extending The Visual Editor:= BUG in text proerty [message #102018 is a reply to message #102010] |
Thu, 11 August 2005 10:49  |
Thank you, when I cleaned up All Projects - it is now RUNNING
Thank you for your help so much, you made me very happy :)
John Cage
> Try this first:
> 1) Open the VE, get the error, close the VE, but leave Eclipse running
> 2) Do Project->Clean...->Clean ALL (all is very important).
> 3) Try the VE again. If you still get the error, please send us the class
> in question so we can see if there is anything in there that could cause
> this.
> Rich Kulp
Re: Extending The Visual Editor:= BUG in text proerty [message #610231 is a reply to message #101880] |
Wed, 10 August 2005 12:55  |
Do you have any errors in the .log file in your workspace's .metadata
directory?
- Jeff
John Cage wrote:
> This bug is the same as "VE properties tab is empty".
> But I have all new VE 1.1, EMF 2.1.0 GEF 3.1 and ECLIPSE 3.1, java 1.5
> this bug is here STILL.
> WHAT IS WRONG - can you help me?
> John Cage
> Thank you in advance
Re: Extending The Visual Editor:= BUG in text proerty [message #610241 is a reply to message #101892] |
Thu, 11 August 2005 04:25  |
Here is my current .log file capturing that error's stacktrace.
Now I am using JAVA 1.4.2 but result (stacktrace and behaviour) is the same
like with java 1.5.0.
Scenario is that when I click on the MyCustomPrompter(from tutorial) than
an exception below is thrown and the eclipse's properties view will be
empty.
!SESSION 2005-08-11 10:19:19.229
eclipse.buildId=unknown
java.version=1.4.2_06
Framework arguments: -product org.eclipse.sdk.ide -pdelaunch
Command-line arguments: -product org.eclipse.sdk.ide -data
C:\ecl31ve\runtime-EclipseApplication -dev
file:C:/ecl31ve/workspace/.metadata/.plugins/org.eclipse.pde .core/Eclipse
Application/dev.properties -pdelaunch -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.ui 4 4 2005-08-11 10:20:01.754
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2005-08-11 10:20:01.754
!MESSAGE Failed to execute runnable (java.lang.NullPointerException)
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable
at org.eclipse.swt.SWT.error(SWT.java:2942)
at org.eclipse.swt.SWT.error(SWT.java:2865)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:126)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3057)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2716)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at
at
at java.lang.reflect.Method.invoke(Method.java:324)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
at
org.eclipse.emf.ecore.impl.EStructuralFeatureImpl.getSetting Delegate(EStructuralFeatureImpl.java:790)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSettingDelegate (BasicEObjectImpl.java:822)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicIsSet(Ba sicEObjectImpl.java:609)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eIsSet(BasicEObj ectImpl.java:600)
at
org.eclipse.ve.internal.java.core.BeanPropertySourceAdapter. getPropertyValue(BeanPropertySourceAdapter.java:89)
at
org.eclipse.ve.internal.swt.WidgetPropertySourceAdapter.getP ropertyValue(WidgetPropertySourceAdapter.java:365)
at
org.eclipse.ve.internal.propertysheet.command.CommandStackPr opertySheetEntry.primGetValues(CommandStackPropertySheetEntr y.java:173)
at
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.refreshValues(AbstractPropertySheetEntry.java:892)
at
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.refreshChildEntries(AbstractPropertySheetEntry.java:823 )
at
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.setValues(AbstractPropertySheetEntry.java:1028)
at
org.eclipse.ui.views.properties.PropertySheetViewer.setInput (PropertySheetViewer.java:875)
at
org.eclipse.ui.views.properties.PropertySheetPage.selectionC hanged(PropertySheetPage.java:392)
at
org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e.superSelectionChanged(EToolsPropertySheetPage.java:250)
at
org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e.access$2(EToolsPropertySheetPage.java:243)
at
org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e$1.run(EToolsPropertySheetPage.java:236)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
... 18 more
Re: Extending The Visual Editor:= BUG in text proerty [message #610248 is a reply to message #101960] |
Thu, 11 August 2005 10:35  |
Try this first:
class in question so we can see if there is anything in there that could
cause this.
Rich Kulp
Re: Extending The Visual Editor:= BUG in text proerty [message #610250 is a reply to message #102010] |
John Cage
> Try this first:
> this.
> Rich Kulp
FUDForum. Page generated in 0.09444 seconds
