Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » EMF model generation- performance problem?
EMF model generation- performance problem? [message #99212] Tue, 16 October 2007 06:55 Go to next message
Using Europa with both JDK 5 and also separately 6.
I am using the tutorial in the help for "Generating an EMF model using
XML Schema (XSD)". But instead of using the library.xsd I am using a
large XSD, 1.5MB in size. This is on a dual core 2GHz laptop with 2GB of
RAM. I have allowed Eclipse 750MB of working memory (-Xmx) and it is
using all of it, it has been using 100% of 1 core now for 16 hours. This
is after checking the "Create XML Schema to ECore map" checkbox and
clicking Finish button. I am also running it on a separate desktop with
dual Opterons, 4GB RAM and RAID5, it cannot even redraw the Eclipse UI,
with one cpu at 100%.
So is this expected or is there something wrong?
David
Re: EMF model generation- performance problem? [message #99230 is a reply to message #99212] Tue, 16 October 2007 07:51 Go to previous messageGo to next message
David,
Sixteen hours is a little long. =-O It's a really bad idea to use
"Create XML Schema to Ecore map" for anything but a toy schema example.
I know that this feature has some very bad combinatorial behavior so I
suggest you avoid using it. The generation process doesn't rely on it
and should proceed a 1000 times faster without it.
david wrote:
> of RAM. I have allowed Eclipse 750MB of working memory (-Xmx) and it
> is using all of it, it has been using 100% of 1 core now for 16 hours.
> This is after checking the "Create XML Schema to ECore map" checkbox
> and clicking Finish button. I am also running it on a separate desktop
> with dual Opterons, 4GB RAM and RAID5, it cannot even redraw the
> Eclipse UI, with one cpu at 100%.
> David
Re: EMF model generation- performance problem? [message #99424 is a reply to message #99230] Wed, 17 October 2007 09:04 Go to previous messageGo to next message
I tried again to get to first base, following the library example but
using a much larger xsd. I get further but an error.
Severity and Description Path Resource Location Creation Time Id
Package 'org.mddl.mddl._3.util' does not exist in this plug-in
MDDL_3b/META-INF MANIFEST.MF line 11 1192620812875 4
Package 'org.mddl.mddl._3' does not exist in this plug-in
MDDL_3b/META-INF MANIFEST.MF line 9 1192620812875 3
This is after right clicking the genmodel and selecting 'Generate All'.
Unfortunately the xsd has a rather unfortunately named element '_3' not
sure this has anything to do with this problem, but it may. It does not
show an error on the Export Package of org.mddl.mddl._3.impl though.
There are 603 elements in this model.
Thx.
David
Ed Merks wrote:
> David,
> david wrote:
>> Hi,
>> Thanks,
>> David
Re: EMF model generation- performance problem? [message #99450 is a reply to message #99424] Wed, 17 October 2007 09:46 Go to previous messageGo to next message
--------------040303050908090602040406
David,
Note that the plugin.xml and MANIFEST.MF do no regenerate or merge if
you make changes to the model 150092
<https://bugs.eclipse.org/bugs/show_bug.cgi?id=150092>, so perhaps
deleting these two files and regenerating will fix the problem. I'm
slightly confused though, if there is an org.mddl.mddl._3.impl package
containing classes, are you saying there isn't really an
org.mddl.mddl._3 package nor an org.mddl.mddl._3.util package also
containing classes? I would expect the former to contain all the
interfaces and the later to contain things like the XyzSwitch for the
model...
david wrote:
> Time Id
> All'. Unfortunately the xsd has a rather unfortunately named element
> '_3' not sure this has anything to do with this problem, but it may.
> It does not show an error on the Export Package of
> org.mddl.mddl._3.impl though. There are 603 elements in this model.
> Thx.
> David
> Ed Merks wrote:
>> David,
>> example. I know that this feature has some very bad combinatorial
>> behavior so I suggest you avoid using it. The generation process
>> doesn't rely on it and should proceed a 1000 times faster without it.
>> david wrote:
>>> Hi,
>>> using XML Schema (XSD)". But instead of using the library.xsd I am
>>> using a large XSD, 1.5MB in size. This is on a dual core 2GHz laptop
>>> with 2GB of RAM. I have allowed Eclipse 750MB of working memory
>>> (-Xmx) and it is using all of it, it has been using 100% of 1 core
>>> now for 16 hours. This is after checking the "Create XML Schema to
>>> ECore map" checkbox and clicking Finish button. I am also running it
>>> on a separate desktop with dual Opterons, 4GB RAM and RAID5, it
>>> cannot even redraw the Eclipse UI, with one cpu at 100%.
>>> Thanks,
>>> David
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
David,<br>
<br>
you make changes to the model <a name="b150092"
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=150092">150092</a>,
so perhaps deleting these two files and regenerating will fix the
problem.&nbsp; I'm slightly confused though,&nbsp; if there is an&nbsp;
org.mddl.mddl._3.impl package containing classes, are you saying there
isn't really an org.mddl.mddl._3 package nor an org.mddl.mddl._3.util
package also containing classes?&nbsp; I would expect the former to contain
all the interfaces and the later to contain things like the XyzSwitch
for the model...<br>
<br>
<br>
david wrote:
<blockquote cite="mid:ff517h$d5g$1@build.eclipse.org" type="cite">Hi,
<br>
<br>
<br>
<br>
Severity and Description&nbsp;&nbsp;&nbsp; Path&nbsp;&nbsp;&nbsp; Resource&nbsp;&nbsp;&nbsp; Location&nbsp;&nbsp;&nbsp; Creation
Time&nbsp;&nbsp;&nbsp; Id
<br>
MDDL_3b/META-INF&nbsp;&nbsp;&nbsp; MANIFEST.MF&nbsp;&nbsp;&nbsp; line 11&nbsp;&nbsp;&nbsp; 1192620812875&nbsp;&nbsp;&nbsp; 4
<br>
MDDL_3b/META-INF&nbsp;&nbsp;&nbsp; MANIFEST.MF&nbsp;&nbsp;&nbsp; line 9&nbsp;&nbsp;&nbsp; 1192620812875&nbsp;&nbsp;&nbsp; 3
<br>
<br>
<br>
<br>
Thx.
<br>
<br>
David
<br>
<br>
Ed Merks wrote:
<br>
<blockquote type="cite">David,
<br>
<br>
Sixteen hours is a little long. =-O&nbsp;&nbsp; It's a really bad idea to use
example.&nbsp; I know that this feature has some very bad combinatorial
behavior so I suggest you avoid using it.&nbsp; The generation process
<br>
<br>
<br>
david wrote:
<br>
<blockquote type="cite">Hi,
<br>
<br>
<br>
<br>
of RAM. I have allowed Eclipse 750MB of working memory (-Xmx) and it is
<br>
<br>
<br>
<br>
<br>
<br>
David
<br>
</blockquote>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------040303050908090602040406--
Re: EMF model generation- performance problem? [message #99479 is a reply to message #99450] Wed, 17 October 2007 10:11 Go to previous messageGo to next message
Well I tried generating them one at a time, model, edit etc. and that
worked. Now I have 142 of this type of error one per java file.
Cannot cast from EList<Object> to FeatureMap
MDDL_3b/src/org/mddl/mddl/_3/impl AddressImpl.java line 236
1192626673906 36704
I googled it and only found one reference to this error type and it was
in the context of OHF, with which I am unfamiliar.
Thx.
David
Ed Merks wrote:
> David,
> model...
> david wrote:
>> Hi,
>> Time Id
>> Thx.
>> David
>> Ed Merks wrote:
>>> David,
>>> david wrote:
>>>> Hi,
>>>> Thanks,
>>>> David
Re: EMF model generation- performance problem? [message #99495 is a reply to message #99479] Wed, 17 October 2007 10:25 Go to previous messageGo to next message
--------------010900090802060303080003
David,
This error is an annoying one. It sounds like you've generated code
that targets EMF 2.2/Java 1.4 (GenModel's Compliance Level property set
to 1.4), but are compiling with Java 5.0 source compatibility. You'll
need to change them to match. I would generally expect this code in
ModelImporter.java to ensure that the new GenModel's Compliance Level
matches your preferences:
protected void adjustGenModel(Monitor monitor)
String modelName =
URI.decode(getGenModelPath().removeFileExtension().lastSegme nt());
int index = modelName.lastIndexOf('.');
if (index != -1)
modelName = modelName.substring(0, index);
modelName = CodeGenUtil.capName(modelName);
GenModel genModel = getGenModel();
genModel.setModelName(modelName);
genModel.setModelPluginID(getModelPluginID());
genModel.setModelDirectory(getModelPluginDirectory());
genModel.getUsedGenPackages().addAll(genModel.computeMissing UsedGenPackages());
if (getOriginalGenModel() == null)
URI genModelURI = genModel.eResource().getURI();
if (genModelURI.isPlatformResource())
IFile genModelFile =
ResourcesPlugin.getWorkspace().getRoot().getFile(new
Path(genModelURI.toPlatformString(true)));
IProject project = genModelFile.getProject();
String complianceLevel =
CodeGenUtil.EclipseUtil.getJavaComplianceLevel(project);
if ("1.5".equals(complianceLevel))
genModel.setComplianceLevel(GenJDKLevel.JDK50_LITERAL);
else if ("1.6".equals(complianceLevel))
genModel.setComplianceLevel(GenJDKLevel.JDK60_LITERAL);
else if ("1.4".equals(complianceLevel))
genModel.setComplianceLevel(GenJDKLevel.JDK14_LITERAL);
> 1192626673906 36704
> was in the context of OHF, with which I am unfamiliar.
> Thx.
> David
> Ed Merks wrote:
>> David,
>> package containing classes, are you saying there isn't really an
>> model...
>> david wrote:
>>> Hi,
>>> but using a much larger xsd. I get further but an error.
>>> Time Id
>>> Thx.
>>> David
>>> Ed Merks wrote:
>>>> David,
>>>> david wrote:
>>>>> Hi,
>>>>> laptop with 2GB of RAM. I have allowed Eclipse 750MB of working
>>>>> memory (-Xmx) and it is using all of it, it has been using 100% of
>>>>> 1 core now for 16 hours. This is after checking the "Create XML
>>>>> Schema to ECore map" checkbox and clicking Finish button. I am
>>>>> also running it on a separate desktop with dual Opterons, 4GB RAM
>>>>> and RAID5, it cannot even redraw the Eclipse UI, with one cpu at
>>>>> 100%.
>>>>> Thanks,
>>>>> David
<html>
<head>
</head>
David,<br>
<br>
This error is an annoying one.&nbsp; It sounds like you've generated code
to 1.4), but are compiling with Java 5.0 source compatibility.&nbsp; You'll
need to change them to match.&nbsp; I would generally expect this code in
matches your preferences:<br>
<blockquote><small>&nbsp; protected void adjustGenModel(Monitor monitor)</small><br>
<small>&nbsp; {</small><br>
<small>&nbsp;&nbsp;&nbsp; String modelName =
URI.decode(getGenModelPath().removeFileExtension().lastSegme nt()); </small><br>
<small>&nbsp;&nbsp;&nbsp; int index = modelName.lastIndexOf('.');</small><br>
<small>&nbsp;&nbsp;&nbsp; if (index != -1)</small><br>
<small>&nbsp;&nbsp;&nbsp; {</small><br>
<small>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; modelName = modelName.substring(0, index);</small><br>
<small>&nbsp;&nbsp;&nbsp; }</small><br>
<small>&nbsp;&nbsp;&nbsp; modelName = CodeGenUtil.capName(modelName); </small><br>
<br>
<small>&nbsp;&nbsp;&nbsp; GenModel genModel = getGenModel();</small><br>
<small>&nbsp;&nbsp;&nbsp; genModel.setModelName(modelName);</small><br>
<small>&nbsp;&nbsp;&nbsp; genModel.setModelPluginID(getModelPluginID());</small><br>
<small>&nbsp;&nbsp;&nbsp; genModel.setModelDirectory(getModelPluginDirectory());</small ><br>
genModel.getUsedGenPackages().addAll(genModel.computeMissing UsedGenPackages()); </small><br>
<small>&nbsp;&nbsp;&nbsp; </small><br>
<small>&nbsp;&nbsp;&nbsp; if (getOriginalGenModel() == null)</small><br>
<small>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; URI genModelURI = genModel.eResource().getURI();</small><br>
<small>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; if (genModelURI.isPlatformResource())</small><br>
<small>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; {</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; IFile genModelFile =
Path(genModelURI.toPlatformString(true)));</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; IProject project = genModelFile.getProject();</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; String complianceLevel =
CodeGenUtil.EclipseUtil.getJavaComplianceLevel(project);</small ><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; if ("1.5".equals(complianceLevel))</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; {</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;
genModel.setComplianceLevel(GenJDKLevel.JDK50_LITERAL);</small ><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; }</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; else if ("1.6".equals(complianceLevel))</small><br>
genModel.setComplianceLevel(GenJDKLevel.JDK60_LITERAL);</small ><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; else if ("1.4".equals(complianceLevel))</small><br>
genModel.setComplianceLevel(GenJDKLevel.JDK14_LITERAL);</small ><br>
<small>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; }</small><br>
<small>&nbsp; }</small><br>
</blockquote>
<br>
<br>
david wrote:
<blockquote cite="mid:ff554v$e1k$1@build.eclipse.org" type="cite">Well
<br>
<br>
Cannot cast from EList&lt;Object&gt; to FeatureMap
MDDL_3b/src/org/mddl/mddl/_3/impl&nbsp;&nbsp;&nb sp; AddressImpl.java&nbsp;&nbsp;&nbsp; line 236
1192626673906&nbsp;&nbsp;&nbsp; 36704
<br>
<br>
<br>
<br>
Thx.
<br>
<br>
David
<br>
<br>
<br>
Ed Merks wrote:
<br>
<br>
<br>
<a class="moz-txt-link-rfc2396E" href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=150092">&lt;https://bugs.eclipse.org/bugs/show_bug.cgi?id=150092&gt;</a>, so
for the model...
<br>
<br>
<br>
david wrote:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Thx.
<br>
<br>
David
<br>
<br>
Ed Merks wrote:
<br>
<br>
<br>
<br>
<br>
<br>
david wrote:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
David
<br>
</blockquote>
</blockquote>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------010900090802060303080003--
Re: EMF model generation- performance problem? [message #99509 is a reply to message #99495] Wed, 17 October 2007 10:47 Go to previous messageGo to next message
Ed,
You have lost me. My emf plugins are all 2.3 and I am using Europa and
Java 5. So I am not sure how I could be targeting EMF 2.2 and Java 1.4
since I made no choice, simply followed the library tutorial. I went
through the project properties and could find nothing pertaining to
which EMF version is to be targeted. Am I missing something here?
I also found a reference to the ModelImporter.java class you refer to,
it is in the emf package. Is your suggestion to download the source for
EMF, change it to match your method below and compile? I looked for a
bug like this in the bug list but could not find it.
Thx.
David
Ed Merks wrote:
> David,
> String modelName =
> if (index != -1)
>> 1192626673906 36704
>> Thx.
>> David
>> Ed Merks wrote:
>>> David,
>>> model...
>>> david wrote:
>>>> Hi,
>>>> Time Id
>>>> Thx.
>>>> David
>>>> Ed Merks wrote:
>>>>> David,
>>>>> david wrote:
>>>>>> Hi,
>>>>>> 100%.
>>>>>> Thanks,
>>>>>> David
Re: EMF model generation- performance problem? [message #99524 is a reply to message #99509] Wed, 17 October 2007 10:54 Go to previous messageGo to next message
David,
If you open the .genmodel and look at the properties for the GenModel
(root object in the Generator), what is the "Compliance Level" property
set to? I would expect 5.0 but suspect it's 1.4 instead...
david wrote:
> Ed,
> for EMF, change it to match your method below and compile? I looked
> for a bug like this in the bug list but could not find it.
> Thx.
> David
> Ed Merks wrote:
>> David,
>> set to 1.4), but are compiling with Java 5.0 source compatibility.
>> You'll need to change them to match. I would generally expect this
>> code in ModelImporter.java to ensure that the new GenModel's
>> Compliance Level matches your preferences:
>> String modelName =
>> if (index != -1)
>>> that worked. Now I have 142 of this type of error one per java file.
>>> 1192626673906 36704
>>> Thx.
>>> David
>>> Ed Merks wrote:
>>>> David,
>>>> if you make changes to the model 150092
>>>> I'm slightly confused though, if there is an
>>>> there isn't really an org.mddl.mddl._3 package nor an
>>>> org.mddl.mddl._3.util package also containing classes? I would
>>>> expect the former to contain all the interfaces and the later to
>>>> contain things like the XyzSwitch for the model...
>>>> david wrote:
>>>>> Hi,
>>>>> Creation Time Id
>>>>> element '_3' not sure this has anything to do with this problem,
>>>>> but it may. It does not show an error on the Export Package of
>>>>> Thx.
>>>>> David
>>>>> Ed Merks wrote:
>>>>>> David,
>>>>>> use "Create XML Schema to Ecore map" for anything but a toy
>>>>>> schema example. I know that this feature has some very bad
>>>>>> combinatorial behavior so I suggest you avoid using it. The
>>>>>> generation process doesn't rely on it and should proceed a 1000
>>>>>> david wrote:
>>>>>>> Hi,
>>>>>>> am using a large XSD, 1.5MB in size. This is on a dual core 2GHz
>>>>>>> of 1 core now for 16 hours. This is after checking the "Create
>>>>>>> XML Schema to ECore map" checkbox and clicking Finish button. I
>>>>>>> am also running it on a separate desktop with dual Opterons, 4GB
>>>>>>> RAM and RAID5, it cannot even redraw the Eclipse UI, with one
>>>>>>> cpu at 100%.
>>>>>>> Thanks,
>>>>>>> David
Re: EMF model generation- performance problem? [message #99605 is a reply to message #99450] Thu, 18 October 2007 03:47 Go to previous messageGo to next message
Ed,
I tried this again on my laptop, which is jre 6. I had progressed
further using my workstation which is jre 5. It too did not generate the
org.mddl.mddl._3 package nor an org.mddl.mddl._3.util package, even when
I generated model first (which is the one where these ecore artifacts
should be generated). I have not been able to determine what it is that
is causing this.
David
Ed Merks wrote:
> David,
> model...
> david wrote:
>> Hi,
>> Time Id
>> Thx.
>> David
>> Ed Merks wrote:
>>> David,
>>> david wrote:
>>>> Hi,
>>>> Thanks,
>>>> David
Re: EMF model generation- performance problem? [message #99615 is a reply to message #99524] Thu, 18 October 2007 04:39 Go to previous messageGo to next message
Ed,
Almost there now. I changed the compliance to 5.0 and generated each in
turn. It only has 6 errors now in the generated code for the Impl.
The import org.mddl.mddl._3.Notification collides with another import
statement MDDL_3b/src/org/mddl/mddl/_3/impl CallableImpl.java line 41
1192637021609 64936
statement MDDL_3b/src/org/mddl/mddl/_3/impl PutableImpl.java line 35
1192637040562 64938
statement MDDL_3b/src/org/mddl/mddl/_3/impl SinkableImpl.java line 33
1192637044609 64940
The return type is incompatible with Callable.getNotification()
MDDL_3b/src/org/mddl/mddl/_3/impl CallableImpl.java line 395
1192637021609 64937
The return type is incompatible with Putable.getNotification()
MDDL_3b/src/org/mddl/mddl/_3/impl PutableImpl.java line 347
1192637040562 64939
The return type is incompatible with Sinkable.getNotification()
MDDL_3b/src/org/mddl/mddl/_3/impl SinkableImpl.java line 325
1192637044609 64941
Here is an abridged version of the smallest of these as generated.
* <copyright>
* </copyright>
* $Id$
package org.mddl.mddl._3.impl;
import java.util.Collection;
import org.eclipse.emf.common.notify.Notification;
import org.eclipse.emf.common.notify.NotificationChain;
import org.eclipse.emf.common.util.EList;
import org.eclipse.emf.ecore.EClass;
import org.eclipse.emf.ecore.InternalEObject;
import org.eclipse.emf.ecore.impl.ENotificationImpl;
import org.eclipse.emf.ecore.impl.EObjectImpl;
import org.eclipse.emf.ecore.util.BasicFeatureMap;
import org.eclipse.emf.ecore.util.FeatureMap;
import org.eclipse.emf.ecore.util.InternalEList;
import org.mddl.mddl._3.ExerciseRights;
import org.mddl.mddl._3.FirstAmount;
import org.mddl.mddl._3.FirstDate;
import org.mddl.mddl._3.LastAmount;
import org.mddl.mddl._3.LastDate;
import org.mddl.mddl._3.Limited;
import org.mddl.mddl._3.NextAmount;
import org.mddl.mddl._3.NextDate;
import org.mddl.mddl._3.NextPeriod;
import org.mddl.mddl._3.Notification;
import org.mddl.mddl._3.OtherType;
import org.mddl.mddl._3.PenultimateAmount;
import org.mddl.mddl._3.PenultimateDate;
import org.mddl.mddl._3.Period;
import org.mddl.mddl._3.PutConditionType;
import org.mddl.mddl._3.Putable;
import org.mddl.mddl._3.PutableGroup;
import org.mddl.mddl._3.PutableType;
import org.mddl.mddl._3.QualityEnumeration;
import org.mddl.mddl._3.Schedule;
import org.mddl.mddl._3.Sequence;
import org.mddl.mddl._3.Source;
import org.mddl.mddl._3.WhenType;
import org.mddl.mddl._3.v_3Package;
import org.mddl.mddl._3._3Package;
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @generated
public EList<Notification> getNotification() {
return
getPutableChildren().list(v_3Package.eINSTANCE.getPutable_No tification());
And the Interface generated
* Returns the value of the '<em><b>Notification</b></em>' containment
reference list.
* The list contents are of type {@link org.mddl.mddl._3.Notification}.
* <p>
* If the meaning of the '<em>Notification</em>' containment reference
list isn't clear,
* there really should be more of a description here...
* </p>
* @return the value of the '<em>Notification</em>' containment
reference list.
* @see org.mddl.mddl._3.v_3Package#getPutable_Notification()
* @model containment="true" transient="true" volatile="true"
derived="true"
* extendedMetaData="kind='element' name='notification'
namespace='##targetNamespace' group='#PutableChildren:3'"
* @generated
EList<Notification> getNotification();
I can manually fix these but that does not seem the point, given they
are generated.
A quick question, I do not like the XSD element named '_3' and would
like to override the elements name for my model without changing the
standards based xsd that it is generated from, is there a way of doing
this? I suspect I need to have my own version of the XSD, but thought it
worth enquiring.
thx.
David
Ed Merks wrote:
> David,
> david wrote:
>> Ed,
>> Thx.
>> David
>> Ed Merks wrote:
>>> David,
>>> String modelName =
>>> if (index != -1)
>>>> 1192626673906 36704
>>>> Thx.
>>>> David
>>>> Ed Merks wrote:
>>>>> David,
>>>>> david wrote:
>>>>>> Hi,
>>>>>> Creation Time Id
>>>>>> Thx.
>>>>>> David
>>>>>> Ed Merks wrote:
>>>>>>> David,
>>>>>>> david wrote:
>>>>>>>> Hi,
>>>>>>>> cpu at 100%.
>>>>>>>> Thanks,
>>>>>>>> David
Re: EMF model generation- performance problem? [message #99625 is a reply to message #99615] Thu, 18 October 2007 07:55 Go to previous messageGo to next message
David,
The import manager should normally avoid generating colliding imports,
but it's not smart enough to know what imports are in the target file
that might collide with the imports it will generate. So likely
deleting these files (or just deleting both colliding imports) and
regenerating them will avoid the problem. (I.e., I think you have this
problem purely because you moved form Java 1.4 to Java 5.0 which has
more explicit use of types in things like List<Notification> than does
Java 1.4.)
david wrote:
> Ed,
> in turn. It only has 6 errors now in the generated code for the Impl.
> Time Id
> line 41 1192637021609 64936
> line 35 1192637040562 64938
> line 33 1192637044609 64940
> 1192637021609 64937
> 1192637040562 64939
> 1192637044609 64941
> * <copyright>
> * </copyright>
> * $Id$
> * @generated
> return
> containment reference list.
> * <p>
> reference list isn't clear,
> * </p>
> reference list.
> derived="true"
> * @generated
> are generated.
> it worth enquiring.
> thx.
> David
> Ed Merks wrote:
>> David,
>> property set to? I would expect 5.0 but suspect it's 1.4 instead...
>> david wrote:
>>> Ed,
>>> and Java 5. So I am not sure how I could be targeting EMF 2.2 and
>>> Java 1.4 since I made no choice, simply followed the library
>>> tutorial. I went through the project properties and could find
>>> nothing pertaining to which EMF version is to be targeted. Am I
>>> to, it is in the emf package. Is your suggestion to download the
>>> source for EMF, change it to match your method below and compile? I
>>> looked for a bug like this in the bug list but could not find it.
>>> Thx.
>>> David
>>> Ed Merks wrote:
>>>> David,
>>>> code that targets EMF 2.2/Java 1.4 (GenModel's Compliance Level
>>>> property set to 1.4), but are compiling with Java 5.0 source
>>>> compatibility. You'll need to change them to match. I would
>>>> generally expect this code in ModelImporter.java to ensure that the
>>>> new GenModel's Compliance Level matches your preferences:
>>>> String modelName =
>>>> if (index != -1)
>>>>> 1192626673906 36704
>>>>> it was in the context of OHF, with which I am unfamiliar.
>>>>> Thx.
>>>>> David
>>>>> Ed Merks wrote:
>>>>>> David,
>>>>>> merge if you make changes to the model 150092
>>>>>> problem. I'm slightly confused though, if there is an
>>>>>> david wrote:
>>>>>>> Hi,
>>>>>>> example but using a much larger xsd. I get further but an error.
>>>>>>> Creation Time Id
>>>>>>> 'Generate All'. Unfortunately the xsd has a rather unfortunately
>>>>>>> named element '_3' not sure this has anything to do with this
>>>>>>> problem, but it may. It does not show an error on the Export
>>>>>>> Package of org.mddl.mddl._3.impl though. There are 603 elements
>>>>>>> in this model.
>>>>>>> Thx.
>>>>>>> David
>>>>>>> Ed Merks wrote:
>>>>>>>> David,
>>>>>>>> david wrote:
>>>>>>>>> Hi,
>>>>>>>>> model using XML Schema (XSD)". But instead of using the
>>>>>>>>> library.xsd I am using a large XSD, 1.5MB in size. This is on
>>>>>>>>> a dual core 2GHz laptop with 2GB of RAM. I have allowed
>>>>>>>>> Eclipse 750MB of working memory (-Xmx) and it is using all of
>>>>>>>>> it, it has been using 100% of 1 core now for 16 hours. This is
>>>>>>>>> desktop with dual Opterons, 4GB RAM and RAID5, it cannot even
>>>>>>>>> Thanks,
>>>>>>>>> David
Re: EMF model generation- performance problem? [message #99635 is a reply to message #99605] Thu, 18 October 2007 07:58 Go to previous messageGo to next message
--------------080304010801010204020200
David,
That's very wierd. Your namespaces are kind of horrible though, so
maybe you want to use an ecore:package annotation to specify a decent one.
XML Schema to Ecore Mapping
< http://www.eclipse.org/modeling/emf/docs/overviews/XMLSchema ToEcoreMapping.pdf>
If the problem persists you could send me your schema and I'll try to
reproduce the problem. You can send it to merks at ca dot ibm dot com
if you don't want to post it to the newsgroup for all to see...
david wrote:
> Ed,
> the org.mddl.mddl._3 package nor an org.mddl.mddl._3.util package,
> even when I generated model first (which is the one where these ecore
> artifacts should be generated). I have not been able to determine what
> it is that is causing this.
> David
> Ed Merks wrote:
>> David,
>> model...
>> david wrote:
>>> Hi,
>>> Time Id
>>> Thx.
>>> David
>>> Ed Merks wrote:
>>>> David,
>>>> david wrote:
>>>>> Hi,
>>>>> 100%.
>>>>> Thanks,
>>>>> David
<html>
<head>
</head>
David,<br>
<br>
That's very wierd.&nbsp; Your namespaces are kind of horrible though, so
one.<br>
<blockquote><a
href=" http://www.eclipse.org/modeling/emf/docs/overviews/XMLSchema ToEcoreMapping.pdf">XML
Schema to Ecore Mapping</a><br>
</blockquote>
reproduce the problem.&nbsp; You can send it to merks at ca dot ibm dot com
if you don't want to post it to the newsgroup for all to see...<br>
<br>
<br>
david wrote:
<blockquote cite="mid:ff730k$gkp$1@build.eclipse.org" type="cite">Ed,
<br>
<br>
the org.mddl.mddl._3 package nor an org.mddl.mddl._3.util package, even
<br>
<br>
David
<br>
<br>
Ed Merks wrote:
<br>
<br>
<br>
for the model...
<br>
<br>
<br>
david wrote:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Thx.
<br>
<br>
David
<br>
<br>
Ed Merks wrote:
<br>
<br>
<br>
<br>
<br>
<br>
david wrote:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
David
<br>
</blockquote>
</blockquote>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------080304010801010204020200--
Re: EMF model generation- performance problem? [message #100550 is a reply to message #99635] Fri, 02 November 2007 12:10 Go to previous message
Ed,
Switched to JRE 5 on the laptop, and it fixed the problem, so JRE 6 was
the problem, preventing the generation of the . I also had to Suppress
Interfaces,as the String exceeded the limit. But it worked!
David
Ed Merks wrote:
> David,
> david wrote:
>> Ed,
>> David
>> Ed Merks wrote:
>>> David,
>>> model...
>>> david wrote:
>>>> Hi,
>>>> Time Id
>>>> Thx.
>>>> David
>>>> Ed Merks wrote:
>>>>> David,
>>>>> david wrote:
>>>>>> Hi,
>>>>>> 100%.
>>>>>> Thanks,
>>>>>> David
Re: EMF model generation- performance problem? [message #610019 is a reply to message #99212] Tue, 16 October 2007 07:51 Go to previous message
David,
david wrote:
> David
Re: EMF model generation- performance problem? [message #610047 is a reply to message #99230] Wed, 17 October 2007 09:04 Go to previous message
Thx.
David
Ed Merks wrote:
> David,
> david wrote:
>> Hi,
>> Thanks,
>> David
Re: EMF model generation- performance problem? [message #610049 is a reply to message #99424] Wed, 17 October 2007 09:46 Go to previous message
David,
model...
david wrote:
> Time Id
> Thx.
> David
> Ed Merks wrote:
>> David,
>> david wrote:
>>> Hi,
>>> Thanks,
>>> David
<html>
<head>
</head>
David,<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Thx.
<br>
<br>
David
<br>
<br>
Ed Merks wrote:
<br>
<br>
<br>
<br>
<br>
<br>
david wrote:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
David
<br>
</blockquote>
</blockquote>
</blockquote>
<br>
</body>
</html>
Re: EMF model generation- performance problem? [message #610052 is a reply to message #99450] Wed, 17 October 2007 10:11 Go to previous message
1192626673906 36704
Thx.
David
Ed Merks wrote:
> David,
> model...
> david wrote:
>> Hi,
>> Time Id
>> Thx.
>> David
>> Ed Merks wrote:
>>> David,
>>> david wrote:
>>>> Hi,
>>>> Thanks,
>>>> David
Re: EMF model generation- performance problem? [message #610055 is a reply to message #99479] Wed, 17 October 2007 10:25 Go to previous message
David,
String modelName =
if (index != -1)
> 1192626673906 36704
> Thx.
> David
> Ed Merks wrote:
>> David,
>> model...
>> david wrote:
>>> Hi,
>>> Time Id
>>> Thx.
>>> David
>>> Ed Merks wrote:
>>>> David,
>>>> david wrote:
>>>>> Hi,
>>>>> 100%.
>>>>> Thanks,
>>>>> David
<html>
<head>
</head>
David,<br>
<br>
<br>
</blockquote>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Thx.
<br>
<br>
David
<br>
<br>
<br>
Ed Merks wrote:
<br>
<br>
<br>
for the model...
<br>
<br>
<br>
david wrote:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Thx.
<br>
<br>
David
<br>
<br>
Ed Merks wrote:
<br>
<br>
<br>
<br>
<br>
<br>
david wrote:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
David
<br>
</blockquote>
</blockquote>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
Re: EMF model generation- performance problem? [message #610057 is a reply to message #99495] Wed, 17 October 2007 10:47 Go to previous message
Ed,
Thx.
David
Ed Merks wrote:
> David,
> String modelName =
> if (index != -1)
>> 1192626673906 36704
>> Thx.
>> David
>> Ed Merks wrote:
>>> David,
>>> model...
>>> david wrote:
>>>> Hi,
>>>> Time Id
>>>> Thx.
>>>> David
>>>> Ed Merks wrote:
>>>>> David,
>>>>> david wrote:
>>>>>> Hi,
>>>>>> 100%.
>>>>>> Thanks,
>>>>>> David
Re: EMF model generation- performance problem? [message #610059 is a reply to message #99509] Wed, 17 October 2007 10:54 Go to previous message
David,
david wrote:
> Ed,
> Thx.
> David
> Ed Merks wrote:
>> David,
>> String modelName =
>> if (index != -1)
>>> 1192626673906 36704
>>> Thx.
>>> David
>>> Ed Merks wrote:
>>>> David,
>>>> david wrote:
>>>>> Hi,
>>>>> Creation Time Id
>>>>> Thx.
>>>>> David
>>>>> Ed Merks wrote:
>>>>>> David,
>>>>>> david wrote:
>>>>>>> Hi,
>>>>>>> cpu at 100%.
>>>>>>> Thanks,
>>>>>>> David
Re: EMF model generation- performance problem? [message #610070 is a reply to message #99450] Thu, 18 October 2007 03:47 Go to previous message
Ed,
is causing this.
David
Ed Merks wrote:
> David,
> model...
> david wrote:
>> Hi,
>> Time Id
>> Thx.
>> David
>> Ed Merks wrote:
>>> David,
>>> david wrote:
>>>> Hi,
>>>> Thanks,
>>>> David
Re: EMF model generation- performance problem? [message #610072 is a reply to message #99524] Thu, 18 October 2007 04:39 Go to previous message
Ed,
1192637021609 64936
1192637040562 64938
1192637044609 64940
1192637021609 64937
1192637040562 64939
1192637044609 64941
* <copyright>
* </copyright>
* $Id$
* @generated
return
reference list.
* <p>
list isn't clear,
* </p>
reference list.
derived="true"
* @generated
are generated.
worth enquiring.
thx.
David
Ed Merks wrote:
> David,
> david wrote:
>> Ed,
>> Thx.
>> David
>> Ed Merks wrote:
>>> David,
>>> String modelName =
>>> if (index != -1)
>>>> 1192626673906 36704
>>>> Thx.
>>>> David
>>>> Ed Merks wrote:
>>>>> David,
>>>>> david wrote:
>>>>>> Hi,
>>>>>> Creation Time Id
>>>>>> Thx.
>>>>>> David
>>>>>> Ed Merks wrote:
>>>>>>> David,
>>>>>>> david wrote:
>>>>>>>> Hi,
>>>>>>>> cpu at 100%.
>>>>>>>> Thanks,
>>>>>>>> David
Re: EMF model generation- performance problem? [message #610074 is a reply to message #99615] Thu, 18 October 2007 07:55 Go to previous message
David,
Java 1.4.)
david wrote:
> Ed,
> Time Id
> 1192637021609 64937
> 1192637040562 64939
> 1192637044609 64941
> * <copyright>
> * </copyright>
> * $Id$
> * @generated
> return
> * <p>
> * </p>
> reference list.
> derived="true"
> * @generated
> are generated.
> it worth enquiring.
> thx.
> David
> Ed Merks wrote:
>> David,
>> david wrote:
>>> Ed,
>>> Thx.
>>> David
>>> Ed Merks wrote:
>>>> David,
>>>> String modelName =
>>>> if (index != -1)
>>>>> 1192626673906 36704
>>>>> Thx.
>>>>> David
>>>>> Ed Merks wrote:
>>>>>> David,
>>>>>> david wrote:
>>>>>>> Hi,
>>>>>>> Creation Time Id
>>>>>>> in this model.
>>>>>>> Thx.
>>>>>>> David
>>>>>>> Ed Merks wrote:
>>>>>>>> David,
>>>>>>>> david wrote:
>>>>>>>>> Hi,
>>>>>>>>> Thanks,
>>>>>>>>> David
Re: EMF model generation- performance problem? [message #610076 is a reply to message #99605] Thu, 18 October 2007 07:58 Go to previous message
David,
david wrote:
> Ed,
> David
> Ed Merks wrote:
>> David,
>> model...
>> david wrote:
>>> Hi,
>>> Time Id
>>> Thx.
>>> David
>>> Ed Merks wrote:
>>>> David,
>>>> david wrote:
>>>>> Hi,
>>>>> 100%.
>>>>> Thanks,
>>>>> David
<html>
<head>
</head>
David,<br>
<br>
one.<br>
<blockquote><a
</blockquote>
<br>
<br>
<br>
<br>
<br>
<br>
David
<br>
<br>
Ed Merks wrote:
<br>
<br>
<br>
for the model...
<br>
<br>
<br>
david wrote:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Thx.
<br>
<br>
David
<br>
<br>
Ed Merks wrote:
<br>
<br>
<br>
<br>
<br>
<br>
david wrote:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
David
<br>
</blockquote>
</blockquote>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
Re: EMF model generation- performance problem? [message #610198 is a reply to message #99635] Fri, 02 November 2007 12:10 Go to previous message
Ed,
David
Ed Merks wrote:
> David,
> david wrote:
>> Ed,
>> David
>> Ed Merks wrote:
>>> David,
>>> model...
>>> david wrote:
>>>> Hi,
>>>> Time Id
>>>> Thx.
>>>> David
>>>> Ed Merks wrote:
>>>>> David,
>>>>> david wrote:
>>>>>> Hi,
>>>>>> 100%.
>>>>>> Thanks,
>>>>>> David
Previous Topic:[CDO] New Model Migrator Utility
Next Topic:[Workflow Engine] Chain DSL for the end-user
Current Time: Fri Nov 07 16:03:45 EST 2025
Powered by FUDForum. Page generated in 0.07625 seconds
