Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Search] A few questions
[Search] A few questions [message #97227] |
Mon, 24 September 2007 17:11  |
Hi lb,
Nice work on the new search component, it is a very important addition to
the MDT tools. I am creating modeling tools for HL7 healthcare standards
and the addition of search will help to attract more users. But I do have a
few questions based on my initial review. Looking at your New and Noteworthy
page (http://www.eclipse.org/modeling/emft/?project=search), there are two
features that I cannot get to work.
* How do you invoke the EReferences to an EClass? It looks like this
context menu is in an editor. What is the selection object that adds this
menu? I would like to add it to the contetext menu in the UML2Tools class
diagram.
* I can open the EClass filtered selection dialog using Ctrl+Shift+K (found
in the plugin declaration), but the dialog is always empty. I am looking at
the dialog code but have not yet discovered what resource(s) are used to
populate the dialog list.
This last questions raises a big issue I have with the UML2Tools and use of
a shared Editing Domain. For the selection dialog (and maybe search on a
model), I would like to use an existing resource set, and not reload the
resources each time I open the dialog.
Thanks!
Dave Carlson
www.xmlmodeling.com
Re: [Search] A few questions [message #97307 is a reply to message #97227] |
Tue, 25 September 2007 05:13   |
Originally posted by: lucas.bigeardel.anyware-tech.com
Dave Carlson a écrit :
Hi Dave, my answers below
> Hi lb,
thank you !
But I do have a
> diagram.
Finding references needs user to define EReference to an already defined
type in an ecore model.
For instance, having an XYZ.ecore file defining two types 'A' & 'B' with
'B' having an EReference 'BtoA', allows you to right click the
EReferences menu action from the legacy ecore editor with the 'A' Eclass
as selection.
As a result user gets the Search View populated with 'BtoA' occurence
coming from XYZ.ecore.
Having such feature on UML2Tools GMF based diagram editor needs
developer contribuing an
org.eclipse.gmf.runtime.common.ui.services.action.contributi onItemProviders
extension point.
Can be something like :
<extension
point=" org.eclipse.gmf.runtime.common.ui.services.action.contributi onItemProviders ">
<contributionItemProvider
checkPluginLoaded="false"
class=" org.eclipse.uml2.diagram.search.providers.UML2DiagramSearchC ontributionItemProvider ">
<Priority
name="Medium">
</Priority>
<popupContribution
class=" org.eclipse.gmf.runtime.diagram.ui.providers.DiagramContextM enuProvider ">
<popupStructuredContributionCriteria
objectClass="*[[[YOUR_GENERATED_UML_Class_EditPart]]]*"/>
<popupMenuGroup
id="UML2Search"
path="/"
separator="true">
</popupMenuGroup>
<popupAction path="/UML2Search" id="ereferencesAction"/>
</popupContribution>
</contributionItemProvider>
</extension>
Thus, you need to implement AbstractContributionItemProvider and
implement createAction method handling a UML implementation version of
AbstractModelSearchPopupActionDelegate inspired from the Ecore
"ModelSearchEcoreMetaElementReferenceSearchAction" action applying on
UML Class.
Note that this action extends AbstractModelSearchPopupActionDelegate and
automatically handles the selection for both legacy editors and GMF
based editors. (same action can be reused for org.eclpse.ui.popupMenus
contributions).
It sounds like a bug, I did some changes related to CamelCase support
few days ago and maybe I broke something. This point the fact it is
maybe time to add some more tests ^^ I'll take a look at that today.
To be honnest I didn't really take that into account, give some time to
dig into that.
> Thanks!
> Dave Carlson
> www.xmlmodeling.com
Re: [Search] A few questions [message #97322 is a reply to message #97307] |
Tue, 25 September 2007 05:59   |
>> Hi lb,
>> to the MDT tools. I am creating modeling tools for HL7 healthcare
>> standards and the addition of search will help to attract more users.
> thank you !
> But I do have a
>> Noteworthy page
>> this menu? I would like to add it to the contetext menu in the
>> UML2Tools class diagram.
> as selection.
> extension point.
> <extension
> <Priority
> name="Medium">
> </Priority>
> <popupContribution
> <popupMenuGroup
> id="UML2Search"
> path="/"
> separator="true">
> </popupMenuGroup>
> </extension>
> UML Class.
> contributions).
>> (found in the plugin declaration), but the dialog is always empty. I
>> am looking at the dialog code but have not yet discovered what
>> resource(s) are used to populate the dialog list.
Ctrl + Shift + K works for me with UML Package having non empty names.
Some condition have to be met :
1) create a UML diagram like XYZ.uml
2) have a package with non empty name
3) In filtered Dialog : you must type a non void valid Camel Case
pattern before actually having results
>> use of a shared Editing Domain. For the selection dialog (and maybe
>> search on a model), I would like to use an existing resource set, and
>> not reload the resources each time I open the dialog.
> dig into that.
>> Thanks!
>> Dave Carlson
>> www.xmlmodeling.com
Re: [Search] A few questions [message #97448 is a reply to message #97307] |
Tue, 25 September 2007 12:58  |
Hi Lucus,
> Having such feature on UML2Tools GMF based diagram editor needs developer
> contribuing an
> extension point.
OK, thanks, I'll look into contributing a new plugin for search, e.g.
org.eclipse.uml2.diagram.search.ui
To clarify this last item, the issue I have with UML2Tools is that they do
NOT use a shared editing domain, and I have modified the class diagram to
use a shared editing domain with a navigator. See:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=189974
>> of a shared Editing Domain. For the selection dialog (and maybe search
>> on a model), I would like to use an existing resource set, and not reload
> dig into that.
Re: [Search] A few questions [message #609804 is a reply to message #97227] |
> Hi lb,
thank you !
But I do have a
> diagram.
as selection.
extension point.
<extension
<Priority
name="Medium">
</Priority>
<popupContribution
<popupMenuGroup
id="UML2Search"
path="/"
separator="true">
</popupMenuGroup>
</extension>
UML Class.
contributions).
dig into that.
> Thanks!
> Dave Carlson
> www.xmlmodeling.com
Re: [Search] A few questions [message #609805 is a reply to message #97307] |
>> Hi lb,
> thank you !
> But I do have a
>> Noteworthy page
> as selection.
> extension point.
> <extension
> <Priority
> name="Medium">
> </Priority>
> <popupContribution
> <popupMenuGroup
> id="UML2Search"
> path="/"
> separator="true">
> </popupMenuGroup>
> </extension>
> UML Class.
> contributions).
> dig into that.
>> Thanks!
>> Dave Carlson
>> www.xmlmodeling.com
Re: [Search] A few questions [message #609812 is a reply to message #97322] |
Tue, 25 September 2007 12:45  |
Hi Lucus,
I still don't get results from this. I have a model FpML.uml with about 20
nested packages (all with non-null names). I open the dialog and enter
"Party*" which should find 10 matches to contained classes (these are found
using search). But the dialog is still empty. Does this always search all
..uml resources in the workspace? I tried selecting the desired .uml file
before opening the dialog, but no different. Does it search nested packages
in a model?
Dave
> 3) In filtered Dialog : you must type a non void valid Camel Case pattern
Re: [Search] A few questions [message #609813 is a reply to message #97422] |
Tue, 25 September 2007 12:51  |
> Hi Lucus,
> in a model?
> Dave
Dave,
Can you send me the model, I'll try to take a look.
If you think something really doesn't go the way it should, please file
a bugzilla against [EMFT Search].
regards,
- Lucas
Re: [Search] A few questions [message #609814 is a reply to message #97307] |
Hi Lucus,
> contribuing an
> extension point.
> dig into that.
Current Time: Wed Oct 15 07:35:31 EDT 2025
Powered by FUDForum. Page generated in 0.04900 seconds
