[CDO][0.8.0] Streaming [message #96300] |
Fri, 07 September 2007 10:45  |
Do you think we could stream the data. ?
Use case:
One of my attribute is Binary. I don't want to serialize it it all... it
will take too much time. I want to read it as it stream.(The file could be 1
gigs... 200 megs.. what whatever)
I want to stream it so the consumer can read it as its stream....
We could possibly send a CDOBinary.. and once the user read it.. open a
stream between the server and the client.
I don't think it should be very complicated.. isn't ?
Re: [CDO][0.8.0] Streaming [message #96393 is a reply to message #96333] |
Mon, 10 September 2007 04:32  |
Originally posted by: stepper.sympedia.de
--------------010800060502030909070502
Simon,
If the data is "attached" to the model (at client side) through the use
of an EDataType it gets serialized to a String. Your (generated)
EPackage has control over the exact format. Although this might not be
the perfect way to handle huge amounts of binary data I don't see an
alternative if you insist on accessing it by EMF means.
Of course you could use plain Net4j to develop an own protocol that
optimizes the handling of huge data blocks / streams. But how would that
be connected to EMF / Ecore?
Cheers
/Eike
Simon McDuff schrieb:
> "Eike Stepper" <stepper@sympedia.de> wrote in message
> news:fbrpmr$jr7$1@build.eclipse.org...
>>> Use case:
>>> be 1 gigs... 200 megs.. what whatever)
>> Hmm, I don't have a clue what exactly you mean.
>> By "binary attribute" do you mean an EAttribute with an own EDataType?
>> How is a file related to this?
>> I fear you'll have to explain it in more detail.
>> Cheers
>> /Eike
> Let say we have binary data that is really big on the server. (1 gigs of
> data.. could be a file, or anything else...)
> This binary is attached to the model somehow. (Could be
> EcorePackage.Literals.EBYTE_ARRAY or Base64.)
> How will you make it available to the consumer ?
> The efficient way will be to stream the data...
> What we need to do to achieve that ?
<html>
<head>
http-equiv="Content-Type">
</head>
Simon,<br>
<br>
alternative if you insist on accessing it by EMF means.<br>
<br>
that be connected to EMF / Ecore?<br>
<br>
Cheers<br>
/Eike<br>
<br>
<br>
<blockquote cite="mid:fbrrur$h1f$1@build.eclipse.org" type="cite">
<pre wrap="">"Eike Stepper" <a class="moz-txt-link-rfc2396E" href="mailto:stepper@sympedia.de"><stepper@sympedia.de></a> wrote in message
<a class="moz-txt-link-freetext" href="news:fbrpmr$jr7$1@build.eclipse.org">news:fbrpmr$jr7$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Simon McDuff schrieb:
</pre>
<pre wrap="">Do you think we could stream the data. ?
Use case:
</pre>
</blockquote>
<pre wrap="">Hmm, I don't have a clue what exactly you mean.
Cheers
/Eike
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
</body>
</html>
--------------010800060502030909070502--
Re: [CDO][0.8.0] Streaming [message #609670 is a reply to message #96300] |
Fri, 07 September 2007 11:11  |
> Use case:
Cheers
/Eike
Re: [CDO][0.8.0] Streaming [message #609672 is a reply to message #96318] |
Fri, 07 September 2007 11:49  |
>> Use case:
> Cheers
> /Eike
Re: [CDO][0.8.0] Streaming [message #609683 is a reply to message #96333] |
Simon,
Cheers
/Eike
>>> Use case:
>> Cheers
>> /Eike
<html>
<head>
</head>
Simon,<br>
<br>
<br>
<br>
Cheers<br>
/Eike<br>
<br>
<br>
</pre>
</pre>
Use case:
</pre>
</blockquote>
Cheers
/Eike
</pre>
</blockquote>
</pre>
</blockquote>
</body>
</html>
FUDForum. Page generated in 0.10537 seconds
