Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Re: Web-Frontend for EMF models
Re: Web-Frontend for EMF models [message #95813] Tue, 04 September 2007 03:25 Go to next message
I added the eclipse.technology.emft group to the "to" list because
I found a message form Martin Taal that seems related to the topic:
http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg1 9765.html
@Martin Taal: Did you make any progess in the system mentioned
in that message?
> There's a student working for IBM Canada's Center for Advanced Studies who
> will be investigating WSDL -> Ecore and Ecore -> WSDL mapping analogous to
> what we have for XSD. I expect he'll submit a new component proposal in
> EMFT soon.
That really sounds promising. I don't know much about Eclipse/EMF
development procedures. Does component proposal mean there will
be a EMFT subproject soon?
In what timeframe one could expect first "public beta" code?
> I'm really not sure what's all needed for a web front end, but given that
> it's possible to model an EOperation and to specify its method body,
I don't understand this ... can you give me a link to where this is
explained in more detail?
Is this described somewhere in the EMF book? Are you talking
about specifying the method body with Java?
> I would imagine one could generate pretty much any API. What kinds of
> things do you need for a web front end?
I was thinking about an AJAX framework similar to the EMF.edit and
EMF.editor code.
The HTML and JavaScript code for the client side, the code that
does the communication between the user and the server and updates
the model on the server according to user input and persists the model
(using Hibernat/Teneo) could be generated from an EMF model
(at least parts of it).
Does this make sense? Anybody with expierience in building a
web application using EMF?
Reinhold
> Reinhold Bihler wrote:
>> Hello,
>> the EMF supports the generation of Java based frontends. Is there
>> similar support for web-frontends?
>> What would be your approach to create a web-frontend for an existing
>> EMF model?
>> Regards,
>> Reinhold
Re: Web-Frontend for EMF models [message #95844 is a reply to message #95813] Tue, 04 September 2007 08:34 Go to previous messageGo to next message
--------------090503020307010604050703
Reinhold,
Comments below.
> Hello,
> in that message?
>> EMFT soon.
Yes, that would me a "subproject" within EMFT but EMFT is a subproject
of the Modeling top-level project and the foundation doesn't recognized
subprojects within subprojects but rather refers to such things as
components, so I'm just trying to be precise. I do expect the proposal
to be submitted soon. I can't really say how quickly there will be
prototypes available. I don't drive the student's schedules...
We'll operations/EOperations are in the index, but method body
annotations weren't supported at the time the first edition was
written. He's an example from SDO.ecore:
<eClassifiers xsi:type="ecore:EClass" name="EDataObject"
eSuperTypes="../../org.eclipse.emf.ecore/model/Ecore.ecore#//EObject
#//DataObject">
<eOperations name="getInstanceProperties">
<eAnnotations source="http://www.eclipse.org/emf/2002/GenModel">
<details key="body" value="return
&lt;%org.eclipse.emf.ecore.sdo.util.SDOUtil%>.getInstanceProperties(this); "/>
</eAnnotations>
<eGenericType eClassifier="#//EJavaList">
<eTypeArguments eClassifier="#//Property"/>
</eGenericType>
</eOperations>
</eClassifiers>
So you can define an EAnnotation with the given source URI and with a
key called "body" that maps to a snip of Java code that will be
generated into the final result. Note that <%a.b.C%> will be fed to the
import manager during generation in order to produce either a.b.C or
just C along with "import a.b.C" if there are no import conflicts on C.
> EMF.editor code.
That would be really cool. I think the WSDL <-> Ecore mapping will
focus more on building a web service rather than looking at how to build
a model-backed GUI on a web page. I'd explored using Wicket last year,
but we just don't have the time or resource to do even a fraction of the
cool things I'd like to do. It would sure make a create project for
someone wanting to do that kind of work at Eclipse...
One of the big issues that I see is that there seems to be a new
"popular" framework for this type of thing (widget toolkit for web
applications) every other month, so it's tricky to know which one will
have lasting value. Does anyone have any strong arguments in favor of a
particular technology that's likely to have lasting value? The fact
that our industry produces so much software of a transient nature
because there is always something newer and cooler is, in my opinion,
what's also ensuring that most businesses question all invests in
software because such investments typically don't pay off when the
cycle of newness begins repeats after just a few year. Does anyone care
to argue that SOA is really a revolutionary (or even just evolutionary)
concept rather than a a large dose of hype that disguises
object-oriented programming with specialized service objects as a new
thing? (Today's a company holiday for us in Canada, so I'm feeling a
need for a little rant.)
> Regards,
> Reinhold
>>> Hello,
>>> EMF model?
>>> Regards,
>>> Reinhold
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Reinhold,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:fbj197$jf6$1@build.eclipse.org" type="cite">
<pre wrap="">Hello,
<a class="moz-txt-link-freetext" href=" http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg1 9765.html"> http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg1 9765.html</a>
in that message?
</pre>
<blockquote type="cite">
<pre wrap="">There's a student working for IBM Canada's Center for Advanced Studies who
will be investigating WSDL -&gt; Ecore and Ecore -&gt; WSDL mapping analogous to
EMFT soon.
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
components, so I'm just trying to be precise.&nbsp; I do expect the proposal
to be submitted soon.&nbsp; I can't really say how quickly there will be
prototypes available.&nbsp; I don't drive the student's schedules...<br>
<pre wrap="">
</pre>
<pre wrap=""> I'm really not sure what's all needed for a web front end, but given that
</pre>
</blockquote>
</pre>
</blockquote>
written.&nbsp; He's an example from SDO.ecore:<br>
<blockquote>&nbsp; &lt;eClassifiers xsi:type="ecore:EClass"
name="EDataObject"
#//DataObject"&gt;<br>
&nbsp;&nbsp;&nbsp; &lt;eOperations name="getInstanceProperties"&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;eAnnotations
source=<a class="moz-txt-link-rfc2396E" href="http://www.eclipse.org/emf/2002/GenModel">"http://www.eclipse.org/emf/2002/GenModel"</a>&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; &lt;details key="body" value="return
&amp;lt;%org.eclipse.emf.ecore.sdo.util.SDOUtil%&gt; .getInstanceProperties(this); "/&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;/eAnnotations&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;eGenericType eClassifier="#//EJavaList"&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; &lt;eTypeArguments eClassifier="#//Property"/&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;/eGenericType&gt;<br>
&nbsp;&nbsp;&nbsp; &lt;/eOperations&gt;<br>
&nbsp; &lt;/eClassifiers&gt;<br>
</blockquote>
generated into the final result.&nbsp; Note that &lt;%a.b.C%&gt; will be fed
to the import manager during generation in order to produce either
a.b.C or just C along with "import a.b.C" if there are no import
conflicts on C.<br>
<br>
<pre wrap="">
</pre>
<pre wrap="">I would imagine one could generate pretty much any API. What kinds of
</pre>
</blockquote>
EMF.editor code.
</pre>
</blockquote>
That would be really cool.&nbsp; I think the WSDL &lt;-&gt; Ecore mapping
will focus more on building a web service rather than looking at how to
build a model-backed GUI on a web page.&nbsp; I'd explored using Wicket last
year, but we just don't have the time or resource to do even a fraction
of the cool things I'd like to do.&nbsp; It would sure make a create project
for someone wanting to do that kind of work at Eclipse...<br>
<pre wrap="">
</pre>
</blockquote>
have lasting value.&nbsp; Does anyone have any strong arguments in favor of
a particular technology that's likely to have lasting value? &nbsp; The fact
software because such investments typically don't pay off&nbsp; when the
cycle of newness begins repeats after just a few year.&nbsp; Does anyone
care to argue that SOA is really a revolutionary (or even just
evolutionary) concept rather than a a large dose of hype that disguises
thing?&nbsp; (Today's a company holiday for us in Canada, so I'm feeling a
need for a little rant.)<br>
<pre wrap="">
Reinhold
</pre>
<pre wrap="">
</pre>
<pre wrap="">Hello,
EMF model?
Reinhold
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
--------------090503020307010604050703--
Re: Web-Frontend for EMF models [message #95887 is a reply to message #95844] Wed, 05 September 2007 12:31 Go to previous messageGo to next message
Hi Reinhold,
My progress has been slower than I would like. I have been working on a system which generates jsf
pages from an emf model. Although we had an initial prototype which worked fine, I was not satisfied
with some design choices so I am re-working it all from the ground up.
The idea is to take the emf model enrich it with ui-annotations (for example to direct how to
display an entity in a listbox) and then use this emf model with ui annotations to generate jsf
pages using a set of templates (I am using freemarker right now).
In addition I have implemented some extra code to make it possible to talk to the model directly
from the jsf page (for example to fill a listbox or set 'required' on a jsf component).
This (to-be-open-sourced) development is very much focused on administrative data (products, orders,
customers, etc.) and will not support choices or substitution groups found in xsd (or emf).
(mainly because I do not know any jsf component which supports these concepts).
Regarding your question about experience of using emf in a web environment. The past 1.5 years I
have been working on a larger project in which I use ecore/jsf/hibernate/teneo together. During the
development I have decided to implement my own code generation templates instead of using standard
emf templates. What I also used was the dynamic api (basically eGet and eSet on an eobject). Having
the ecore model available at runtime makes it possible to program (part of) the ui on model level.
The combination of java code generation, the dynamic api and using Teneo helped me to really speed
up development.
I noticed though that in a web environment many emf features are of less use (I did not use
resource, notifications or the edit/editor framework).
So, I also think that an emf-like approach can be very usefull in a web environment. As Ed noted the
issue with ui is which ui-technology (and ui-frameworks like Seam, Spring web flow, Wicket,....) to
choose from.
gr. Martin
btw, Ed I completely agree with your 'rant' :-)
Ed Merks wrote:
> Reinhold,
> Comments below.
>> Hello,
>> in that message?
>>> EMFT soon.
> #//DataObject">
> </eAnnotations>
> </eGenericType>
> </eOperations>
> </eClassifiers>
>> EMF.editor code.
>> Regards,
>> Reinhold
>>>> Hello,
>>>> EMF model?
>>>> Regards,
>>>> Reinhold
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Web-Frontend for EMF models [message #96878 is a reply to message #95813] Tue, 18 September 2007 01:41 Go to previous message
> EMF.editor code.
Eclipse RAP (Rich Ajax Platform) should be a nice fit.
Christoph
Re: Web-Frontend for EMF models [message #609640 is a reply to message #95813] Tue, 04 September 2007 08:34 Go to previous message
Reinhold,
Comments below.
> Hello,
> in that message?
>> EMFT soon.
#//DataObject">
</eAnnotations>
</eGenericType>
</eOperations>
</eClassifiers>
> EMF.editor code.
> Regards,
> Reinhold
>>> Hello,
>>> EMF model?
>>> Regards,
>>> Reinhold
<html>
<head>
</head>
Reinhold,<br>
<br>
Comments below.<br>
<br>
<pre wrap="">Hello,
in that message?
</pre>
EMFT soon.
</pre>
</blockquote>
</pre>
</blockquote>
<pre wrap="">
</pre>
</pre>
</blockquote>
</pre>
</blockquote>
name="EDataObject"
</blockquote>
conflicts on C.<br>
<br>
<pre wrap="">
</pre>
</pre>
</blockquote>
EMF.editor code.
</pre>
</blockquote>
<pre wrap="">
</pre>
</blockquote>
<pre wrap="">
Reinhold
</pre>
<pre wrap="">
</pre>
<pre wrap="">Hello,
EMF model?
Reinhold
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
Re: Web-Frontend for EMF models [message #609643 is a reply to message #95844] Wed, 05 September 2007 12:31 Go to previous message
Hi Reinhold,
up development.
choose from.
gr. Martin
Ed Merks wrote:
> Reinhold,
> Comments below.
>> Hello,
>> in that message?
>>> EMFT soon.
> #//DataObject">
> </eAnnotations>
> </eGenericType>
> </eOperations>
> </eClassifiers>
>> EMF.editor code.
>> Regards,
>> Reinhold
>>>> Hello,
>>>> EMF model?
>>>> Regards,
>>>> Reinhold
The Netherlands
Re: Web-Frontend for EMF models [message #609722 is a reply to message #95813] Tue, 18 September 2007 01:41 Go to previous message
> EMF.editor code.
Christoph
Previous Topic:[EMF Compare] Release Schedule of 0.8.0
Next Topic:[CDO] CDOAware not found
Current Time: Tue Sep 16 13:23:09 EDT 2025
Powered by FUDForum. Page generated in 0.05103 seconds
