Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [CDO][0.8.0] Thread Safe - hanging problems
[CDO][0.8.0] Thread Safe - hanging problems [message #94903] |
Wed, 29 August 2007 20:47  |
------=_NextPart_000_02A8_01C7EA7D.C40E1FA0
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
All the following operations are not thread safe.. Right?
CDORevisionResolverImpl
private Map<CDOID, TimeLine> revisions =3D new HashMap();
and=20
CDOViewImpl=20
private Map<CDOID, InternalCDOObject> objects =3D new HashMap();
Do you think it could be the problem of the hanging ?
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.6000.16525" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV><FONT face=3DArial size=3D2>All the following operations =
<FONT face=3DArial=20
size=3D2>are not thread safe.. Right?</FONT></FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>CDORevisionResolverImpl</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>private Map<CDOID, TimeLine> =
revisions =3D new=20
HashMap();</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>and </FONT></DIV>
<DIV><FONT face=3DArial size=3D2>CDOViewImpl </FONT></DIV>
<DIV><FONT face=3DArial size=3D2>private Map<CDOID, =
InternalCDOObject> objects=20
=3D new HashMap();</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Do you think it could be the problem of =
the hanging=20
?</FONT></DIV></BODY></HTML>
------=_NextPart_000_02A8_01C7EA7D.C40E1FA0--
Re: [CDO][0.8.0] Thread Safe - hanging problems [message #94979 is a reply to message #94920] |
Thu, 30 August 2007 07:57   |
--------------020604010706030100090106
Eike,
One example I often give when people ask about thread safety is to
consider the following code applied to a thread safe list.
int index = list.indexOf(x);
list.remove(index);
Even though the list might well be thread safe, this code isn't. So
generally, even if everything you use is thread safe, that doesn't mean
your higher level algorithms will be thread safe. Any code that changes
the state of a complex model will require higher level concurrency control.
I often tell people to consider as well what would happen if we put
synchronized on every method. Not only wouldn't that solve all life's
threading problems, it would in fact be more than likely to cause new
ones, i.e., deadlock.
So all that pontificating aside, EMF models are generally read-only
thread safe, but since demand loading of proxies effectively changes the
state of a model, even things you think involve read only access might
well do more. Ecore itself is designed to be read-only thread safe.
And of course the above aren't a reason to throw up your hands. There
are definitely places where you will need to ensure that something is
done safely because the method being called really is intended to
support more than one thread calling it at once.
Eike Stepper wrote:
> The operations (assignment of HashMap) are thread safe because they
> happen during construction time of their containing instance.
> I guess you mean that subsequent operations on the maps are not thread
> safe?
>> private Map<CDOID, TimeLine> revisions = new HashMap();
> First I thought this one is thread safe because it is protected by the
> internal semantics of ITransaction.
> A CDORevision itself is immutable once created so there's no danger.
> But now I'm not sure if it could come to problems due to the internal
> mechanics of HashMap.
> Maybe it'd be better to use a ConcurrentHashMap for
> CDORevisionResolverImpl.revisions and a ConcurrentLinkedQueue as super
> class of TimeLine.
>> CDOViewImpl
>> private Map<CDOID, InternalCDOObject> objects = new HashMap();
> A CDOView is not thread safe by definition.
> It shall only be used by a single thread because it contains a
> ResourceSet with Resources with EObjects and EObjects are not thread
> safe by default (Ed?).
> Even EModelElements are only read-only thread safe
> ( http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg2 6143.html).
> Basically I believe that the root cause is somewhere in Net4j rather
> than in CDO.
> I have more comments in
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=201366
> Cheers
> /Eike
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Eike,<br>
<br>
consider the following code applied to a thread safe list.<br>
<blockquote>int index = list.indexOf(x);<br>
list.remove(index);<br>
</blockquote>
changes the state of a complex model will require higher level
concurrency control.<br>
<br>
ones, i.e., deadlock.<br>
<br>
the state of a model, even things you think involve read only access
might well do more. Ecore itself is designed to be read-only thread
safe. And of course the above aren't a reason to throw up your hands.
There are definitely places where you will need to ensure that
something is done safely because the method being called really is
intended to support more than one thread calling it at once.<br>
<br>
<br>
Eike Stepper wrote:
<blockquote cite="mid:fb5kgk$sri$1@build.eclipse.org" type="cite">
<blockquote cite="mid:fb542f$90d$1@build.eclipse.org" type="cite">
<meta http-equiv="Content-Type" content="text/html; ">
<meta content="MSHTML 6.00.6000.16525" name="GENERATOR">
<style></style>
<div><font face="Arial" size="2">All the following operations <font
face="Arial" size="2">are not thread safe.. Right?</font></font></div>
</blockquote>
happen during construction time of their containing instance.<br>
safe?<br>
....<br>
<br>
<div><font face="Arial" size="2">CDORevisionResolverImpl</font></div>
<div><font face="Arial" size="2">private Map<CDOID, TimeLine>
revisions = new HashMap();</font></div>
</blockquote>
internal semantics of ITransaction.<br>
A CDORevision itself is immutable once created so there's no danger.<br>
mechanics of HashMap.<br>
Maybe it'd be better to use a ConcurrentHashMap for <font face="Arial"
size="2">CDORevisionResolverImpl.revisions and a ConcurrentLinkedQueue
as super class of TimeLine</font>.<br>
<br>
<div><font face="Arial" size="2">CDOViewImpl </font></div>
InternalCDOObject> objects = new HashMap();</font></div>
</blockquote>
A CDOView is not thread safe by definition.<br>
safe by default (Ed?).<br>
(<a moz-do-not-send="true" class="moz-txt-link-freetext"
href=" http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg2 6143.html"> http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg2 6143.html</a>).<br>
<br>
than in CDO.<br>
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=201366">https://bugs.eclipse.org/bugs/show_bug.cgi?id=201366</a><br>
<br>
Cheers<br>
/Eike<br>
<br>
<br>
</blockquote>
<br>
</body>
</html>
--------------020604010706030100090106--
Re: [CDO][0.8.0] Thread Safe - hanging problems [message #95012 is a reply to message #94979] |
Thu, 30 August 2007 08:13   |
--------------080905090106060702000003
Ed,
It's clear to me that I have to protect subsequent accesses to a thread
safe data structure, for example:
synchronized (revisions)
TimeLine timeLine = revisions.get(id);
if (timeLine == null)
timeLine = new TimeLine(id);
revisions.put(id, timeLine);
return timeLine;
But if the used data structure is not thread safe in itself two threads
could mess it up with a single access each.
A HashMap.put() for example could cause rehashing while another thread
is trying to access the map.
Cheers
/Eike
Ed Merks schrieb:
> Eike,
> list.remove(index);
> mean your higher level algorithms will be thread safe. Any code that
> hands. There are definitely places where you will need to ensure that
>> thread safe?
>> the internal semantics of ITransaction.
>> super class of TimeLine.
>>> CDOViewImpl
>> than in CDO.
>> Cheers
>> /Eike
<html>
<head>
</head>
Ed,<br>
<br>
safe data structure, for example:<br>
<br>
synchronized (revisions)<br>
{<br>
TimeLine timeLine = revisions.get(id);<br>
if (timeLine == null)<br>
{<br>
timeLine = new TimeLine(id);<br>
revisions.put(id, timeLine);<br>
}<br>
<br>
return timeLine;<br>
}<br>
<br>
could mess it up with a single access each.<br>
is trying to access the map.<br>
<br>
Cheers<br>
/Eike<br>
<br>
<br>
Ed Merks schrieb:
<blockquote cite="mid:fb6b7f$n49$1@build.eclipse.org" type="cite">
Eike,<br>
<br>
</blockquote>
<br>
<br>
<br>
<br>
<style></style>
</blockquote>
safe?<br>
.....<br>
<br>
TimeLine>
</blockquote>
<br>
</blockquote>
<br>
than in CDO.<br>
I have more comments in <a moz-do-not-send="true"
<br>
Cheers<br>
/Eike<br>
<br>
<br>
</blockquote>
<br>
</blockquote>
</body>
</html>
--------------080905090106060702000003--
Re: [CDO][0.8.0] Thread Safe - hanging problems [message #95025 is a reply to message #94964] |
Thu, 30 August 2007 08:14   |
--------------080608000109070005090109
I've added chained synchronization to CDORevisionResolverImpl.
What do you think?
> Sorry Eike, I wasn't clear enough.. but I thought it was obvious.
> Everyone that connect to that repository will go through these
> variable and call
> *if* (timeLine == *null*)
> timeLine = *new* TimeLine(id);
> *return* timeLine;
> We could have a problem there.... everywhere where we use revisions...
> not when we contruct it.
> Same thing for other attributs I mention...
> "Eike Stepper" <stepper@sympedia.de <mailto:stepper@sympedia.de>>
> wrote in message news:fb5kgk$sri$1@build.eclipse.org...
> they happen during construction time of their containing instance.
> thread safe?
> internal mechanics of HashMap.
>> CDOViewImpl
> thread safe by default (Ed?).
> rather than in CDO.
> Cheers
> /Eike
<html>
<head>
</head>
I've added chained synchronization to CDORevisionResolverImpl.<br>
What do you think?<br>
<br>
<br>
<blockquote cite="mid:fb68qk$f43$1@build.eclipse.org" type="cite">
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<meta content="MSHTML 6.00.2900.3157" name="GENERATOR">
<div><font face="Arial" size="2">Sorry Eike, I wasn't clear enough..
but I thought it was obvious.</font></div>
<div> </div>
<div><font face="Arial" size="2">Everyone that connect to that
repository will go through these variable and call</font></div>
<div> </div>
<div><font size="2">
</font>
<p align="left"><font size="2">TimeLine timeLine = </font><font
color="#0000c0" size="2">revisions</font><font size="2">.get(id);</font></p>
<p align="left"><b><font color="#7f0055" size="2">if</font></b><font
size="2"> (timeLine == </font><b><font color="#7f0055" size="2">null</font></b><font
size="2">)</font></p>
<p align="left"><font size="2">{</font></p>
<p align="left"><font size="2">timeLine = </font><b><font
color="#7f0055" size="2">new</font></b><font size="2"> TimeLine(id);</font></p>
<p align="left"><font color="#0000c0" size="2">revisions</font><font
size="2">.put(id, timeLine);</font></p>
<p align="left"><font size="2">}</font></p>
<p align="left"><b><font color="#7f0055" size="2">return</font></b><font
size="2"> timeLine;</font></p>
<p align="left"> </p>
<p align="left"><font size="2">We could have a problem there....
everywhere where we use <font color="#0000c0">revisions... not when we
contruct it.</font></font></p>
<p align="left"><font size="2"><font face="Arial">Same thing for
other attributs I mention... </font></font></p>
<p align="left"><font size="2"> </font></p>
</div>
<div> </div>
<div> </div>
<blockquote
style="border-left: 2px solid rgb(0, 0, 0); padding-right: 0px; padding-left: 5px; margin-left: 5px; margin-right: 0px;">
<div>"Eike Stepper" <<a moz-do-not-send="true"
href="mailto:stepper@sympedia.de">stepper@sympedia.de</a>> wrote in
message <a moz-do-not-send="true"
href="news:fb5kgk$sri$1@build.eclipse.org">news:fb5kgk$sri$1@build.eclipse.org</a>...</div>
<style></style>
</blockquote>
safe?<br>
....<br>
<br>
TimeLine> revisions = new HashMap();</font></div>
</blockquote>
<br>
</blockquote>
Even EModelElements are only read-only thread safe (<a
<br>
than in CDO.<br>
<br>
Cheers<br>
/Eike<br>
<br>
<br>
</blockquote>
</blockquote>
</body>
</html>
--------------080608000109070005090109--
Re: [CDO][0.8.0] Thread Safe - hanging problems [message #95040 is a reply to message #95025] |
Thu, 30 August 2007 08:32   |
------=_NextPart_000_0311_01C7EAE0.564C3FC0
This seems to be well done. But I'm not an expert :-)
It is working with my JCSMap as well !!!!
"Eike Stepper" <stepper@sympedia.de> wrote in message =
news:fb6cak$sri$4@build.eclipse.org...
What do you think?
Simon McDuff schrieb:=20
Everyone that connect to that repository will go through these =
variable and call
TimeLine timeLine =3D revisions.get(id);
if (timeLine =3D=3D null)
timeLine =3D new TimeLine(id);
return timeLine;
We could have a problem there.... everywhere where we use =
revisions... not when we contruct it.
Same thing for other attributs I mention...=20
The operations (assignment of HashMap) are thread safe because =
I guess you mean that subsequent operations on the maps are not =
thread safe?
First I thought this one is thread safe because it is protected by =
A CDORevision itself is immutable once created so there's no =
danger.
But now I'm not sure if it could come to problems due to the =
Maybe it'd be better to use a ConcurrentHashMap for =
CDORevisionResolverImpl.revisions and a ConcurrentLinkedQueue as super =
class of TimeLine.
CDOViewImpl=20
It shall only be used by a single thread because it contains a =
ResourceSet with Resources with EObjects and EObjects are not thread =
Even EModelElements are only read-only thread safe =
Basically I believe that the root cause is somewhere in Net4j =
rather than in CDO.
I have more comments in =
https://bugs.eclipse.org/bugs/show_bug.cgi?id=3D201366
Cheers
/Eike
<HTML><HEAD>
<META http-equiv=3DContent-Type =
content=3Dtext/html;charset=3DISO-8859-1>
<META content=3D"MSHTML 6.00.2900.3157" name=3DGENERATOR></HEAD>
<BODY text=3D#000000 bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>This seems to be well done. But I'm not =
an expert=20
:-)</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>It is working with my JCSMap as well=20
!!!!</FONT></DIV>
<DIV> </DIV>
<DIV>"Eike Stepper" <<A=20
href=3D"mailto:stepper@sympedia.de">stepper@sympedia.de</A>> wrote in =
message=20
<A=20
href=3D"news:fb6cak$sri$4@build.eclipse.org">news:fb6cak$sri$4@build.ecli=
pse.org</A>...</DIV>
<BLOCKQUOTE dir=3Dltr=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">I've=20
added chained synchronization to CDORevisionResolverImpl.<BR>What do =
you=20
think?<BR><BR><BR>Simon McDuff schrieb:=20
<BLOCKQUOTE cite=3Dmid:fb68qk$f43$1@build.eclipse.org type=3D"cite">
<DIV><FONT face=3DArial size=3D2>Sorry Eike, I wasn't clear enough.. =
but I=20
thought it was obvious.</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>Everyone that connect to that =
repository will=20
go through these variable and call</FONT></DIV>
<DIV> </DIV>
<DIV><FONT size=3D2></FONT>
<P align=3Dleft><FONT size=3D2>TimeLine timeLine =3D </FONT><FONT =
color=3D#0000c0=20
size=3D2>revisions</FONT><FONT size=3D2>.get(id);</FONT></P>
<P align=3Dleft><B><FONT color=3D#7f0055 size=3D2>if</FONT></B><FONT =
size=3D2>=20
(timeLine =3D=3D </FONT><B><FONT color=3D#7f0055 =
size=3D2>null</FONT></B><FONT=20
size=3D2>)</FONT></P>
<P align=3Dleft><FONT size=3D2>{</FONT></P>
<P align=3Dleft><FONT size=3D2>timeLine =3D </FONT><B><FONT =
color=3D#7f0055=20
size=3D2>new</FONT></B><FONT size=3D2> TimeLine(id);</FONT></P>
<P align=3Dleft><FONT color=3D#0000c0 size=3D2>revisions</FONT><FONT =
size=3D2>.put(id, timeLine);</FONT></P>
<P align=3Dleft><FONT size=3D2>}</FONT></P>
<P align=3Dleft><B><FONT color=3D#7f0055 =
size=3D2>return</FONT></B><FONT size=3D2>=20
timeLine;</FONT></P>
<P align=3Dleft> </P>
<P align=3Dleft><FONT size=3D2>We could have a problem there.... =
everywhere=20
where we use <FONT color=3D#0000c0>revisions... not when we contruct =
it.</FONT></FONT></P>
<P align=3Dleft><FONT size=3D2><FONT face=3DArial>Same thing for =
other attributs I=20
mention... </FONT></FONT></P>
<P align=3Dleft><FONT size=3D2></FONT> </P></DIV>
<DIV> </DIV>
<DIV> </DIV>
<BLOCKQUOTE=20
BORDER-LEFT: rgb(0,0,0) 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Eike Stepper" <<A href=3D"mailto:stepper@sympedia.de"=20
moz-do-not-send=3D"true">stepper@sympedia.de</A>> wrote in =
message <A=20
href=3D"news:fb5kgk$sri$1@build.eclipse.org"=20
moz-do-not-send=3D"true">news:fb5kgk$sri$1@build.eclipse.org</A>...</DIV>=
Simon=20
McDuff schrieb:=20
<BLOCKQUOTE cite=3Dmid:fb542f$90d$1@build.eclipse.org =
type=3D"cite">
<STYLE></STYLE>
<DIV><FONT face=3DArial size=3D2>All the following =
operations <FONT=20
face=3DArial size=3D2>are not thread safe..=20
Right?</FONT></FONT></DIV></BLOCKQUOTE>The operations (assignment =
of=20
HashMap) are thread safe because they happen during construction =
time of=20
their containing instance.<BR>I guess you mean that subsequent =
operations=20
on the maps are not thread safe?<BR>...<BR><BR>
type=3D"cite">
<DIV><FONT face=3DArial =
TimeLine>=20
revisions =3D new HashMap();</FONT></DIV></BLOCKQUOTE>First I =
thought this=20
one is thread safe because it is protected by the internal =
semantics of=20
ITransaction.<BR>A CDORevision itself is immutable once created so =
there's=20
no danger.<BR>But now I'm not sure if it could come to problems =
due to the=20
internal mechanics of HashMap.<BR>Maybe it'd be better to use a=20
ConcurrentHashMap for <FONT face=3DArial=20
size=3D2>CDORevisionResolverImpl.revisions and a =
ConcurrentLinkedQueue as=20
super class of TimeLine</FONT>.<BR><BR>
type=3D"cite">
InternalCDOObject>=20
objects =3D new HashMap();</FONT></DIV></BLOCKQUOTE>A CDOView is =
not thread=20
safe by definition.<BR>It shall only be used by a single thread =
because it=20
contains a ResourceSet with Resources with EObjects and EObjects =
are not=20
thread safe by default (Ed?).<BR>Even EModelElements are only =
read-only=20
thread safe (<A class=3Dmoz-txt-link-freetext=20
href=3D" http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg2 6143.=
html"=20
moz-do-not-send=3D"true">http://dev.eclipse.org/newslists/news.eclipse.to=
ols.emf/msg26143.html</A>).<BR><BR>Basically=20
I believe that the root cause is somewhere in Net4j rather than in =
CDO.<BR>I have more comments in <A class=3Dmoz-txt-link-freetext=20
href=3D"https://bugs.eclipse.org/bugs/show_bug.cgi?id=3D201366"=20
moz-do-not-send=3D"true">https://bugs.eclipse.org/bugs/show_bug.cgi?id=3D=
201366</A><BR><BR>Cheers<BR>/Eike<BR><BR><BR></BLOCKQUOTE ></BLOCKQUOTE></=
BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_0311_01C7EAE0.564C3FC0--
Re: [CDO][0.8.0] Thread Safe - hanging problems [message #95055 is a reply to message #95012] |
Thu, 30 August 2007 10:35   |
--------------000807020602010305060601
Eike,
Yes, this is definitely a case where you need to synchronize properly.
Eike Stepper wrote:
> Ed,
> thread safe data structure, for example:
> return timeLine;
> threads could mess it up with a single access each.
> Cheers
> /Eike
> Ed Merks schrieb:
>> Eike,
>> list.remove(index);
>> life's threading problems, it would in fact be more than likely to
>> cause new ones, i.e., deadlock.
>> that something is done safely because the method being called really
>> is intended to support more than one thread calling it at once.
>>> thread safe?
>>>> CDOViewImpl
>>> than in CDO.
>>> Cheers
>>> /Eike
<html>
<head>
</head>
Eike,<br>
<br>
Yes, this is definitely a case where you need to synchronize properly.<br>
<br>
<br>
Eike Stepper wrote:
<blockquote cite="mid:fb6c86$sri$3@build.eclipse.org" type="cite">
Ed,<br>
<br>
<br>
{<br>
{<br>
}<br>
<br>
}<br>
<br>
<br>
Cheers<br>
/Eike<br>
<br>
<br>
Eike,<br>
<br>
</blockquote>
<br>
<br>
<br>
<br>
<style></style>
</blockquote>
safe?<br>
.....<br>
<br>
TimeLine>
</blockquote>
<br>
</blockquote>
<br>
than in CDO.<br>
<br>
Cheers<br>
/Eike<br>
<br>
<br>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------000807020602010305060601--
Re: [CDO][0.8.0] Thread Safe - hanging problems [message #95070 is a reply to message #95040] |
Thu, 30 August 2007 10:49  |
--------------050408050200070208000101
Cool!!! I'm happy that it's solved and sorry for the inconvenience.
Maybe in the future when we recognize that too many threads are being
allocated we are brave enough to give AsynchronousWorkSerializer another
try ;-)
BTW. I've added the following to Channel.doDeactivate()
if (receiveSerializer != null)
receiveSerializer.dispose();
receiveSerializer = null;
Cheers
/Eike
<html>
<head>
</head>
<blockquote cite="mid:fb6ddd$i4i$1@build.eclipse.org" type="cite">
<div><font face="Arial" size="2">This seems to be well done. But I'm
not an expert :-)</font></div>
<div><font face="Arial" size="2">It is working with my JCSMap as well
!!!!</font></div>
</blockquote>
Cool!!! I'm happy that it's solved and sorry for the inconvenience.<br>
another try ;-)<br>
<br>
BTW. I've added the following to Channel.doDeactivate()<br>
<br>
if (receiveSerializer != null)<br>
{<br>
receiveSerializer.dispose();<br>
receiveSerializer = null;<br>
}<br>
<br>
Cheers<br>
/Eike<br>
<br>
</body>
</html>
--------------050408050200070208000101--
Re: [CDO][0.8.0] Thread Safe - hanging problems [message #609582 is a reply to message #94903] |
Thu, 30 August 2007 01:27  |
--------------090507060303030202050003
I guess you mean that subsequent operations on the maps are not thread safe?
class of TimeLine.
> CDOViewImpl
than in CDO.
I have more comments in https://bugs.eclipse.org/bugs/show_bug.cgi?id=201366
Cheers
/Eike
<html>
<head>
</head>
<style></style>
</blockquote>
safe?<br>
....<br>
<br>
</blockquote>
<br>
</blockquote>
(<a class="moz-txt-link-freetext" href=" http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg2 6143.html"> http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg2 6143.html</a>).<br>
<br>
than in CDO.<br>
<a class="moz-txt-link-freetext" href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=201366">https://bugs.eclipse.org/bugs/show_bug.cgi?id=201366</a><br>
<br>
Cheers<br>
/Eike<br>
<br>
<br>
</body>
</html>
--------------090507060303030202050003--
Re: [CDO][0.8.0] Thread Safe - hanging problems [message #609583 is a reply to message #94920] |
Thu, 30 August 2007 01:38  |
--------------090606060501000402050104
.... another reason why I don't bellive that missing sync on the maps is
not the cause for the deadlocks is the following:
I believe that in general too few sync *can* cause problems like data
corruption and subsequent failure but deadlock is more likely to occur
with too much or wrong sync.
Cheers
/Eike
> safe?
> class of TimeLine.
>> CDOViewImpl
> than in CDO.
> Cheers
> /Eike
<html>
<head>
</head>
not the cause for the deadlocks is the following:<br>
with too much or wrong sync.<br>
<br>
Cheers<br>
/Eike<br>
<br>
<br>
<style></style>
</blockquote>
safe?<br>
.....<br>
<br>
</blockquote>
<br>
</blockquote>
<br>
than in CDO.<br>
<br>
Cheers<br>
/Eike<br>
<br>
<br>
</blockquote>
</body>
</html>
--------------090606060501000402050104--
Re: [CDO][0.8.0] Thread Safe - hanging problems [message #609585 is a reply to message #94920] |
Thu, 30 August 2007 07:14  |
------=_NextPart_000_02A4_01C7EAD5.6777B320
Everyone that connect to that repository will go through these variable =
and call
return timeLine;
We could have a problem there.... everywhere where we use revisions... =
The operations (assignment of HashMap) are thread safe because they =
I guess you mean that subsequent operations on the maps are not thread =
safe?
First I thought this one is thread safe because it is protected by the =
But now I'm not sure if it could come to problems due to the internal =
class of TimeLine.
CDOViewImpl=20
Basically I believe that the root cause is somewhere in Net4j rather =
than in CDO.
Cheers
/Eike
<HTML><HEAD>
<DIV><FONT face=3DArial size=3D2>Sorry Eike, I wasn't clear enough.. but =
I thought=20
repository will go=20
<P align=3Dleft>TimeLine timeLine =3D </FONT><FONT color=3D#0000c0=20
size=3D2>revisions</FONT><FONT size=3D2>.get(id);</P>
<P align=3Dleft></FONT><B><FONT color=3D#7f0055 =
size=3D2>if</B></FONT><FONT size=3D2>=20
size=3D2>null</B></FONT><FONT=20
size=3D2>)</P>
<P align=3Dleft>{</P>
<P align=3Dleft>timeLine =3D </FONT><B><FONT color=3D#7f0055=20
size=3D2>new</B></FONT><FONT size=3D2> TimeLine(id);</P>
<P align=3Dleft></FONT><FONT color=3D#0000c0 =
size=3D2>revisions</FONT><FONT=20
size=3D2>.put(id, timeLine);</P>
<P align=3Dleft>}</P>
<P align=3Dleft></P>
size=3D2>return</B></FONT><FONT=20
size=3D2> timeLine;</FONT></P>
everywhere where we=20
<P align=3Dleft><FONT size=3D2><FONT face=3DArial>Same thing for other =
attributs I=20
<P align=3Dleft><FONT size=3D2><FONT =
face=3DArial></FONT> </P></FONT></DIV>
<BLOCKQUOTE=20
href=3D"mailto:stepper@sympedia.de">stepper@sympedia.de</A>> wrote =
in message=20
<A=20
href=3D"news:fb5kgk$sri$1@build.eclipse.org">news:fb5kgk$sri$1@build.ecli=
pse.org</A>...</DIV>Simon=20
McDuff schrieb:=20
<BLOCKQUOTE cite=3Dmid:fb542f$90d$1@build.eclipse.org type=3D"cite">
<STYLE></STYLE>
<FONT=20
Right?</FONT></FONT></DIV></BLOCKQUOTE>The operations (assignment of =
HashMap)=20
are thread safe because they happen during construction time of their=20
containing instance.<BR>I guess you mean that subsequent operations on =
the=20
revisions =3D=20
new HashMap();</FONT></DIV></BLOCKQUOTE>First I thought this one is =
thread=20
safe because it is protected by the internal semantics of =
ITransaction.<BR>A=20
danger.<BR>But now=20
mechanics of=20
HashMap.<BR>Maybe it'd be better to use a ConcurrentHashMap for <FONT=20
face=3DArial size=3D2>CDORevisionResolverImpl.revisions and a=20
ConcurrentLinkedQueue as super class of TimeLine</FONT>.<BR><BR>
objects =3D new HashMap();</FONT></DIV></BLOCKQUOTE>A CDOView is not =
thread safe=20
by definition.<BR>It shall only be used by a single thread because it =
contains=20
a ResourceSet with Resources with EObjects and EObjects are not thread =
safe by=20
default (Ed?).<BR>Even EModelElements are only read-only thread safe =
(<A=20
html"> http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg2 6143.ht=
CDO.<BR>I=20
href=3D"https://bugs.eclipse.org/bugs/show_bug.cgi?id=3D201366">https://b=
ugs.eclipse.org/bugs/show_bug.cgi?id=3D201366</A><BR><BR>Cheers <BR>/Eike<=
BR><BR><BR></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_02A4_01C7EAD5.6777B320--
Re: [CDO][0.8.0] Thread Safe - hanging problems [message #609586 is a reply to message #94920] |
Eike,
list.remove(index);
> safe?
> class of TimeLine.
>> CDOViewImpl
> than in CDO.
> Cheers
> /Eike
<html>
<head>
</head>
Eike,<br>
<br>
</blockquote>
<br>
<br>
<br>
<br>
<style></style>
</blockquote>
safe?<br>
....<br>
<br>
</blockquote>
<br>
</blockquote>
<br>
than in CDO.<br>
<br>
Cheers<br>
/Eike<br>
<br>
<br>
</blockquote>
<br>
</body>
</html>
Re: [CDO][0.8.0] Thread Safe - hanging problems [message #609588 is a reply to message #94979] |
Ed,
return timeLine;
Cheers
/Eike
Ed Merks schrieb:
> Eike,
> list.remove(index);
>> thread safe?
>>> CDOViewImpl
>> than in CDO.
>> Cheers
>> /Eike
<html>
<head>
</head>
Ed,<br>
<br>
<br>
{<br>
{<br>
}<br>
<br>
}<br>
<br>
<br>
Cheers<br>
/Eike<br>
<br>
<br>
Eike,<br>
<br>
</blockquote>
<br>
<br>
<br>
<br>
<style></style>
</blockquote>
safe?<br>
.....<br>
<br>
TimeLine>
</blockquote>
<br>
</blockquote>
<br>
than in CDO.<br>
<br>
Cheers<br>
/Eike<br>
<br>
<br>
</blockquote>
<br>
</blockquote>
</body>
</html>
Re: [CDO][0.8.0] Thread Safe - hanging problems [message #609589 is a reply to message #94964] |
What do you think?
> variable and call
> *return* timeLine;
> thread safe?
>> CDOViewImpl
> rather than in CDO.
> Cheers
> /Eike
<html>
<head>
</head>
<br>
<br>
<div> </div>
<div> </div>
</font>
</div>
<div> </div>
<div> </div>
<blockquote
<style></style>
</blockquote>
safe?<br>
....<br>
<br>
</blockquote>
<br>
</blockquote>
<br>
than in CDO.<br>
<br>
Cheers<br>
/Eike<br>
<br>
<br>
</blockquote>
</blockquote>
</body>
</html>
Re: [CDO][0.8.0] Thread Safe - hanging problems [message #609590 is a reply to message #95025] |
What do you think?
variable and call
return timeLine;
thread safe?
danger.
class of TimeLine.
CDOViewImpl=20
rather than in CDO.
Cheers
/Eike
<HTML><HEAD>
an expert=20
:-)</FONT></DIV>
!!!!</FONT></DIV>
<DIV> </DIV>
message=20
<A=20
you=20
but I=20
<DIV> </DIV>
repository will=20
<DIV> </DIV>
color=3D#0000c0=20
size=3D2>=20
color=3D#7f0055=20
everywhere=20
<DIV> </DIV>
<DIV> </DIV>
<BLOCKQUOTE=20
message <A=20
Simon=20
McDuff schrieb:=20
type=3D"cite">
<STYLE></STYLE>
operations <FONT=20
of=20
time of=20
operations=20
type=3D"cite">
TimeLine>=20
thought this=20
semantics of=20
there's=20
due to the=20
type=3D"cite">
not thread=20
because it=20
are not=20
read-only=20
html"=20
Re: [CDO][0.8.0] Thread Safe - hanging problems [message #609591 is a reply to message #95012] |
Eike,
Eike Stepper wrote:
> Ed,
> return timeLine;
> Cheers
> /Eike
> Ed Merks schrieb:
>> Eike,
>> list.remove(index);
>>> thread safe?
>>>> CDOViewImpl
>>> than in CDO.
>>> Cheers
>>> /Eike
<html>
<head>
</head>
Eike,<br>
<br>
<br>
<br>
Ed,<br>
<br>
<br>
{<br>
{<br>
}<br>
<br>
}<br>
<br>
<br>
Cheers<br>
/Eike<br>
<br>
<br>
Eike,<br>
<br>
</blockquote>
<br>
<br>
<br>
<br>
<style></style>
</blockquote>
safe?<br>
.....<br>
<br>
TimeLine>
</blockquote>
<br>
</blockquote>
<br>
than in CDO.<br>
<br>
Cheers<br>
/Eike<br>
<br>
<br>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
Re: [CDO][0.8.0] Thread Safe - hanging problems [message #609592 is a reply to message #95040] |
try ;-)
Cheers
/Eike
<html>
<head>
</head>
!!!!</font></div>
</blockquote>
another try ;-)<br>
<br>
<br>
{<br>
}<br>
<br>
Cheers<br>
/Eike<br>
<br>
</body>
</html>
Current Time: Sun Sep 21 00:23:17 EDT 2025
Powered by FUDForum. Page generated in 0.06518 seconds
