Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [CDO] Hanging (client)
[CDO] Hanging (client) [message #94273] Mon, 27 August 2007 16:03 Go to next message
Eike,
Sometimes the server and the client hang...
If I stop the client and restart and a new one.. it is working correctly.
Each time I try to run it in debug mode... it doesn't hang. I only see the
behavior in release.
I wasn't sure at the beginning.. but I have that problem for the last 2
weeks.
Have you seen this behavior in you environment ?
I'm using Java sun 1.5_0_10
Re: [CDO] Hanging (client) [message #94370 is a reply to message #94273] Tue, 28 August 2007 01:45 Go to previous messageGo to next message
Originally posted by: stepper.sympedia.de
Simon McDuff schrieb:
> Eike,
That's typical for threading problems (deadlocks).
Sometime there's a chance to hit it in debug mode if all tracing is
disabled (or sent to file instead of the console).
> weeks.
Yes, unfortunately I have this phenomenon aproximately once or twice a
month which is really rare and most of the times without debug mode ;-(
This is one of the most urgent issues to fix (probably in Net4j). Since
it occurs so rarely I planned to investigate it after my work with the
cdo mapper is at least so far that users can try a horizontal mapping
with a table per reference.
I can remember of a single place in Net4j where I had the feeling a race
condition could occur.
When I recall this place I'll tell you about.
I know there are some tools available that try to find synchronization
problems through static code analysis.
Do you have experinece with one of these tools?
I'm using a jre1.6.0_02 for my IDE and the code is compiled against a
J2SE-1.5 execution environment which is associated with a jdk1.5.0_12
here at the moment.
If you are ever able to hit the deadlock in debug mode it'd be great if
you send me a stack trace of the main thread (not sure if it's easily
possible to copy *all* stack traces from the debugger).
Cheers
/Eike
Re: [CDO] Hanging (client) [message #94413 is a reply to message #94370] Tue, 28 August 2007 05:53 Go to previous messageGo to next message
Eike,
I read somewhere that you can generate a thread dump after a deadlock
occurs under Unix/Linux by running kill -QUIT <pid> and under Windows by
hitting Ctrl + Break.
>> Eike,
>> correctly.
>> see the behavior in release.
>> 2 weeks.
> Since it occurs so rarely I planned to investigate it after my work
> with the cdo mapper is at least so far that users can try a horizontal
> mapping with a table per reference.
> race condition could occur.
> here at the moment.
> if you send me a stack trace of the main thread (not sure if it's
> easily possible to copy *all* stack traces from the debugger).
> Cheers
> /Eike
Re: [CDO] Hanging (client) [message #94443 is a reply to message #94413] Tue, 28 August 2007 06:36 Go to previous messageGo to next message
Ed,
That sounds really interesting!
What does "generate" mean? Text in the clipboard? A file?
Or do you mean hitting Ctrl+Break in the concole where the deadlocked
process is running?
This at least doesn't work with the IDE console.
Or should I use debug mode?
No, Then I could simply suspend the locked thread.
Hmmm, it's not clear to me...
/Eike
Ed Merks schrieb:
> Eike,
> by hitting Ctrl + Break.
>>> Eike,
>>> correctly.
>>> last 2 weeks.
>> a month which is really rare and most of the times without debug mode
>> horizontal mapping with a table per reference.
>> synchronization problems through static code analysis.
>> here at the moment.
>> Cheers
>> /Eike
Re: [CDO] Hanging (client) [message #94459 is a reply to message #94443] Tue, 28 August 2007 06:41 Go to previous messageGo to next message
http://java.sun.com/developer/technicalArticles/Programming/ Stacktrace/
Eike Stepper schrieb:
> Ed,
> process is running?
> /Eike
> Ed Merks schrieb:
>> Eike,
>>>> Eike,
>>>> correctly.
>>>> last 2 weeks.
>>> mode ;-(
>>> a J2SE-1.5 execution environment which is associated with a
>>> jdk1.5.0_12 here at the moment.
>>> Cheers
>>> /Eike
Re: [CDO] Hanging (client) [message #94473 is a reply to message #94443] Tue, 28 August 2007 06:53 Go to previous messageGo to next message
This one was also useful:
http://wiki.eclipse.org/How_to_report_a_deadlock
> Ed,
> process is running?
> /Eike
> Ed Merks schrieb:
>> Eike,
>>>> Eike,
>>>> correctly.
>>>> last 2 weeks.
>>> mode ;-(
>>> Cheers
>>> /Eike
Re: [CDO] Hanging (client) [message #94488 is a reply to message #94413] Tue, 28 August 2007 07:11 Go to previous messageGo to next message
Ed,
Wow, I'm really impressed ;-)
With the both tools mentioned at the bottom of
http://wiki.eclipse.org/How_to_report_a_deadlock it really works.
This is really a tremendous help in tracking down deadlocks!!!
Many many thanks!!!
/Eike
Ed Merks schrieb:
> Eike,
>>> Eike,
>>> correctly.
>>> last 2 weeks.
>> here at the moment.
>> Cheers
>> /Eike
Re: [CDO] Hanging (client) [message #94519 is a reply to message #94443] Tue, 28 August 2007 07:14 Go to previous messageGo to next message
--------------030705030603070201020208
Eike,
I run Eclipse like this:
eclipse.exe -consolelog
When I hit ctrl-break in the console it prints
JVMDUMP006I Processing Dump Event "user", detail "" - Please Wait.
JVMDUMP007I JVM Requesting Java Dump using
'd:\sandbox\3.3RC4\eclipse\javacore.20070828.071146.107920.t xt'
JVMDUMP010I Java Dump written to
d:\sandbox\3.3RC4\eclipse\javacore.20070828.071146.107920.tx t
JVMDUMP013I Processed Dump Event "user", detail "".
Too bad if the IDE launched things don't support this. You might open a
bugzilla to ask for it since this is awfully useful.
Eike Stepper wrote:
> Ed,
> process is running?
> /Eike
> Ed Merks schrieb:
>> Eike,
>>>> Eike,
>>>> correctly.
>>>> last 2 weeks.
>>> mode ;-(
>>> Cheers
>>> /Eike
<html>
<head>
http-equiv="Content-Type">
</head>
Eike,<br>
<br>
I run Eclipse like this:<br>
<blockquote>eclipse.exe -consolelog<br>
</blockquote>
When I hit ctrl-break in the console it prints<br>
<blockquote>JVMDUMP006I Processing Dump Event "user", detail "" -
Please Wait.<br>
'd:\sandbox\3.3RC4\eclipse\javacore.20070828.071146.107920.t xt' <br>
d:\sandbox\3.3RC4\eclipse\javacore.20070828.071146.107920.tx t <br>
JVMDUMP013I Processed Dump Event "user", detail "".<br>
</blockquote>
Re: [CDO] Hanging (client) [message #94551 is a reply to message #94488] Tue, 28 August 2007 07:16 Go to previous messageGo to next message
Eike,
I should read all the notes before replying. :-)
Eike Stepper wrote:
> Ed,
> Many many thanks!!!
> /Eike
> Ed Merks schrieb:
>> Eike,
>>>> Eike,
>>>> correctly.
>>>> last 2 weeks.
>>> mode ;-(
>>> Cheers
>>> /Eike
Re: [CDO] Hanging (client) [message #94566 is a reply to message #94273] Tue, 28 August 2007 07:16 Go to previous messageGo to next message
Simon,
I guess you have followed the other postings to this thread.
If not, here is a short explanation of what to do if deadlock occurs in
a non-debug runtime launch:
1. Download and run
http://www.microsoft.com/technet/sysinternals/utilities/Proc essExplorer.mspx
2. Find the pid of the launched process under Eclipse.exe
3. Download
http://www.latenighthacking.com/projects/2003/sendSignal/Sen dSignal.exe
4. Run SendSignal.exe <pid> in any console
5. Copy the stack traces from the IDE console and send them to me
Cheers
/Eike
> Eike,
> weeks.
Re: [CDO] Hanging (client) [message #94581 is a reply to message #94551] Tue, 28 August 2007 07:19 Go to previous messageGo to next message
Ed Merks schrieb:
> Eike,
....and I should try everything before I spam the group ;-)
Cheers
/Eike
Re: [CDO] Hanging (client) [message #94626 is a reply to message #94443] Tue, 28 August 2007 07:59 Go to previous message
It is working well... wow!!!
OK.. so the next time it happen... I have some tools!!!
Thank you Ed and Eike!
"Eike Stepper" <stepper@sympedia.de> wrote in message
news:fb0ts0$odv$7@build.eclipse.org...
> Ed,
> process is running?
> /Eike
> Ed Merks schrieb:
>> Eike,
>>>> Eike,
>>>> correctly.
>>>> weeks.
>>> here at the moment.
>>> Cheers
>>> /Eike
Re: [CDO] Hanging (client) [message #609547 is a reply to message #94273] Tue, 28 August 2007 01:45 Go to previous message
> Eike,
> weeks.
here at the moment.
Cheers
/Eike
Re: [CDO] Hanging (client) [message #609550 is a reply to message #94370] Tue, 28 August 2007 05:53 Go to previous message
Eike,
>> Eike,
>> correctly.
>> 2 weeks.
> here at the moment.
> Cheers
> /Eike
Re: [CDO] Hanging (client) [message #609552 is a reply to message #94413] Tue, 28 August 2007 06:36 Go to previous message
Ed,
process is running?
/Eike
Ed Merks schrieb:
> Eike,
>>> Eike,
>>> correctly.
>>> last 2 weeks.
>> here at the moment.
>> Cheers
>> /Eike
Re: [CDO] Hanging (client) [message #609553 is a reply to message #94443] Tue, 28 August 2007 06:41 Go to previous message
> Ed,
> process is running?
> /Eike
> Ed Merks schrieb:
>> Eike,
>>>> Eike,
>>>> correctly.
>>>> last 2 weeks.
>>> mode ;-(
>>> Cheers
>>> /Eike
Re: [CDO] Hanging (client) [message #609554 is a reply to message #94443] Tue, 28 August 2007 06:53 Go to previous message
> Ed,
> process is running?
> /Eike
> Ed Merks schrieb:
>> Eike,
>>>> Eike,
>>>> correctly.
>>>> last 2 weeks.
>>> mode ;-(
>>> Cheers
>>> /Eike
Re: [CDO] Hanging (client) [message #609555 is a reply to message #94413] Tue, 28 August 2007 07:11 Go to previous message
Ed,
Many many thanks!!!
/Eike
Ed Merks schrieb:
> Eike,
>>> Eike,
>>> correctly.
>>> last 2 weeks.
>> here at the moment.
>> Cheers
>> /Eike
Re: [CDO] Hanging (client) [message #609557 is a reply to message #94443] Tue, 28 August 2007 07:14 Go to previous message
Eike,
Eike Stepper wrote:
> Ed,
> process is running?
> /Eike
> Ed Merks schrieb:
>> Eike,
>>>> Eike,
>>>> correctly.
>>>> last 2 weeks.
>>> mode ;-(
>>> Cheers
>>> /Eike
<html>
<head>
</head>
Eike,<br>
<br>
</blockquote>
Please Wait.<br>
</blockquote>
Re: [CDO] Hanging (client) [message #609559 is a reply to message #94488] Tue, 28 August 2007 07:16 Go to previous message
Eike,
Eike Stepper wrote:
> Ed,
> Many many thanks!!!
> /Eike
> Ed Merks schrieb:
>> Eike,
>>>> Eike,
>>>> correctly.
>>>> last 2 weeks.
>>> mode ;-(
>>> Cheers
>>> /Eike
Re: [CDO] Hanging (client) [message #609560 is a reply to message #94273] Tue, 28 August 2007 07:16 Go to previous message
Simon,
1. Download and run
3. Download
Cheers
/Eike
> Eike,
> weeks.
Re: [CDO] Hanging (client) [message #609561 is a reply to message #94551] Tue, 28 August 2007 07:19 Go to previous message
Ed Merks schrieb:
> Eike,
Cheers
/Eike
Re: [CDO] Hanging (client) [message #609564 is a reply to message #94443] Tue, 28 August 2007 07:59 Go to previous message
> Ed,
> process is running?
> /Eike
> Ed Merks schrieb:
>> Eike,
>>>> Eike,
>>>> correctly.
>>>> weeks.
>>> here at the moment.
>>> Cheers
>>> /Eike
Previous Topic:Problem using generated hibernate mapping file
Next Topic:[NET4J]
Current Time: Tue Jul 29 01:30:55 EDT 2025
Powered by FUDForum. Page generated in 0.10988 seconds
