Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [CDO][0.8.0]
[CDO][0.8.0] [message #94255] |
Sun, 26 August 2007 16:15  |
Hi Eike,
Did you try using GZIPOutpuStream and GZIPInputStream in your framework ?
If yes do you have some result ?
If no, where should be plug GZIPOutpuStream and GZipInputStrea, in your
framework ?
Simon
Re: [CDO][0.8.0] [message #94265 is a reply to message #94255] |
Mon, 27 August 2007 10:45   |
Originally posted by: stepper.sympedia.de
Hi Simon,
I've just provided the infrastructure for wrapping the streams to be
used by signals.
The easiest way to do so is adding an element processor to the managed
container:
<extension point="org.eclipse.net4j.util.elementProcessors">
<elementProcessor
class=" org.eclipse.emf.cdo.protocol.util.CDOXORStreamWrapperInjecto r "/>
</extension>
The element processor injects an IStreamWrapper into protocols of the
given name (here cdo).
The example above is taken from the cdo.ui plugin and wraps the signal
streams with xor'ing filter streams.
This is mostly useful for testing or simple cyphering.
For you I've provided CDOGZIPStreamWrapperInjector which is a subclass
of GZIPStreamWrapperInjector.
Sounds good? Unfortunately both of them don't work correctly ;-(
I've tried for hours to track it down, without success until now.
I guess that it relates somehow to the transmission of byte arrays.
The Java stream API is evil in my opinion for the following reason:
The read() method of InputStream and the write() methop of OutputStream
return/take an int value instead of a byte value.
I suspect it is somehow to enable read() to signal an EndOfStream (-1)
without throwing an exception.
Certainly only Sun knows why a magic number in a too large data type is
better than a matching data type plus an exception for a special case.
Maybe they have good reason that I'm just to silly to imagine ;-)
I believe that my BufferInputStream and BufferOutputStream have
correctly implemented read() and write().
Without the newly introduced stream wrapping they pass all test cases.
This could of course also be because two bugs eleminate themselves
counterwise.
That would mean that this elimination of bugs does not happen when the
streams are wrapped.
But that's only a vague idea.
Anyway the result when wrapping the streams leads to an exception when
opening a CDOSession.
At first the repository name is transmitted as
[00 00 00 05]
[114, 101, 112, 111, 49]
But the following is received:
[00 00 00 05]
[-40, 48, -38, 58, -101]
Interesting that the length is correctly received. Only the byte array
is crippled somehow.
Maybe you can have a look at it and have an idea what's going on.
I suggest that you set breakpoints in
ExtendedIOUtil.readByteArray(DataInput) and
ExtendedIOUtil.writeByteArray(DataOutput, byte[])
Cheers
/Eike
Simon McDuff schrieb:
> Hi Eike,
> framework ?
> Simon
Re: [CDO][0.8.0] [message #94384 is a reply to message #94265] |
Tue, 28 August 2007 03:04   |
Hi Simon,
I think I found the root cause of the problem. It seems to be another
flaw in the Java stream API.
java.io.FilterOutputStream.write(byte[], int, int) calls its own int
read() method so that arrays are filtered by the override of int read().
This is not necessary since the super implementation of
java.io.InputStream seems to do the same logic.
java.io.FilterInputStream.read(byte[], int, int) in contrast does *not*
call its own implementation/override of int read().
Instead it calls in.read(b, off, len) where in is the delegate
InputStream. This way an override logic in its own read() method is
ignored ;-(
I believe in both cases it'd be better to simply not override the array
methods and rather use the base implementations from InputStream and
OutputStream which both delegate to read().
At least I would expect the same (redundant) logic as in FilterOutputStream!
What do you think?
Cheers
/Eike
Eike Stepper schrieb:
> Hi Simon,
> used by signals.
> container:
> <elementProcessor
> </extension>
> OutputStream return/take an int value instead of a byte value.
> is better than a matching data type plus an exception for a special case.
> counterwise.
> At first the repository name is transmitted as [00 00 00 05]
> [00 00 00 05]
> Cheers
> /Eike
>> Hi Eike,
>> framework ?
>> your framework ?
>> Simon
Re: [CDO][0.8.0] [message #94398 is a reply to message #94384] |
Tue, 28 August 2007 05:15   |
Update:
My XORInputStream and XOROutputStream now work correctly because they no
longer extend java.io.FilterInputStream and java.io.FilterOutputStream.
Instead they use org.eclipse.net4j.util.io.DelegatingInputStream and
org.eclipse.net4j.util.io.DelegatingOutputStream which don't have the
problem I described in the previous post.
GZIPInputStream and GZIPOutputStream still don't work but it seems to be
a different root cause. They seem to correctly override the array read()
and write() methods.
A GZIPOutputStream properly deflates written data and the corresponding
GZIPInputStream properly receives the deflated bytes.
However there's a fill() method in InflaterInputStream which tries to
fill a full (512 bytes) buffer.
Since the the output stream has (correctly) written only parts of its
512 bytes buffer the input stream indefinately waits for the rest of the
bytes. They will never come ;-(
I have never used GZIP streams before and have no idea who's fault this
is or how it could be fixed.
If you want to use GZIP stream wrapping you'll have to help me.
Cheers
/Eike
> Hi Simon,
> *not* call its own implementation/override of int read().
> ignored ;-(
> array methods and rather use the base implementations from InputStream
> and OutputStream which both delegate to read().
> FilterOutputStream!
> What do you think?
> Cheers
> /Eike
>> Hi Simon,
>> used by signals.
>> managed container:
>> <elementProcessor
>> </extension>
>> signal streams with xor'ing filter streams.
>> subclass of GZIPStreamWrapperInjector.
>> (-1) without throwing an exception.
>> case.
>> counterwise.
>> the streams are wrapped.
>> when opening a CDOSession.
>> [00 00 00 05]
>> array is crippled somehow.
>> Cheers
>> /Eike
>>> Hi Eike,
>>> framework ?
>>> your framework ?
>>> Simon
Re: [CDO][0.8.0] GZIP solved [message #94428 is a reply to message #94398] |
Tue, 28 August 2007 06:31   |
Finally I found the root cause: in the subclasses of Signal I used
flush() instead of flushWithEOS() so that the receiving party assumed
there are more buffers to read from.
It is fixed now in CVS and the GZIPStreamWrapper seems to work like a
charme ;-)
Please tell me if you can compare the results, for example with your
huge transactions or huge revisions.
Cheers
/Eike
> Update:
> no longer extend java.io.FilterInputStream and
> be a different root cause. They seem to correctly override the array
> read() and write() methods.
> corresponding GZIPInputStream properly receives the deflated bytes.
> the bytes. They will never come ;-(
> this is or how it could be fixed.
> Cheers
> /Eike
>> Hi Simon,
>> ignored ;-(
>> InputStream and OutputStream which both delegate to read().
>> FilterOutputStream!
>> What do you think?
>> Cheers
>> /Eike
>>> Hi Simon,
>>> used by signals.
>>> managed container:
>>> <elementProcessor
>>> </extension>
>>> the given name (here cdo).
>>> case.
>>> counterwise.
>>> [00 00 00 05]
>>> Cheers
>>> /Eike
>>>> Hi Eike,
>>>> framework ?
>>>> your framework ?
>>>> Simon
Re: [CDO][0.8.0] GZIP solved [message #94534 is a reply to message #94428] |
Tue, 28 August 2007 07:15   |
Wow perfect!!!
Maybe it will fix the hangling problem that we had ?? :-) ... I will
benchmark it at home and let you know the result tonight.
Simon
"Eike Stepper" <stepper@sympedia.de> wrote in message
news:fb0thn$odv$6@build.eclipse.org...
> Finally I found the root cause: in the subclasses of Signal I used flush()
> instead of flushWithEOS() so that the receiving party assumed there are
> charme ;-)
> Please tell me if you can compare the results, for example with your huge
> Cheers
> /Eike
>> Update:
>> Since the the output stream has (correctly) written only parts of its 512
>> Cheers
>> /Eike
>>> Hi Simon,
>>> ignored ;-(
>>> FilterOutputStream!
>>> What do you think?
>>> Cheers
>>> /Eike
>>>> Hi Simon,
>>>> used by signals.
>>>> container:
>>>> <elementProcessor
>>>> </extension>
>>>> counterwise.
>>>> [00 00 00 05]
>>>> Cheers
>>>> /Eike
>>>>> Hi Eike,
>>>>> framework ?
>>>>> your framework ?
>>>>> Simon
Re: [CDO][0.8.0] GZIP solved [message #94596 is a reply to message #94534] |
Tue, 28 August 2007 07:25   |
--------------050409080204030607050901
> Wow perfect!!!
That's indeed possible, although I'm wondering how it could ever run
without deadlocks then ;-)
> I will benchmark it at home and let you know the result tonight.
Looking forward to see the results!
Cheers
/Eike
> Simon
>> charme ;-)
>> Cheers
>> /Eike
>>> Update:
>>> Cheers
>>> /Eike
>>>> Hi Simon,
>>>> ignored ;-(
>>>> FilterOutputStream!
>>>> What do you think?
>>>> Cheers
>>>> /Eike
>>>>> Hi Simon,
>>>>> used by signals.
>>>>> container:
>>>>> <elementProcessor
>>>>> </extension>
>>>>> counterwise.
>>>>> [00 00 00 05]
>>>>> Cheers
>>>>> /Eike
>>>>>> Hi Eike,
>>>>>> framework ?
>>>>>> your framework ?
>>>>>> Simon
<html>
<head>
http-equiv="Content-Type">
</head>
<blockquote cite="mid:fb104a$ot1$1@build.eclipse.org" type="cite">
<pre wrap="">Wow perfect!!!
Maybe it will fix the hangling problem that we had ?? :-) ...</pre>
</blockquote>
Re: [CDO][0.8.0] GZIP solved [message #94888 is a reply to message #94596] |
Wed, 29 August 2007 07:38  |
------=_NextPart_000_0276_01C7EA0F.A20A1FD0
charset="ISO-8859-15"
Content-Transfer-Encoding: quoted-printable
Not for nothing...=20
I didn't have the problem yesterday.. usaully I have it...
Maybe I was lucky!!! I will update the code internally... and see if it =
solved the problem.
"Eike Stepper" <stepper@sympedia.de> wrote in message =
news:fb10mm$odv$13@build.eclipse.org...
Simon McDuff schrieb:=20
Wow perfect!!!
Maybe it will fix the hangling problem that we had ?? :-) ...That's =
indeed possible, although I'm wondering how it could ever run without =
deadlocks then ;-)
Cheers
/Eike
Simon
"Eike Stepper" <stepper@sympedia.de> wrote in message=20
Finally I found the root cause: in the subclasses of Signal I used =
flush()=20
instead of flushWithEOS() so that the receiving party assumed there are=20
It is fixed now in CVS and the GZIPStreamWrapper seems to work like a=20
charme ;-)
Please tell me if you can compare the results, for example with your =
huge=20
Cheers
/Eike
Update:
My XORInputStream and XOROutputStream now work correctly because they no =
Instead they use org.eclipse.net4j.util.io.DelegatingInputStream and=20
org.eclipse.net4j.util.io.DelegatingOutputStream which don't have the=20
GZIPInputStream and GZIPOutputStream still don't work but it seems to be =
a different root cause. They seem to correctly override the array read() =
A GZIPOutputStream properly deflates written data and the corresponding=20
However there's a fill() method in InflaterInputStream which tries to=20
Since the the output stream has (correctly) written only parts of its =
512=20
bytes buffer the input stream indefinately waits for the rest of the=20
I have never used GZIP streams before and have no idea who's fault this=20
Cheers
/Eike
Hi Simon,
I think I found the root cause of the problem. It seems to be another=20
java.io.FilterOutputStream.write(byte[], int, int) calls its own int=20
This is not necessary since the super implementation of=20
java.io.FilterInputStream.read(byte[], int, int) in contrast does *not*=20
Instead it calls in.read(b, off, len) where in is the delegate=20
InputStream. This way an override logic in its own read() method is=20
ignored ;-(
I believe in both cases it'd be better to simply not override the array=20
methods and rather use the base implementations from InputStream and=20
At least I would expect the same (redundant) logic as in=20
FilterOutputStream!
What do you think?
Cheers
/Eike
Hi Simon,
I've just provided the infrastructure for wrapping the streams to be=20
used by signals.
The easiest way to do so is adding an element processor to the managed=20
container:
<extension point=3D"org.eclipse.net4j.util.elementProcessors">
<elementProcessor=20
class=3D" org.eclipse.emf.cdo.protocol.util.CDOXORStreamWrapperInjecto r "/>=
</extension>
The element processor injects an IStreamWrapper into protocols of the=20
The example above is taken from the cdo.ui plugin and wraps the signal=20
For you I've provided CDOGZIPStreamWrapperInjector which is a subclass=20
The read() method of InputStream and the write() methop of=20
I suspect it is somehow to enable read() to signal an EndOfStream (-1)=20
Certainly only Sun knows why a magic number in a too large data type is=20
I believe that my BufferInputStream and BufferOutputStream have=20
This could of course also be because two bugs eleminate themselves=20
counterwise.
That would mean that this elimination of bugs does not happen when the=20
Anyway the result when wrapping the streams leads to an exception when=20
[00 00 00 05]
Interesting that the length is correctly received. Only the byte array=20
I suggest that you set breakpoints in=20
ExtendedIOUtil.readByteArray(DataInput) and=20
Cheers
/Eike
Hi Eike,
Did you try using GZIPOutpuStream and GZIPInputStream in your=20
framework ?
If no, where should be plug GZIPOutpuStream and GZipInputStrea, in=20
your framework ?
Simon
=20
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type =
content=3Dtext/html;charset=3DISO-8859-15>
<META content=3D"MSHTML 6.00.2900.3157" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY text=3D#000000 bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Not for nothing... </FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV>I didn't have the problem yesterday.. usaully I have it...</DIV>
<DIV><FONT face=3DArial size=3D2>Maybe I was lucky!!! I will update the =
code=20
internally... and see if it solved the problem.</FONT></DIV>
<BLOCKQUOTE dir=3Dltr=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Eike Stepper" <<A=20
href=3D"mailto:stepper@sympedia.de">stepper@sympedia.de</A>> wrote =
in message=20
<A=20
href=3D"news:fb10mm$odv$13@build.eclipse.org">news:fb10mm$odv$13@build.ec=
lipse.org</A>...</DIV>Simon=20
McDuff schrieb:=20
<BLOCKQUOTE cite=3Dmid:fb104a$ot1$1@build.eclipse.org =
type=3D"cite"><PRE wrap=3D"">Wow perfect!!!
Maybe it will fix the hangling problem that we had ?? :-) =
....</PRE></BLOCKQUOTE>That's=20
indeed possible, although I'm wondering how it could ever run without=20
deadlocks then ;-)<BR><BR>
type=3D"cite"><PRE wrap=3D""> I will benchmark it at home and let you =
</PRE></BLOCKQUOTE>Looking forward to see the=20
results!<BR><BR>Cheers<BR>/Eike<BR><BR><BR>
type=3D"cite"><PRE wrap=3D"">Simon
"Eike Stepper" <A class=3Dmoz-txt-link-rfc2396E =
href=3D"mailto:stepper@sympedia.de"><stepper@sympedia.de></A> =
wrote in message=20
<A class=3Dmoz-txt-link-freetext =
href=3D"news:fb0thn$odv$6@build.eclipse.org">news:fb0thn$odv$6@build.ecli=
pse.org</A>...
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Finally I found the root =
cause: in the subclasses of Signal I used flush()=20
charme ;-)
huge=20
Cheers
/Eike
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Update:
512=20
Cheers
/Eike
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Hi Simon,
ignored ;-(
FilterOutputStream!
What do you think?
Cheers
/Eike
</PRE>
used by signals.
container:
class=3D" org.eclipse.emf.cdo.protocol.util.CDOXORStreamWrapperInjecto r "/&=
gt;
</extension>
counterwise.
[00 00 00 05]
Cheers
/Eike
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Hi Eike,
framework ?
your framework ?
Simon
</PRE></BLOCKQUOTE></BLOCKQUOTE></BLOCKQUOTE></BLOCKQUOTE ></BLOCKQUOTE><P=
RE wrap=3D""><!---->
</PRE></BLOCKQUOTE></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_0276_01C7EA0F.A20A1FD0--
Re: [CDO][0.8.0] [message #609534 is a reply to message #94255] |
Hi Simon,
used by signals.
container:
<elementProcessor
</extension>
counterwise.
[00 00 00 05]
[00 00 00 05]
Cheers
/Eike
> Hi Eike,
> framework ?
> Simon
Re: [CDO][0.8.0] [message #609548 is a reply to message #94265] |
Hi Simon,
ignored ;-(
What do you think?
Cheers
/Eike
> Hi Simon,
> used by signals.
> container:
> <elementProcessor
> </extension>
> counterwise.
> [00 00 00 05]
> Cheers
> /Eike
>> Hi Eike,
>> framework ?
>> your framework ?
>> Simon
Re: [CDO][0.8.0] [message #609549 is a reply to message #94384] |
Update:
Cheers
/Eike
> Hi Simon,
> ignored ;-(
> FilterOutputStream!
> What do you think?
> Cheers
> /Eike
>> Hi Simon,
>> used by signals.
>> managed container:
>> <elementProcessor
>> </extension>
>> case.
>> counterwise.
>> [00 00 00 05]
>> Cheers
>> /Eike
>>> Hi Eike,
>>> framework ?
>>> your framework ?
>>> Simon
Re: [CDO][0.8.0] GZIP solved [message #609551 is a reply to message #94398] |
charme ;-)
Cheers
/Eike
> Update:
> Cheers
> /Eike
>> Hi Simon,
>> ignored ;-(
>> FilterOutputStream!
>> What do you think?
>> Cheers
>> /Eike
>>> Hi Simon,
>>> used by signals.
>>> managed container:
>>> <elementProcessor
>>> </extension>
>>> case.
>>> counterwise.
>>> [00 00 00 05]
>>> Cheers
>>> /Eike
>>>> Hi Eike,
>>>> framework ?
>>>> your framework ?
>>>> Simon
Re: [CDO][0.8.0] GZIP solved [message #609558 is a reply to message #94428] |
Wow perfect!!!
Simon
> charme ;-)
> Cheers
> /Eike
>> Update:
>> Cheers
>> /Eike
>>> Hi Simon,
>>> ignored ;-(
>>> FilterOutputStream!
>>> What do you think?
>>> Cheers
>>> /Eike
>>>> Hi Simon,
>>>> used by signals.
>>>> container:
>>>> <elementProcessor
>>>> </extension>
>>>> counterwise.
>>>> [00 00 00 05]
>>>> Cheers
>>>> /Eike
>>>>> Hi Eike,
>>>>> framework ?
>>>>> your framework ?
>>>>> Simon
Re: [CDO][0.8.0] GZIP solved [message #609562 is a reply to message #94534] |
> Wow perfect!!!
Cheers
/Eike
> Simon
>> charme ;-)
>> Cheers
>> /Eike
>>> Update:
>>> Cheers
>>> /Eike
>>>> Hi Simon,
>>>> ignored ;-(
>>>> FilterOutputStream!
>>>> What do you think?
>>>> Cheers
>>>> /Eike
>>>>> Hi Simon,
>>>>> used by signals.
>>>>> container:
>>>>> <elementProcessor
>>>>> </extension>
>>>>> counterwise.
>>>>> [00 00 00 05]
>>>>> Cheers
>>>>> /Eike
>>>>>> Hi Eike,
>>>>>> framework ?
>>>>>> your framework ?
>>>>>> Simon
<html>
<head>
</head>
</blockquote>
Re: [CDO][0.8.0] [message #609573 is a reply to message #94255] |
Tue, 28 August 2007 18:47  |
Without GZIP 1080 objects/sec...
With GZip 200 Objects/sec.
My memory usage goes very HIGH... I believe we create too much objects for
so little.
I will look where it allocate so much memory... But for now.. it is not that
good....
"Simon McDuff" <smcduff@hotmail.com> a
Re: [CDO][0.8.0] [message #609577 is a reply to message #94775] |
Wed, 29 August 2007 02:43  |
--------------010007080201090501040706
Gosh! So I spent two whole days to reduce throughput by 80% !!!
That's more than I ever managed before ;-)
> so little.
Who is "we"? I don't know what the GZIP streams do internally but I
don't create objects other than the GZIP streams.
Maybe they are not garbage collected?
> good....
Agreed ;-)
Cheers
/Eike
Re: [CDO][0.8.0] GZIP solved [message #609580 is a reply to message #94596] |
solved the problem.
Wow perfect!!!
deadlocks then ;-)
Cheers
/Eike
Simon
flush()=20
charme ;-)
huge=20
Cheers
/Eike
Update:
512=20
Cheers
/Eike
Hi Simon,
ignored ;-(
FilterOutputStream!
What do you think?
Cheers
/Eike
Hi Simon,
used by signals.
container:
</extension>
counterwise.
[00 00 00 05]
Cheers
/Eike
Hi Eike,
framework ?
your framework ?
Simon
=20
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
code=20
in message=20
<A=20
McDuff schrieb:=20
wrote in message=20
pse.org</A>...
</PRE>
charme ;-)
huge=20
Cheers
/Eike
</PRE>
512=20
Cheers
/Eike
</PRE>
ignored ;-(
FilterOutputStream!
What do you think?
Cheers
/Eike
</PRE>
used by signals.
container:
gt;
</extension>
counterwise.
[00 00 00 05]
Cheers
/Eike
</PRE>
framework ?
your framework ?
Simon
Current Time: Mon Jul 28 17:42:10 EDT 2025
Powered by FUDForum. Page generated in 0.05679 seconds
