Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » DataStore.initialize fails with eclipse.org/bpel - Model
DataStore.initialize fails with eclipse.org/bpel - Model [message #93680] |
Tue, 21 August 2007 07:53  |
i have a problem with the generation of the hibernate-mapping file.
My model project is the standard Bpel-Model from www.eclipse.org/bpel/.
I use Eclipse 3.3 WTP. And teneo 0.8. The code of the DB initialization is:
final String dataStoreName = "bpel20";
final HbDataStore dataStore = (HbDataStore) HbHelper.INSTANCE
.createRegisterDataStore(dataStoreName);
Properties hibernateProperties = new Properties();
hibernateProperties.setProperty(Environment.DRIVER,
"com.mysql.jdbc.Driver");
hibernateProperties.setProperty(Environment.USER, "XXX");
hibernateProperties.setProperty(Environment.URL,
"jdbc:mysql://127.0.0.1:3306/bpel20");
hibernateProperties.setProperty(Environment.PASS, "XXX");
hibernateProperties.setProperty(Environment.DIALECT,
"org.hibernate.dialect.MySQLInnoDBDialect");
dataStore.setHibernateProperties(hibernateProperties);
// coonfig persistence options
Properties persistenceOptions = new Properties();
persistenceOptions.setProperty(PersistenceOptions.INHERITANC E_MAPPING,
"JOINED");
PersistenceOptions.FETCH_CONTAINMENT_EAGERLY, "true");
dataStore.setPersistenceProperties(persistenceOptions);
dataStore.setEPackages(new EPackage[] {
org.eclipse.bpel.model.BPELPackage.eINSTANCE });
dataStore.initialize();
I get an error at the dataStore initalization. The following error
occured:
[main] DEBUG org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator -
Creating mapping for eclass Process
1236 [main] DEBUG
org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator - Creating
mapping for eclass ExtensibleElement
Exception in thread "main" java.lang.IllegalArgumentException: No
annotated model element present for: ExtensibleElement for type EClass
has its epackage been registered with Teneo?
at
org.eclipse.emf.teneo.annotations.pamodel.impl.PAnnotatedMod elImpl.checkAnnotatedPresent(PAnnotatedModelImpl.java:322)
at
org.eclipse.emf.teneo.annotations.pamodel.impl.PAnnotatedMod elImpl.getPAnnotated(PAnnotatedModelImpl.java:268)
at
org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator.pr ocessClass(DefaultAnnotator.java:353)
at
org.eclipse.emf.teneo.hibernate.hbannotation.util.HibernateD efaultAnnotator.processClass(HibernateDefaultAnnotator.java: 178)
at
org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator.pr ocessClass(DefaultAnnotator.java:362)
at
at
org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator.pr ocessPackage(DefaultAnnotator.java:319)
at
org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator.ma p(DefaultAnnotator.java:210)
at
org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder.buildMapping(PersistenceMappingBuilder.java:128)
at
org.eclipse.emf.teneo.hibernate.HbDataStore.mapEPackages(HbD ataStore.java:531)
at
org.eclipse.emf.teneo.hibernate.HbSessionDataStore.mapModel( HbSessionDataStore.java:149)
at
org.eclipse.emf.teneo.hibernate.HbSessionDataStore.initializ e(HbSessionDataStore.java:70)
at test.MainTest.createDatabase(MainTest.java:27)
at test.MainTest.main(MainTest.java:19)
With kind regards
Daniel Gerlach
Re: DataStore.initialize fails with eclipse.org/bpel - Model [message #93696 is a reply to message #93680] |
Tue, 21 August 2007 10:27   |
Hi Daniel,
I don't know the bpel package but Teneo seems to miss the epackage which contains the
ExtensibleElement eclass. You can try to also pass the epackage instance which contains this eclass
in the setEPackages call.
gr. Martin
daniel.gerlach1@gmx.de wrote:
> public static void main(String[] args) {
> "JOINED");
> occured:
> 1236 [main] DEBUG
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> With kind regards
> Daniel Gerlach
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: DataStore.initialize fails with eclipse.org/bpel - Model [message #93787 is a reply to message #93772] |
Tue, 21 August 2007 13:34  |
Hi Daniel,
In this case you should set the EntityNameStrategy to make the entityname unique. See here:
http://www.elver.org/hibernate/extensions.html
and then the section on the EntityNameStrategy extensionpoint.
gr. Martin
Daniel Gerlach wrote:
> now i tried the dataStore.setPackages() with all dependencies of the
> eclipse bpel.model-project, this is XSDPackage, WSDLPackage etc.
> BPELPackage bpel = BPELPackage.eINSTANCE;
> PartnerlinktypePackage partnerLink =
> PartnerlinktypePackage.eINSTANCE;
> MessagepropertiesPackage messageProperties =
> MessagepropertiesPackage.eINSTANCE;
> WSDLPackage wsdlPackage = WSDLPackage.eINSTANCE;
> XSDPackage xsdPackage = XSDPackage.eINSTANCE;
> dataStore.setEPackages(new EPackage[] { bpel, partnerLink,
> messageProperties, wsdlPackage, xsdPackage });
> Now it works but i get a "duplicate class error" for
> "ExtensibleElement.class" because it emerges in the BPELPackage and the
> WSDLPackage. Any suggestions?
> Exception in thread "main" org.hibernate.DuplicateMappingException:
> Duplicate class/entity mapping ExtensibleElement
> at org.hibernate.cfg.Mappings.addClass(Mappings.java:118)
> at
> org.hibernate.cfg.HbmBinder.handleJoinedSubclass(HbmBinder.j ava:2214)
> at org.hibernate.cfg.HbmBinder.bindRoot(HbmBinder.java:153)
> at org.hibernate.cfg.Configuration.add(Configuration.java:669)
> at org.hibernate.cfg.Configuration.addXML(Configuration.java:44 0)
> at
> org.eclipse.emf.teneo.hibernate.HbSessionDataStore.mapModel( HbSessionDataStore.java:150)
> at
> at test.MainTest.createDatabase(MainTest.java:32)
> at test.MainTest.main(MainTest.java:24)
> With kind regards
> Daniel Gerlach
The Netherlands
Re: DataStore.initialize fails with eclipse.org/bpel - Model [message #609490 is a reply to message #93680] |
Hi Daniel,
gr. Martin
> "JOINED");
> occured:
> 1236 [main] DEBUG
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> With kind regards
> Daniel Gerlach
The Netherlands
Re: DataStore.initialize fails with eclipse.org/bpel - Model [message #609495 is a reply to message #93696] |
Tue, 21 August 2007 13:26  |
PartnerlinktypePackage partnerLink = PartnerlinktypePackage.eINSTANCE;
at org.hibernate.cfg.HbmBinder.handleJoinedSubclass(HbmBinder.j ava:2214)
at
at
With kind regards
Daniel Gerlach
Re: DataStore.initialize fails with eclipse.org/bpel - Model [message #609496 is a reply to message #93772] |
Hi Daniel,
gr. Martin
> at
> at
> at
> With kind regards
> Daniel Gerlach
The Netherlands
Current Time: Wed Jul 23 21:38:20 EDT 2025
Powered by FUDForum. Page generated in 0.27079 seconds
