Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Teneo - Migrating 0.75 to 0.8
Teneo - Migrating 0.75 to 0.8 [message #93368] Wed, 15 August 2007 11:52 Go to next message
We are migrating from teneo 0.7.5 to 0.8
in 0.7.5 we implemented a method to load a hibernate file
public class ConfigurationFactory extends HbContextImpl
public Configuration createConfiguration()
// code to load hibernate.hbm.xml file
return config;
In 0.8 what changes do we need to make to implement this??
Shane
Re: Teneo - Migrating 0.75 to 0.8 [message #93462 is a reply to message #93368] Thu, 16 August 2007 13:55 Go to previous message
Hi Shane,
You have to extend the HbSessionDataStore or the HbEntityManagerDataStore to accomplish this. The
reason that this was removed from the HbContext is that Teneo supports both the classic Hibernate
Session and the Hibernate EntityManager. Both require their own configuration. Instead of creating
two types of HbContext I decided to move this method back to the datastore level. Also because
HbContext will probably disappear sometime in the future and be replaced by the extension mechanism
which I added to Teneo.
gr. Martin
Shane Coughlan wrote:
> public class ConfigurationFactory extends HbContextImpl {
> @Override
> return config;
> Shane
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Teneo - Migrating 0.75 to 0.8 [message #609475 is a reply to message #93368] Thu, 16 August 2007 13:55 Go to previous message
Hi Shane,
gr. Martin
> @Override
> return config;
> Shane
The Netherlands
Previous Topic:[Teneo] Turn off lazy-loading
Next Topic:[Teneo] Problem with the length of element names
Current Time: Fri Nov 07 19:18:49 EST 2025
Powered by FUDForum. Page generated in 0.04502 seconds
