Home » Archived » Visual Editor (VE) » VE1.1 - NoClassDefFoundError -JavaVisualEditorPart
VE1.1 - NoClassDefFoundError -JavaVisualEditorPart [message #99554] |
Sat, 23 July 2005 09:36  |
Originally posted by: tcnesham.email.uophx.edu
------=_NextPart_000_0012_01C58F61.A9EA9550
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Any help appreciated.
After installing and opening a previous project I get the error below =
(configuration details appended):
Note: I have MyEclipse installed (4.0 M2).
!ENTRY org.eclipse.ui 4 4 2005-07-23 08:21:31.357
!MESSAGE Unhandled event loop exception
ENTRY org.eclipse.ui 4 0 2005-07-23 08:21:31.397
!MESSAGE java.lang.NoClassDefFoundError
!STACK 0
at =
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.init=
(JavaVisualEditorPart.java:231)
at =
org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:773)
at =
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.=
java:572)
at =
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:3=
65)
at =
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartRefer=
ence.java:552)
at =
org.eclipse.ui.internal.PartPane.requestActivation(PartPane. java:239)
at =
org.eclipse.ui.internal.EditorPane.requestActivation(EditorP ane.java:88)
at org.eclipse.ui.internal.PartPane.setFocus(PartPane.java:295)
at org.eclipse.ui.internal.EditorPane.setFocus(EditorPane.java: 116)
at =
org.eclipse.ui.internal.presentations.PresentablePart.setFoc us(Presentabl=
ePart.java:135)
at =
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation$1.hand=
leEvent(TabbedStackPresentation.java:92)
at =
org.eclipse.ui.internal.presentations.util.AbstractTabFolder .fireEvent(Ab=
stractTabFolder.java:267)
at =
stractTabFolder.java:272)
at =
org.eclipse.ui.internal.presentations.util.AbstractTabFolder .handleMouseD=
own(AbstractTabFolder.java:342)
at =
org.eclipse.ui.internal.presentations.util.AbstractTabFolder $3.mouseDown(=
AbstractTabFolder.java:79)
at =
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:133)=
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2713)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at =
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:36=
7)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at =
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at =
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivat=
or.java:226)
at =
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:3=
76)
at =
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:1=
63)
at =
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java=
:39)
at =
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorI=
mpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:324)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=
*** Date: Sat Jul 23 08:25:06 CDT 2005
*** Platform Details:
*** System properties:
awt.toolkit=3Dsun.awt.windows.WToolkit
bea.home=3Dc:\bea
catalina.base=3D/c:/eclipse/plugins/org.eclipse.tomcat_4.1.3 0.1/
catalina.home=3D/c:/eclipse/plugins/org.eclipse.tomcat_4.1.3 0.1/
catalina.useNaming=3Dtrue
eclipse.application=3Dorg.eclipse.ui.ide.workbench
eclipse.buildId=3DI20050627-1435
eclipse.commands=3D-os
win32
-ws
win32
-arch
x86
-launcher
C:\eclipse\eclipse.exe
-name
Eclipse
-showsplash
600
-exitdata
e54_68
-vm
C:\j2sdk1.4.2_05\bin\javaw.exe
eclipse.product=3Dorg.eclipse.sdk.ide
eclipse.startTime=3D1122123271488
eclipse.vm=3DC:\j2sdk1.4.2_05\bin\javaw.exe
eclipse.vmargs=3D-Xms256M
-Xmx512M
-XX:NewSize=3D128m
-XX:MaxNewSize=3D128m
-Dbea.home=3Dc:\bea
-Duser.language=3Den
-Xmx512M
-Dosgi.splashLocation=3DC:\Program =
-jar
C:\eclipse\startup.jar
eof=3Deof
file.encoding=3DCp1252
file.encoding.pkg=3Dsun.io
file.separator=3D\
java.awt.graphicsenv=3Dsun.awt.Win32GraphicsEnvironment
java.awt.printerjob=3Dsun.awt.windows.WPrinterJob
java.class.path=3DC:\eclipse\startup.jar
java.class.version=3D48.0
java.endorsed.dirs=3DC:\j2sdk1.4.2_05\jre\lib\endorsed
java.ext.dirs=3DC:\j2sdk1.4.2_05\jre\lib\ext
java.home=3DC:\j2sdk1.4.2_05\jre
java.io.tmpdir=3DC:\DOCUME~1\TCNESH~1.CVT\LOCALS~1\Temp\
java.library.path=3DC:\j2sdk1.4.2_05\bin;.;C:\WINDOWS\System 32;C:\WINDOWS=
;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;c:\ cygwin\sbin;c=
:\cygwin\usr\sbin;c:\cygwin\usr\local\sbin;c:\cygwin\bin;c:\ cygwin\usr\bi=
n;c:\cygwin\usr\local\bin;C:\Program Files\Starbase\StarGate =
SDK\Lib;C:\Program Files\Microsoft SQL =
Server\80\Tools\BINN;c:\jdk1.3.1\bin;C:\vslick10\win;c:\vsli ck10\win;c:\b=
ea;c:\eclipse
java.naming.factory.initial=3Dorg.apache.naming.java.javaURL ContextFactor=
y
java.naming.factory.url.pkgs=3Dorg.apache.naming
java.runtime.name=3DJava(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=3D1.4.2_05-b04
java.specification.name=3DJava Platform API Specification
java.specification.vendor=3DSun Microsystems Inc.
java.specification.version=3D1.4
java.util.prefs.PreferencesFactory=3Djava.util.prefs.Windows PreferencesFa=
ctory
java.vendor=3DSun Microsystems Inc.
java.vendor.url=3Dhttp://java.sun.com/
java.vendor.url.bug=3Dhttp://java.sun.com/cgi-bin/bugreport.cgi
java.version=3D1.4.2_05
java.vm.info=3Dmixed mode
java.vm.name=3DJava HotSpot(TM) Client VM
java.vm.specification.name=3DJava Virtual Machine Specification
java.vm.specification.vendor=3DSun Microsystems Inc.
java.vm.specification.version=3D1.0
java.vm.vendor=3DSun Microsystems Inc.
java.vm.version=3D1.4.2_05-b04
line.separator=3D
org.eclipse.jdt.debug.ui.scrapbookActive=3Dfalse
org.osgi.framework.bootdelegation=3D*
org.osgi.framework.executionenvironment=3DJ2SE-1.4
org.osgi.framework.language=3Den
org.osgi.framework.os.name=3DWindowsXP
org.osgi.framework.os.version=3D5.1
org.osgi.framework.processor=3Dx86
org.osgi.framework.system.packages=3Djavax.accessibility,jav ax.crypto,jav=
ax.crypto.interfaces,javax.crypto.spec,javax.imageio,javax.i mageio.event,=
javax.imageio.metadata,javax.imageio.plugins.jpeg,javax.imag eio.spi,javax=
..imageio.stream,javax.naming,javax.naming.directory,javax.n aming.event,ja=
vax.naming.ldap,javax.naming.spi,javax.net,javax.net.ssl,jav ax.print,java=
x.print.attribute,javax.print.attribute.standard,javax.print .event,javax.=
rmi,javax.rmi.CORBA,javax.security.auth,javax.security.auth. callback,java=
x.security.auth.kerberos,javax.security.auth.login,javax.sec urity.auth.sp=
i,javax.security.auth.x500,javax.security.cert,javax.sound.m idi,javax.sou=
nd.midi.spi,javax.sound.sampled,javax.sound.sampled.spi,java x.sql,javax.s=
wing,javax.swing.border,javax.swing.colorchooser,javax.swing .event,javax.=
swing.filechooser,javax.swing.plaf,javax.swing.plaf.basic,ja vax.swing.pla=
f.metal,javax.swing.plaf.multi,javax.swing.table,javax.swing .text,javax.s=
wing.text.html,javax.swing.text.html.parser,javax.swing.text .rtf,javax.sw=
ing.tree,javax.swing.undo,javax.transaction,javax.transactio n.xa,javax.xm=
l.parsers,javax.xml.transform,javax.xml.transform.dom,javax. xml.transform=
..sax,javax.xml.transform.stream,org.ietf.jgss,org.omg.CORBA ,org.omg.CORBA=
_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynAnyPackage, org.omg.CORBA=
..ORBPackage,org.omg.CORBA.portable,org.omg.CORBA.TypeCodePa ckage,org.omg.=
CosNaming,org.omg.CosNaming.NamingContextExtPackage,org.omg. CosNaming.Nam=
ingContextPackage,org.omg.Dynamic,org.omg.DynamicAny,org.omg .DynamicAny.D=
ynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,org.omg .IOP,org.omg.=
IOP.CodecFactoryPackage,org.omg.IOP.CodecPackage,org.omg.Mes saging,org.om=
g.PortableInterceptor,org.omg.PortableInterceptor.ORBInitInf oPackage,org.=
omg.PortableServer,org.omg.PortableServer.CurrentPackage,org .omg.Portable=
Server.POAManagerPackage,org.omg.PortableServer.POAPackage,o rg.omg.Portab=
leServer.portable,org.omg.PortableServer.ServantLocatorPacka ge,org.omg.Se=
ndingContext,org.omg.stub.java.rmi,org.w3c.dom,org.xml.sax,o rg.xml.sax.ex=
t,org.xml.sax.helpers
org.osgi.framework.vendor=3DEclipse
org.osgi.framework.version=3D1.3.0
org.osgi.supports.framework.extension=3Dtrue
os.arch=3Dx86
os.name=3DWindows XP
os.version=3D5.1
osgi.arch=3Dx86
osgi.bundles=3Dorg.eclipse.core.runtime@2:start, =
org.eclipse.update.configurator@3:start
osgi.bundlestore=3Dc:\eclipse\configuration\org.eclipse.osgi \bundles
osgi.configuration.area=3Dfile:/c:/eclipse/configuration/
osgi.framework=3Dfile:/c:/eclipse/plugins/org.eclipse.osgi_3 .1.0.jar
osgi.framework.beginningstartlevel=3D1
osgi.framework.shape=3Djar
osgi.framework.version=3D3.0.0
osgi.install.area=3Dfile:/c:/eclipse/
osgi.instance.area=3Dfile:/C:/eclipse/
osgi.instance.area.default=3Dfile:/C:/Documents and =
Settings/tcnesham.CVTY/workspace/
osgi.logfile=3DC:\eclipse\.metadata\.log
osgi.manifest.cache=3Dc:\eclipse\configuration\org.eclipse.o sgi\manifests=
osgi.nl=3Den_US
osgi.os=3Dwin32
osgi.splashPath=3Dplatform:/base/plugins/org.eclipse.platfor m
osgi.syspath=3Dc:\eclipse\plugins
osgi.ws=3Dwin32
path.separator=3D;
sun.arch.data.model=3D32
sun.boot.class.path=3DC:\j2sdk1.4.2_05\jre\lib\rt.jar;C:\j2s dk1.4.2_05\jr=
e\lib\i18n.jar;C:\j2sdk1.4.2_05\jre\lib\sunrsasign.jar;C:\j2 sdk1.4.2_05\j=
re\lib\jsse.jar;C:\j2sdk1.4.2_05\jre\lib\jce.jar;C:\j2sdk1.4 .2_05\jre\lib=
\charsets.jar;C:\j2sdk1.4.2_05\jre\classes
sun.boot.library.path=3DC:\j2sdk1.4.2_05\jre\bin
sun.cpu.endian=3Dlittle
sun.cpu.isalist=3Dpentium i486 i386
sun.io.unicode.encoding=3DUnicodeLittle
sun.java2d.fontpath=3D
sun.os.patch.level=3DService Pack 1
user.country=3DUS
user.dir=3DC:\eclipse
user.home=3DC:\Documents and Settings\tcnesham.CVTY
user.language=3Den
user.name=3Dtcnesham
user.timezone=3DAmerica/Chicago
user.variant=3D
*** Features:
com.genuitec.myeclipse.ast (3.9.210) "MyEclipse Application Server =
Tooling"
com.genuitec.myeclipse.bugzilla (3.9.210) "MyEclipse Bugzilla Feature"
com.genuitec.myeclipse.core (3.9.211) "MyEclipse Core Feature"
com.genuitec.myeclipse.database (3.9.210) "MyEclipse Database Feature"
com.genuitec.myeclipse.enterprise (3.8.4) "MyEclipse Enterprise =
Workbench"
com.genuitec.myeclipse.enterprise.workbench (3.9.211) "MyEclipse =
Enterprise Workbench Feature"
com.genuitec.myeclipse.help (3.9.211) "MyEclipse Help Feature"
com.genuitec.myeclipse.hibernate (3.9.211) "MyEclipse Hibernate Feature"
com.genuitec.myeclipse.jsf (3.9.210) "MyEclipse JSF Feature"
com.genuitec.myeclipse.jspdesign (3.9.211) "MyEclipse JSP Design =
Feature"
com.genuitec.myeclipse.platform (3.9.210) "MyEclipse Base Platform =
Feature"
com.genuitec.myeclipse.spring (3.9.211) "MyEclipse Spring Feature"
com.genuitec.myeclipse.struts (3.9.211) "MyEclipse Struts Feature"
com.genuitec.myeclipse.tapestry (3.9.210) "MyEclipse Tapestry / Spindle =
Feature"
com.genuitec.myeclipse.uml (3.9.211) "MyEclipse UML Feature"
com.genuitec.myeclipse.wdt (3.9.210) "MyEclipse Web Development Feature"
org.eclipse.emf (2.1.0) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.ecore.sdo (2.1.0) "EMF Service Data Objects (SDO)"
org.eclipse.gef (3.1.0) "Graphical Editing Framework"
org.eclipse.jdt (3.1.0) "Eclipse Java Development Tools"
org.eclipse.jdt.source (3.1.0) "Eclipse Java Development Tools SDK"
org.eclipse.jem (1.1.0) "Java EMF Model"
org.eclipse.pde (3.1.0) "Eclipse Plug-in Development Environment"
org.eclipse.pde.source (3.1.0) "Eclipse Plug-in Development Environment =
Developer Resources"
org.eclipse.platform (3.1.0) "Eclipse Platform"
org.eclipse.platform.source (3.1.0) "Eclipse Platform Plug-in Developer =
Resources"
org.eclipse.rcp (3.1.0) "Eclipse RCP"
org.eclipse.rcp.source (3.1.0) "Eclipse RCP Plug-in Developer Resources"
org.eclipse.sdk (3.1.0) "Eclipse Project SDK"
org.eclipse.ve (1.1.0) "Visual Editor"
*** Plug-in Registry:
com.genuitec.eclipse.ast.deploy.core (3.8.4) "Deployment Core Plug-in" =
[Installed]
com.genuitec.eclipse.ast.deploy.core (3.9.210) "Deployment Core Plug-in" =
[Active]
com.genuitec.eclipse.browser (3.8.4) "Web Browser Plug-in" [Resolved]
com.genuitec.eclipse.bugzilla (3.8.4) "MyEclipse Bugzilla Integration =
Plug-in" [Installed]
com.genuitec.eclipse.bugzilla (3.9.210) "MyEclipse Bugzilla Integration =
Plug-in" [Resolved]
com.genuitec.eclipse.core (3.8.4) "Genuitec Core" [Installed]
com.genuitec.eclipse.core (3.9.210) "Genuitec Core" [Active]
com.genuitec.eclipse.cross.easystruts.eclipse (3.8.4) "MyEclipse Stuts =
Support" [Installed]
com.genuitec.eclipse.cross.easystruts.eclipse (3.9.210) "MyEclipse Stuts =
Support" [Active]
com.genuitec.eclipse.easie.bejy (3.8.1) "Genuitec EASIE Bejy Tiger" =
[Active]
com.genuitec.eclipse.easie.core (3.8.4) "Genuitec EASIE Core" =
[Installed]
com.genuitec.eclipse.easie.core (3.9.210) "Genuitec EASIE Core" [Active]
com.genuitec.eclipse.easie.jboss (3.8.2) "Genuitec EASIE JBoss" [Active]
com.genuitec.eclipse.easie.jboss2 (3.8.1) "Genuitec EASIE JBoss 2" =
[Active]
com.genuitec.eclipse.easie.jboss3 (3.8.2) "Genuitec EASIE JBoss 3" =
[Active]
com.genuitec.eclipse.easie.jboss4 (3.8.2) "Genuitec EASIE JBoss 4" =
[Active]
com.genuitec.eclipse.easie.jetty (3.8.1) "Genuitec EASIE Jetty" [Active]
com.genuitec.eclipse.easie.jetty4 (3.8.1) "Genuitec EASIE Jetty 4" =
[Active]
com.genuitec.eclipse.easie.jetty5 (3.8.1) "Genuitec EASIE Jetty 5" =
[Active]
com.genuitec.eclipse.easie.jonas (3.8.3) "Genuitec EASIE Jonas" [Active]
com.genuitec.eclipse.easie.jonas3 (3.8.3) "Genuitec EASIE Jonas 3" =
[Active]
com.genuitec.eclipse.easie.jonas4 (3.8.3) "Genuitec EASIE Jonas 4" =
[Active]
com.genuitec.eclipse.easie.jrun (3.8.1) "Genuitec EASIE JRun" [Active]
com.genuitec.eclipse.easie.jrun4 (3.8.1) "Genuitec EASIE JRun 4" =
[Active]
com.genuitec.eclipse.easie.oracle (3.8.1) "Genuitec EASIE Oracle AS" =
[Active]
com.genuitec.eclipse.easie.oracle9 (3.8.1) "Genuitec EASIE Oracle 9i/AS" =
[Active]
com.genuitec.eclipse.easie.orion1 (3.8.1) "Genuitec EASIE Orion 1" =
[Active]
com.genuitec.eclipse.easie.orion2 (3.8.1) "Genuitec EASIE Orion 2" =
[Active]
com.genuitec.eclipse.easie.resin (3.8.1) "Genuitec EASIE Resin" [Active]
com.genuitec.eclipse.easie.resin2 (3.8.1) "Genuitec EASIE Resin 2" =
[Active]
com.genuitec.eclipse.easie.resin3 (3.8.3) "Genuitec EASIE Resin 3" =
[Active]
com.genuitec.eclipse.easie.sun (3.8.3) "Genuitec EASIE Sun One" [Active]
com.genuitec.eclipse.easie.sun8 (3.8.3) "Genuitec EASIE Sun 8" [Active]
com.genuitec.eclipse.easie.sun81 (3.8.3) "Genuitec EASIE Sun 8.1" =
[Active]
com.genuitec.eclipse.easie.tomcat (3.8.1) "Genuitec EASIE Tomcat" =
[Active]
com.genuitec.eclipse.easie.tomcat4 (3.8.1) "Genuitec EASIE Tomcat 4" =
[Active]
com.genuitec.eclipse.easie.tomcat5 (3.8.1) "Genuitec EASIE Tomcat 5" =
[Active]
com.genuitec.eclipse.easie.weblogic (3.8.3) "Genuitec EASIE WebLogic" =
[Installed]
com.genuitec.eclipse.easie.weblogic (3.9.210) "Genuitec EASIE WebLogic" =
[Active]
com.genuitec.eclipse.easie.weblogic6 (3.8.1) "Genuitec EASIE WebLogic 6" =
[Active]
com.genuitec.eclipse.easie.weblogic7 (3.8.1) "Genuitec EASIE WebLogic 7" =
[Active]
com.genuitec.eclipse.easie.weblogic8 (3.8.1) "Genuitec EASIE WebLogic 8" =
[Active]
com.genuitec.eclipse.easie.weblogic9 (3.9.210) "Genuitec EASIE WebLogic =
9" [Active]
com.genuitec.eclipse.easie.websphere (3.8.1) "Genuitec EASIE WebSphere =
4" [Active]
com.genuitec.eclipse.easie.websphere5 (3.8.1) "Genuitec EASIE WebSphere =
5" [Active]
com.genuitec.eclipse.export.wizard (3.8.4) "MyEclipse J2EE Export =
Wizards" [Installed]
com.genuitec.eclipse.export.wizard (3.9.210) "MyEclipse J2EE Export =
Wizards" [Resolved]
com.genuitec.eclipse.hibernate (3.8.4) "MyEclipse Hibernate =
Capabilities" [Installed]
com.genuitec.eclipse.hibernate (3.9.211) "MyEclipse Hibernate =
Capabilities" [Active]
com.genuitec.eclipse.integration (3.8.4) "MyEclipse Integration =
Utilities" [Resolved]
com.genuitec.eclipse.integration (3.9.211) "MyEclipse Integration =
Utilities" [Active]
com.genuitec.eclipse.j2eedt.core (3.8.4) "Genuitec J2EE Development =
Tooling" [Installed]
com.genuitec.eclipse.j2eedt.core (3.9.210) "Genuitec J2EE Development =
Tooling" [Active]
com.genuitec.eclipse.jface.text.wtpfragment (3.8.1) "Wtpextendfragment =
Fragment" [Resolved]
com.genuitec.eclipse.jsf (3.8.1) "JSF Plug-in" [Installed]
com.genuitec.eclipse.jsf (3.9.210) "MyEclipse JSF Capabilities" [Active]
com.genuitec.eclipse.modeling.core (3.8.4) "MyEclipse Modeling Core" =
[Resolved]
com.genuitec.eclipse.modeling.core (3.9.210) "MyEclipse Modeling Core" =
[Resolved]
com.genuitec.eclipse.springframework (3.9.211) "Springframework Plug-in" =
[Resolved]
com.genuitec.eclipse.sqlexplorer (3.8.4) "MyEclipse Database Explorer =
Plugin" [Installed]
com.genuitec.eclipse.sqlexplorer (3.9.210) "MyEclipse Database Explorer =
Plugin" [Resolved]
com.genuitec.eclipse.sqlexplorer.doc (3.8.4) "MyEclipse Database =
Explorer Help Plug-in" [Resolved]
com.genuitec.eclipse.sqlexplorer.oracle (3.8.4) "Oracle Database =
Explorer Plug-in" [Resolved]
com.genuitec.eclipse.sqlexplorer.oracle (3.9.210) "Oracle Database =
com.genuitec.eclipse.struts (3.8.4) "MyEclipse Struts Capabilities" =
[Installed]
com.genuitec.eclipse.struts (3.9.211) "MyEclipse Struts Capabilities" =
[Active]
com.genuitec.eclipse.tapestry (3.9.210) "MyEclipse Tapestry Integration =
Plug-in" [Resolved]
com.genuitec.eclipse.tapestry.docs.contrib (3.9.210) "MyEclipse Tapestry =
Documentation Integration Fragment" [Resolved]
com.genuitec.eclipse.tapestry.ui.contrib (3.9.210) "MyEclipse Tapestry =
UI Integration Fragment" [Resolved]
com.genuitec.eclipse.uml (3.9.211) "MyEclipse UML Plug-in" [Resolved]
com.genuitec.eclipse.wdt.jsp.debug (3.8.4) "MyEclipse JSP Debug Tooling" =
[Installed]
com.genuitec.eclipse.wdt.jsp.debug (3.9.210) "MyEclipse JSP Debug =
Tooling" [Active]
com.genuitec.eclipse.web.imagepreviewer (3.8.3) "MyEclipse Image =
Previewer Plug-in" [Installed]
com.genuitec.eclipse.web.imagepreviewer (3.9.210) "MyEclipse Image =
Previewer Plug-in" [Active]
com.genuitec.eclipse.webdesigner (3.8.3) "Web Designer Plug-in" =
[Installed]
com.genuitec.eclipse.webdesigner (3.9.210) "Web Designer Plug-in" =
[Active]
com.genuitec.eclipse.webdesigner.support (3.8.1) "WebDesigner Support" =
[Resolved]
com.genuitec.eclipse.webdesigner.support (3.9.211) "WebDesigner Support" =
[Resolved]
com.genuitec.eclipse.wizards (3.8.4) "MyEclipse File Creation Wizards" =
[Installed]
com.genuitec.eclipse.wizards (3.9.210) "MyEclipse File Creation Wizards" =
[Active]
com.genuitec.eclipsetidy (3.8.1) "MyEclipse HTML Formatting" [Active]
com.genuitec.jboss.ide.eclipse.apache.xalan (3.8.1) "Genuitec XDoclet =
Apache Xalan Plug-in" [Resolved]
com.genuitec.jboss.ide.eclipse.core (3.8.3) "Genuitec XDoclet Support =
Core Plug-in" [Resolved]
com.genuitec.jboss.ide.eclipse.xdoclet.assist (3.8.4) "Genuitec XDoclet =
Assist Plug-in" [Installed]
com.genuitec.jboss.ide.eclipse.xdoclet.assist (3.9.210) "Genuitec =
XDoclet Assist Plug-in" [Resolved]
com.genuitec.jboss.ide.eclipse.xdoclet.core (3.8.3) "Genuitec XDoclet =
Core Plug-in" [Installed]
com.genuitec.jboss.ide.eclipse.xdoclet.core (3.9.210) "Genuitec XDoclet =
com.genuitec.jboss.ide.eclipse.xdoclet.run (3.8.3) "Genuitec XDoclet =
Runner Plug-in" [Installed]
com.genuitec.jboss.ide.eclipse.xdoclet.run (3.9.210) "Genuitec XDoclet =
Runner Plug-in" [Resolved]
com.genuitec.jboss.ide.eclipse.xdoclet.ui (3.8.3) "Genuitec XDoclet UI =
com.genuitec.jboss.ide.eclipse.xdoclet.ui (3.9.210) "Genuitec XDoclet UI =
Plug-in" [Resolved]
com.genuitec.myeclipse.ast (3.8.4) "MyEclipse Application Server =
Tooling" [Resolved]
Tooling" [Resolved]
com.genuitec.myeclipse.bugzilla (3.9.210) "MyEclipse Bugzilla Feature" =
[Resolved]
com.genuitec.myeclipse.core (3.9.211) "MyEclipse Core Feature" =
[Resolved]
com.genuitec.myeclipse.core (3.8.4) "MyEclipse Core Tooling" [Resolved]
com.genuitec.myeclipse.database (3.9.210) "MyEclipse Database Feature" =
[Resolved]
com.genuitec.myeclipse.doc (3.8.4) "MyEclipse Documentation" [Installed]
com.genuitec.myeclipse.doc (3.9.211) "MyEclipse Documentation" =
[Resolved]
Workbench" [Resolved]
Enterprise Workbench Feature" [Resolved]
com.genuitec.myeclipse.help (3.8.4) "MyEclipse Help Documentation" =
[Resolved]
com.genuitec.myeclipse.help (3.9.211) "MyEclipse Help Feature" =
[Resolved]
com.genuitec.myeclipse.hibernate (3.9.211) "MyEclipse Hibernate Feature" =
[Resolved]
com.genuitec.myeclipse.jsf (3.9.210) "MyEclipse JSF Feature" [Resolved]
Feature" [Resolved]
com.genuitec.myeclipse.perspective (3.8.4) "MyEclipse Perspective =
com.genuitec.myeclipse.perspective (3.9.210) "MyEclipse Perspective =
Plug-in" [Active]
Feature" [Resolved]
com.genuitec.myeclipse.spring (3.9.211) "MyEclipse Spring Feature" =
[Resolved]
com.genuitec.myeclipse.struts (3.9.211) "MyEclipse Struts Feature" =
[Resolved]
Feature" [Resolved]
com.genuitec.myeclipse.uml (3.9.211) "MyEclipse UML Feature" [Resolved]
com.genuitec.myeclipse.wdt (3.9.210) "MyEclipse Web Development Feature" =
[Resolved]
com.genuitec.myeclipse.wdt (3.8.4) "MyEclipse Web Development Tooling" =
[Resolved]
com.ibm.base.extensions (13.8.1) "Eclipse base extensions" [Resolved]
com.ibm.base.extensions.ui (13.8.3) "Eclipse Base UI extensions" =
[Installed]
com.ibm.base.extensions.ui (13.9.210) "Eclipse Base UI extensions" =
[Active]
com.ibm.encoding.resource (13.8.3) "Coded Resource" [Resolved]
com.ibm.encoding.resource (13.9.210) "Coded Resource" [Active]
com.ibm.etools.contentmodel (13.8.4) "Content Model" [Resolved]
com.ibm.etools.contentmodel.dtd (13.8.2) "Content Model for DTD" =
[Resolved]
com.ibm.etools.contentmodel.xsd (13.8.1) "Content Model for XML Schema" =
[Resolved]
com.ibm.etools.dtdmodel (13.8.2) "DTD Model" [Resolved]
com.ibm.etools.dtdparser (13.8.1) "DTD Parser" [Resolved]
com.ibm.etools.emf.event (3.0.0.1) "Event Model" [Resolved]
com.ibm.etools.internet (13.8.1) "Internet Preferences" [Active]
com.ibm.etools.uri.resolver (13.8.3) "com.ibm.etools.uri.resolver" =
[Active]
com.ibm.etools.validation (13.8.4) "Validation Framework" [Active]
com.ibm.etools.validation.core (13.8.4) "Validation Framework Core" =
[Resolved]
com.ibm.etools.validation.dtd (13.8.4) "DTD Validator" [Active]
com.ibm.etools.validation.html (13.8.3) "HTML Validation" [Resolved]
com.ibm.etools.validation.mof (13.8.1) "Validation Framework MOF =
support" [Resolved]
com.ibm.etools.validation.ui (13.8.3) "Validation Framework UI" =
[Resolved]
com.ibm.etools.validation.xml (13.8.4) "XML Validator" [Active]
com.ibm.etools.validation.xmltools (13.8.1) "XML Tools Validation" =
[Active]
com.ibm.etools.validation.xsd (13.8.4) "XML Schema Validator" [Active]
com.ibm.etools.xml.gef.util (13.8.1) "XML Tools Common GEF Utilities" =
[Resolved]
com.ibm.etools.xml.gef.util (13.9.210) "XML Tools Common GEF Utilities" =
[Resolved]
com.ibm.etools.xmlcatalog (13.8.4) "com.ibm.etools.xmlcatalog" [Active]
com.ibm.etools.xmlcatalog.ui (13.8.4) "XML Catalog UI" [Active]
com.ibm.etools.xmlutility (13.8.1) "XML Utility" [Resolved]
com.ibm.sse.contentproperties (13.8.1) "Content Properties" [Active]
com.ibm.sse.editor (13.8.4) "MyEclipse Source Editors" [Installed]
com.ibm.sse.editor (13.9.210) "MyEclipse Source Editors" [Active]
com.ibm.sse.editor.css (13.8.3) "SSE CSS Source Editor" [Installed]
com.ibm.sse.editor.css (13.9.210) "SSE CSS Source Editor" [Resolved]
com.ibm.sse.editor.dtd (13.8.3) "SSE DTD Source Editor" [Installed]
com.ibm.sse.editor.dtd (13.9.210) "SSE DTD Source Editor" [Resolved]
com.ibm.sse.editor.extensions (13.8.1) "Structured Source Editing Editor =
Extensions" [Resolved]
com.ibm.sse.editor.html (13.8.3) "SSE HTML Source Editor" [Installed]
com.ibm.sse.editor.html (13.9.210) "SSE HTML Source Editor" [Resolved]
com.ibm.sse.editor.javascript (13.8.4) "SSE JavaScript Source Editor" =
[Resolved]
com.ibm.sse.editor.jsp (13.8.4) "SSE JSP Source Editor" [Installed]
com.ibm.sse.editor.jsp (13.9.210) "SSE JSP Source Editor" [Resolved]
com.ibm.sse.editor.xml (13.8.4) "SSE XML Source Editor" [Installed]
com.ibm.sse.editor.xml (13.9.210) "SSE XML Source Editor" [Resolved]
com.ibm.sse.javascript.common.ui (13.8.1) "SSE JavaScript Common UI" =
[Resolved]
com.ibm.sse.model (13.8.4) "Structured Text Model" [Installed]
com.ibm.sse.model (13.9.210) "Structured Text Model" [Active]
com.ibm.sse.model.css (13.8.3) "Structured Source CSS Model" [Active]
com.ibm.sse.model.dtd (13.8.3) "Structured Source DTD Model" [Active]
com.ibm.sse.model.html (13.8.3) "Structured Source HTML Model" =
[Installed]
com.ibm.sse.model.html (13.9.210) "Structured Source HTML Model" =
[Active]
com.ibm.sse.model.javascript (13.8.3) "Structured Source JavaScript =
Model" [Resolved]
com.ibm.sse.model.jsp (13.8.4) "Structured Source JSP Model" [Installed]
com.ibm.sse.model.jsp (13.9.210) "Structured Source JSP Model" [Active]
com.ibm.sse.model.xml (13.8.4) "Structured Source XML Model" [Installed]
com.ibm.sse.model.xml (13.9.210) "Structured Source XML Model" [Active]
com.ibm.sse.snippets (13.8.3) "SSE Snippets View" [Active]
com.ibm.webtooling.system.dtds (13.8.4) "Known DTDs" [Installed]
com.ibm.webtooling.system.dtds (13.9.210) "Known DTDs" [Resolved]
com.ibm.wtp.annotations.controller (13.8.1) "Annotation Controller =
Plug-in" [Resolved]
com.ibm.wtp.annotations.core (13.8.1) "Annotation Core Plug-in" =
[Resolved]
com.ibm.wtp.annotations.core (13.9.210) "Annotation Core Plug-in" =
[Resolved]
com.ibm.wtp.annotations.ui (13.8.1) "Ui Plug-in" [Resolved]
com.ibm.wtp.common (13.8.1) "com.ibm.wtp.common" [Active]
com.ibm.wtp.common.ui (13.8.1) "WTP UI Plug-in" [Resolved]
com.ibm.wtp.common.util (1.0.0) "Logging Plug-in" [Active]
com.ibm.wtp.emf (13.8.1) "EMF Utilities" [Resolved]
com.ibm.wtp.emf.workbench (1.0.0) "EMF Workbench" [Resolved]
com.ibm.wtp.emf.workbench.edit (13.8.4) "EMF Workbench Edit Plug-in" =
[Resolved]
com.ibm.wtp.jdt.integration (13.8.1) "Integration Plug-in" [Resolved]
com.ibm.xmleditor (13.8.3) "SSE XML Editor" [Installed]
com.ibm.xmleditor (13.9.210) "SSE XML Editor" [Resolved]
com.ibm.xmlwizard (13.8.3) "XML Wizards" [Installed]
com.ibm.xmlwizard (13.9.210) "XML Wizards" [Resolved]
com.ibm.xsdeditor (13.8.3) "MyEclipse Schema Editor" [Installed]
com.ibm.xsdeditor (13.9.210) "MyEclipse Schema Editor" [Active]
com.ibm.xtools.common.ui.properties (13.8.1) "IBM Rational Common UI =
Properties" [Resolved]
com.iw.plugins.spindle.core (3.9.210) "Spindle Core Plugin" [Resolved]
com.iw.plugins.spindle.docs (3.9.210) "Spindle 3 Documentation" =
[Resolved]
com.iw.plugins.spindle.ui (3.9.210) "Spindle UI plugin" [Resolved]
de.bb.bje.eclipse (3.8.1) "BJE Plug-in" [Resolved]
net.sf.solareclipse.ui (0.4.0.spindle-dep-6) "SolarEclipse UI" =
[Resolved]
net.sf.solareclipse.xml.ui (0.4.0.spindle-dep-6) "XML Development Tools =
UI" [Resolved]
org.apache.ant (1.6.5) "Apache Ant" [Resolved]
org.apache.lucene (1.4.3) "Apache Lucene" [Resolved]
org.apache.xerces (4.0.13) "Spindle 3 Xerces Plug-in" [Resolved]
org.eclipse.ant.core (3.1.0) "Ant Build Tool Core" [Resolved]
org.eclipse.ant.ui (3.1.0) "Ant UI" [Resolved]
org.eclipse.compare (3.1.0) "Compare Support" [Active]
org.eclipse.core.boot (3.1.0) "Core Boot" [Resolved]
org.eclipse.core.commands (3.1.0) "Commands" [Active]
org.eclipse.core.expressions (3.1.0) "Expression Language" [Active]
org.eclipse.core.filebuffers (3.1.0) "File Buffers" [Active]
org.eclipse.core.resources (3.1.0) "Core Resource Management" [Active]
org.eclipse.core.resources.compatibility (3.1.0) "Core Resource =
Management Compatibility Fragment" [Resolved]
org.eclipse.core.resources.win32 (3.1.0) "Core Resource Management Win32 =
org.eclipse.core.runtime (3.1.0) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.0) "Core Runtime Plug-in =
Compatibility" [Active]
org.eclipse.core.variables (3.1.0) "Core Variables" [Resolved]
org.eclipse.debug.core (3.1.0) "Debug Core" [Active]
org.eclipse.debug.ui (3.1.0) "Debug UI" [Active]
org.eclipse.draw2d (3.0.0) "Draw2d" [Resolved]
org.eclipse.draw2d (3.1.0) "Draw2d" [Active]
org.eclipse.emf (2.1.0) "Eclipse Modeling Framework (EMF)" [Resolved]
org.eclipse.emf.ant (2.1.0) "EMF Ant Tasks" [Resolved]
org.eclipse.emf.codegen (2.0.0) "EMF Template Code Generator" =
[Installed]
org.eclipse.emf.codegen (2.1.0) "EMF Template Code Generator" [Active]
org.eclipse.emf.codegen.ecore (2.0.0) "EMF Ecore Code Generation" =
[Installed]
org.eclipse.emf.codegen.ecore (2.1.0) "EMF Ecore Code Generation" =
[Resolved]
org.eclipse.emf.codegen.ecore.ui (2.1.0) "EMF Ecore Code Generation UI" =
[Resolved]
org.eclipse.emf.codegen.ui (2.1.0) "EMF Template Code Generator UI" =
[Resolved]
org.eclipse.emf.common (2.0.0) "EMF Common" [Resolved]
org.eclipse.emf.common (2.1.0) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.0.0) "EMF Common UI" [Resolved]
org.eclipse.emf.common.ui (2.0.1) "EMF Common UI" [Resolved]
org.eclipse.emf.common.ui (2.1.0) "EMF Common UI" [Resolved]
org.eclipse.emf.commonj.sdo (2.1.0) "CommonJ SDO" [Resolved]
org.eclipse.emf.ecore (2.0.0) "EMF Ecore" [Installed]
org.eclipse.emf.ecore (2.1.0) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.1.0) "EMF Ecore Change Model" [Resolved]
org.eclipse.emf.ecore.change.edit (2.1.0) "EMF Ecore Change Edit =
Support" [Resolved]
org.eclipse.emf.ecore.edit (2.1.0) "EMF Ecore Edit Support" [Resolved]
org.eclipse.emf.ecore.editor (2.1.0) "Sample Ecore Editor" [Resolved]
org.eclipse.emf.ecore.sdo (2.1.0) "EMF Service Data Objects (SDO)" =
[Resolved]
org.eclipse.emf.ecore.sdo.edit (2.1.0) "EMF Service Data Objects (SDO) =
org.eclipse.emf.ecore.sdo.editor (2.1.0) "EMF Service Data Objects (SDO) =
Editor" [Resolved]
org.eclipse.emf.ecore.xmi (2.0.0) "EMF XMI" [Installed]
org.eclipse.emf.ecore.xmi (2.1.0) "EMF XMI" [Resolved]
org.eclipse.emf.edit (2.0.0) "EMF Edit" [Installed]
org.eclipse.emf.edit (2.1.0) "EMF Edit" [Resolved]
org.eclipse.emf.edit.ui (2.0.0) "EMF Edit UI" [Resolved]
org.eclipse.emf.edit.ui (2.1.0) "EMF Edit UI" [Resolved]
org.eclipse.emf.importer (2.1.0) "EMF Model Import Support" [Resolved]
org.eclipse.emf.importer.ecore (2.1.0) "EMF Ecore Importer" [Resolved]
org.eclipse.emf.importer.java (2.1.0) "EMF Annotated Java Importer" =
[Resolved]
org.eclipse.emf.importer.rose (2.1.0) "EMF Rose Importer" [Resolved]
org.eclipse.emf.mapping (2.1.0) "EMF Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore (2.1.0) "Ecore to Ecore Mapping" =
[Resolved]
org.eclipse.emf.mapping.ecore2ecore.editor (2.1.0) "Ecore to Ecore =
Mapping Editor" [Resolved]
org.eclipse.emf.mapping.ecore2xml (2.1.0) "Ecore to XML Mapping" =
[Resolved]
org.eclipse.emf.mapping.ecore2xml.ui (2.1.0) "Ecore to XML Mapping UI" =
[Resolved]
org.eclipse.emf.mapping.ui (2.1.0) "EMF Mapping UI" [Resolved]
org.eclipse.gef (3.0.0) "Graphical Editing Framework" [Installed]
org.eclipse.gef (3.1.0) "Graphical Editing Framework" [Active]
org.eclipse.help (3.1.0) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.0) "Help Application Server" [Active]
org.eclipse.help.base (3.1.0) "Help System Base" [Active]
org.eclipse.help.ui (3.1.0) "Help System UI" [Active]
org.eclipse.help.webapp (3.1.0) "Help System Webapp" [Resolved]
org.eclipse.jdt (3.1.0) "Eclipse Java Development Tools" [Resolved]
org.eclipse.jdt.core (3.1.0) "Java Development Tools Core" [Active]
org.eclipse.jdt.debug (3.1.0) "JDI Debug Model" [Active]
org.eclipse.jdt.debug.ui (3.1.0) "JDI Debug UI" [Active]
org.eclipse.jdt.doc.isv (3.1.0) "Eclipse JDT Plug-in Developer Guide" =
[Resolved]
org.eclipse.jdt.doc.user (3.1.0) "Eclipse Java Development User Guide" =
[Resolved]
org.eclipse.jdt.junit (3.1.0) "Java Development Tools JUnit support" =
[Resolved]
org.eclipse.jdt.junit.runtime (3.1.0) "Java Development Tools JUnit =
runtime support" [Resolved]
org.eclipse.jdt.launching (3.1.0) "Java Development Tools Launching =
Support" [Active]
org.eclipse.jdt.source (3.1.0) "Eclipse Java Development Tools SDK" =
[Resolved]
org.eclipse.jdt.ui (3.1.0) "Java Development Tools UI" [Active]
org.eclipse.jem (1.0.0) "Java EMF Model" [Installed]
org.eclipse.jem (1.0.2) "Java EMF Model" [Installed]
org.eclipse.jem (1.1.0) "Java EMF Model" [Active]
org.eclipse.jem.beaninfo (1.1.0) "Java EMF Model BeanInfo =
(Introspection) Support" [Resolved]
org.eclipse.jem.proxy (1.0.0) "Java EMF Model Proxy Support" [Installed]
org.eclipse.jem.proxy (1.0.2) "Java EMF Model Proxy Support" [Installed]
org.eclipse.jem.proxy (1.1.0) "Java EMF Model Proxy Support" [Active]
org.eclipse.jem.ui (1.1.0) "Java EMF Model UI" [Resolved]
org.eclipse.jem.util (1.1.0) "Java EMF Model Utilities" [Active]
org.eclipse.jem.workbench (1.0.0) "Java EMF Model Workbench Support" =
[Installed]
org.eclipse.jem.workbench (1.0.2) "Java EMF Model Workbench Support" =
[Installed]
org.eclipse.jem.workbench (1.1.0) "Java EMF Model Workbench Support" =
[Resolved]
org.eclipse.jface (3.1.0) "JFace" [Active]
org.eclipse.jface.text (3.1.0) "JFace Text" [Active]
org.eclipse.ltk.core.refactoring (3.1.0) "Refactoring Core" [Active]
org.eclipse.ltk.ui.refactoring (3.1.0) "Refactoring UI" [Active]
org.eclipse.monitor.core (13.8.1) "Monitor" [Resolved]
org.eclipse.monitor.ui (13.8.1) "TCP/IP Monitor" [Resolved]
org.eclipse.osgi.services (3.1.0) "OSGi Release 3 Services" [Resolved]
org.eclipse.osgi.util (3.1.0) "OSGi R3 Utility Classes" [Resolved]
org.eclipse.pde (3.1.0) "Eclipse Plug-in Development Environment" =
[Resolved]
org.eclipse.pde.build (3.1.0) "Plug-in Development Environment Build =
Support" [Resolved]
org.eclipse.pde.core (3.1.0) "Plug-in Development Core" [Active]
org.eclipse.pde.doc.user (3.1.0) "Eclipse Plug-in Development User =
Guide" [Resolved]
org.eclipse.pde.junit.runtime (3.1.0) "PDE JUnit Plug-in Test" =
[Resolved]
org.eclipse.pde.runtime (3.1.0) "Plug-in Development Environment =
Runtime" [Resolved]
Developer Resources" [Resolved]
org.eclipse.pde.ui (3.1.0) "Plug-in Development UI" [Resolved]
org.eclipse.platform (3.1.0) "Eclipse Platform" [Resolved]
org.eclipse.platform.doc.isv (3.1.0) "Eclipse Platform Plug-in Developer =
Guide" [Resolved]
org.eclipse.platform.doc.user (3.1.0) "Eclipse Workbench User Guide" =
[Resolved]
org.eclipse.platform.source.win32.win32.x86 (3.1.0) "Eclipse Platform =
Plug-in Developer Resources" [Resolved]
org.eclipse.rcp (3.1.0) "Eclipse RCP" [Resolved]
org.eclipse.rcp.source (3.1.0) "Eclipse RCP Plug-in Developer Resources" =
[Resolved]
org.eclipse.rcp.source.win32.win32.x86 (3.1.0) "Eclipse RCP Plug-in =
org.eclipse.sdk (3.1.0) "Eclipse Project SDK" [Resolved]
org.eclipse.search (3.1.0) "Search Support" [Resolved]
org.eclipse.swt (3.1.0) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.win32.win32.x86 (3.1.0) "Standard Widget Toolkit for =
Windows" [Resolved]
org.eclipse.team.core (3.1.0) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.1.0) "CVS Team Provider Core" [Resolved]
org.eclipse.team.cvs.ssh (3.1.0) "CVS SSH Core" [Resolved]
org.eclipse.team.cvs.ssh2 (3.1.0) "CVS SSH2" [Resolved]
org.eclipse.team.cvs.ui (3.1.0) "CVS Team Provider UI" [Resolved]
org.eclipse.team.ui (3.1.0) "Team Support UI" [Resolved]
org.eclipse.text (3.1.0) "Text" [Active]
org.eclipse.tomcat (4.1.30.1) "Tomcat Wrapper" [Active]
org.eclipse.ui (3.1.0) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.1.0) "Browser Support" [Resolved]
org.eclipse.ui.cheatsheets (3.1.0) "Cheat Sheets" [Resolved]
org.eclipse.ui.console (3.1.0) "Console" [Resolved]
org.eclipse.ui.editors (3.1.0) "Default Text Editor" [Active]
org.eclipse.ui.externaltools (3.1.0) "External Tools" [Active]
org.eclipse.ui.forms (3.1.0) "Eclipse Forms" [Active]
org.eclipse.ui.ide (3.1.0) "Eclipse IDE UI" [Active]
org.eclipse.ui.intro (3.1.0) "Welcome Framework" [Resolved]
org.eclipse.ui.presentations.r21 (3.1.0) "R21 Presentation Plug-in" =
[Resolved]
org.eclipse.ui.views (3.1.0) "Views" [Active]
org.eclipse.ui.views.navigator (13.8.1) "Navigator View" [Resolved]
org.eclipse.ui.win32 (3.1.0) "Eclipse UI Win32 Enhancements" [Resolved]
org.eclipse.ui.workbench (3.1.0) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.1.0) "Workbench Compatibility" =
[Resolved]
org.eclipse.ui.workbench.texteditor (3.1.0) "Text Editor Framework" =
[Active]
org.eclipse.update.configurator (3.1.0) "Install/Update Configurator" =
[Active]
org.eclipse.update.core (3.1.0) "Install/Update Core" [Resolved]
org.eclipse.update.core.win32 (3.1.0) "Install/Update Core for Windows" =
[Resolved]
org.eclipse.update.scheduler (3.1.0) "Automatic Updates Scheduler" =
[Active]
org.eclipse.update.ui (3.1.0) "Install/Update UI" [Resolved]
org.eclipse.ve (1.1.0) "Visual Editor" [Resolved]
org.eclipse.ve.cde (1.1.0) "Visual Editor Common Data Editor" [Active]
org.eclipse.ve.doc (1.1.0) "Visual Editor for Java User Guide" =
[Resolved]
org.eclipse.ve.java.core (1.1.0) "Visual Editor Java Core" [Active]
org.eclipse.ve.jfc (1.1.0) "Visual Editor for Java Foundation Classes" =
[Resolved]
org.eclipse.ve.propertysheet (1.1.0) "Visual Editor PropertySheet" =
[Active]
org.eclipse.ve.swt (1.1.0) "Visual Editor for Standard Widget Toolkit" =
[Active]
org.eclipse.webbrowser (13.8.4) "Web Browser" [Active]
org.eclipse.xsd (2.0.0) "XML Schema Infoset Model (XSD)" [Installed]
org.eclipse.xsd (2.1.0) "XML Schema Infoset Model (XSD)" [Resolved]
org.eclipse.xsd.edit (2.0.0) "XML Schema Edit Framework" [Resolved]
org.eclipse.xsd.edit (2.0.1) "XML Schema Edit Framework" [Resolved]
org.junit (3.8.1) "JUnit Testing Framework" [Resolved]
org.springframework.ide.eclipse.beans.core (3.9.210) "MyEclipse Spring =
IDE Beans Support Core" [Active]
org.springframework.ide.eclipse.beans.ui (3.9.210) "MyEclipse Spring IDE =
Beans UI" [Active]
org.springframework.ide.eclipse.beans.ui.doc (3.9.211) "MyEclipse Spring =
IDE Support Documentation" [Resolved]
org.springframework.ide.eclipse.beans.ui.graph (3.9.210) "MyEclipse =
Spring IDE Support Graph" [Resolved]
org.springframework.ide.eclipse.core (3.9.210) "MyEclipse Spring IDE =
Core" [Active]
org.springframework.ide.eclipse.core.doc (3.9.210) "MyEclipse Spring =
Framework Reference Documentation" [Resolved]
org.springframework.ide.eclipse.ui (3.9.211) "MyEclipse Spring IDE UI" =
[Active]
system.bundle (3.1.0) "OSGi System Bundle" [Active]
*** User Preferences:
#Sat Jul 23 08:25:15 CDT 2005
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.comment.ind=
ent_parameter_description=3Dtrue
@org.eclipse.ui.editors=3D3.1.0
/instance/com.genuitec.eclipse.easie.weblogic/JDK_INSTALLATI ON_NAME=3Dj2s=
dk1.4.2_05
@org.eclipse.debug.ui=3D3.1.0
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_spac=
e_after_at_in_annotation_type_declaration=3Ddo not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.brace_posit=
ion_for_enum_constant=3Dend_of_line
/instance/com.genuitec.eclipse.wizards/object.template.4.lab el=3DDefault =
template for Servlet
@com.genuitec.eclipse.easie.websphere5=3D3.8.1
e_after_binary_operator=3Dinsert
e_after_comma_in_method_invocation_arguments=3Dinsert
e_after_prefix_operator=3Ddo not insert
e_before_closing_paren_in_if=3Ddo not insert
e_after_comma_in_type_arguments=3Dinsert
/instance/org.eclipse.jdt.debug.ui/org.eclipse.debug.ui.Vari ableView.org.=
eclipse.jdt.debug.ui.show_null_entries=3Dtrue
@com.ibm.sse.editor=3D13.9.210
e_before_comma_in_method_declaration_throws=3Ddo not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.alignment_f=
or_enum_constants=3D0
e_before_opening_brace_in_annotation_type_declaration=3Dinse rt
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_ templates=3D <=
?xml version\=3D"1.0" encoding\=3D"UTF-8"?>\r\n<templates><template =
name\=3D"hibarray" description\=3D"@hibernate.array" =
context\=3D"javadoc" enabled\=3D"true" =
deleted\=3D"false">@hibernate.array table\=3D"" =
cascade\=3D"save-update"</template><template name\=3D"hibbag" =
description\=3D"@hibernate.bag" context\=3D"javadoc" enabled\=3D"true" =
deleted\=3D"false">@hibernate.bag table\=3D"" lazy\=3D"false" =
cascade\=3D"none" inverse\=3D"false"</template><template =
name\=3D"hibclass" description\=3D"@hibernate.class" =
deleted\=3D"false">@hibernate.class =
table\=3D"${enclosing_type}"</template><template name\=3D"hibcolelm" =
description\=3D"@hibernate.collection-element" context\=3D"javadoc" =
enabled\=3D"true" deleted\=3D"false">@hibernate.collection-element =
column\=3D"" type\=3D"" length\=3D""</template><template =
name\=3D"hibcolidx" description\=3D"@hibernate.collection-index" =
deleted\=3D"false">@hibernate.collection-index column\=3D"" type\=3D"" =
length\=3D""</template><template name\=3D"hibcolkey" =
description\=3D"@hibernate.collection-key" context\=3D"javadoc" =
enabled\=3D"true" deleted\=3D"false">@hibernate.collection-key =
column\=3D"" generator-class\=3D"native"</template><template =
name\=3D"hibcolmtm" description\=3D"@hibernate.many-to-many" =
context\=3D"javadoc" enabled\=3D"true" deleted\=3D"false">@hibernate.set =
name\=3D"${enclosing_method}" table\=3D"link_table_name_here" =
cascade\=3D"save-update" inverse\=3D"true|false" lazy\=3D"true"\r\n\t * =
@hibernate.collection-key column\=3D"${enclosing_type}_ID"\r\n\t * =
@hibernate.collection-many-to-many =
class\=3D"relationship_class_the_set_contains" =
column\=3D"relationship_foreign_key"\r\n\t * @return =
${return_type}</template><template name\=3D"hibcolotm" =
description\=3D"@hibernate.one-to-many relationship" =
name\=3D"${enclosing_method}" table\=3D"relationship_table"\r\n\t * =
\t\t\t\t\tsort\=3D"comparator_class" inverse\=3D"true|false"\r\n\t * =
\t\t\t\t\tcascade\=3D"save-update" lazy\=3D"true"\r\n\t * =
@hibernate.collection-one-to-many class\=3D"relationship_class"\r\n\t =
*\r\n\t * @return ${return_type}</template><template name\=3D"hibcomelm" =
description\=3D"@hibernate.collection-composite-element" =
deleted\=3D"false">@hibernate.collection-composite-element =
class\=3D""</template><template name\=3D"hibcomp" =
description\=3D"@hibernate.component" context\=3D"javadoc" =
enabled\=3D"true" deleted\=3D"false">@hibernate.component =
class\=3D"component_class_name"</template><template name\=3D"hibdisc" =
description\=3D"@hibernate.discriminator" context\=3D"javadoc" =
enabled\=3D"true" deleted\=3D"false">@hibernate.discriminator =
column\=3D"subclass" type\=3D"character"</template><template =
name\=3D"hibid" description\=3D"@hibernate.id" context\=3D"javadoc" =
enabled\=3D"true" deleted\=3D"false">Note\: unsaved-value An identifier =
property value that indicates that an instance \r\n\t * is newly =
instantiated (unsaved), distinguishing it from transient instances that =
\r\n\t * were saved or loaded in a previous session. If not specified =
you will get an exception like this\:\r\n\t * another object associated =
with the session has the same identifier\r\n\t *\r\n\t * @hibernate.id =
generator-class\=3D"" type\=3D"${return_type}" =
column\=3D"${enclosing_type}_ID" \r\n\t * unsaved-value\=3D"null" =
length\=3D""\r\n\t * @return ${return_type}</template><template =
name\=3D"hiblist" description\=3D"@hibernate.list" context\=3D"javadoc" =
enabled\=3D"true" deleted\=3D"false">@hibernate.list =
table\=3D"relationship-table" lazy\=3D"false" =
cascade\=3D"none"</template><template name\=3D"hibmap" =
description\=3D"@hibernate.map" context\=3D"javadoc" enabled\=3D"true" =
deleted\=3D"false">@hibernate.map name\=3D"${enclosing_method}" =
cascade\=3D"none"</template><template name\=3D"hibmto" =
description\=3D"@hibernate.many-to-one" context\=3D"javadoc" =
enabled\=3D"true" deleted\=3D"false">@hibernate.many-to-one =
column\=3D"${return_type}_ID" class\=3D"package.${return_type}"\r\n\t =
*\r\n\t * @return ${return_type}\r\n\t *</template><template =
name\=3D"hiboto" description\=3D"@hibernate.one-to-one" =
deleted\=3D"false">hibernate.one-to-one cascade\=3D"none" class\=3D"" =
outer-join\=3D"auto"</template><template name\=3D"hibprimarr" =
description\=3D"@hibernate.primitive-array" context\=3D"javadoc" =
enabled\=3D"true" deleted\=3D"false">@hibernate.primitive-array =
table\=3D"" cascade\=3D"none"</template><template name\=3D"hibprop" =
description\=3D"@hibernate.property" context\=3D"javadoc" =
enabled\=3D"true" deleted\=3D"false">@hibernate.property =
name\=3D"${enclosing_method}" column\=3D"${enclosing_method}" =
type\=3D"${return_type}" not-null\=3D"false" unique\=3D"false"\r\n\t * =
\r\n\t * @return ${return_type}</template><template name\=3D"hibquery" =
description\=3D"@hibernate.query" context\=3D"javadoc" enabled\=3D"true" =
deleted\=3D"false">@hibernate.query name\=3D"" =
query\=3D""</template><template name\=3D"hibset" =
description\=3D"@hibernate.set" context\=3D"javadoc" enabled\=3D"true" =
deleted\=3D"false">@hibernate.set name\=3D"${enclosing_method}" =
\t\t\t\t\tsort\=3D"comparator_class" inverse\=3D"true"\r\n\t * =
\t\t\t\t\tcascade\=3D"save-update" lazy\=3D"true"</template><template =
name\=3D"hibsubc" description\=3D"@hibernate.subclass" =
deleted\=3D"false">@hibernate.subclass name\=3D"" =
discriminator-value\=3D""</template><template name\=3D"hibts" =
description\=3D"@hibernate.timestamp" context\=3D"javadoc" =
enabled\=3D"true" deleted\=3D"false">@hibernate.timestamp =
column\=3D"${enclosing_method}" \r\n\t * \r\n\t * @return =
${return_type}</template><template name\=3D"hibver" =
description\=3D"@hibernate.version" context\=3D"javadoc" =
enabled\=3D"true" deleted\=3D"false">@hibernate.version =
${return_type}</template></templates>
e_after_opening_bracket_in_array_allocation_expression=3Ddo not insert
/instance/com.genuitec.eclipse.easie.weblogic8/JDK_INSTALLAT ION_NAME=3Dj2=
sdk1.4.2_05
/instance/org.eclipse.ui.ide/EXIT_PROMPT_ON_CLOSE_LAST_WINDO W=3Dfalse
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.indent_swit=
chstatements_compare_to_cases=3Dtrue
/instance/com.genuitec.eclipse.wizards/jsp.template.4.label= 3DStandard =
JSP using Struts 1.2
e_before_closing_paren_in_synchronized=3Ddo not insert
/instance/com.genuitec.eclipse.easie.sun8/JDK_INSTALLATION_N AME=3Dj2sdk1.=
4.2_05
e_before_question_in_conditional=3Dinsert
/instance/com.genuitec.eclipse.wizards/list.template.3.label =3DDefault =
template for List with basic types WRAPPED
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.keep_else_s=
tatement_on_same_line=3Dfalse
e_after_opening_paren_in_parenthesized_expression=3Ddo not insert
/configuration/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_D IALOG=3Dfalse=
e_before_comma_in_for_increments=3Ddo not insert
/instance/org.eclipse.ui.ide/quickStart=3Dtrue
e_before_closing_angle_bracket_in_parameterized_type_referen ce=3Ddo not =
insert
/instance/com.genuitec.eclipse.wizards/map.template.2=3DTemp lates/MapObje=
ctType.java
/instance/com.genuitec.eclipse.wizards/map.template.1=3DTemp lates/MapBasi=
cType.java
e_before_comma_in_multiple_field_declarations=3Ddo not insert
/instance/org.eclipse.jdt.ui/org.eclipse.jface.textfont=3D1| Courier =
New|10|0|WINDOWS|1|0|0|0|0|0|0|0|0|1|0|0|0|0|Courier New;
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.comment.cle=
ar_blank_lines=3Dfalse
e_before_opening_paren_in_constructor_declaration=3Ddo not insert
/instance/org.eclipse.jdt.ui/formatter_profile=3D_MinimumFor matting3.0.0
or_conditional_expression=3D48
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.comment.for=
mat_header=3Dfalse
/instance/com.genuitec.eclipse.wizards/object.template.7.lab el=3DDefault =
template for a Struts DispatchAction class
/instance/org.eclipse.ui.workbench/RECENT_FILES=3D10
/instance/org.eclipse.core.resources/version=3D1
@com.genuitec.eclipse.easie.oracle9=3D3.8.1
e_before_opening_angle_bracket_in_parameterized_type_referen ce=3Ddo not =
insert
e_between_empty_parens_in_enum_constant=3Ddo not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.comment.ins=
ert_new_line_before_root_tags=3Ddo not insert
@org.eclipse.ui=3D3.1.0
/instance/com.genuitec.eclipse.wizards/object.template.3.lab el=3DDefault =
template for Applet
or_compact_if=3D52
/instance/com.genuitec.eclipse.wizards/xml.template.4=3DTemp lates/StrutsC=
onfig.xml
/instance/com.genuitec.eclipse.wizards/xml.template.3=3DTemp lates/WebXmlS=
truts.xml
Re: VE1.1 - NoClassDefFoundError -JavaVisualEditorPart [message #99637 is a reply to message #99554] |
Sat, 23 July 2005 13:12   |
------=_NextPart_000_0017_01C58F7F.BE9EBDA0
I reinstalled 3.1 fresh with all the latest=20
swt-3.1-win32-win32-x86.zip
emf-sdo-runtime-2.1.0.zip
GEF-runtime-3.1.zip
VE-runtime-1.1.zip
But I left out MyEclipse, and if I create a new Visual class everything =
looks ok. However, if I try to load a pre-existing visual class the =
Visual Editor does not appear, I just have the java editor. How can I =
get the Visual Editor to work with the previous version of the Visual =
editor?
--=20
"Timothy Nesham" <tcnesham@email.uophx.edu> wrote in message =
news:dbth5a$2fh$1@news.eclipse.org...
!STACK 0
at =
at =
at =
java:572)
at =
65)
at =
ence.java:552)
at =
at =
at =
ePart.java:135)
at =
at =
at =
at =
at =
at =
at =
at =
7)
at =
at =
at =
or.java:226)
at =
76)
at =
63)
at =
:39)
at =
mpl.java:25)
bea.home=3Dc:\bea
win32
-ws
win32
-arch
x86
-launcher
-name
Eclipse
-showsplash
600
-exitdata
e54_68
-vm
-Xmx512M
-XX:NewSize=3D128m
-Dbea.home=3Dc:\bea
-Xmx512M
-jar
eof=3Deof
file.separator=3D\
ea;c:\eclipse
y
ctory
line.separator=3D
os.arch=3Dx86
os.version=3D5.1
osgi.arch=3Dx86
osgi.nl=3Den_US
osgi.os=3Dwin32
osgi.ws=3Dwin32
path.separator=3D;
user.country=3DUS
user.language=3Den
user.variant=3D
*** Features:
Tooling"
Workbench"
com.genuitec.myeclipse.hibernate (3.9.211) "MyEclipse Hibernate =
Feature"
Feature"
Feature"
com.genuitec.myeclipse.tapestry (3.9.210) "MyEclipse Tapestry / =
Spindle Feature"
com.genuitec.myeclipse.wdt (3.9.210) "MyEclipse Web Development =
Feature"
org.eclipse.pde.source (3.1.0) "Eclipse Plug-in Development =
Environment Developer Resources"
org.eclipse.platform.source (3.1.0) "Eclipse Platform Plug-in =
org.eclipse.rcp.source (3.1.0) "Eclipse RCP Plug-in Developer =
Resources"
[Installed]
com.genuitec.eclipse.ast.deploy.core (3.9.210) "Deployment Core =
Plug-in" [Active]
com.genuitec.eclipse.bugzilla (3.9.210) "MyEclipse Bugzilla =
com.genuitec.eclipse.cross.easystruts.eclipse (3.9.210) "MyEclipse =
Stuts Support" [Active]
[Active]
[Installed]
com.genuitec.eclipse.easie.core (3.9.210) "Genuitec EASIE Core" =
[Active]
com.genuitec.eclipse.easie.jboss (3.8.2) "Genuitec EASIE JBoss" =
[Active]
[Active]
[Active]
[Active]
com.genuitec.eclipse.easie.jetty (3.8.1) "Genuitec EASIE Jetty" =
[Active]
[Active]
[Active]
com.genuitec.eclipse.easie.jonas (3.8.3) "Genuitec EASIE Jonas" =
[Active]
[Active]
[Active]
[Active]
[Active]
com.genuitec.eclipse.easie.oracle9 (3.8.1) "Genuitec EASIE Oracle =
9i/AS" [Active]
[Active]
[Active]
com.genuitec.eclipse.easie.resin (3.8.1) "Genuitec EASIE Resin" =
[Active]
[Active]
[Active]
com.genuitec.eclipse.easie.sun (3.8.3) "Genuitec EASIE Sun One" =
[Active]
com.genuitec.eclipse.easie.sun8 (3.8.3) "Genuitec EASIE Sun 8" =
[Active]
[Active]
[Active]
[Active]
[Active]
[Installed]
com.genuitec.eclipse.easie.weblogic (3.9.210) "Genuitec EASIE =
WebLogic" [Active]
com.genuitec.eclipse.easie.weblogic6 (3.8.1) "Genuitec EASIE WebLogic =
6" [Active]
com.genuitec.eclipse.easie.weblogic7 (3.8.1) "Genuitec EASIE WebLogic =
7" [Active]
com.genuitec.eclipse.easie.weblogic8 (3.8.1) "Genuitec EASIE WebLogic =
8" [Active]
com.genuitec.eclipse.easie.weblogic9 (3.9.210) "Genuitec EASIE =
WebLogic 9" [Active]
4" [Active]
com.genuitec.eclipse.easie.websphere5 (3.8.1) "Genuitec EASIE =
WebSphere 5" [Active]
Wizards" [Resolved]
Utilities" [Active]
Tooling" [Active]
com.genuitec.eclipse.jsf (3.9.210) "MyEclipse JSF Capabilities" =
[Active]
[Resolved]
[Resolved]
com.genuitec.eclipse.springframework (3.9.211) "Springframework =
Plug-in" [Resolved]
Plugin" [Installed]
com.genuitec.eclipse.sqlexplorer (3.9.210) "MyEclipse Database =
Explorer Plugin" [Resolved]
[Installed]
[Active]
com.genuitec.eclipse.tapestry (3.9.210) "MyEclipse Tapestry =
com.genuitec.eclipse.tapestry.docs.contrib (3.9.210) "MyEclipse =
Tapestry Documentation Integration Fragment" [Resolved]
com.genuitec.eclipse.wdt.jsp.debug (3.8.4) "MyEclipse JSP Debug =
Tooling" [Active]
[Installed]
[Active]
[Resolved]
com.genuitec.eclipse.webdesigner.support (3.9.211) "WebDesigner =
Support" [Resolved]
[Installed]
com.genuitec.eclipse.wizards (3.9.210) "MyEclipse File Creation =
Wizards" [Active]
com.genuitec.jboss.ide.eclipse.xdoclet.assist (3.8.4) "Genuitec =
XDoclet Assist Plug-in" [Installed]
com.genuitec.jboss.ide.eclipse.xdoclet.core (3.9.210) "Genuitec =
XDoclet Core Plug-in" [Resolved]
com.genuitec.jboss.ide.eclipse.xdoclet.ui (3.9.210) "Genuitec XDoclet =
Tooling" [Resolved]
Tooling" [Resolved]
[Resolved]
[Resolved]
com.genuitec.myeclipse.core (3.8.4) "MyEclipse Core Tooling" =
[Resolved]
[Resolved]
com.genuitec.myeclipse.doc (3.8.4) "MyEclipse Documentation" =
[Installed]
[Resolved]
[Resolved]
[Resolved]
Feature" [Resolved]
com.genuitec.myeclipse.jsf (3.9.210) "MyEclipse JSF Feature" =
[Resolved]
Feature" [Resolved]
Plug-in" [Active]
Feature" [Resolved]
[Resolved]
[Resolved]
Spindle Feature" [Resolved]
com.genuitec.myeclipse.uml (3.9.211) "MyEclipse UML Feature" =
[Resolved]
Feature" [Resolved]
[Resolved]
[Installed]
[Active]
[Resolved]
com.ibm.etools.contentmodel.xsd (13.8.1) "Content Model for XML =
Schema" [Resolved]
[Active]
[Resolved]
support" [Resolved]
[Resolved]
[Active]
[Resolved]
com.ibm.etools.xml.gef.util (13.9.210) "XML Tools Common GEF =
com.ibm.etools.xmlcatalog (13.8.4) "com.ibm.etools.xmlcatalog" =
[Active]
com.ibm.sse.editor.extensions (13.8.1) "Structured Source Editing =
Editor Extensions" [Resolved]
[Resolved]
[Resolved]
[Installed]
[Active]
Model" [Resolved]
com.ibm.sse.model.jsp (13.8.4) "Structured Source JSP Model" =
[Installed]
com.ibm.sse.model.jsp (13.9.210) "Structured Source JSP Model" =
[Active]
com.ibm.sse.model.xml (13.8.4) "Structured Source XML Model" =
[Installed]
com.ibm.sse.model.xml (13.9.210) "Structured Source XML Model" =
[Active]
Plug-in" [Resolved]
[Resolved]
[Resolved]
[Resolved]
[Resolved]
[Resolved]
net.sf.solareclipse.xml.ui (0.4.0.spindle-dep-6) "XML Development =
Tools UI" [Resolved]
org.eclipse.core.resources.win32 (3.1.0) "Core Resource Management =
Win32 Fragment" [Resolved]
[Installed]
[Installed]
[Resolved]
org.eclipse.emf.codegen.ecore.ui (2.1.0) "EMF Ecore Code Generation =
UI" [Resolved]
[Resolved]
org.eclipse.emf.ecore.change (2.1.0) "EMF Ecore Change Model" =
[Resolved]
Support" [Resolved]
[Resolved]
org.eclipse.emf.ecore.sdo.editor (2.1.0) "EMF Service Data Objects =
(SDO) Editor" [Resolved]
[Resolved]
[Resolved]
[Resolved]
[Resolved]
[Resolved]
[Resolved]
[Resolved]
Support" [Active]
[Resolved]
org.eclipse.jem.proxy (1.0.0) "Java EMF Model Proxy Support" =
[Installed]
org.eclipse.jem.proxy (1.0.2) "Java EMF Model Proxy Support" =
[Installed]
[Installed]
[Installed]
[Resolved]
[Resolved]
Support" [Resolved]
Guide" [Resolved]
[Resolved]
Runtime" [Resolved]
Environment Developer Resources" [Resolved]
org.eclipse.platform.doc.isv (3.1.0) "Eclipse Platform Plug-in =
Developer Guide" [Resolved]
[Resolved]
Windows" [Resolved]
[Resolved]
org.eclipse.ui.win32 (3.1.0) "Eclipse UI Win32 Enhancements" =
[Resolved]
org.eclipse.ui.workbench.compatibility (3.1.0) "Workbench =
Compatibility" [Resolved]
[Active]
[Active]
org.eclipse.update.core.win32 (3.1.0) "Install/Update Core for =
Windows" [Resolved]
[Active]
[Resolved]
[Resolved]
[Active]
[Active]
org.springframework.ide.eclipse.beans.ui (3.9.210) "MyEclipse Spring =
IDE Beans UI" [Active]
org.springframework.ide.eclipse.beans.ui.doc (3.9.211) "MyEclipse =
Spring IDE Support Documentation" [Resolved]
Core" [Active]
[Active]
dk1.4.2_05
sdk1.4.2_05
4.2_05
Re: VE1.1 - NoClassDefFoundError -JavaVisualEditorPart [message #99768 is a reply to message #99652] |
Mon, 25 July 2005 08:22  |
Hi Timothy,
Visual Editor is like a peer of the Java Editor when it comes to
editing .java files. If you would like to use the Visual Editor by
default on a workspace Window>Preferences>General>Editors>File
Associations should help in selecting the default editor for that workspace.
Sri.
Timothy Nesham wrote:
> There is a "Open with Visual Editor" menu option that works. Problem
> solved, I had expected the Visual editor to open automatically when
> selecting a VE class.
> Let me restate that:
> How can I get the Visual Editor to work with the previous version of
> the Visual editor classes?
> GEF-runtime-3.1.zip
> VE-runtime-1.1.zip
> everything looks ok. However, if I try to load a pre-existing
> visual class the Visual Editor does not appear, I just have the
> java editor. How can I get the Visual Editor to work with the
> previous version of the Visual editor?
Re: VE1.1 - NoClassDefFoundError -JavaVisualEditorPart [message #609200 is a reply to message #99554] |
GEF-runtime-3.1.zip
VE-runtime-1.1.zip
editor?
--=20
!STACK 0
at =
at =
at =
java:572)
at =
65)
at =
ence.java:552)
at =
at =
at =
ePart.java:135)
at =
at =
at =
at =
at =
at =
at =
at =
7)
at =
at =
at =
or.java:226)
at =
76)
at =
63)
at =
:39)
at =
mpl.java:25)
bea.home=3Dc:\bea
win32
-ws
win32
-arch
x86
-launcher
-name
Eclipse
-showsplash
600
-exitdata
e54_68
-vm
-Xmx512M
-XX:NewSize=3D128m
-Dbea.home=3Dc:\bea
-Xmx512M
-jar
eof=3Deof
file.separator=3D\
ea;c:\eclipse
y
ctory
line.separator=3D
os.arch=3Dx86
os.version=3D5.1
osgi.arch=3Dx86
osgi.nl=3Den_US
osgi.os=3Dwin32
osgi.ws=3Dwin32
path.separator=3D;
user.country=3DUS
user.language=3Den
user.variant=3D
*** Features:
Tooling"
Workbench"
Feature"
Feature"
Feature"
Spindle Feature"
Feature"
Resources"
[Installed]
Plug-in" [Active]
[Active]
[Installed]
[Active]
[Active]
[Active]
[Active]
[Active]
[Active]
[Active]
[Active]
[Active]
[Active]
[Active]
[Active]
[Active]
9i/AS" [Active]
[Active]
[Active]
[Active]
[Active]
[Active]
[Active]
[Active]
[Active]
[Active]
[Active]
[Active]
[Installed]
WebLogic" [Active]
6" [Active]
7" [Active]
8" [Active]
4" [Active]
Wizards" [Resolved]
Utilities" [Active]
Tooling" [Active]
[Active]
[Resolved]
[Resolved]
Plug-in" [Resolved]
Plugin" [Installed]
[Installed]
[Active]
Tooling" [Active]
[Installed]
[Active]
[Resolved]
Support" [Resolved]
[Installed]
Wizards" [Active]
Tooling" [Resolved]
Tooling" [Resolved]
[Resolved]
[Resolved]
[Resolved]
[Resolved]
[Installed]
[Resolved]
[Resolved]
[Resolved]
Feature" [Resolved]
[Resolved]
Feature" [Resolved]
Plug-in" [Active]
Feature" [Resolved]
[Resolved]
[Resolved]
[Resolved]
Feature" [Resolved]
[Resolved]
[Installed]
[Active]
[Resolved]
Schema" [Resolved]
[Active]
[Resolved]
support" [Resolved]
[Resolved]
[Active]
[Resolved]
[Active]
[Resolved]
[Resolved]
[Installed]
[Active]
Model" [Resolved]
[Installed]
[Active]
[Installed]
[Active]
Plug-in" [Resolved]
[Resolved]
[Resolved]
[Resolved]
[Resolved]
[Resolved]
[Installed]
[Installed]
[Resolved]
UI" [Resolved]
[Resolved]
[Resolved]
Support" [Resolved]
[Resolved]
[Resolved]
[Resolved]
[Resolved]
[Resolved]
[Resolved]
[Resolved]
[Resolved]
Support" [Active]
[Resolved]
[Installed]
[Installed]
[Installed]
[Installed]
[Resolved]
[Resolved]
Support" [Resolved]
Guide" [Resolved]
[Resolved]
Runtime" [Resolved]
[Resolved]
Windows" [Resolved]
[Resolved]
[Resolved]
[Active]
[Active]
Windows" [Resolved]
[Active]
[Resolved]
[Resolved]
[Active]
[Active]
Core" [Active]
[Active]
dk1.4.2_05
sdk1.4.2_05
4.2_05
Re: VE1.1 - NoClassDefFoundError -JavaVisualEditorPart [message #609201 is a reply to message #99637] |
Sat, 23 July 2005 13:25  |
------=_NextPart_000_0031_01C58F81.A653CC70
How can I get the Visual Editor to work with the previous version of the =
--=20
Timothy C. Nesham
Work: tcnesham@cvty.com
I have not failed. I've just found 10,000 ways that don't work. - Thomas =
Edison
news:dbttp2$dfe$1@news.eclipse.org...
GEF-runtime-3.1.zip
VE-runtime-1.1.zip
But I left out MyEclipse, and if I create a new Visual class =
everything looks ok. However, if I try to load a pre-existing visual =
class the Visual Editor does not appear, I just have the java editor. =
Visual editor?
--=20
Content-Type: text/html;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2800.1498" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Let me restate that:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>How can I get the Visual Editor to work =
with the=20
previous version of the Visual editor classes?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT><FONT face=3DArial =
size=3D2></FONT><BR>--=20
<BR>Timothy C. Nesham<BR><A=20
href=3D"mailto:tcnesham@email.uophx.edu">tcnesham@email.uophx.edu</A><BR>=
Work: <A=20
href=3D"mailto:tcnesham@cvty.com">tcnesham@cvty.com</A><BR>I have not =
failed. I've=20
just found 10,000 ways that don't work. - Thomas Edison</DIV>
<BLOCKQUOTE dir=3Dltr=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Timothy Nesham" <<A=20
href=3D"mailto:tcnesham@email.uophx.edu">tcnesham@email.uophx.edu</A>>=
wrote=20
in message <A=20
href=3D"news:dbttp2$dfe$1@news.eclipse.org">news:dbttp2$dfe$1@news.eclips=
e.org</A>...</DIV>
<DIV><FONT face=3DArial size=3D2>I reinstalled 3.1 fresh with all the =
latest=20
</FONT></DIV>
<DIV>swt-3.1-win32-win32-x86.zip<BR>emf-sdo-runtime-2.1.0.zip <BR>GEF-runt=
ime-3.1.zip<BR>VE-runtime-1.1.zip</DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>But I left out MyEclipse, =
</FONT><FONT face=3DArial=20
size=3D2>and if I create a new Visual class everything looks ok. =
However, if I=20
try to load a pre-existing visual class the Visual Editor does not =
appear, I=20
just have the java editor. How can I get the Visual Editor to =
work with=20
the previous version of the Visual editor?</FONT></DIV>
size=3D2></FONT><FONT=20
face=3DArial size=3D2></FONT><FONT face=3DArial size=3D2></FONT><FONT =
face=3DArial=20
size=3D2></FONT><BR>-- <BR><FONT face=3DArial size=3D2><FONT=20
size=3D3></DIV></BLOCKQUOTE></FONT></FONT></BODY></HTML >
------=_NextPart_000_0031_01C58F81.A653CC70--
Re: VE1.1 - NoClassDefFoundError -JavaVisualEditorPart [message #609202 is a reply to message #99644] |
Sat, 23 July 2005 13:37  |
Originally posted by: tcnesham.email.uophx.edu
------=_NextPart_000_0045_01C58F83.5B5B6050
Content-Type: text/plain;
There is a "Open with Visual Editor" menu option that works. Problem =
solved, I had expected the Visual editor to open automatically when =
--=20
How can I get the Visual Editor to work with the previous version of =
GEF-runtime-3.1.zip
VE-runtime-1.1.zip
Visual editor?
--=20
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>There is a "Open with Visual Editor" =
menu option=20
that works. Problem solved, I had expected the Visual editor to open=20
automatically when selecting a VE class.</FONT></DIV>
<BR><FONT face=3DArial size=3D2>Let me restate that:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>How can I get the Visual Editor to =
work with the=20
size=3D2></FONT><BR><FONT face=3DArial=20
size=3D2>I reinstalled 3.1 fresh with all the latest </FONT></DIV>
</FONT><FONT=20
face=3DArial size=3D2>and if I create a new Visual class everything =
looks ok.=20
However, if I try to load a pre-existing visual class the Visual =
Editor does=20
not appear, I just have the java editor. How can I get the =
Visual=20
size=3D2></FONT><FONT face=3DArial=20
size=3D3></DIV></BLOCKQUOTE></BLOCKQUOTE></FONT></FONT> </BODY></HTML>
------=_NextPart_000_0045_01C58F83.5B5B6050--
Re: VE1.1 - NoClassDefFoundError -JavaVisualEditorPart [message #609219 is a reply to message #99652] |
Hi Timothy,
Sri.
> GEF-runtime-3.1.zip
> VE-runtime-1.1.zip
Current Time: Fri Jul 18 18:10:14 EDT 2025
Powered by FUDForum. Page generated in 0.06837 seconds
