Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » JPA Annotation for Composite Foregin Key
JPA Annotation for Composite Foregin Key [message #89012] |
Wed, 11 July 2007 12:48  |
I have composite key in Object A i.e. (type,id,version,node). Object B has
relation ship to A. So when I use Teneo to create HBM file and then create
DDL script from it , I need those 4 fields be added in table B (with
convention as A_id,A_type ...etc.) and foreign key is created in table B
with reference to table A.
I tried that with @JoinColumns annotations and Teneo gave me exception
sayings is not supported. Whats the mechansim to represent composite
foregin keys ?
Re: JPA Annotation for Composite Foregin Key [message #89116 is a reply to message #89101] |
Wed, 11 July 2007 17:11   |
Yes, I see, multiple join columns on a many-to-one are not yet supported. I am currently working on
a new release. If you enter a bugzilla for this then I can try to incorporate this in this next
release (within a week).
gr. Martin
Vaibhav Kulkarni wrote:
> I get following exception :
> Caused by: org.eclipse.emf.teneo.hibernate.mapper.MappingException:
> Unsupported multiple join columns, EReference/subclass
> at
> org.eclipse.emf.teneo.hibernate.mapper.ManyToOneMapper.proce ss(ManyToOneMapper.java:64)
> at
> org.eclipse.emf.teneo.hibernate.mapper.FeatureMapper.process PAnnotatedEReference(FeatureMapper.java:161)
> at
> org.eclipse.emf.teneo.hibernate.mapper.FeatureMapper.process (FeatureMapper.java:97)
> at
> org.eclipse.emf.teneo.hibernate.mapper.EntityMapper.processF eature(EntityMapper.java:553)
> at
> org.eclipse.emf.teneo.hibernate.mapper.EntityMapper.processF eatures(EntityMapper.java:438)
> at
> org.eclipse.emf.teneo.hibernate.mapper.EntityMapper.processE ntity(EntityMapper.java:335)
> at
> org.eclipse.emf.teneo.hibernate.mapper.HibernateMappingGener ator.processPAClass(HibernateMappingGenerator.java:194)
> at
> org.eclipse.emf.teneo.hibernate.mapper.HibernateMappingGener ator.processPersistentClasses(HibernateMappingGenerator.java :162)
> at
> org.eclipse.emf.teneo.hibernate.mapper.HibernateMappingGener ator.generate(HibernateMappingGenerator.java:124)
> ... 7 more
> I am cut pasting annotations in ecore ..
> <eClassifiers xsi:type="ecore:EClass" name="RelationshipClass">
> <eStructuralFeatures xsi:type="ecore:EAttribute" name="relationname"
> eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
> <eStructuralFeatures xsi:type="ecore:EReference" name="subclass"
> eType="#//Subclass">
> <eAnnotations source="teneo.jpa">
> <details key="appinfo"
> value=" @JoinColumns({@JoinColumn(name="owning_id" ,
> referencedColumnName="id"),@JoinColumn(nam e="owning_ver",
> referencedColumnName="version"),@JoinColum n(name="owning_type",
> referencedColumnName="type")})"/>
> </eAnnotations>
> </eStructuralFeatures>
> </eClassifiers>
> RelationshipClass has 0 to 1 relationship to class named "Subclass".
> This Subclass has its primary key as id, type and version. So I want to
> add this 3 columns in RelationshipClass table with customized names (as
> shown above) as foreign keys.
> is this right annotation to be used to solve composite forign key issue ?
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: JPA Annotation for Composite Foregin Key [message #89146 is a reply to message #89131] |
Wed, 11 July 2007 17:57   |
--------------080706000602050300090804
I have a testcase which covers this case as well as a one-to-many using a composite-key. I have
attached the ecore and the resulting hbm so you can see if there are any differences with your approach.
gr. martin
> I have similar issue for composite primary keys when
> @Inheritance(strategy="JOINED") is used between concrete parent class
> and its concrete sub class. I want only composite parent keys are added
> in subclass table as a foreign keys to parent class. Parent table should
> have only properties in Parent class and Child table should have only
> properties in Child subclass.
> Caused by: org.hibernate.MappingException: Foreign key
> (FK6F2A564026128853:relationshipclass [subclass_subclass_id])) must have
> same number of columns as the referenced primary key (subclass
> [id,type,version])
> at org.hibernate.mapping.ForeignKey.alignColumns(ForeignKey.jav a:90)
> at org.hibernate.mapping.ForeignKey.alignColumns(ForeignKey.jav a:73)
The Netherlands
Content-Type: text/xml;
name="JoinColumnsTest$1_mysql_s_o_hibernate.hbm.xml"
Content-Disposition: inline;
filename="JoinColumnsTest$1_mysql_s_o_hibernate.hbm.xml"
<!DOCTYPE hibernate-mapping PUBLIC "-//Hibernate/Hibernate Mapping DTD 3.0//EN" "http://hibernate.sourceforge.net/hibernate-mapping-3.0.dtd">
<!-- Generated by Teneo on Wed Jul 11 23:53:48 CEST 2007 -->
<hibernate-mapping auto-import="false">
<class name=" org.eclipse.emf.teneo.samples.emf.annotations.joincolumns.im pl.PersonImpl " entity-name="Person" abstract="false" lazy="false" table="`person`">
<meta attribute="eclassName">Person</meta>
<meta attribute="epackage"> http://www.eclipse.org/emf/teneo/samples/emf/annotations/joi ncolumns</meta>
<composite-id class=" org.eclipse.emf.teneo.samples.emf.annotations.compositeid.Pe rsonID " mapped="true">
<key-property name="firstName" type="java.lang.String">
<column not-null="true" unique="false" name="`firstname`"/>
</key-property>
<key-property name="lastName" type="java.lang.String">
<column not-null="true" unique="false" name="`lastname`"/>
</key-property>
</composite-id>
<version name="myversion" column="myversion" access=" org.eclipse.emf.teneo.hibernate.mapping.property.VersionProp ertyHandler ">
<meta attribute="syntheticVersion">true</meta>
</version>
</class>
<joined-subclass name=" org.eclipse.emf.teneo.samples.emf.annotations.joincolumns.im pl.ParentImpl " entity-name="Parent" abstract="false" lazy="false" extends="Person" table="`parent`">
<meta attribute="eclassName">Parent</meta>
<key>
<column name="`person_firstname`"/>
<column name="`person_lastname`"/>
</key>
<list name="children" lazy="true" cascade="merge,persist,save-update,lock,refresh">
<key update="true">
<column name="`myparentfirstname`" not-null="false" unique="false"/>
<column name="`myparentlastname`" not-null="false" unique="false"/>
</key>
<list-index column="`parent_children_idx`"/>
<one-to-many entity-name="Child"/>
</list>
</joined-subclass>
<joined-subclass name=" org.eclipse.emf.teneo.samples.emf.annotations.joincolumns.im pl.ChildImpl " entity-name="Child" abstract="false" lazy="false" extends="Person" table="`child`">
<meta attribute="eclassName">Child</meta>
<key>
</key>
</joined-subclass>
</hibernate-mapping>
name="jc.ecore"
filename="jc.ecore"
<ecore:EPackage xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="joincolumns"
nsURI=" http://www.eclipse.org/emf/teneo/samples/emf/annotations/joi ncolumns" nsPrefix="joincolumns">
<eClassifiers xsi:type="ecore:EClass" name="Parent" eSuperTypes="#//Person">
<eStructuralFeatures xsi:type="ecore:EReference" name="children" upperBound="-1"
eType="#//Child">
<details key="appinfo" value=" @JoinColumns({@JoinColumn(name="myParentFirstName&a mp;quot; referencedColumnName="firstName"),
 ;	@JoinColumn(name="myParentLastName&qu ot; referencedColumnName="lastName")})"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Child" eSuperTypes="#//Person"/>
<eClassifiers xsi:type="ecore:EClass" name="Person">
<details key="appinfo" value=" @IdClass(org.eclipse.emf.teneo.samples.emf.annotations.compo siteid.PersonID) "/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="firstName" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString">
<details key="appinfo" value="@Id"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="lastName" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString">
</eAnnotations>
</eClassifiers>
</ecore:EPackage>
--------------080706000602050300090804--
Re: JPA Annotation for Composite Foregin Key [message #89605 is a reply to message #89591] |
Thu, 12 July 2007 17:27   |
--------------000406030309050207020308
See my comments inline.
gr. Martin
> I have noticed few differences as well as I am confused with the test
> case result and DDL it generates.
> 1) I am using @EmbeddedId and @Embeddeable and test case uses @IdClass.
> Hopefullly they should work the same way. It works for me for one class.
> But as soon as I extend that class it doesnt.
MT>> I attached also a testcase which has embeddedid. Unfortunately it is simpler
than the joincolumn one.
> 2) Test ecore shows 0 to many relation ship between Parent and Child.
> That means it should create join table 4 columns (parent_firstname,
> parent_lastname, child_firstname , child_lastname) .. Its doing some
> thing different. Its instead adding these columns into child table . If
> relation ships is shown between Parent and Child , then shouldnt it
> create tables accordingly ?
MT>> It is a relation without a join table, so then the foreign key is placed
in the child table.
With a join table it would look differently but I did not test that case.
> 3) If Parent has foreign key to Person , then why its adding Persons
> primary key to Child table. One can go from Child to Parent and then to
> Person to pick up all colums from Parent .
MT>> Also child inherits from Person, therefore there is a foreign key from the child table
to the person table.
> I will try to see if @IdClass works but I do see with representing these
> relationships in the data base.
The Netherlands
name="embeddedid.ecore"
filename="embeddedid.ecore"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="embeddedid"
nsURI=" http://www.eclipse.org/emf/teneo/samples/emf/annotations/emb eddedid" nsPrefix="embeddedid">
<eClassifiers xsi:type="ecore:EClass" name="Name">
<details key="appinfo" value="@Embeddable"/>
</eAnnotations>
<eAnnotations source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
<details key="name" value="Name"/>
<details key="kind" value="elementOnly"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="firstName" unique="false"
lowerBound="1" eType="ecore:EDataType http://www.eclipse.org/emf/2003/XMLType#//String">
<details key="kind" value="element"/>
<details key="name" value="firstName"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="lastName" unique="false"
<details key="name" value="lastName"/>
</eAnnotations>
</eClassifiers>
<details key="name" value="Person"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="name" lowerBound="1" eType="#//Name"
containment="true" resolveProxies="false">
<details key="appinfo" value="@EmbeddedId"/>
</eAnnotations>
<details key="name" value="name"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="address" unique="false"
<details key="appinfo" value="@Lob"/>
</eAnnotations>
<details key="name" value="address"/>
</eAnnotations>
</eClassifiers>
</ecore:EPackage>
name="EmbeddedId.xsd"
filename="EmbeddedId.xsd"
<?xml version="1.0" encoding="utf-8"?>
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema" targetNamespace=" http://www.eclipse.org/emf/teneo/samples/emf/annotations/emb eddedid"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" xmlns:this=" http://www.eclipse.org/emf/teneo/samples/emf/annotations/emb eddedid">
<xsd:complexType name="Person">
<xsd:sequence>
<xsd:element name="name" type="this:Name">
<xsd:annotation>
<xsd:appinfo source="teneo.jpa">@EmbeddedId</xsd:appinfo>
</xsd:annotation>
</xsd:element>
<xsd:element name="address" type="xsd:string" minOccurs="0">
<xsd:annotation>
<xsd:appinfo source="teneo.jpa">@Lob</xsd:appinfo>
</xsd:annotation>
</xsd:element>
</xsd:sequence>
</xsd:complexType>
<xsd:complexType name="Name">
<xsd:annotation>
<xsd:appinfo source="teneo.jpa">@Embeddable</xsd:appinfo>
</xsd:annotation>
<xsd:sequence>
<xsd:element name="firstName" type="xsd:string"/>
<xsd:element name="lastName" type="xsd:string"/>
</xsd:sequence>
</xsd:complexType>
</xsd:schema>
name="EmbeddedIdAction_mysql_s_o_hibernate.hbm.xml"
filename="EmbeddedIdAction_mysql_s_o_hibernate.hbm.xml"
<!-- Generated by Teneo on Thu Jul 12 19:26:02 CEST 2007 -->
<class name=" org.eclipse.emf.teneo.samples.emf.annotations.embeddedid.imp l.PersonImpl " entity-name="Person" abstract="false" lazy="false" table="`person`">
<meta attribute="epackage"> http://www.eclipse.org/emf/teneo/samples/emf/annotations/emb eddedid</meta>
<composite-id name="name" class=" org.eclipse.emf.teneo.samples.emf.annotations.embeddedid.imp l.NameImpl ">
</key-property>
</key-property>
</composite-id>
<version name="e_version" column="e_version" access=" org.eclipse.emf.teneo.hibernate.mapping.property.VersionProp ertyHandler ">
</version>
<property name="address" lazy="false" insert="true" update="true" not-null="false" unique="false" type="text">
<column not-null="false" unique="false" name="`address`"/>
</property>
</class>
--------------000406030309050207020308--
Re: JPA Annotation for Composite Foregin Key [message #90168 is a reply to message #89967] |
Tue, 17 July 2007 11:25   |
Hi Vaibhav,
See my comments in line.
> I have summarized issues after doing some more evaluation around JPA
> annotations.
> 1) Join table is not created for many to many or many to one non
> contained associations even though Teneo persistence option of
> "JOIN_TABLE_FOR_NON_CONTAINED_ASSOCIATIONS=true" WHEN primary key is
> composed of more than one columns. When I changed Primary Key to contain
> only one column , it worked well & I did not had to specify @JoinTable
> annotations. As I beleive this option is created to avoid specifying
> explicit @JoinTable annotation. Pls fix this and test it using composite
> primary key expresedd using @IdClass or @Embedeable/@EmbeddedId
MT>> Yes I am looking into this.
Btw, to me (as a non-native english speaker) the phrase 'Pls fix this and test it' sounds kind of
commandeering, probably you don't mean it that way...
> 2) If JOIN_TABLE_FOR_NON_CONTAINED_ASSOCIATIONS option is set to "true"
> and @JoinColumns annotations is used then it does create DDL and adds
> foreign key columns in the table for class representing other side of
> the relation ship . I think this is covered in your Person/Child/Parent
> test case where columns are added in Child table even though "children"
> relationship is present in Parent class. This works with both single
> column PK as well as composite PK. But does than mean @JoinColumns
> annotations take precedence over
> JOIN_TABLE_FOR_NON_CONTAINED_ASSOCIATIONS ?
MT>> No the option should take precedence, if it doesn't then it is a bug. As I am looking into this
topic (of composite-ids) right now I will also check it.
> 3) Same thing true for INHERITANCE_MAPPING=JOINED settings. It works
> for single column PK but not for composite PK. Once composite PK is
> defined it fails to add one column in the table (representing subclass)
> for every column in PK of parent class. Once fixed it also needs to be
> tested with JPA annotation of @Inheritance(strategy="JOINED") to check
> if it gives same result as INHERITANCE_MAPPING=JOINED settings.
MT> The person-child testcase I sent you earlier covers this case, all test cases are run for single
and joined inheritance mapping.
> 4) Came across below exception when attempt was made to customize
> inverse column names using @JoinTable annotation.
MT>> I will adapt the testcase to also include a jointable with a composite-id, hopefully this
exception will also appear there.
> Caused by: org.xml.sax.SAXParseException: Attribute "update" must be
> declared for element type "many-to-many".
> at
> com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper. createSAXParseException(Unknown
> Source)
> at
> com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper. error(Unknown
> Source)
> at
> com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.rep ortError(Unknown
> Source)
> Heres is annotation :
> "appinfo", "@JoinTable(name=\"parent_child\",
> joinColumns=@JoinColumn(name=\"parent_FirstName\"
> referencedColumnName=\"firstName\"), " +
> "inverseJoinColumns=@JoinColumn(name=\"child_FirstName\"
> referencedColumnName=\"firstName\") )"
The Netherlands
Re: JPA Annotation for Composite Foregin Key [message #92598 is a reply to message #92579] |
Fri, 03 August 2007 18:25  |
I was thinking to try property-ref (see the hibernate manual), to get property-ref working the
refered-to eclass needs a property which is part of a unique index. Is this available in your case?
It will be a few days before I have time to look at this further.
gr. Martin
> Martin
> Is it possible to provide Secondary key on Entity and use that instead
> (in some cases) to represent foreign keys ? If Yes then i dont need to
> use subset of PK and i can define secondary key for certain
> infrastructure classes.
> Your comment is appreciated.
The Netherlands
Re: JPA Annotation for Composite Foregin Key [message #608699 is a reply to message #89012] |
Wed, 11 July 2007 12:59  |
What is the exception and how does your annotation look like?
And can you show (part of) the ecore describing this relation?
gr. Martin
> has relation ship to A. So when I use Teneo to create HBM file and then
> create DDL script from it , I need those 4 fields be added in table B
> (with convention as A_id,A_type ...etc.) and foreign key is created in
> table B with reference to table A.
> foregin keys ?
The Netherlands
Re: JPA Annotation for Composite Foregin Key [message #608704 is a reply to message #89028] |
Wed, 11 July 2007 16:57  |
at
at
at
at
at
at
at
at
at
... 7 more
</eAnnotations>
</eClassifiers>
RelationshipClass has 0 to 1 relationship to class named "Subclass". This
Subclass has its primary key as id, type and version. So I want to add
this 3 columns in RelationshipClass table with customized names (as shown
Re: JPA Annotation for Composite Foregin Key [message #608705 is a reply to message #89101] |
gr. Martin
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 7 more
> </eAnnotations>
> </eClassifiers>
The Netherlands
Re: JPA Annotation for Composite Foregin Key [message #608706 is a reply to message #89101] |
Wed, 11 July 2007 17:15  |
@Inheritance(strategy="JOINED") is used between concrete parent class and
its concrete sub class. I want only composite parent keys are added in
subclass table as a foreign keys to parent class. Parent table should have
[id,type,version])
Re: JPA Annotation for Composite Foregin Key [message #608707 is a reply to message #89131] |
gr. martin
> [id,type,version])
The Netherlands
</key-property>
</key-property>
</composite-id>
</version>
</class>
<key>
</key>
<key update="true">
</key>
</list>
</joined-subclass>
<key>
</key>
</joined-subclass>
name="jc.ecore"
filename="jc.ecore"
eType="#//Child">
</eAnnotations>
</eClassifiers>
</eAnnotations>
</eAnnotations>
</eAnnotations>
</eClassifiers>
</ecore:EPackage>
Re: JPA Annotation for Composite Foregin Key [message #608736 is a reply to message #89146] |
Thu, 12 July 2007 17:19  |
I have noticed few differences as well as I am confused with the test case
2) Test ecore shows 0 to many relation ship between Parent and Child. That
parent_lastname, child_firstname , child_lastname) .. Its doing some thing
different. Its instead adding these columns into child table . If relation
ships is shown between Parent and Child , then shouldnt it create tables
accordingly ?
Re: JPA Annotation for Composite Foregin Key [message #608737 is a reply to message #89591] |
gr. Martin
in the child table.
The Netherlands
</eAnnotations>
</eAnnotations>
</eAnnotations>
</eAnnotations>
</eClassifiers>
</eAnnotations>
</eAnnotations>
</eAnnotations>
</eAnnotations>
</eAnnotations>
</eClassifiers>
</ecore:EPackage>
<xsd:sequence>
<xsd:annotation>
</xsd:annotation>
</xsd:element>
<xsd:annotation>
</xsd:annotation>
</xsd:element>
</xsd:sequence>
</xsd:complexType>
<xsd:annotation>
</xsd:annotation>
<xsd:sequence>
</xsd:sequence>
</xsd:complexType>
</xsd:schema>
</key-property>
</key-property>
</composite-id>
</version>
</property>
</class>
Re: JPA Annotation for Composite Foregin Key [message #608759 is a reply to message #89605] |
Tue, 17 July 2007 06:15  |
annotations.
1) Join table is not created for many to many or many to one non contained
foreign key columns in the table for class representing other side of the
relation ship . I think this is covered in your Person/Child/Parent test
annotations take precedence over JOIN_TABLE_FOR_NON_CONTAINED_ASSOCIATIONS
3) Same thing true for INHERITANCE_MAPPING=JOINED settings. It works for
single column PK but not for composite PK. Once composite PK is defined it
fails to add one column in the table (representing subclass) for every
column in PK of parent class. Once fixed it also needs to be tested with
JPA annotation of
@Inheritance(strategy="JOINED") to check if it gives same result as
4) Came across below exception when attempt was made to customize inverse
at
Source)
at
Source)
at
Source)
Re: JPA Annotation for Composite Foregin Key [message #608772 is a reply to message #89967] |
Hi Vaibhav,
> annotations.
> at
> Source)
> at
> Source)
> at
> Source)
The Netherlands
Re: JPA Annotation for Composite Foregin Key [message #608788 is a reply to message #90260] |
Wed, 18 July 2007 07:23  |
Hi Vaibhav,
Thanks, no problem, regarding the four topics you mention:
1) the testcase I added yesterday to your bugzilla covers this case, this works now afaics.
2) I tested this case but I could not replicate this issue
3) the testcase covers this also and it seemed to work.
4) I was able to reproduce this error, it has been solved in cvs.
Let me know if the testcase I added to the bugzilla covers your case (or not ofcourse).
This will be in the next build (today or tomorrow).
gr. Martin
> Martin
> Thanks and I apologize if you interpret it that way. Ofcourse i didnt
> mean it that way.
> Thanks again and you being a great help.
The Netherlands
Re: JPA Annotation for Composite Foregin Key [message #608845 is a reply to message #90409] |
Mon, 23 July 2007 05:55  |
Martin
I just verified 2007/07/18 release and it works. Thanks for fixing it.
I have one more question. I have composite primary key with 4 columns but
in some cases I just want to add id column in the join table rather than
all columns in the primary. I tried using @JoinColumn and specify only
column and it doesnt work. Can you pls point me to the write annotation ?
e.g. A has identity (id,version,type,node) . B has 0 to many relation
ship to A. In the "B_A" join table i just want to refer to A's id with
column name "A_id".
Re: JPA Annotation for Composite Foregin Key [message #608891 is a reply to message #91274] |
Tue, 24 July 2007 23:59  |
Vaibhav,
Did you also try referencedColumnName?
Something like:
@JoinColumns({@JoinColumn(name="myParentFirstName" referencedColumnName="firstName"),
@JoinColumn(name="myParentLastName" referencedColumnName="lastName")})
gr. Martin
> Martin
> but in some cases I just want to add id column in the join table rather
> than all columns in the primary. I tried using @JoinColumn and specify
> only column and it doesnt work. Can you pls point me to the write
> annotation ?
> column name "A_id".
The Netherlands
Re: JPA Annotation for Composite Foregin Key [message #609357 is a reply to message #91689] |
Mon, 30 July 2007 11:14  |
I did try using referencedColumnName for both @JoinTable and @JoinColumns
options but it always expects all columns in Primary Key to be included.
Currently i dont find annotation where i can just pick few columns from
Primary Key to represent associations.
Re: JPA Annotation for Composite Foregin Key [message #609361 is a reply to message #92047] |
Mon, 30 July 2007 16:25  |
Hmm, this does not seem to work currently.
Is a subset of the pk column-set also unique?
Can you make a (small) test model which reflects what you want to achieve? Then I can try to build
this into a working testcase for Teneo.
gr. Martin
> @JoinColumns options but it always expects all columns in Primary Key to
> be included. Currently i dont find annotation where i can just pick few
> columns from Primary Key to represent associations.
The Netherlands
Re: JPA Annotation for Composite Foregin Key [message #609394 is a reply to message #92062] |
Tue, 31 July 2007 11:23  |
In our app, subset of PK will be made unique for certain infrastructure
classes only. All other domain objects will have 4 column PK. As domain
objects will have relation ship to these infrastructure classes , every
domain object will need 4 foreign columns to point to these infrastructure
persistent classes, something i find as redundant information. Hence I am
trying to see if in certain scenarios can I represent relation ship by
choosing only certain columns from PK.
e.g in Parent, Child and Person example I am looking for "parent_child"
table with only 2 columns . parent_firstname and child_firstname (even
though PK is composed of firstname and lastname)
Let me know if I still need to send ecore or testmodel and I will be happy
to do that.
Re: JPA Annotation for Composite Foregin Key [message #609396 is a reply to message #92209] |
Tue, 31 July 2007 12:25  |
Okay I can reuse the person testcase. Can you enter a bugzilla for this? Then I will look at it.
gr. Martin
> domain objects will have relation ship to these infrastructure classes ,
> every domain object will need 4 foreign columns to point to these
> infrastructure persistent classes, something i find as redundant
> information. Hence I am trying to see if in certain scenarios can I
> represent relation ship by choosing only certain columns from PK.
> happy to do that.
The Netherlands
Re: JPA Annotation for Composite Foregin Key [message #609401 is a reply to message #92062] |
Tue, 31 July 2007 17:09  |
Subset of PK will be unique and will be guranteed to have unique values
for some infrastructure classes. All other domain objects will have 4
column PK. As domain objects have relation ship to infrastructure classes
, have 4 column foreign key is redundant and makes data model complex.
Hence i would like to specify 1/2 column as forign key using either
@JoinTable annotation or @JoinColumns annotation.
e.g. in your Parent/Child & Person example , I want only
"parent_firstname" and "child_firstname" columns in "parent_child" join
table.
If there is another mechanism to achive this pls let me know. In EMF
diagram, I just need a way to express association between two entities. In
cetain scenarios full PK makes sense. In few scenario it doesnt.
Re: JPA Annotation for Composite Foregin Key [message #609423 is a reply to message #92223] |
Fri, 03 August 2007 11:13  |
Martin
Is it possible to provide Secondary key on Entity and use that instead (in
some cases) to represent foreign keys ? If Yes then i dont need to use
subset of PK and i can define secondary key for certain infrastructure
classes.
Re: JPA Annotation for Composite Foregin Key [message #609424 is a reply to message #92579] |
gr. Martin
> Martin
The Netherlands
Current Time: Wed Jul 23 18:20:15 EDT 2025
Powered by FUDForum. Page generated in 0.11237 seconds
