Load EMF model from memory [message #87149] |
Fri, 22 June 2007 13:55  |
Originally posted by: dkrebs.tibco.com
I've been looking at the tests plugin that is generated as an example of
how to load/unload emf models, these examples are loading/saving the files
to a location on the file system. I have an application that wants to
load/save emf models as strings in a database. So what I have is a string
of the model in memory and want to load the root EObject from that. I'm
getting hungup on what to supply as the URI when trying to use the example
code in the tests plugin, can anyone point me in the right direction?
Re: Load EMF model from memory [message #87185 is a reply to message #87149] |
Fri, 22 June 2007 15:15   |
--------------050301020306060000080506
Duncan,
Here's a generic example that saves to a StringWriter and then loads a
new resource from that string:
Resource resource =
resourceSet.createResource(URI.createURI("http:///My.library"));
DocumentRoot documentRoot =
LibraryFactory.eINSTANCE.createDocumentRoot();
EObject root = EcoreFactory.eINSTANCE.createEObject();
documentRoot.setA(root);
resource.getContents().add(documentRoot);
resource.save(System.out, null);
StringWriter out = new StringWriter();
resource.save(new URIConverter.WriteableOutputStream(out,
"UTF-8"), null);
Resource resource2 =
resourceSet.createResource(URI.createURI("*.library"));
resource2.load(new
URIConverter.ReadableInputStream(out.toString()), null);
resource2.save(System.err, null);
None of the URIs really matter in this type of scenario, except in so
far as they are used to create the right type of resource based on the
file extension. If you want to cast to XMLResource, there are APIs that
directly work with StringWriter or an InputSource that can wrap as
StringReader. Please ask general EMF questions in the EMF newsgroup in
the future.
Duncan Krebs wrote:
> Hi, I've been looking at the tests plugin that is generated as an
> example of how to load/unload emf models, these examples are
> loading/saving the files to a location on the file system. I have an
> application that wants to load/save emf models as strings in a
> database. So what I have is a string of the model in memory and want
> to load the root EObject from that. I'm getting hungup on what to
> supply as the URI when trying to use the example code in the tests
<html>
<head>
http-equiv="Content-Type">
</head>
Duncan,<br>
<br>
new resource from that string:<br>
<small><br>
Re: Load EMF model from memory [message #608577 is a reply to message #87149] |
Duncan,
Resource resource =
"UTF-8"), null);
resource2.load(new
the future.
<html>
<head>
</head>
Duncan,<br>
<br>
<small><br>
FUDForum. Page generated in 0.38889 seconds
