Home » Eclipse Projects » JavaServer Faces » JSF and Dynamic Web Project Wizard
JSF and Dynamic Web Project Wizard [message #471492] Thu, 16 March 2006 15:05 Go to next message
I just downloaded the following modules and extracted them into a folder in
the following order:
eclipse-SDK-3.2M5a-win32.zip
emf-sdo-xsd-SDK-2.2.0M5.zip
GEF-SDK-3.2M5.zip
JEM-SDK-1.2M2.zip
wtp-S-1.5M5-200603022222.zip
I then tried to create a dynamic web project and was able to start using the
wizard to do so. I wanted to create a new jsf project and when I noticed
that wasn't available I downloaded the following:
wtp-jsf-I200512161901.zip
After doing so I tried to create a new project but could no longer select
the Dynamic Web Project Wizard. Anybody have any ideas on why? I was trying
to use the following tutorial:
http://www.eclipse.org/webtools/jsf/dev_resource/JSFTutorial /JSFTools_milestone1_tutorial.html
Perhaps I am to bleeding edge. Should I download all the release builds
rather than the milestones?
Re: JSF and Dynamic Web Project Wizard [message #471493 is a reply to message #471492] Fri, 17 March 2006 02:28 Go to previous messageGo to next message
JSF M1 is WTP 1.0 based, maybe problem is caused by using it with WTP 1.5M5.
Try use it with Eclipse 3.1 and WTP 1.0. Or wait for JSF M5.
Bye,
Lumir
Re: JSF and Dynamic Web Project Wizard [message #471495 is a reply to message #471493] Sun, 19 March 2006 15:51 Go to previous messageGo to next message
I have just posted a build that works with WTP 1.5 M5 builds. Please
review and post your feedback.
Raghu
Re: JSF and Dynamic Web Project Wizard [message #473813 is a reply to message #471492] Sun, 21 January 2007 18:29 Go to previous messageGo to next message
I'm having the same problem although I'm not using wtp-jsf... just plain
wtp.
My enviromnent is a clean install of Eclipse 3.2 with
wtp-R-1.5.2-200610261841 running on Windows Vista. I just can't find the
entry point for the "Dynamic Web Project" wizard.
Any clue anyone?
Thiago Souza
"Silas" <stchristiansen@xactware.com> wrote in message
news:dvcgk2$7hf$1@utils.eclipse.org...
> GEF-SDK-3.2M5.zip
> JEM-SDK-1.2M2.zip
> the wizard to do so. I wanted to create a new jsf project and when I
> noticed that wasn't available I downloaded the following:
> trying to use the following tutorial:
> Thanks
Re: JSF and Dynamic Web Project Wizard [message #473821 is a reply to message #473813] Tue, 30 January 2007 11:23 Go to previous message
I am not sure I understand your issue. Are you saying that you cannot
find where to launch the "Dynamic Web Project" wizard? If so, it should
be found under the "Web" category of new projects.
If the wizard is not present do the following. Using the menus Help ->
Software Updates -> Manage Configuration, ensure that the WST and JST
features are correctly installed. If missing, or disabled for any reason,
check the pre-requisites for WTP on the WTP download webpage.
If this hasn't helped, you may be better served if you post this question
to the eclipse.webtools newsgroup.
Gerry Kessler
Re: JSF and Dynamic Web Project Wizard [message #596583 is a reply to message #471492] Fri, 17 March 2006 02:28 Go to previous message
Bye,
Lumir
Re: JSF and Dynamic Web Project Wizard [message #596593 is a reply to message #471493] Sun, 19 March 2006 15:51 Go to previous message
Raghu
Re: JSF and Dynamic Web Project Wizard [message #608393 is a reply to message #471492] Sun, 21 January 2007 18:29 Go to previous message
wtp.
Any clue anyone?
Thiago Souza
> GEF-SDK-3.2M5.zip
> JEM-SDK-1.2M2.zip
> Thanks
Re: JSF and Dynamic Web Project Wizard [message #608397 is a reply to message #473813] Tue, 30 January 2007 11:23 Go to previous message
Gerry Kessler
Previous Topic:eclipsecon 2007 submission deadlines: short talks / demos by Jan 31st
Next Topic:JSF Monthly status call
Current Time: Mon Nov 10 03:16:01 EST 2025
Powered by FUDForum. Page generated in 0.08057 seconds
