Home » Eclipse Projects » JavaServer Faces » JSF unknown tag since WTP 1.5.1 and JSF 0.5.1 upgrade
JSF unknown tag since WTP 1.5.1 and JSF 0.5.1 upgrade [message #473665] Thu, 26 October 2006 11:16 Go to next message
I have used JSF 0.5.0 and WTP 1.5.0 pluginq in order to develop JSF web
apps.
Since upgrade of my Eclipse (3.2.0 -> 3.2.1, WTP 1.5.0 -> 1.5.1 and JSF
O.5.0 -> 0.5.1), JSF tags aren't anymore recognized in my apps.
I have tried to clean all projects, to launch Eclipse with -clean option ,
I have plenty of unknow tags warning in my JSF pages.
Content assist doesn't work anymore.
What can I do ? thanks for help.
Arnaud
Re: JSF unknown tag since WTP 1.5.1 and JSF 0.5.1 upgrade [message #473666 is a reply to message #473665] Thu, 26 October 2006 14:11 Go to previous messageGo to next message
Are the projects showing problems ones that have been imported from
existing or that you created new using the WTP 1.5.1 build?
--Cam
Re: JSF unknown tag since WTP 1.5.1 and JSF 0.5.1 upgrade [message #473667 is a reply to message #473666] Fri, 27 October 2006 04:42 Go to previous messageGo to next message
new projects works perfectly
"Old" WTP 1.5.0 and JSF 0.5.0 created projects doesn't work anymore.
I tried without success to manually change properties setting in old
projects
Arnaud
> --Cam
Re: JSF unknown tag since WTP 1.5.1 and JSF 0.5.1 upgrade [message #473669 is a reply to message #473667] Fri, 27 October 2006 05:29 Go to previous messageGo to next message
projects
Arnaud
> --Cam
Re: JSF unknown tag since WTP 1.5.1 and JSF 0.5.1 upgrade [message #473670 is a reply to message #473669] Fri, 27 October 2006 18:31 Go to previous messageGo to next message
I think there may be an issue with the TLD loading. Can see what happens
if you delete and re-add the module dependencies for the jars in one of
your projects?
--Cam
Re: JSF unknown tag since WTP 1.5.1 and JSF 0.5.1 upgrade [message #473673 is a reply to message #473670] Mon, 30 October 2006 03:11 Go to previous messageGo to next message
I have tried but it changes anything.
I have tried to clean and rebuild, to clean eclipse internet cache and
so on ..., without success.
Arnaud
> happens if you delete and re-add the module dependencies for the jars in
> one of your projects?
> --Cam
Re: JSF unknown tag since WTP 1.5.1 and JSF 0.5.1 upgrade [message #473674 is a reply to message #473673] Mon, 30 October 2006 05:18 Go to previous messageGo to next message
I have solved the problem copying all .settings properties, .project and
..classpath of a new JSF project into an old JSF project. I have manually
changed param like project name when it was necessary, and now tags are
recognized.
Arnaud
> Arnaud
>> in one of your projects?
>> --Cam
Re: JSF unknown tag since WTP 1.5.1 and JSF 0.5.1 upgrade [message #473697 is a reply to message #473674] Mon, 30 October 2006 17:46 Go to previous messageGo to next message
Hmm.. that's not good. I try to follow that up with WTP.
--Cam
Re: JSF unknown tag since WTP 1.5.1 and JSF 0.5.1 upgrade [message #473699 is a reply to message #473697] Fri, 03 November 2006 04:31 Go to previous messageGo to next message
I 'have updated to WTP 1.5.2, removing/re-adding JSF libs dependency,
JSF tags are recognized, something should be probably fixed in WTP.
thanks
Arnaud
> --Cam
Re: JSF unknown tag since WTP 1.5.1 and JSF 0.5.1 upgrade [message #473700 is a reply to message #473699] Fri, 03 November 2006 16:25 Go to previous messageGo to next message
Could you clarify? Are you saying that your problem went away in 1.5.2
builds? Or is there still a problem?
--Cam
amergey@sunopsis.com wrote:
> thanks
> Arnaud
>> --Cam
Re: JSF unknown tag since WTP 1.5.1 and JSF 0.5.1 upgrade [message #473704 is a reply to message #473700] Mon, 06 November 2006 03:44 Go to previous messageGo to next message
Sorry for my poor english,
with WTP 1.5.2 the problem doesn't exist anymore.
Arnaud
> --Cam
>> Hi,
>> thanks
>> Arnaud
>>> --Cam
Re: JSF unknown tag since WTP 1.5.1 and JSF 0.5.1 upgrade [message #473705 is a reply to message #473704] Mon, 06 November 2006 13:45 Go to previous message
Thanks Arnaud. That's good to hear.
> Regards,
> Arnaud
Re: JSF unknown tag since WTP 1.5.1 and JSF 0.5.1 upgrade [message #608340 is a reply to message #473665] Thu, 26 October 2006 14:11 Go to previous message
--Cam
Re: JSF unknown tag since WTP 1.5.1 and JSF 0.5.1 upgrade [message #608342 is a reply to message #473666] Fri, 27 October 2006 04:42 Go to previous message
projects
Arnaud
> --Cam
Re: JSF unknown tag since WTP 1.5.1 and JSF 0.5.1 upgrade [message #608348 is a reply to message #473667] Fri, 27 October 2006 05:29 Go to previous message
projects
Arnaud
> --Cam
Re: JSF unknown tag since WTP 1.5.1 and JSF 0.5.1 upgrade [message #608350 is a reply to message #473669] Fri, 27 October 2006 18:31 Go to previous message
your projects?
--Cam
Re: JSF unknown tag since WTP 1.5.1 and JSF 0.5.1 upgrade [message #608357 is a reply to message #473670] Mon, 30 October 2006 03:11 Go to previous message
Arnaud
> --Cam
Re: JSF unknown tag since WTP 1.5.1 and JSF 0.5.1 upgrade [message #608359 is a reply to message #473673] Mon, 30 October 2006 05:18 Go to previous message
recognized.
Arnaud
> Arnaud
>> --Cam
Re: JSF unknown tag since WTP 1.5.1 and JSF 0.5.1 upgrade [message #608364 is a reply to message #473674] Mon, 30 October 2006 17:46 Go to previous message
--Cam
Re: JSF unknown tag since WTP 1.5.1 and JSF 0.5.1 upgrade [message #608366 is a reply to message #473697] Fri, 03 November 2006 04:31 Go to previous message
thanks
Arnaud
> --Cam
Re: JSF unknown tag since WTP 1.5.1 and JSF 0.5.1 upgrade [message #608367 is a reply to message #473699] Fri, 03 November 2006 16:25 Go to previous message
--Cam
> thanks
> Arnaud
>> --Cam
Re: JSF unknown tag since WTP 1.5.1 and JSF 0.5.1 upgrade [message #608371 is a reply to message #473700] Mon, 06 November 2006 03:44 Go to previous message
Arnaud
> --Cam
>> Hi,
>> thanks
>> Arnaud
>>> --Cam
Re: JSF unknown tag since WTP 1.5.1 and JSF 0.5.1 upgrade [message #608372 is a reply to message #473704] Mon, 06 November 2006 13:45 Go to previous message
> Regards,
> Arnaud
Previous Topic:JSP import problems
Next Topic:Exception when accessing JSP page
Current Time: Thu Jul 24 12:37:02 EDT 2025
Powered by FUDForum. Page generated in 0.33332 seconds
