Home » Archived » GMT (Generative Modeling Technologies) » [TCS]:Error with TCS Wizard
[TCS]:Error with TCS Wizard [message #380338] Mon, 12 November 2007 12:39 Go to next message
Originally posted by: youssedek.gmail.com
hi,
I used the Plugin Builder to create My project TCS.
the first steps ,I installed the plugings "TCS Builder plugin" and "TCS
Wizard plugin" (checkout in the TCS plugigns And Copy - Paste in
Eclipse/plugings Folder)
the next I'm checkout the AMMACore project in my workspace.
But when I start the TCS Wizard (File->New->Project...->ATL->TCS Language
Project)
I find the problem following:
The select wizard could not be started.
Reason:
Pluging org.eclipse.gmt.tcs.wizard was enable to load a class
org.eclipse.gmt.tcs.wizard.TcsProjectWizard.
what is the problem? (installation of wizard??)
thank You
Youssef
Re: [TCS]:Error with TCS Wizard [message #380365 is a reply to message #380338] Thu, 15 November 2007 17:34 Go to previous messageGo to next message
Originally posted by: samuel.calvaro.yahoo.es
Hi Youssef
I have the same error in my project?
try to see this link: http://wiki.eclipse.org/TCS/TCS_Toolkit_Tutorial
Samuel calvaro
Re: [TCS]:Error with TCS Wizard [message #380369 is a reply to message #380365] Fri, 16 November 2007 11:53 Go to previous messageGo to next message
Do you still have a problem?
Frédéric Jouault
Re: [TCS]:Error with TCS Wizard [message #380372 is a reply to message #380369] Sun, 18 November 2007 15:53 Go to previous messageGo to next message
I find the same problem in the TCS wizard.
do you have a explanation because I'm new in TCS.
Samuel Calvaro
Re: [TCS]:Error with TCS Wizard [message #380373 is a reply to message #380372] Mon, 19 November 2007 17:54 Go to previous messageGo to next message
> Regards
Could you please check if there are other (more detailed) error messages
(e.g., in the Error Log)?
One possibility is that you miss a required dependency (e.g., AM3, or
ATL), or that you are using a version that is too old.
Frédéric Jouault
Re: [TCS]:Error with TCS Wizard [message #380467 is a reply to message #380373] Fri, 23 November 2007 16:58 Go to previous messageGo to next message
In my case I didn't have any error message in the Error Log;except the
error which I announced in my first message.
I use the plugings AM3 0.2 et ATL feature 2.0 in my project
but i have the same problem
Could you please indicate the link for download ATL and KM3 plugings?
youssef
Re: [TCS]:Error with TCS Wizard [message #380470 is a reply to message #380467] Fri, 23 November 2007 20:33 Go to previous message
Please use the latest version of ATL, AM3, and TCS. Not simply the
latest binary builds, but CVS HEAD.
Documentation to do this is available on the Eclipse wiki:
http://wiki.eclipse.org/ATL/How_Install_ATL_From_CVS/
http://wiki.eclipse.org/ATL/CVS_Repositories/
Frédéric Jouault
> Regards,
> youssef
Re: [TCS]:Error with TCS Wizard [message #608258 is a reply to message #380338] Thu, 15 November 2007 17:34 Go to previous message
Hi Youssef
Samuel calvaro
Re: [TCS]:Error with TCS Wizard [message #608262 is a reply to message #380365] Fri, 16 November 2007 11:53 Go to previous message
Frédéric Jouault
Re: [TCS]:Error with TCS Wizard [message #609280 is a reply to message #380369] Sun, 18 November 2007 15:53 Go to previous message
Samuel Calvaro
Re: [TCS]:Error with TCS Wizard [message #609282 is a reply to message #380372] Mon, 19 November 2007 17:54 Go to previous message
> Regards
Frédéric Jouault
Re: [TCS]:Error with TCS Wizard [message #609662 is a reply to message #380373] Fri, 23 November 2007 16:58 Go to previous message
youssef
Re: [TCS]:Error with TCS Wizard [message #609665 is a reply to message #380467] Fri, 23 November 2007 20:33 Go to previous message
Frédéric Jouault
> Regards,
> youssef
Previous Topic:Re: [MOFScript] Unprotected regions
Next Topic:[Epsilon] running the ETL sample from Java
Current Time: Sat Jul 26 02:51:54 EDT 2025
Powered by FUDForum. Page generated in 0.06380 seconds
