Home » Archived » B3 » Branchpoint - literals or expressions?
Branchpoint - literals or expressions? [message #534972] |
Thu, 20 May 2010 16:40  |
currently branch points are literals (i.e. timestamp, revision, or tag).
This means they can not be set from properties (as this requires
evaluation). I think that should be possible.
I can still provide validation and code completion for the most common
case of using a literal string, and issue warnings that validation is
deferred until runtime if the expression is more complex.
Agree?
- henrik
Re: Branchpoint - literals or expressions? [message #535085 is a reply to message #535036] |
Fri, 21 May 2010 05:00   |
The other way around, a repository has a (search) list of branches, a
branch has a branch point type, and branch point data.
E.g
main latest;
my_branch tag : "before_experiment3";
You may want to parameterize this so you can control the tag from the
command line, and write:
my_branch tag : $tag.experiment;
The branch point types are:
Latest
Tag
Revision
Timestamp
- henrik
Eike Stepper <stepper@esc-net.de> wrote:
> Hi Henrik,
> Does a branch point *include* a reference to a branch?
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
> Am 20.05.2010 22:40, schrieb Henrik Lindberg:
> > Hi,
> > currently branch points are literals (i.e. timestamp, revision, or >
> > tag). This means they can not be set from properties (as this
> > requires > evaluation). I think that should be possible.
> > common > case of using a literal string, and issue warnings that
> > validation is > deferred until runtime if the expression is more
> > complex.
> > Agree?
> > - henrik
- henrik
Re: Branchpoint - literals or expressions? [message #535105 is a reply to message #535085] |
Fri, 21 May 2010 05:36   |
Am 21.05.2010 11:00, schrieb Henrik Lindberg:
Do you mean something like:
branch ::= <branch name> <branch point type> [ ":" <branch point data>]
If so, I find it very confusing. IMHO it should be more like:
<branch point> ::= <branch> <branch point type> [ ":" <branch point data>]
But I may not get the intent of all this correctly because in CDO we
also have branch and branch point concepts, where a branch point really
is a "point (in time) of a branch" ;-)
Cheers
/Eike
> E.g
> main latest;
> Latest
> Tag
> Revision
> Timestamp
> - henrik
> Eike Stepper<stepper@esc-net.de> wrote:
>> Hi Henrik,
>> Cheers
>> /Eike
>>> Hi,
>>> currently branch points are literals (i.e. timestamp, revision, or>
>>> requires> evaluation). I think that should be possible.
>>> common> case of using a literal string, and issue warnings that
>>> validation is> deferred until runtime if the expression is more
>>> complex.
>>> Agree?
>>> - henrik
Re: Branchpoint - literals or expressions? [message #535113 is a reply to message #535105] |
Fri, 21 May 2010 06:29   |
Agree
In the current b3 model, the class is called Branch, it is really a
BranchPoint, because it has branch name, bp type and bp data as
features.
- henrik
> > a
> data>]
> data>]
> really is a "point (in time) of a branch" ;-)
> Cheers
> /Eike
> > E.g
> > main latest;
> > the
> > Latest
> > Tag
> > Revision
> > Timestamp
> > - henrik
> > >> Hi Henrik,
> >> Cheers
> >> /Eike
> >> >>> Hi,
> > > > or>
> >>> complex.
> >>> Agree?
> >>> - henrik
- henrik
Re: Branchpoint - literals or expressions? [message #535119 is a reply to message #535113] |
Fri, 21 May 2010 06:59   |
So should we rename it to branch-points ?
- thomas
On 05/21/2010 12:29 PM, Henrik Lindberg wrote:
> Agree
> features.
> - henrik
>>> a
>> branch ::=<branch name> <branch point type> [ ":"<branch point
>> data>]
>> <branch point> ::=<branch> <branch point type> [ ":"<branch point
>> data>]
>> Cheers
>> /Eike
>>> E.g
>>> main latest;
>>> the
>>> Latest
>>> Tag
>>> Revision
>>> Timestamp
>>> - henrik
>>> >> Hi Henrik,
>>>> Cheers
>>>> /Eike
>>>> >>> Hi,
>>>>> or>
>>>>> complex.
>>>>> Agree?
>>>>> - henrik
Re: Branchpoint - literals or expressions? [message #535135 is a reply to message #535113] |
Fri, 21 May 2010 08:21   |
Am 21.05.2010 12:29, schrieb Henrik Lindberg:
> Agree
> features.
Now I understand ;-)
Cheers
/Eike
> - henrik
>>> a
>> data>]
>> data>]
>> Cheers
>> /Eike
>>> E.g
>>> main latest;
>>> the
>>> Latest
>>> Tag
>>> Revision
>>> Timestamp
>>> - henrik
>>> >> Hi Henrik,
>>>> Cheers
>>>> /Eike
>>>> >>> Hi,
>>>>> or>
>>>>> complex.
>>>>> Agree?
>>>>> - henrik
Re: Branchpoint - literals or expressions? [message #535234 is a reply to message #535135] |
Fri, 21 May 2010 12:30  |
Good !
- henrik
>> Agree
>> features.
> Cheers
> /Eike
>> - henrik
>>>> a
>>> data>]
>>> data>]
>>> Cheers
>>> /Eike
>>>> E.g
>>>> main latest;
>>>> the
>>>> Latest
>>>> Tag
>>>> Revision
>>>> Timestamp
>>>> - henrik
>>>> >> Hi Henrik,
>>>>> Cheers
>>>>> /Eike
>>>>> >>> Hi,
>>>>>> or>
>>>>>> complex.
>>>>>> Agree?
>>>>>> - henrik
Re: Branchpoint - literals or expressions? [message #608084 is a reply to message #534972] |
Thu, 20 May 2010 17:02  |
An alternative is naturally to allow property expansion in such
literals. The use of property expansion in strings have been avoided so
far. Don't know if they are required. They do facilitate "injection" of
properties that in turn have property expansion. If required, I would
prefer to do property expansion while loading properties (i.e. getting
properties from the command line, or from property files) as opposed to
having to perform property expansion on every string during evaluation.
- henrik
On 5/20/10 10:40 PM, Henrik Lindberg wrote:
> Agree?
> - henrik
Re: Branchpoint - literals or expressions? [message #608088 is a reply to message #534972] |
Fri, 21 May 2010 03:17  |
Hi Henrik,
Cheers
/Eike
> tag). This means they can not be set from properties (as this requires
> Agree?
> - henrik
Re: Branchpoint - literals or expressions? [message #608089 is a reply to message #535036] |
E.g
main latest;
Latest
Tag
Revision
Timestamp
- henrik
> Hi Henrik,
> Cheers
> /Eike
> > Hi,
> > complex.
> > Agree?
> > - henrik
- henrik
Re: Branchpoint - literals or expressions? [message #608092 is a reply to message #535085] |
Cheers
/Eike
> E.g
> main latest;
> Latest
> Tag
> Revision
> Timestamp
> - henrik
>> Hi Henrik,
>> Cheers
>> /Eike
>>> Hi,
>>> complex.
>>> Agree?
>>> - henrik
Re: Branchpoint - literals or expressions? [message #608093 is a reply to message #535105] |
Agree
features.
- henrik
> > a
> data>]
> data>]
> Cheers
> /Eike
> > E.g
> > main latest;
> > the
> > Latest
> > Tag
> > Revision
> > Timestamp
> > - henrik
> > >> Hi Henrik,
> >> Cheers
> >> /Eike
> >> >>> Hi,
> > > > or>
> >>> complex.
> >>> Agree?
> >>> - henrik
- henrik
Re: Branchpoint - literals or expressions? [message #608095 is a reply to message #535113] |
- thomas
> Agree
> features.
> - henrik
>>> a
>> data>]
>> data>]
>> Cheers
>> /Eike
>>> E.g
>>> main latest;
>>> the
>>> Latest
>>> Tag
>>> Revision
>>> Timestamp
>>> - henrik
>>> >> Hi Henrik,
>>>> Cheers
>>>> /Eike
>>>> >>> Hi,
>>>>> or>
>>>>> complex.
>>>>> Agree?
>>>>> - henrik
Re: Branchpoint - literals or expressions? [message #608097 is a reply to message #535113] |
> Agree
> features.
Cheers
/Eike
> - henrik
>>> a
>> data>]
>> data>]
>> Cheers
>> /Eike
>>> E.g
>>> main latest;
>>> the
>>> Latest
>>> Tag
>>> Revision
>>> Timestamp
>>> - henrik
>>> >> Hi Henrik,
>>>> Cheers
>>>> /Eike
>>>> >>> Hi,
>>>>> or>
>>>>> complex.
>>>>> Agree?
>>>>> - henrik
Re: Branchpoint - literals or expressions? [message #608099 is a reply to message #535119] |
Fri, 21 May 2010 12:23  |
> - thomas
Nah, it works fine as we specify them in the order
branch name tag : foo
If we did
branch-point name tag : foo
it looks odd
Some other syntax would work better like:
pick tag : foo from branch name
or somesuch...
But I like to keep the syntax as it is.
We can rename it in the model if you think it makes a difference.
- henrik
Re: Branchpoint - literals or expressions? [message #608101 is a reply to message #535135] |
Good !
- henrik
>> Agree
>> features.
> Cheers
> /Eike
>> - henrik
>>>> a
>>> data>]
>>> data>]
>>> Cheers
>>> /Eike
>>>> E.g
>>>> main latest;
>>>> the
>>>> Latest
>>>> Tag
>>>> Revision
>>>> Timestamp
>>>> - henrik
>>>> >> Hi Henrik,
>>>>> Cheers
>>>>> /Eike
>>>>> >>> Hi,
>>>>>> or>
>>>>>> complex.
>>>>>> Agree?
>>>>>> - henrik
Current Time: Wed Sep 17 16:23:21 EDT 2025
Powered by FUDForum. Page generated in 0.06378 seconds
