Home » Archived » GMT (Generative Modeling Technologies) » [TCS - Transformations Outside Eclipse ]
[TCS - Transformations Outside Eclipse ] [message #378864] Tue, 14 August 2007 12:45 Go to next message
Originally posted by: luigi.mazzucchetti.gmail.com
Hi.
I'm trying to execute 2 TCS transformations, 1 text2model and 1 model2text,
that works inside eclipse, using command line (I'm on linux).
I receive these errors when launching ant command:
- for text2model: java.lang.IllegalStateException: Workspace is closed.
during evaluation of buildxml block:
<am3.loadModel modelHandler="EMF" name="M" metamodel="MM" path="${MUri}">
<injector name="ebnf">
<param name="name" value="${classNamePrefix}"/>
<classpath>
<pathelement location="${EBNFInjectorUri}" />
</classpath>
</injector>
</am3.loadModel>
- for model2text: org.eclipse.core.runtime.AssertionFailedException:
assertion failed: The application has not been initialized.
<am3.saveModel model="M" path="${MUri}.adb">
<extractor name="ebnf">
<param name="format" value="MM.tcs"/>
<param name="indentString" value=" "/>
<param name="serializeComments" value="false"/>
</extractor>
</am3.saveModel>
Anyone know what is wrong? Have I to post my transformations related files?
Thanks in advance.
Luigi
Re: [TCS - Transformations Outside Eclipse ] [message #379859 is a reply to message #378864] Sat, 06 October 2007 16:20 Go to previous message
The AM3 ant scripts have not been extended to run outside of Eclipse.
You can however use TCS using command line tools and/or Java code.
See:
http://wiki.eclipse.org/ATL_Howtos#How_do_I_launch_transform ations_programmatically.3F
Frédéric Jouault
Luigi wrote:
> Hi.
> <classpath>
> </classpath>
> </injector>
> </am3.loadModel>
> </extractor>
> </am3.saveModel>
> Thanks in advance.
> Luigi
Re: [TCS - Transformations Outside Eclipse ] [message #608059 is a reply to message #378864] Sat, 06 October 2007 16:20 Go to previous message
See:
Frédéric Jouault
Luigi wrote:
> Hi.
> <classpath>
> </classpath>
> </injector>
> </am3.loadModel>
> </extractor>
> </am3.saveModel>
> Thanks in advance.
> Luigi
Previous Topic:[TCS] Symbols, operators, tokens, and lexer section
Next Topic:[UMLX] Problem lookingup ambiguous classifiers qualified with its EPackage name
Current Time: Sun Jul 27 09:20:11 EDT 2025
Powered by FUDForum. Page generated in 0.25103 seconds
