Regression in the Integration build [message #92119] |
Thu, 26 May 2005 22:23  |
Originally posted by: no.ddress.here
VE-runtime-I20050526.zip
GEF-runtime-3.1M7.zip
emf-sdo-runtime-I200505261142.zip
Any attempt to run a bean customizer results in an NPE:
!SESSION 2005-05-26 19:17:45.229
eclipse.buildId=I20050513-1415
java.version=1.5.0
Command-line arguments: -os win32 -ws win32 -arch x86 -clean -data D:
\DevFiles\EclipseWorkSpace31M6
!ENTRY org.eclipse.ve.java.core 2 0 2005-05-26 19:19:02.740
!MESSAGE Exception thrown.
!STACK 0
IWAV0073I *** RemoteVM Exception - Trace from Remote VM:
at
org.eclipse.ve.internal.java.remotevm.BeanPropertyEditorJFra me.setProper
tyEditor(BeanPropertyEditorJFrame.java:211)
at
org.eclipse.ve.internal.java.remotevm.WindowLauncher.launchE ditor
(WindowLauncher.java:107)
at org.eclipse.ve.internal.java.remotevm.WindowLauncher.<init>
(WindowLauncher.java:50)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e
Method)
(NativeConstructorAccessorImpl.java:39)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance
(DelegatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:4 94)
at sun.reflect.NativeMethodAccessorImpl.invoke
(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke
(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:585)
at org.eclipse.jem.internal.proxy.vm.remote.ConnectionHandler.r un
(ConnectionHandler.java:317)
at org.eclipse.jem.internal.proxy.vm.remote.ConnectionThread.ru n
(ConnectionThread.java:47)
IWAV0074I *** Local StackTrace:
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanProxyP roxy:
at
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanTypePr oxy.createTh
rowableBeanProxy(REMThrowableBeanTypeProxy.java:34)
at
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanTypePr oxy.newBeanP
roxy(REMThrowableBeanTypeProxy.java:65)
at
org.eclipse.jem.internal.proxy.remote.REMStandardBeanProxyFa ctory.getBea
nProxy(REMStandardBeanProxyFactory.java:454)
at
org.eclipse.jem.internal.proxy.remote.REMStandardBeanProxyFa ctory.proces
sErrorReturn(REMStandardBeanProxyFactory.java:505)
at org.eclipse.jem.internal.proxy.remote.REMMethodProxy.invoke
(REMMethodProxy.java:213)
at
org.eclipse.jem.internal.proxy.remote.REMMethodProxy.invokeW ithParms
(REMMethodProxy.java:172)
at
org.eclipse.jem.internal.proxy.remote.REMConstructorProxy.ne wInstance
(REMConstructorProxy.java:61)
at org.eclipse.ve.internal.java.core.CustomizeJavaBeanAction.ru n
(CustomizeJavaBeanAction.java:121)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
at org.eclipse.ui.actions.RetargetAction.runWithEvent
(RetargetAction.java:216)
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection
(ActionContributionItem.java:538)
at org.eclipse.jface.action.ActionContributionItem.access$2
(ActionContributionItem.java:488)
at org.eclipse.jface.action.ActionContributionItem$6.handleEven t
(ActionContributionItem.java:441)
at org.eclipse.swt.widgets.EventTable.sendEvent
(EventTable.java:82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:842)
at org.eclipse.swt.widgets.Display.runDeferredEvents
(Display.java:2921)
at org.eclipse.swt.widgets.Display.readAndDispatch
(Display.java:2554)
at org.eclipse.ui.internal.Workbench.runEventLoop
(Workbench.java:1601)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1565)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench
(Workbench.java:315)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench
(PlatformUI.java:143)
at org.eclipse.ui.internal.ide.IDEApplication.run
(IDEApplication.java:103)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run
(PlatformActivator.java:230)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run
(EclipseStarter.java:371)
(EclipseStarter.java:160)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:330 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:274)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Re: Regression in the Integration build [message #92699 is a reply to message #92686] |
Tue, 31 May 2005 19:01  |
I just found out because of an EMF change that we needed, your IDE that
you are checking out into must be an M7 IDE with the EMF I200505261142
installed in it too. Not just the target, but the development IDE. Make
sure you start the first time with -clean to get the IDE configuration.
However, there is some problem with the javajet things, so go to the
the java.core, jfc, and swt projects and do a replace with latest from HEAD.
That should fix FastCompare and create(String) problems.
The removeReferenceTo(...) is an outright bug that was accidently
released. It should be fixed by tomorrow. The only thing that breaks is
cut/copy/paste of the graphical stuff.
Gerald Rosenberg wrote:
> Ok, checked out as 12 separate projects. Looks like just one issue
> remaining.
> Java 5, compatibility set to 1.4.2
> Eclipse 3.1M7
> GEF 3.1M7
> EMF I200505261142
> Getting compile errors on four statements (12 instances total) due to
> signature errors. For example (retyped, since there seems to be no easy
> way to dump them):
> org.jem.internal.beaninfo.adapters.BeaninfoClassAdapter.java @line 1265
> "Constructor ...FastCompare(...) is undefined."
> org.eclipse.ve.internal.java.codegen.java.rules.AbstractCont ainerAddDeco
> derHelper.java @ line 190 "method getFeatureID(...) is undefined"
> org.eclipse.ve.internal.java.codegen.jjet.util/AnonymousEven tMethodTempl
> ate.java @ line 41 "method create(String) is undefined"
> org.eclipse.ve.internal.jfc.core.ComponentCopyEditPolicy.jav a @ line 37
> "method removeReferenceTo(...) is not applicable to arguments ..."
> Did I just get an inconsistent copy from Head? Or is this something
> else?
> Thanks for all of the assistance.
Rich Kulp
Re: Regression in the Integration build [message #607836 is a reply to message #92119] |
Fri, 27 May 2005 10:02  |
Gerald,
Many thanks for finding this and my apologies for not testing it better.
My test case an AWT canvas customizer and you have a Swing one. I
have tested it with Swing now and released the code just now into Head.
Joe
> java.version=1.5.0
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !STACK 0
> at
> at
> Method)
> at
> at
> at
> at
> at
> at
> at
> (Display.java:2921)
> (Display.java:2554)
Gr
Re: Regression in the Integration build [message #607841 is a reply to message #92237] |
Fri, 27 May 2005 19:58  |
In article <d779gr$qej$1@news.eclipse.org>, winchest@uk.ibm.com says...
> Gerald,
Would like to test, but there is no new nightly.
Checking out ve-dev-base from CVS (per the VE FAQ procedure) only
retrieves javainst and mofjava folders and throws lots of errors about
an inconsistent CVS repository structure. Not sure what the problem is.
Is there a more detailed spec for checking out and, in particular,
building the full VE plugin. Or, maybe a comprehensive build script for
constructing a nightly/integration build?
Re: Regression in the Integration build [message #607851 is a reply to message #92314] |
Tue, 31 May 2005 09:49  |
Are you sure you checked out against HEAD? I just tried it and it
worked. Though you need to have Eclipse/GEF 3.1M7 and EMF I200505261142
for HEAD to compile correctly.
Rich Kulp
Re: Regression in the Integration build [message #607858 is a reply to message #92462] |
Tue, 31 May 2005 13:45  |
In article <d7hqb7$769$1@news.eclipse.org>, richkulp@us.NO_SPAM.ibm.com
says...
Absolutely.
> worked.
Are you just refreshing or going from scratch.
Here are my steps:
CVS Perspective
click on ":pserver ... :/home/tools
click on HEAD to expand
right click on ve-dev-base
select Check out as ... a project in the workspace
select the HEAD tag and click Finish
What am I doing different/wrong?
Here is the complete error log -- notice that only javainst and mofjava
are successful:
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/PTParen thesizedExpr
ession.java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/PTPrefi xExpression.
java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/PTPrefi xOperator.ja
va
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/PTStrin gLiteral.jav
a
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/PTThisL iteral.java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/PTTypeL iteral.java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/ParseTr eeAllocation
..java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/ParseVi sitor.java
cvs checkout: Updating VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/base
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/base/Fe atureValuePr
ovider.java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/base/IJ avaDataTypeI
nstance.java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/base/IJ avaInstance.
java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/base/IJ avaObjectIns
tance.java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/base/In stantiationB
aseMessages.java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/base/Ja vaDataTypeIn
stance.java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/base/Ja vaFactoryHan
dler.java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/base/Ja vaInstantiat
ion.java
U VE-dev-
ionHandlerFactoryAdapter.java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/base/Ja vaObjectInst
ance.java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/base/Pa rseTreeAlloc
ationInstantiationVisitor.java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/base/me ssages.prope
rties
base/javainst/org/eclipse/jem/internal/instantiation/impl
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/impl/Im plicitAlloca
tionImpl.java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/impl/In itStringAllo
cationImpl.java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/impl/In stantiationF
actoryImpl.java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/impl/In stantiationI
mplMessages.java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/impl/In stantiationP
ackageImpl.java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/impl/Ja vaAllocation
Impl.java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/impl/Na iveExpressio
nFlattener.java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/impl/PT ArrayAccessI
mpl.java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/impl/PT ArrayCreatio
nImpl.java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/impl/PT ArrayInitial
izerImpl.java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/impl/PT BooleanLiter
alImpl.java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/impl/PT CastExpressi
onImpl.java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/impl/PT CharacterLit
eralImpl.java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/impl/PT ClassInstanc
eCreationImpl.java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/impl/PT ConditionalE
xpressionImpl.java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/impl/PT ExpressionIm
pl.java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/impl/PT FieldAccessI
mpl.java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/impl/PT InfixExpress
ionImpl.java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/impl/PT InstanceRefe
renceImpl.java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/impl/PT InstanceofIm
pl.java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/impl/PT InvalidExpre
ssionImpl.java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/impl/PT MethodInvoca
tionImpl.java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/impl/PT NameImpl.jav
a
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/impl/PT NullLiteralI
mpl.java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/impl/PT NumberLitera
lImpl.java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/impl/PT Parenthesize
dExpressionImpl.java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/impl/PT PrefixExpres
sionImpl.java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/impl/PT StringLitera
lImpl.java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/impl/PT ThisLiteralI
mpl.java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/impl/PT TypeLiteralI
mpl.java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/impl/Pa rseTreeAlloc
ationImpl.java
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/impl/me ssages.prope
rties
base/javainst/org/eclipse/jem/internal/instantiation/util
cvs checkout: Updating VE-dev-base/model
U VE-dev-base/model/instance.ecore
U VE-dev-base/model/instance.genmodel
U VE-dev-base/model/java.ecore
U VE-dev-base/model/javaModel.genmodel
cvs checkout: Updating VE-dev-base/mofjava
U VE-dev-base/mofjava/javaadapters.properties
cvs checkout: Updating VE-dev-base/mofjava/org
cvs checkout: Updating VE-dev-base/mofjava/org/eclipse
cvs checkout: Updating VE-dev-base/mofjava/org/eclipse/jem
cvs checkout: Updating VE-dev-base/mofjava/org/eclipse/jem/internal
base/mofjava/org/eclipse/jem/internal/core
U VE-dev-base/mofjava/org/eclipse/jem/internal/core/JEMPlugin. java
base/mofjava/org/eclipse/jem/internal/java
base/mofjava/org/eclipse/jem/internal/java/adapters
U VE-dev-
base/mofjava/org/eclipse/jem/internal/java/adapters/IJavaCla ssAdaptor.ja
va
U VE-dev-
base/mofjava/org/eclipse/jem/internal/java/adapters/IJavaMet hodAdapter.j
ava
U VE-dev-
base/mofjava/org/eclipse/jem/internal/java/adapters/IJavaRef lectionKeyEx
tension.java
U VE-dev-
base/mofjava/org/eclipse/jem/internal/java/adapters/Internal ReadAdaptabl
e.java
U VE-dev-
base/mofjava/org/eclipse/jem/internal/java/adapters/JavaArra yTypeReflect
ionAdapter.java
U VE-dev-
base/mofjava/org/eclipse/jem/internal/java/adapters/JavaRefl ectionAdapte
rFactory.java
U VE-dev-
base/mofjava/org/eclipse/jem/internal/java/adapters/JavaRefl ectionAdapto
r.java
U VE-dev-
base/mofjava/org/eclipse/jem/internal/java/adapters/JavaRefl ectionKey.ja
va
U VE-dev-
base/mofjava/org/eclipse/jem/internal/java/adapters/JavaXMIF actoryImpl.j
ava
U VE-dev-
base/mofjava/org/eclipse/jem/internal/java/adapters/ReadAdap tor.java
U VE-dev-
base/mofjava/org/eclipse/jem/internal/java/adapters/Reflecti onAdaptor.ja
va
base/mofjava/org/eclipse/jem/internal/java/adapters/jdk
U VE-dev-
base/mofjava/org/eclipse/jem/internal/java/adapters/jdk/JDKA daptor.java
U VE-dev-
base/mofjava/org/eclipse/jem/internal/java/adapters/jdk/Java ClassJDKAdap
tor.java
U VE-dev-
base/mofjava/org/eclipse/jem/internal/java/adapters/jdk/Java FieldJDKAdap
tor.java
U VE-dev-
base/mofjava/org/eclipse/jem/internal/java/adapters/jdk/Java JDKAdapterFa
ctory.java
U VE-dev-
base/mofjava/org/eclipse/jem/internal/java/adapters/jdk/Java MethodJDKAda
ptor.java
base/mofjava/org/eclipse/jem/internal/java/adapters/nls
U VE-dev-
base/mofjava/org/eclipse/jem/internal/java/adapters/nls/Reso urceHandler.
java
base/mofjava/org/eclipse/jem/internal/java/beaninfo
U VE-dev-
base/mofjava/org/eclipse/jem/internal/java/beaninfo/IIntrosp ectionAdapte
r.java
base/mofjava/org/eclipse/jem/internal/java/impl
base/mofjava/org/eclipse/jem/internal/java/init
U VE-dev-
base/mofjava/org/eclipse/jem/internal/java/init/JavaInit.jav a
base/mofjava/org/eclipse/jem/internal/java/instantiation
U VE-dev-
base/mofjava/org/eclipse/jem/internal/java/instantiation/IIn stantiationH
andler.java
U VE-dev-
U VE-dev-
base/mofjava/org/eclipse/jem/internal/java/instantiation/IIn stantiationI
nstance.java
base/mofjava/org/eclipse/jem/internal/java/util
cvs checkout: Updating VE-dev-base/mofjava/org/eclipse/jem/java
U VE-dev-base/mofjava/org/eclipse/jem/java/ArrayType.java
U VE-dev-base/mofjava/org/eclipse/jem/java/Block.java
U VE-dev-base/mofjava/org/eclipse/jem/java/Comment.java
U VE-dev-base/mofjava/org/eclipse/jem/java/Field.java
U VE-dev-
base/mofjava/org/eclipse/jem/java/InheritanceCycleException. java
U VE-dev-base/mofjava/org/eclipse/jem/java/Initializer.java
U VE-dev-base/mofjava/org/eclipse/jem/java/JavaClass.java
U VE-dev-base/mofjava/org/eclipse/jem/java/JavaDataType.java
U VE-dev-base/mofjava/org/eclipse/jem/java/JavaEvent.java
U VE-dev-base/mofjava/org/eclipse/jem/java/JavaHelpers.java
U VE-dev-base/mofjava/org/eclipse/jem/java/JavaPackage.java
U VE-dev-base/mofjava/org/eclipse/jem/java/JavaParameter.java
U VE-dev-base/mofjava/org/eclipse/jem/java/JavaParameterKind.j ava
U VE-dev-base/mofjava/org/eclipse/jem/java/JavaRefFactory.java
U VE-dev-base/mofjava/org/eclipse/jem/java/JavaRefPackage.java
U VE-dev-base/mofjava/org/eclipse/jem/java/JavaURL.java
U VE-dev-base/mofjava/org/eclipse/jem/java/JavaVisibilityKind. java
U VE-dev-base/mofjava/org/eclipse/jem/java/Method.java
U VE-dev-base/mofjava/org/eclipse/jem/java/Statement.java
U VE-dev-base/mofjava/org/eclipse/jem/java/TypeKind.java
cvs checkout: Updating VE-dev-base/mofjava/org/eclipse/jem/java/impl
U VE-dev-base/mofjava/org/eclipse/jem/java/impl/ArrayTypeImpl. java
U VE-dev-base/mofjava/org/eclipse/jem/java/impl/BlockImpl.java
U VE-dev-base/mofjava/org/eclipse/jem/java/impl/CommentImpl.ja va
U VE-dev-base/mofjava/org/eclipse/jem/java/impl/FieldImpl.java
U VE-dev-base/mofjava/org/eclipse/jem/java/impl/InitializerImp l.java
U VE-dev-base/mofjava/org/eclipse/jem/java/impl/JavaClassImpl. java
U VE-dev-
base/mofjava/org/eclipse/jem/java/impl/JavaDataTypeImpl.java
U VE-dev-base/mofjava/org/eclipse/jem/java/impl/JavaEventImpl. java
U VE-dev-base/mofjava/org/eclipse/jem/java/impl/JavaFactoryImp l.java
U VE-dev-base/mofjava/org/eclipse/jem/java/impl/JavaPackageImp l.java
U VE-dev-
base/mofjava/org/eclipse/jem/java/impl/JavaParameterImpl.jav a
U VE-dev-
base/mofjava/org/eclipse/jem/java/impl/JavaRefFactoryImpl.ja va
U VE-dev-
base/mofjava/org/eclipse/jem/java/impl/JavaRefPackageImpl.ja va
U VE-dev-base/mofjava/org/eclipse/jem/java/impl/MethodImpl.jav a
U VE-dev-base/mofjava/org/eclipse/jem/java/impl/StatementImpl. java
U VE-dev-base/mofjava/org/eclipse/jem/java/impl/URL.java
cvs checkout: Updating VE-dev-base/mofjava/org/eclipse/jem/java/util
U VE-dev-
base/mofjava/org/eclipse/jem/java/util/JavaRefAdapterFactory .java
U VE-dev-base/mofjava/org/eclipse/jem/java/util/JavaRefSwitch. java
U VE-dev-
base/mofjava/org/eclipse/jem/java/util/NotificationUtil.java
cvs checkout: Updating VE-dev-base/overrides
U VE-dev-base/overrides/..ROOT...override
cvs checkout: Updating VE-dev-base/overrides/java
cvs checkout: Updating VE-dev-base/overrides/java/lang
U VE-dev-base/overrides/java/lang/Object.override
cvs checkout: Updating VE-dev-base/rose
U VE-dev-base/rose/.cvsignore
U VE-dev-base/rose/edocjava2.cat
U VE-dev-base/rose/instance.mdl
U VE-dev-base/rose/instantiation.cat
U VE-dev-base/rose/javaModel.mdl
cvs checkout: existing repository /home/tools/org.eclipse.jem does
not match /home/tools/org.eclipse.jem.beaninfo
cvs checkout: ignoring module org.eclipse.jem.beaninfo
not match /home/tools/org.eclipse.jem.proxy
cvs checkout: ignoring module org.eclipse.jem.proxy
not match /home/tools/org.eclipse.jem.workbench
cvs checkout: ignoring module org.eclipse.jem.workbench
not match /home/tools/org.eclipse.ve.cde
cvs checkout: ignoring module org.eclipse.ve.cde
not match /home/tools/org.eclipse.ve.java.core
cvs checkout: ignoring module org.eclipse.ve.java.core
not match /home/tools/org.eclipse.ve.jfc
cvs checkout: ignoring module org.eclipse.ve.jfc
not match /home/tools/org.eclipse.ve.propertysheet
cvs checkout: ignoring module org.eclipse.ve.propertysheet
not match /home/tools/org.eclipse.ve.swt
cvs checkout: ignoring module org.eclipse.ve.swt
not match /home/tools/org.eclipse.jem.ui
cvs checkout: ignoring module org.eclipse.jem.ui
not match /home/tools/org.eclipse.jem-feature/com.ibm.etools.emf.event
cvs checkout: ignoring module ve-emf-event
not match /home/tools/org.eclipse.jem.util
cvs checkout: ignoring module org.eclipse.jem.util
The server reported an error while performing the "cvs checkout"
command. (took 1:00.207)
Error: : cvs checkout: existing repository
/home/tools/org.eclipse.jem does not match
Error: : cvs checkout: ignoring module org.eclipse.jem.beaninfo
Error: : cvs checkout: ignoring module org.eclipse.jem.proxy
Error: : cvs checkout: ignoring module org.eclipse.jem.workbench
Error: : cvs checkout: ignoring module org.eclipse.ve.cde
Error: : cvs checkout: ignoring module org.eclipse.ve.java.core
Error: : cvs checkout: ignoring module org.eclipse.ve.jfc
Error: : cvs checkout: ignoring module org.eclipse.ve.propertysheet
Error: : cvs checkout: ignoring module org.eclipse.ve.swt
Error: : cvs checkout: ignoring module org.eclipse.jem.ui
/home/tools/org.eclipse.jem does not match /home/tools/org.eclipse.jem-
Error: : cvs checkout: ignoring module ve-emf-event
Error: : cvs checkout: ignoring module org.eclipse.jem.util
U VE-dev-
base/javainst/org/eclipse/jem/internal/instantiation/PTNumbe rLiteral.jav
a
Re: Regression in the Integration build [message #607860 is a reply to message #92564] |
Tue, 31 May 2005 13:56  |
Not Checkout AS... JUST Checkout.. by itself. CheckOutAS tries to make
it one bit project. It is not one project, it is many projects. The
project files are checked into CVS so just doing Checkout... by itself
is sufficient for Eclipse to know what is a project.
Rich Kulp
Re: Regression in the Integration build [message #607861 is a reply to message #92594] |
Tue, 31 May 2005 13:57  |
It tries to make one big project (not one bit project :-) ).
Rich Kulp
Re: Regression in the Integration build [message #607866 is a reply to message #92609] |
Tue, 31 May 2005 16:30  |
remaining.
Eclipse 3.1M7
GEF 3.1M7
EMF I200505261142
way to dump them):
else?
Re: Regression in the Integration build [message #607867 is a reply to message #92686] |
> remaining.
> Eclipse 3.1M7
> GEF 3.1M7
> EMF I200505261142
> way to dump them):
> else?
Rich Kulp
FUDForum. Page generated in 0.06850 seconds
