Home » Archived » Eclipse Communications Framework (ECF) » Shared_Text_Editor
Shared_Text_Editor [message #607556] Mon, 28 August 2006 07:31 Go to next message
I am trying to integrate ECF 0.9 Shared text editor by following steps
mentioned http://wiki.eclipse.org/index.php/Example_Shared_Text_Editor
(help provided by you people).I am able to succeed after step 8.
I made new project and then text file then I selected Team -> Initiate
Shared Session. then I open JI session and Selected
File->New->Team->Shared Editor Session I am not able to get those editors
on JI and it is giving error: File name must be specified
Please suggest me the possible solution
Thanks in advance
Digvijay S Rana
Re: Shared_Text_Editor [message #607558 is a reply to message #607556] Mon, 28 August 2006 08:09 Go to previous messageGo to next message
Adding some more to above
When I look for the shared file from the other machine it gives error
message: file can't be found in workspace.
Re: Shared_Text_Editor [message #607564 is a reply to message #607558] Mon, 28 August 2006 11:24 Go to previous messageGo to next message
Hello Mandar and Digvijay,
Is perhaps the project on the initial shared session out of sync with
the file system? If there is an error in the PDE log please post it.
Also, all the errors you getting are from joiners and not the initiating
Eclipse instance?
Thanks!
Ken
Re: Shared_Text_Editor [message #607585 is a reply to message #607558] Fri, 22 September 2006 16:36 Go to previous message
I assume that you did not start the server.
Have a look at: http://www.eclipse.org/ecf/scribbleshare.html
Previous Topic:Can't get XMPPClient to work
Next Topic:Is ECF suitable for simple file transfer?
Current Time: Sun Jun 08 12:23:15 EDT 2025
Powered by FUDForum. Page generated in 0.04693 seconds
