| IWAV0125E "DebugGraphics.NONE_OPTION" is too complicated [message #90041] | Sun, 08 May 2005 00:55  |  |
| Eclipse User  |  |  |  |  | Originally posted by: no.ddress.here
 Installed VE with the correct dependencies for 3.1M6.  When I use the
 Visual Class wizard, I get a frame which looks correct.
 However, if I click on the content pane, the properties view shows a
 "debugGraphicsOptions" property with the value "IWAV0104E ERROR - Value
 not one of the enumerated values"
 Visual composition does not work: dropping a button on the content pane
 looks correct and a getJButton() method is created, but VE does not
 generate the expected linking code (jContentPane.add(getJButton() ... ))
 in getContentPane() method.
 Cleaning the workspace does not help.  Switching to a completely new and
 empty workspace *does* enable VE to work as expected.  I have too much
 good stuff in my current workspace to manually transfer the projects.
 Any clues as to the problem and a (practical) way to fix up my existing
 workspace?
 !SESSION 2005-05-07 21:24:33.157
 eclipse.buildId=I20050401-1645
 java.version=1.5.0
 Command-line arguments:  -os win32 -ws win32 -arch x86 -clean -data D:
 \DevFiles\EclipseWorkSpace31M6
 !ENTRY org.eclipse.jem.proxy 2 0 2005-05-07 21:24:33.157
 !MESSAGE java.lang.RuntimeException
 at org.eclipse.jem.internal.proxy.initParser.Static.evaluate
 (Static.java:123)
 at
 org.eclipse.jem.internal.proxy.initParser.InitializationStri ngParser.eva
 luate(InitializationStringParser.java:157)
 at  org.eclipse.jem.internal.proxy.vm.remote.ConnectionHandler.r un
 (ConnectionHandler.java:236)
 at  org.eclipse.jem.internal.proxy.vm.remote.ConnectionThread.ru n
 (ConnectionThread.java:47)
 !ENTRY org.eclipse.ve.java.core 2 0 2005-05-07 21:24:33.167
 !MESSAGE
 +++ Warning +++: Sat May 07 21:24:33 PDT 2005    Unable to create
 enumeration value for DebugGraphics.NONE_OPTION
 !MESSAGE Exception thrown.
 !STACK 0
 java.lang.InstantiationException: IWAV0125E "DebugGraphics.NONE_OPTION"
 is too complicated to be evaluated
 at
 org.eclipse.jem.internal.proxy.remote.REMStandardBeanProxyFa ctory.create
 BeanProxy(REMStandardBeanProxyFactory.java:262)
 at
 org.eclipse.jem.internal.proxy.remote.REMAbstractBeanTypePro xy.newInstan
 ce(REMAbstractBeanTypeProxy.java:536)
 at
 org.eclipse.jem.internal.proxy.remote.REMIntegerTypeBeanType Proxy.newIns
 tance(REMIntegerTypeBeanTypeProxy.java:103)
 at
 org.eclipse.ve.internal.java.core.EnumeratedLabelProvider.ge tEnumeratedV
 alues(EnumeratedLabelProvider.java:51)
 at
 org.eclipse.ve.internal.java.core.EnumeratedLabelProvider.ge tText
 (EnumeratedLabelProvider.java:90)
 at
 org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.getValu
 eAsString(AbstractPropertySheetEntry.java:722)
 at  org.eclipse.ui.views.properties.PropertySheetViewer.updateEn try
 (PropertySheetViewer.java:1220)
 at  org.eclipse.ui.views.properties.PropertySheetViewer.createIt em
 (PropertySheetViewer.java:359)
 at
 org.eclipse.ui.views.properties.PropertySheetViewer.updateCh ildrenOf
 (PropertySheetViewer.java:1177)
 at  org.eclipse.ui.views.properties.PropertySheetViewer.access$2
 (PropertySheetViewer.java:1101)
 $3.childEntriesChanged(PropertySheetViewer.java:308)
 at
 org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.fireChi
 ldEntriesChanged(AbstractPropertySheetEntry.java:373)
 at
 org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.refresh
 ChildEntries(AbstractPropertySheetEntry.java:831)
 at
 org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.setValu
 es(AbstractPropertySheetEntry.java:1013)
 at  org.eclipse.ui.views.properties.PropertySheetViewer.setInput
 (PropertySheetViewer.java:875)
 at
 org.eclipse.ui.views.properties.PropertySheetPage.selectionC hanged
 (PropertySheetPage.java:392)
 at
 org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e.superSelec
 tionChanged(EToolsPropertySheetPage.java:230)
 at
 org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e.access$2
 (EToolsPropertySheetPage.java:223)
 at  org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e
 $1.run(EToolsPropertySheetPage.java:216)
 at  org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
 at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages
 (Synchronizer.java:118)
 at org.eclipse.swt.widgets.Display.runAsyncMessages
 (Display.java:2871)
 at org.eclipse.swt.widgets.Display.readAndDispatch
 (Display.java:2530)
 at org.eclipse.ui.internal.Workbench.runEventLoop
 (Workbench.java:1570)
 at  org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1534)
 at org.eclipse.ui.internal.Workbench.createAndRunWorkbench
 (Workbench.java:306)
 at org.eclipse.ui.PlatformUI.createAndRunWorkbench
 (PlatformUI.java:143)
 at org.eclipse.ui.internal.ide.IDEApplication.run
 (IDEApplication.java:103)
 at org.eclipse.core.internal.runtime.PlatformActivator$1.run
 (PlatformActivator.java:228)
 at org.eclipse.core.runtime.adaptor.EclipseStarter.run
 (EclipseStarter.java:344)
 (EclipseStarter.java:156)
 at sun.reflect.NativeMethodAccessorImpl.invoke
 (NativeMethodAccessorImpl.java:39)
 at sun.reflect.DelegatingMethodAccessorImpl.invoke
 (DelegatingMethodAccessorImpl.java:25)
 at java.lang.reflect.Method.invoke(Method.java:585)
 at  org.eclipse.core.launcher.Main.invokeFramework(Main.java:315 )
 at org.eclipse.core.launcher.Main.basicRun(Main.java:268)
 at org.eclipse.core.launcher.Main.run(Main.java:942)
 at org.eclipse.core.launcher.Main.main(Main.java:926)
| Re: IWAV0125E "DebugGraphics.NONE_OPTION" is too complicated [message #90118 is a reply to message #90104] | Sun, 08 May 2005 15:22  |  |
| Eclipse User  |  |  |  |  | Originally posted by: richkulp.us.NO_SPAM.ibm.com
 Actually I'm glad you came up with this problem! A few weeks ago I was
 tearing my hair out working with another person getting a similar error.
 But I couldn't track it down. In her case it was a property that we had
 supplied an enumeration for and I couldn't see how our  BeanInfo could
 come up bad like that.
 Your case was the key to finding the problem because for you it was
 debugGraphicsOption. We don't even provide an enumeration for that
 property! So that clued me in to there being another BeanInfo and I was
 able to track it down to dt.jar then. Thanks!
 Gerald Rosenberg wrote:
 > In article <d5lfll$pf0$1@news.eclipse.org>, richkulp@us.NO_SPAM.ibm.com
 > says...
 >>Found part of your problem. You have dt.jar in your classpath somewhere.
 >>This is Sun's version of the Swing beaninfo, and it conflicts with ours,
 >>  but there is no way to override theirs. You don't need it, it has
 >>nothing but beaninfo stuff in it.
 >>That cause the problem with the debugGraphicsOption. After you remove
 >>the jar you will need to do a clean all projects build because we need
 >>to clear out some cached info.
 > Great catch!  Did have the dt.jar in for the legacy reason that it
 > contains the SwingBeanInfo.class (but, it has been dropped as of Java 5,
 > so I had pulled the class out anyway - just did not think to remove the
 > jar).
 > Everything is now working as expected.
 > Thanks again.
 Rich Kulp
| Re: IWAV0125E "DebugGraphics.NONE_OPTION" is too complicated [message #607361 is a reply to message #90041] | Sun, 08 May 2005 12:37  |  |
 Rich Kulp
| Re: IWAV0125E "DebugGraphics.NONE_OPTION" is too complicated [message #607363 is a reply to message #90075] | Sun, 08 May 2005 15:00  |  |
| Eclipse User  |  |  |  |  | In article <d5lfll$pf0$1@news.eclipse.org>, richkulp@us.NO_SPAM.ibm.com says...
 jar).
 Thanks again.
| Re: IWAV0125E "DebugGraphics.NONE_OPTION" is too complicated [message #607364 is a reply to message #90104] | Sun, 08 May 2005 15:22  |  |
 > says...
 > jar).
 > Thanks again.
 Rich Kulp
FUDForum. Page generated in 0.04895 seconds
